Creating a Report Design
To create a new report design:
Select the New action. The New Report Design page appears.
Figure 3-11 New Report Design Page
Enter the details.
Table 3-6 New Report Design Page
Details Description Code
Enter a unique uppercase code for this report design. Mandatory field.
Version
The version will default to 1. Read-only field.
Status
This will default to Draft. Read-only field.
System Delivered
This will default to No. Read-only field.
Description
Enter the description for this report design in the supported languages. The description for the default language is mandatory.
Report Template
Click the icon to select the report template to be used for this report design.
Report Data Source
Click the icon to select the data source to be used for this report design.
Optionally add any filters to be applied to the report design. See Filters for Report Designs.
Save the changes and exit.
