Creating an Extract Criteria
To create a new extract criteria:
Select the New action. The New Extract Criteria page appears.
Figure 7-4 New Extract Criteria Page
Enter the details.
Table 7-2 New Extract Criteria Page
Details Description Code
Enter a unique uppercase code for this extract criteria. Mandatory field.
Version
The version will default to 1. Read-only field.
Status
This will default to Draft. Read-only field.
Description
Enter the description for this extract criteria in the supported languages. The description for the default language is mandatory.
Optionally add any filters to be applied to the extract criteria. See Filters.
Save the changes and exit.
