Locating the Data Source
Before creating a report template, you must locate the data source in the form of an XML file. This provides the data structure of the report.
The XML files are downloaded from their Report Data Source records (see Data Sources). Open the data source record and use the Download Data for RTF Template Design action to save the file locally for use when building the template.
