Editing a Report Design
To edit a report design, select the report design on the Report Designs page and select the Edit action. The report design record opens in edit mode in a new tab.
Report Designs are maintained as a versioned glossary. When the report design is created, it is assigned version 1 and the status will be Draft. At this status, all fields except the code, version, status and system delivered flag may be edited.
The system delivered flag identifies if the record is part of the suite of delivered core reports, in which case the flag will be Yes. The system delivered report designs may be copied using the Copy action to form new custom variants, in which case the flag will be No.
Figure 3-12 Report Design Details
This figure shows the Report Design Details.
