Info Panels
Most list views include an information panel, which slides out from the right, showing additional data relating to the row selected in the grid.
Figure 6-9 Info Panel
To view the info panel, select a single row in the grid and click the i icon in the title bar.
Selecting a different single row in the grid will refresh the panel contents accordingly.
Use the X to close the panel or use the i icon to toggle between open and closed.
Some views may be designed to open the info panel by default.
The contents of the panel are read only and may be presented across multiple tabs. The heading may include key information such as the record’s description, code, or status.
If a page contains multiple fields with the same name, the group name is appended to the label.
