Audit & Visit Dates and What They Mean
Due Date
The Due Date is the deadline for completing each corrective action, typically set by agreement between the Supplier and Retailer Lead Technologist.
If an Issue is not completed by its Due Date, the Audit/Visit will appear in the Urgent Items list for the Audit & Visits Contacts and any other assigned users.
When an Audit or Visit is at Awaiting Corrective Action or Awaiting Amendment status, who can edit the Due Date depends on configuration. The user may also be asked to provide a reason for changing the Due Date.
Booked Date
The Booked Date represents the date on which the Audit/Visit will be carried out. This does not need to be entered straightaway, but can be entered at any time to indicate that arrangements have been made by the relevant parties for the Audit or Visit to take place.
This is the date you will put in your calendar.
The Booked Date would normally be on or before the Due Date, though the system does not restrict this as practical circumstances may prevent this from being possible.
The Booked Date may be entered as either a past or future date.
Audit or Visit From/To Date
The Audit or Visit From / To Dates represent the actual dates when the Audit/Visit took place. Both the From and To Dates must be entered, to indicate whether the activity took place over a number of days, but both dates may be the same if all activity happened on a single day.
The From and To Dates may not be set in the future as they should only be entered once the Audit/Visit has actually been carried out.
Once the From and To Dates have been entered (and the record is saved), the status will automatically be updated to In Progress, which correctly represents the activity at this time.
