16 Items Management
This section describes the common functionality and configurations available for Items Management.
Implementation Overview
This section provides an implementation overview.
Functionality
The Items Management module gives the possibility to create and maintain Items (either by UI or by file export/import) and publishes them to MFCS.
Status Workflow
Figure 16-1 Items Management Status Workflow
Items Management follows a workflow path, and the status can change depending on:
  • The user permissions
  • The current Status of the Item
Item Status:
  • Draft – Draft is the initial status of an item is when the creation process starts. At any time during in Draft a user can save and continue later, staying in draft status. When submitting if enough information is available to submit the Item Status can be changed to New, if the user does not have approval permissions, or directly to Approved Status (via Processing).
  • New – New is the status of an item with a minimum amount of information to be created is in. In this status an Item can be Approved to send the item to MFCS or Rejected to change the status of the item to Rejected.
  • Rejected – In Rejected Status an item can still be updated and submitted back to New Status, to restart the approval process if needed.
  • Approved – An Approved Item is an Item that exists in MFCS and is complete to be used on all processes in SPCH.
  • Changes Proposed – Changes Proposed is a status used when a user without approve permissions updates an Approved Item. During this Status the changes can be approved and then sent to MFCS or Rejected and the changes are discarded.
  • Processing – Processing Status is an interim status while an item is being interfaced with MFCS. Since the integration is not near real-time. The item is not editable whilst on this status. Once the integration is successful, the item will move to Approved Status. If during Processing an issue is encountered that is a recoverable error (data validations for example), the Item Status will be moved to the previous Status to allow the Item data to be fixed before processing the item again, if the issue found is non recoverable the Item will move to Error Status instead.
  • Error – Error Status is used when an issue is encountered while interfacing the Item into MFCS and when in this status technical support will be required to understand what caused the error.
Integration High Level
SPIM Integration Overview
Figure 16-2 Items Management Integration High Level
Configuration
This section describes the configurations.
POM Configuration
Batch scheduler details with all batches, dependencies and frequencies can be downloaded following the steps in the Supply Chain Hub Frameworks section.
Figure 16-3 Items Management Batch Schedule Overview
Items Management Batch Schedule for MFCS Integration
Similar Items
Items Management enables the possibility of adding views configurations so they can return possible similar the new item being created and stop the item approval process until the changes are merged in the existing item, or the data that makes the new item look similar is changed.
To support it the System Parameter NEW_ITEM_MERGE_RECOM can be configured as Y and during the submit process the views configured in table ORCV_SPIM_SIMILAR_ITEMS_VIEWS are executed to insert possible matches in table ORCV_SPIM_SIMILAR_ITEMS. After executing the views with success and any rows are inserted, the process does not continue to approval and a new validation issue is raised to notify the user that they may have duplicates and must act.
When the user enters the new or existing item with possible duplicates a new button is displayed that opens a popup for the user to choose which of the existing duplicate items to merge the changes to. After confirming the new item is deleted, the changes merged into existing item and the existing item is sent for approval.
Database Objects
Views
The views that can be created must return the following two fields so that the process can use them to filter and insert in similar items tables. The views must be added to ORCV_SPIM_SIMILAR_ITEMS_VIEWS.
Column Data Type Notes
EXISTING_ITEM VARCHAR2(25) This fields contains the approved MFCS item that has a duplicated barcode in a SPIM unapproved item.
NEW_ITEM VARCHAR2(25) This fields contains the not approved SPIM item that has a duplicated barcode in a MFCS approved item.
Other Cloud Services Configuration
This section describes implementation details that must be reviewed from Oracle Retail Merchandising System perspective.
System Options
Configuration of System Options in RPCS are being used by this Cloud Service.
RPCS System Option Description
ZONE_RANGING Defines whether item ranging and pricing maintenance are managed at the zone level (price zones) or at the individual location (store/warehouse) level.
Configuration of System Options in MFCS are being used by this Cloud Service.
MFCS System Option Description
AIP_IND When ‘Y’, item validations apply additional AIP-driven mandatory checks,
CONSIGN_CONCESSION_IND Indicates whether the enterprise uses supplier site granularity (supplier locations) in item/supplier processes.
HTS_TRACKING_LEVEL Controls how HTS (Harmonized Tariff Schedule) compliance is validated for items. It must be set to ‘S’.
To ensure that Items can correctly integrate with MFCS some configurations in the MFCS configuration table CORESVC_ITEM_CONFIG must be made. To allow Items Management to explode Item level 1 information to lower levels the following parameters must be set to N in CORESVC_ITEM_CONFIG.
PARAMETER VALUE
CASCADE_UDA_DETAILS N
CASCADE_IUD_ITEM_SUPP_COUNTRY N
CASCADE_IUD_ISC_DIMENSIONS N
CASCADE_IUD_ISMC N
ISC_UPDATE_ALL_LOCS N
ISC_UPDATE_ALL_CHILD_LOCS N
CASCADE_VAT_ITEM N
CASCADE_IIM_DETAILS N
CASCADE_IUD_ITEM_SUPPLIER N
CASCADE_ITEM_HTS N
CASCADE_ITEM_HTS_ASSESS N
CASCADE_ITEM_EXPENSES N
CASCADE_ITEM_TICKET N
CASCADE_ITEM_SEASONS N
CASCADE_ITEM_UPCHRG N
Furthermore, two of the configurations must be aligned with their corresponding configurations in the Items Management System Parameters in table ORCV_SYSTEM_PARAMETERS with area CONFIG and module Items Management.
MFCS CORESVC_ITEM_CONFIG ORCV ORCV_SYSTEM_PARAMETERS
MAX_ITEM_RESV_QTY RESERVE_ITEM_MAX_AMOUNT
MAX_ITEM_EXPIRY_DAYS RESERVE_ITEM_MAX_EXPIRY
MAX_ITEM_RESV_QTY must be configured with at least value 10.
Reason Codes
Whenever a user updates an Item that is already approved, they need to specify a reason for that update. These reasons are identified by reason codes which are defined at system level. Below you can find the list of the codes available, the sequence and their description.
The codes are defined in the ORCV_CODE_HEAD and ORCV_CODE_DETAIL tables.
Code Head
CODE TYPE CODE TYPE DESCRIPTION
IMRR SPIM revision reason code, to be used on the ORCV_SPIM_ITEM_REV_CTRL table.
Code Detail
CODE CODE DESCRIPTION
D Discontinue
C Change Availability
U UI Update Details
S S9T Update Details
R Reject
A Approve
UDAs
Items Management uses some attributes that are specific to it but still need to be integrated with MFCS, to do so specific user-defined attributes need to be created in MFCS. The user attribute identifier on the table below is an implementation example.
These attributes are specified below.
UDA ID UDA DESCRIPTION UDA TYPE UDA VALUE UDA VALUE DESCRIPTION SINGLE VALUE INDICATOR
9001 ORCV Item Integration Revision FF (Free Form) NA NA Y
9002 On Sale Date DT (Date) NA NA Y
9003 Off Sale Date DT (Date) NA NA Y
9004 Stock Available LV (List of Values) 1 Y Y
9004 Stock Available LV (List of Values) 2 N Y
Important to note is that these UDAs need to be aligned with the following System Parameters in ORCV_SYSTEM_PARAMETERS, if they need to have a different ID.
AREA PARAMETER DESCRIPTION VALUE 1 VALUE 2
CONFIG ITEM_INT_REVISION_UDA UDA that must be used exclusively in the integration process. 9001 NA
CONFIG EXCLUDED_UDA UDAs that should be excluded from the user assigning to an item. ON_SALE_DATE 9002
CONFIG EXCLUDED_UDA UDAs that should be excluded from the user assigning to an item. OFF_SALE_DATE 9003
CONFIG EXCLUDED_UDA UDAs that should be excluded from the user assigning to an item. STOCK_AVAIL 9004
Batches
The MFCS integration item induction job, IINDBATCH_JOB, should be configured to execute with high frequency to assure that items changes made in Items Management are integrated into MFCS as soon as possible with final target the merchandising tables via parameter "RMS".
Others
Items Management integration with MFCS Item Induction uses the Upload Download Framework that defines the induction template to generate Item Induction files. If MFCS is not using the standard induction template, it is required to update the Items System Parameter INDUCTION_TEMPLATE with the MFCS template key. After applying any changes to the MFCS induction template or updating the above-mentioned system parameter, it is required to run ORCV_INT_S9T_TEMPLATE_SYNC_JOB to ensure all changes are reflected in RSCH.
Other Implementation Considerations
This section describes Item Management implementation considerations.
Notifications and Alerts
Items Management uses Events Framework to inform users about events occurred by generating notifications and alerts. Below is the list of Notifications and Alerts available. The notifications are implemented through the Rule Engine Framework documented in the Supply Chain Hub Frameworks section.
Notifications
This section describes the notifications for Items Management.
ORCV_SPIM_EVENT_ITEM_RECOVERY
Notification triggered when user approves an item and the item fails the approval.
Property Value
Event Name SPIM_EVENT_ITEM_RECOVERY
Event Type ORCV_SPIM_EVENT_ITEM_RECOVERY
Description An error(s) occurred during the item(s) approval process.
Trigger UI action
Target Users User that approved the item.
ORCV_SPIM_EVENT_PROP_CHANG_EXIST_ITEM
Notification triggered when a change propose is submitted.
Property Value
Event Name SPIM_EVENT_PROP_CHANG_EXIST_ITEM
Event Type ORCV_SPIM_EVENT_PROP_CHANG_EXIST_ITEM
Description Items with new changes proposed by Retailer
Trigger UI/S9T action
Target Users All Retailer users with permissions for the item department or primary supplier will receive the notification.
ORCV_SPIM_EVENT_SUBM_NEW_ITEM
Notification triggered when a new item is submitted.
Property Value
Event Name SPIM_EVENT_SUBM_NEW_ITEM
Event Type ORCV_SPIM_EVENT_SUBM_NEW_ITEM
Description New Items submitted
Alerts
ORCV_SPIM_EVENT_ITEMS_PENDING
Email sent with the List of Items that were submitted 'x' days ago and still in 'New' or 'Changes Proposed'.
Property Value
Event Name SPIM_EVENT_ITEMS_PENDING_ACTION
Event Type ORCV_SPIM_EVENT_ITEMS_PENDING
Alert Type EMAIL
Description Items with actions pending
Trigger Rules Engine Batch with key: SPIM_ITEM_EVT_PND
Target Users Retail Contact for the item Suppliers
Custom Validations
The application performs validations by implementing Custom Validation Groups of the Custom Validations Framework described in the Supply Chain Hub Frameworks section. The groups are listed below.
SPIM_ITEM_APPROVE
Triggered when the user approves an Item by UI or S9T.
FUNCTION VALIDATION SEQ NO
VALIDATE_HEADER Validate item header data. 1
VALIDATE_IMPORT Validate item import data. 2
VALIDATE_IMAGE Validate item image data. 3
VALIDATE_PACKITEM Validate pack item data. 4
VALIDATE_PRICING Validate item pricing data. 5
VALIDATE_RANGING Validate item ranging data. 6
VALIDATE_SUPPLIER Validate item supplier data. 7
VALIDATE_BUY_ATTR Validate item buy attributes. 8
VALIDATE_DIFFS Validate item diffs. 9
VALIDATE_EXISTING_BARCODES Validate if similar Barcodes exist. 10
VALIDATE_CFA_ITEM_MASTER Validate Item CFA 11
VALIDATE_CFA_ITEM_SUPPLIER Validate Item/Supplier CFA 12
VALIDATE_CFA_ITEM_SUPP_CTRY Validate Item/Supplier Country CFA 13
VALIDATE_CFA_ITEM_LOC Validate Item/Location CFA 14
SPIM_ITEM_SUBMIT
Triggered when the user submits an Item by UI or S9T.
VALIDATE_DIFFS Validate item diffs data 8
VALIDATE_BUY_ATTR Validate item buy attributes. 9
VALIDATE_CFA_ITEM_MASTER Validate Item CFA 10
VALIDATE_CFA_ITEM_SUPPLIER Validate Item/Supplier CFA 11
VALIDATE_CFA_ITEM_SUPP_CTRY Validate Item/Supplier Country CFA 12
VALIDATE_CFA_ITEM_LOC Validate Item/Location CFA 13
Custom Flex Attributes
This application supports three different types of Custom Flex Attributes (CFA): Item Master, Item Supplier and Item Supplier Country. For each CFA there is a corresponding System Parameter to allow their use.
Before importing CFA attribute configuration from MFCS, make sure the entities defined in ORCV_CFA_EXT_ENTITY match the entities on the MFCS side. To import the CFAs run the import batch. Afterwards the attributes will be synchronized every time a user accesses that CFA group in the UI. The import only needs to be run if there are any changes in the group sets or groups and the details are available in the Supply Chain Hub Frameworks section.
Specific Batch Configuration
This section describes specific batch configurations.
Check Status Batch
The Check Status batch is used to validate if an item was successfully published into MFCS.
  • Job: ORCV_SPIM_CHECK_STATUS_JOB
  • Frequency: Nightly
  • Dependency: None
  • Inter Scheduler Dependency: None
Batch configuration table: ORCV_BATCH_CONFIG
COLUMN NAME DEFAULT VALUES
PROGRAM_NAME ORCV_SPIM_CHECK_STATUS_JOB
MAX_CHUNK_SIZE 1000
MAX_CONCURRENT_THREADS 4
RETRY_LOCK_ATTEMPTS 3
RETRY_WAIT_TIME 3
RETRY_MAX_ATTEMPTS_COUNT 3
RETRY_ORDERED N
RETRY_IND N
Codes
Certain operations require codes to define the options available at system level. Below you can find the list of code types available.
IDTF SPIM Display Type field code, to be used on the ORCV_SPIM_SELL_ATTR table.
IMCB SPIM item Location Calculation Basis, to be used on the Add Locations popup screen.
IMEL SPIM error level. To be used in the ORCV_SPIM_ITEM_ERRORS table.
IMIT SPIM item type, to be used on the dashboard screen.
IMLT SPIM item Location Type, to be used on the Add Locations popup screen.
IMRS SPIM revision status, to be used on the ORCV_SPIM_ITEM_REV_CTRL table.
IMST SPIM item status, to be used on the dashboard screen.
Templates
Items Management uses a spreadsheet download and upload process, developed as part of the Retail Supply Chain Hub Frameworks, for creation, maintenance, and extraction of data. To support these processes there are some templates which must be configured, and several configurations should be reviewed as part of the implementation.
Template SPIM Item Data
Table 16-1 Template key: SPIM_ITEM_DATA
ACTION TYPE ROLE NAME
Download ORCV_SPIM_ITEM_APPR_JOB
Download ORCV_SPIM_ITEM_EDIT_JOB
Download ORCV_SPIM_ITEM_VIEW_JOB
Download Blank ORCV_SPIM_APP_JOB
Upload ORCV_SPIM_ITEM_APPR_JOB
Upload ORCV_SPIM_ITEM_EDIT_JOB
Table 16-2 Worksheet Item Header
ACTION MANDATORY CELLS / FIELDS NOTES
Create
Item or VPN,
Item type,
Supplier,
Vendor Description,
Item Description,
Inventory,
Orderable,
Sellable,
Department ID,
Class ID,
Subclass ID,
Standard UOM
Creates a new Item.
When the user has Edit permissions, it creates the Item with status New.
When the user has Approve permissions, it creates the Item with status Approved.
If other column or columns are mandatory, the enrichment process will populate the proper default values.
Update
Item or VPN
Updatable: vendor description, Item description, brand ID, season, on sale date, off sale date, recommend retail price
Updates the Item with the new details.
When a user with Edit permissions does the upload, if the previous status was New or Reject, the Item status will be New. If the previous status was Approved or Change Proposed, the status will be Change Proposed. When a user with Approve permissions does the upload, the Item status will be Approved.
Approve Item or VPN Approves items, if in Change Proposed approves the latest changes.
Reject Item or VPN Rejects all changes.
Table 16-3 Worksheet Item SKU
Create
Item parent or VPN parent,
Item SKU or Primary VPN SKU,
Diff Value 1
Diff Value 2
Diff Value 3
Diff Value 4
Adds item skus to the style (item parent).
The diff values are mandatory if exists diff groups or diff ids associated to the item parent.
Update
Item SKU
Updatable: primary VPN SKU, primary barcode, primary barcode type
Updates the item SKU of the Item parent associated.
Table 16-4 Worksheet Item Barcodes
Create
Item SKU or VPN SKU,
Barcode,
Barcode Type,
Primary Barcode
Adds item barcode to the SKU.
Update
Item SKU or VPN SKU
Updatable: barcode, barcode type, primary barcode
Updates the barcode of the associated SKU item.
Delete Item SKU or VPN SKU Deletes the barcode of the associated SKU item.
Table 16-5 Worksheet Pack Components
Create
Item Parent or VPN Parent,
Component,
VPN Component,
Qty
Adds item component to pack.
Table 16-6 Worksheet Item Supplier Country
Create
Item or VPN,
Supplier,
Primary Supplier,
Origin Country,
Primary Country,
Unit cost or Purchase rate,
Purchase Type
Adds supplier country to the Item.
Unit cost or Purchase rate are mandatory depending on Purchase type selected.
Update
Item or VPN
Updatable: lead time, pickup lead time, supplier pack size, packing method, min order qty, max order qty
Updates information related to the supplier country associated.
Table 16-7 Worksheet Item Supplier Country Dim
Create
Item or VPN,
Supplier,
Origin Country,
Dim Object
Adds supplier country dimension to the Item.
Update
Item or VPN
Updatable: item length, item width, item height, LWH UOM, weight, WEIGHT UOM
Updates information related to the supplier country dimensions associated.
Table 16-8 Worksheet Item Buying Attributes
Create
Item or VPN,
UDA Type,
UDA ID,
UDA Date or UDA FF/LOV
Adds buying attributes to the Item.
UDA Date or UDA FF/LOV depends on UDA Type selected.
Table 16-9 Worksheet Item Selling Attributes
Create
Item or VPN,
Attribute,
Value
Adds selling attributes to the Item.
Update
Item or VPN
Updatable: value
Updates the value of the attribute associated.
Table 16-10 Worksheet Item Import
Create
Item or VPN,
Origin country,
Import country,
HTS
Adds HTS to the Item.
Table 16-11 Worksheet Item Range
Create
Item or VPN,
Location,
Status
Adds range to the Item.
In case of the Purchase Type exceptions, it’s necessary to fill the purchase type, if different from owned, then must fill the cost per unit or purchase rate (only one can be filled).
Update
Item or VPN
Updatable: status
Updates the status of the location.
Table 16-12 Worksheet Item Retail by Zone
Create
Item or VPN,
Zone ID,
Retail price
Adds retail price per zone ID to the Item.
Table 16-13 Worksheet Item Image
Create
Item or VPN,
Image name,
Image address,
Primary image,
Display priority
Adds image to the Item.
Update
Item or VPN
Updatable: primary image
Updates the primary image indicator.
Template SPIM Supplier Default
Table 16-14 Template Key: SPIM_SUPP_DFLT
Table 16-15 Worksheet Supplier Defaults
Create
Supplier,
Entity – Attribute,
Value 1,
Default Value
Creates a new attribute (selected from the entity-attribute list) for the supplier.
Value 2, value 3 and value 4 can be filled according to selected entity attribute.
Update
Supplier,
Entity – Attribute
Updatable: value 1, value 2, value 3, value 4, default value
Updates the values and default value indicator for the entity-attribute to supplier related.
Delete
Supplier,
Entity – Attribute,
Value 1,
Value 2,
Value 3,
Value 4
Deletes the entity-attribute for the supplier.
Table 16-16 Worksheet Supplier Merch Mappings
Create
Supplier,
At least one of the following fields:
Brand or Ref 1,
Dept
Creates a new mapping between brand and/or supplier references (1 to 5) to the Merch Hierarchy.
Update
Supplier,
Brand and/or Ref (1 to 5)
Updates the Merch Hierarchy mapping (department, class, subclass).
Delete
Supplier,
Deletes the Merch Hierarchy mapping.
Table 16-17 Worksheet Supplier Selling Attributes
Create
Supplier,
Selling attribute ID,
Dept,
Value,
Required
Adds selling attributes values to the supplier.
Update
Supplier,
Dept
Updatable: value, required
Updates the supplier selling attributes.
Delete
Supplier,
Dept
Deletes the supplier selling attributes.
Codes
The codes are defined in the ORCV_S9T_CODE_HEAD and ORCV_S9T_CODE_DETAIL tables.
IHAC Item Management Header - Item Data Action
IHIT Item Management - Item Type
IDAC Item Management - Item Data Action
IDUT Item Management - Item UDA Type
IDID Item Management - Item Detail Action
IPAC Item Management - Pack Component Action
IHIY Item Management - Indicator LOV (Yes)
SDAC Supplier Defaults - Action
SDEA Supplier Defaults - Entity Attribute
References
Items Management also uses the Queries module to enable communication between retailer and supplier users, details about Queries are available in the Supply Chain Hub Frameworks section. It also has the ability to attach documents to Items, if the user type is Retailer the attachments will be available for all Retailer and Supplier users of the Item and if the user is Supplier the attachments will be available for Retailer users and Supplier users with access to the same supplier.
Operations
This section describes Inventory and Sales operations.
Integration by Module
Figure 16-4 Items Management Integration by Module
Items Management Integration with MFCS by Module.
STEP DESCRIPTION
0 RSCH Data Access of MFCS data
1 Items Management calls Items Induction Item Induction Database Integration and publishes files to MFCS File Transfer Services (FTS) or MFCS shared folder (depending on configuration).
2 Items Management calls Upload Download Java Service to transform files, depending on the request details, Upload Download Java Service might need to callback to Item Management to get more details.
3 Items Management calls MFCS ReST Merch Integration with xItemLoc messages for items to be published.
4 Item Management calls Items MFCS ReST Merch Integration request for Item IDs.
5 Items Integration calling Diff Group and Diff Rest endpoint of MFCS ReST Merch Integration to create Diffs and Diff Details.
6 Items Integration calling Items updates endpoint of MFCS ReST Merch Integration to publish Item Master, Item Supplier and Item Supplier Country CFAs.
7
Event Alert Java Service checks if there are alerts to be triggered.
Batch by Module
This section describes the batch by module.
Check Item Status Batch
Authentication Method: OAuth2
BaseURL: https://<BASE_URL>/ords/rsch/orcv/merch/itemsmanagement/batch/checkstatus/<URL_PATH>
URL PATH REQUEST METHOD REQUEST BODY AFFECTED TABLES
start POST
"cycleName": "",
"flowName": "",
"processName": "",
"async": "",
"executionId": "",
"jobName": "ORCV_SPIM_CHECK_STATUS_JOB",
"agentExecutionId": "",
"parameters": ""
ORCV_BATCH_STATUS_CONTROL
ORCV_THREAD_CONTROL
ORCV_BATCH_AUDIT_STATUS
ORCV_SPIM_ITEM_RESERVE_XREF
ORCV_SPIM_ITEM_HEADER
restart POST
"cycleName": "",
"flowName": "",
"processName": "",
"async": "",
"executionId": <EXEC_ID>,
"parameters": ""
ORCV_THREAD_CONTROL
log GET
URL query parameters:
/log?jobName=ORCV_SPIM_CHECK_STATUS_JOB
&executionId=<EXEC_ID>&logDate=YYYY-DD-MM
N/A
kill POST
"cycleName": "",
"flowName": "",
"processName": "",
"async": "",
"parameters": ""
ORCV_THREAD_CONTROL
status GET
/status?jobName=ORCV_SPIM_CHECK_STATUS_JOB
N/A
status/all GET
/status?<EXEC_IDs>
N/A
config GET Empty N/A
Alerts
Items Management sends alerts using the Rules Engine Framework documented in the Supply Chain Hub Frameworks section, below is the list of rules batch-based rules required to be executed in batch scheduler.
EVENT NAME RULE JOB
ORCV_SPIM_EVENT_ITEMS_PENDING SPIM_ITEM_EVT_PND ORCV_SPIM_ITEM_EVT_PND_JOB
Service by Module
This section describes the Service by Module.
Recalculate Defaults
This service will be used to update the default weights for the default mappings between the defined entities based on configuration defined in ORCV_SPIM_MERCH_MAP_CFG_WEIGHT.
Rest URL: /ords/rsch/orcv/merch/itemsmanagement/recalculate/defaults
Weight
Url Path <Rest URL>/weight
Request Method PUT
Sample Request Body NA
Sample Success Message
"msg": "Success"
Response Code: 200 (Success)
Sample Failure Message
"statusMsg": "Processed with error.",
"errorMsg": "Invalid Column"
Response Code: 400 (Bad Request)
Affected Tables ORCV_SPIM_MERCH_MAP_CFG_WEIGHT
Reference
Please refer to the Supply Chain Hub Frameworks section for operational details on integration and item reserve services.
