Filters
Use the Filters page to define the extract criteria to be applied as the filter when generating the Brief Extract report.
Figure 7-6 Extract Criteria Details - Filters
This figure shows the Extract Criteria Details for filters.
To add a filter to an extract criteria:
  1. Open the extract criteria in edit mode and navigate to the Filters page.
  2. Add a row to the Questions tables and click Add.
  3. Enter the details.
    Table 7-3 Filters
    Details Description
    Process Filters
    Optionally choose any specific Processes to be included in the extract by selecting any combination of Process Titles, Parent Processes, Process Status, Process Templates, Process Types, Business Categories, and Process Managers.
    The Proposed Start and End dates can also be used to apply filters:
    • Proposed Start Date (From) includes Processes with a start date later than that specified; Proposed Start Date (To) includes Processes with a start date earlier than that specified. Use of both the filters creates a date range between which Process records will be included.
    • Proposed End Date (From) includes Processes with an end date later than that specified; Proposed End Date (To) includes Processes with an end date earlier than that specified. Use of both the filters creates a date range between which Process records will be included.
    If none are selected, all will be included (subject to other filters).
    Activity Filters
    Optionally choose any specific Activities to be included in the extract by selecting any combination of Activity Templates and Responsible Roles.
    Process Extract Questions
    When adding a row to the Process Extract Questions table, a list of Process Briefs is presented for the selection of their questions.
    Activity Extract Questions
    When adding a row to the Activity Extract Questions table, a list of Activity Briefs is presented for the selection of their questions.
  4. Save the changes and exit. If no Process or Activity questions have been selected, validation will show a warning message.
