15 Post Release Tasks
When preparing to implement Supplier Evaluation Cloud Service, the following system configuration tasks must be taken into account.
System Parameters
Configure all system parameters according to the requirements for your installation of Supplier Evaluation.
The following system parameters are specifically concerned with the Evaluation Scoring and Merchandising Integration features:
Inbound - Supplier & Site integration with Merchandising. If enabling the feature, also set:
- Configure the Use Non-Primary Address and Address Type ID parameters if Supplier and Site integration is to be conditioned using a configured non-primary Address Type from Merchandising.
An appropriate interval/time for the interface process to run (the initial default is to run every 90 minutes).
The Merchandising Invoicing System, first ensuring the value is present in the glossary.
The account coding rules for the allocation of Supplier and Site codes. For details of the available options, see Integration with Merchandising.
If the Merchandising supplier and site codes are to also be used as the Supplier Evaluation codes, a prerequisite for the integration to succeed is that the Supplier Evaluation supplier and site code minimum length rules be configured in a way that allows for the Merchandising codes being in the range 1 to 9999999999.
The default value for the Technologist. This is the user to be notified of new Merchandising sites requiring activation. It is recommended this be a user with permissions that permit them to reassign the sites to the appropriate individual Technologists, using the Global Change facility.
The default values for Business Category, Business Unit, Supplier Type, and Site Type. These are the default values to be used when creating a Site.
The Supplier Administrator user role, used when creating the initial supplier user.
The rules for whether Merchandising accounts at Active status are created in Supplier Evaluation, and if those set to Inactive status in Merchandising are to be automatically delisted in Supplier Evaluation.
The purging interval (the default is 90 days).
Any credentials or URLs necessary to access the Merchandising API.
GLN coding rules.
A prerequisite for the integration to succeed will be that the portal be configured so that GLN codes are non-mandatory for suppliers and sites, as the codes are not included in the Merchandising data. Validation will reject the creation of a new supplier or site if GLN codes are configured to be mandatory.
Inbound - Partner integration with Merchandising. If enabling the feature, configure the Partner Integration (Inbound) system parameters. The available parameters are similar to those used for Inbound Supplier & Site integration with Merchandising, so they require the same configuration setup, but this must be completed separately for Partner integration.
See the Supplier & Site integration configuration details above and the system parameters table for the full list of Partner Integration parameters.
Review the same prerequisite actions described for Inbound Supplier & Site integration, including URLs, credentials, GLN configuration, External Primary Language, and country/region mapping.
Inbound - Item integration with Merchandising. If enabling the feature, also set:
The Integration System, first ensuring the value is present in the glossary.
The default value for the Specification Type. Selection is from the Spec Types glossary; it is possible to configure a TBC specification type for use as placeholder if there is not a suitable default specification type.
Once the Product Record has been created the specification type may then be manually edited to assign the appropriate specification type if necessary.
The MFCS Item Level to be retrieved (Style or SKU).
Consider whether Product Records represent a single or multiple variants before enabling the integration. The recommended and default method is single variant, where the Allow Creation of Multiple Products system parameter is No. This means a Product Record represents a single variant of a product, thus multiple Product Records can be linked to a Specification in order to cover multiple product variants - meaning the item integration will create a separate Product Record for each item variant. The setting cannot be changed once the first Product Record has been created.
A Retailer User is created with the name TBC as part of a new installation. This is used as a default if a Technologist or other contact cannot be derived when creating a Product Record through integration.
A prerequisite for the inbound item integration to succeed is that the MFCS Supplier & Site inbound integration is enable, in order to synchronize details of the suppliers of the items.
To use CFA filtering on Item Integration complete the corresponding CFA system parameters under Item Integration (Inbound) detailed in Product Administration under Integration with Merchandising.
Supplier Evaluation Scoring (for automated scoring). If enabling the feature, also set an appropriate interval/time for the scoring processes to run (the initial default is for the Scoring routine to run daily - every 1440 minutes).
- Item Evaluation Scoring (for automated scoring)
- Review Scoring (for automated scoring)
Glossaries
Populate all glossaries according to the requirements for your installation of Supplier Evaluation.
The following glossaries are specifically concerned with the Supplier Evaluation and Scoring features:
Evaluation Types. †
Evaluation Scores.
Photo Album images.
Evaluation Scoring Rules. †
- Entity Scoring Rules.
- Review Scoring Rules.
Evaluation Site Type Groups.
Assessment Questions and Templates. †
- Assessment Picklists.
- Summary Attributes.
- Accredited Bodies.
- Selection Statuses.
Audit & Visit Templates. †
Processes
Assign the relevant Evaluation Types to Assessment Templates, Audits/Visit Templates, and Documents.
Review the configuration of the Countries glossary. The two character ISO country code is used to map the country when integrating addresses with Merchandising. Corresponding codes for Regions will be present for UK counties, US states, and China provinces; configure additional Regions, as required.
†Pre-defined glossaries, templates, and scoring rules, based on industry standards, are available to download from MOS and/or the Branding area of the portal.
