13 Procure to Pay
This section describes the common functionality and configurations available for Procure to Pay.
Procure to Pay features include the possibility of creating and maintaining Purchase Orders, Shipments and create Finance Documents. It also includes the functionality of downloading and uploading majority of those entries being a more effective way to maintain in bulk. Each of the entities maintained in Procure to Pay have specific sections to details of the implementation details.
Purchase Orders
This section describes the Purchase Orders features.
Implementation Overview
This section provides an implementation overview of the Purchase Orders functionality.
Functionality
Procure to Pay, Purchase Orders, will allow retailers and suppliers to create and maintain purchase orders.
Status Workflow
Figure 13-1 Procure to Pay Purchase Orders Status Workflow
Purchase Order follows a workflow path, and the status can change depending on:
- The user permissions
- The current status of the purchase order
Purchase Order Status:
- New – New is the initial status of a Purchase Order. In this status a Purchase Order can be approved to send the Purchase Order to MFCS or Rejected to change the status of the Purchase Order to rejected.
- Rejected – Reject status is for Purchase Orders that were not previously approved.
- Approved – This status is used after the Purchase Order is Approved, in this state the Order has been sent to MFCS.
- Changes Proposed – Changes proposed is the status used when a user without approval permissions updates an approved Purchase Order. During this status the changes made on the purchase order can be approved and then sent to MFCS or rejected and the changes are discarded.
- Cancelled – Cancelled status is used when the Purchase Order is cancelled in Procure to Pay.
- Shipped – Shipped status is used whenever a shipment has been created for the Purchase Order.
- Closed – Closed is the final status of the order once MFCS closes the order. This status can also be used for MFCS side cancelled orders, i.e., not done via SCH.
Integration High Level
Figure 13-2 SPPP Purchase Order Integration Overview
The integration of Purchase Orders from Procure to Pay to MFCS described above is done in the following order:
- Purchase Orders are created and managed in Procure to Pay, either through the UI or via upload functionality.
- After being approved or cancelled, Purchase Orders are published by a batch process.
- Purchase Orders Induction Database Services adds Purchase Orders to an MFCS induction file, which is transferred to MFCS SFTP/FTS.
- Finally, MFCS induction batch for Purchase Orders is executed and integrates Purchase Orders to MFCS.
Configuration
This section describes the Procure to Pay configuration.
POM Configuration
Batch scheduler details with all batches, dependencies and frequencies can be downloaded following the steps in the Supply Chain Hub Frameworks section.
Other Cloud Services Configuration
This section describes implementation details that must be reviewed from an Oracle Retail Merchandising System perspective.
Batches
The MFCS integration order induction job, POINDBATCH_JOB, should be configured to execute with high frequency to assure that purchase orders changes made in Procure to Pay are integrated into MFCS as soon as possible with final target the merchandising tables via parameter “RMS”.
Others
Procure to Pay integration with MFCS Orders Induction uses the Upload Download Framework that defines the induction template to generate Orders Induction files. If MFCS is not using the standard induction template, it is required to update the Orders System Parameter INDUCTION_TEMPLATE with the MFCS template key. After applying any changes to the MFCS induction template or updating the above-mentioned system parameter, it is required to run ORCV_INT_S9T_TEMPLATE_SYNC_JOB to ensure all changes are reflected in RSCH.
Other Implementation Considerations
This section describes implementation considerations for Purchase Order features.
Custom Validations - Purchase Orders
The module performs validations by implementing Custom Validation Groups of the Custom Validations Framework described in the Supply Chain Hub Frameworks section. The groups listed below can be used to add Custom Validations for Purchase Orders.
| Group Id | Executed When |
| SPPP_ORDER_APPROVE | Purchase Order is Approved |
| SPPP_ORDER_CANCEL | Purchase Order is Cancelled |
| SPPP_ORDER_REJECT | Purchase Order is Rejected |
| SPPP_ORDER_SUBMIT | Purchase Order is Submitted for Approval |
Materialized Views
This application requires some results to be materialized in tables using the Materialized View Framework described in the Supply Chain Hub Frameworks section, below is the list for this application. Materialized views used in Procure to Pay, Purchase Orders, are listed in this section.
ORCV_MV_SPPP_DASH_ALL_PO
Materialize View to support Supply Chain Hub dashboard “All POs Available” showing all Purchase Orders available.
- Pre-Dependencies: None
- Post-Dependencies: None
- Frequency: Ad-hoc.
ORCV_MV_SPPP_DASH_PO_NEW
- Frequency: Ad-hoc
ORCV_MV_SPPP_DASH_PO_PENDING
Description: Materialize View to support Supply Chain Hub dashboard “POs Pending Action” showing Purchase Orders with pending actions by Status.
Frequency: Ad-hoc.
ORCV_MV_SPPP_DASH_PO_QTY_L5W
Materialize View to support Supply Chain Hub dashboard “PO Quantity Expected” showing Purchase Orders expected Quantities.
ORCV_MV_SPPP_DASH_PO_WAIT_ASN
Materialize View to support Supply Chain Hub dashboard “POs Waiting Shipment” showing Purchase Orders with Status "Approved" without shipment.
ORCV_MV_SPPP_DASH_PO_WAIT_DOC
Materialize View to support Supply Chain Hub dashboard “POs Waiting Invoices” showing Purchase Orders with Status "Approved" or "Closed" without invoice.
ORCV_MV_SPPP_DASH_PO_WAIT_REV
Materialize View to support Supply Chain Hub dashboard “POs Waiting Review” showing Purchase Orders with Status "Changes Proposed" without revision.
ORCV_MV_SPPP_PO_LAST_REV
Revision number for Purchase Orders.
Frequency: Ad-hoc, Nightly
Codes
Certain operations require codes to define the options available at system level. Below you can find the list of code types available.
The codes are defined in the ORCV_CODE_HEAD and ORCV_CODE_DETAIL tables.
Table 13-1 Codes
| CODE TYPE | CODE TYPE DESCRIPTION |
| ORRC | Purchase Order Reason Codes |
| ORST | Purchase Order Status |
| ORTP | Purchase Order Type |
| PRTP | Purchase Order Type |
| PYMT | Payment Method |
Templates
Procure to Pay, Purchase Orders, uses a spreadsheet download and upload process, developed as part of the Supply Chain Hub Frameworks framework, for creation, maintenance, and extraction of data. To support these processes there are some templates which must be configured, and several configurations should be reviewed as part of the implementation.
Templates SPPP Purchase Orders Data
Table 13-2 Template Key: SPPP_PURCHASE_ORDER_DATA
| ACTION TYPE | ROLE NAME |
| Download | ORCV_SPPP_ORDER_APPR_JOB |
| Download | ORCV_SPPP_ORDER_EDIT_JOB |
| Download | ORCV_SPPP_ORDER_VIEW_JOB |
| Download Blank | ORCV_SPPP_APP_JOB |
| Upload | ORCV_SPPP_ORDER_APPR_JOB |
| Upload | ORCV_SPPP_ORDER_EDIT_JOB |
Table 13-3 Orders Worksheet
| ACTION | STATUS | MANDATORY CELLS / FIELDS | NOTES |
| Create | New |
Action, Master order number, order number, status, location type, location, supplier, currency code, exchange rate terms |
When user has edit permissions Create an order status New. |
| Create | Approve |
When user has approval permissions Create an approved order |
| Update | New |
If the upload is done by a user with edit permissions, the order keeps the status New, if it is done by a user with approval permissions, the order status will change to Approved. Update order/items data (Applicable to scenarios where the order only exists in the SPPP application |
| Update |
Approve
If the upload is done by a user with approval permissions, the order keeps the approved status, if it is done by a user with edit permissions, the order status will change to Change Proposed. If the order does not yet exist in SPPP, the order will be created based on information that exists in MFCS |
| Update | Change Proposed |
If the upload is done by a user with edit permissions, the order keeps the change proposed status, if it is done by a user with approval permissions, the order status will change to Approved. If the order does not yet exist in SPPP, the order will be created based on information that exists in MFCS. |
| Approve | Not Applicable |
When the user has approval permissions. Only for order status evolution. The order will be approved (applicable to existing SPPP orders with status New or Change Proposed) Order items worksheet data will not be used; worksheet can be left blank, or if there is data, leave the action field empty. |
| Acknowledge | Not Applicable |
When user has edit permissions. This action will only be executed successfully if there is a higher approved order revision in the MFCS than the one in the SPPP. If the order does not yet exist in SPPP, the order will be created based on information that exists in MFCS. Order items worksheet data will not be used; worksheet can be left blank, or if there is data, leave the action field empty |
| Cancel | Not Applicable |
When the user has approval permissions. Only for order status evolution. The order will be cancelled (applicable to existing orders with status Approve or Change Proposed). If the order does not yet exist in SPPP, the order will be created based on information that exists in MFCS. Order items worksheet data will not be used; worksheet can be left blank, or if there is data, leave the action field empty. |
| Reject | Not Applicable |
When the user has edit permissions, can only reject orders with status New. When user has approval permissions, can reject order with status New and Change Proposed. If the order has change proposed status, status orders will stay approve and order's data will be reverted to the last approved values. Order items worksheet data will not be used; worksheet can be left blank, or if there is data, leave the action field empty. |
Table 13-4 Order Items Worksheet
| ACTION | MANDATORY CELLS / FIELDS | NOTES |
| Create |
Action, Quantity Item or Reference Item or VPN Supplier pack size Country of sourcing |
Add items to delivery. Applicable when the action on the orders worksheet is Create or Update |
| Update |
Update delivery items data Applicable when the action on the orders worksheet is Update |
| Cancel |
Action, Item or Reference Item or VPN |
Cancel delivery items data (zero out quantity value) Applicable when the action on the orders worksheet is Update |
Codes
| PPAC | Purchase Order Actions |
| PPST | Purchase Orders Status |
| PPIA | Purchase Order Items Actions |
Interactive Grid Additional Columns
This application supports adding additional fields to the Interactive Grids by using the Interactive Grid Additional Columns functionality described in the Supply Chain Hub Frameworks section.
The Interactive Grids that support this functionality are listed below:
| Interactive Grid | Grid ID | User Types | Page | Non Based View | Entity Key |
| Purchase Orders Dashboard Grid | P1_IG_ORDERS | Retail Administrator, Retailer User, Supplier Administrator, Supplier User | Home | ORCV_V_SPPP_ORD_NB | ORDER_NO |
| Deliveries Grid | P2_IG_DELIVERY_GRID | Retail Administrator, Retailer User, Supplier Administrator, Supplier User | Create or Edit PO | ORCV_V_SPPP_ORD_NB | ORDER_NO |
References
Procure to Pay, Purchase Orders, also uses the Queries module to enable communications between retailer and supplier users, the details about Queries are available in the Supply Chain Hub Frameworks section. It also has dependencies from other modules batch jobs listed in POM Configuration that are documented in the Supply Chain Hub Frameworks section.
Operations
This section describes Purchase Order operations.
Integration by Modules
Figure 13-4 Procure to Pay Purchase Orders Integration by Module
| STEP | DESCRIPTION |
| 0 | RSCH Data Access of MFCS data |
| 1 | Order No Reserve calls MFCS Services with a request to reserve Order No. |
| 2 | PO Induction Database Service publishes changes to MFCS File Transfer Services (FTS) or MFCS shared folder (depending on configuration). |
| 3 | Procure to Pay calls Upload Download Java Service to transform files, depending on the request details, Upload Download Java Service might need to callback to Procure to Pay to get more details. |
| 4 | Event Alert Java Service checks if there are alerts to be triggered. |
Reference
For operational details on integration and order reserve services, refer to the Supply Chain Hub Frameworks section.
Materialized Views Refresh Detail
This section describes Materialized Views Refresh Details.
| Parameter | Description | Value |
| Result Synonym | Synonym name pointing to the latest result table. | ORCV_MV_SPPP_DASH_ALL_PO |
| Result Table A | Name of _A result table. | ORCV_SPPP_DASH_ALL_PO_A_R |
| Result Table B | Name of _B result table. | ORCV_SPPP_DASH_ALL_PO_B_R |
| Source View | View used to refresh the result tables. | ORCV_V_SPPP_DASH_ALL_PO_R |
| Driving View | View used to distribute the refresh of result tables. | ORCV_V_SPPP_DASH_ALL_PO_RC |
| Pre-Processor | Pre-process procedure to execute, if applicable. |
ORCV_COMMON_MV_REFRESH. COMMON_PRE_PROCESSOR |
| Check Function | Check function to validate if there is a need to refresh or if there are any batch dependencies. | NA |
| Preserve Data | Flag to decide if the data needs to be preserved until the next run cycle. | Y |
| Restart Indicator | Flag to indicate if restart is allowed or not. | N |
| Max Concurrent Threads | The maximum concurrent threads to refresh result tables. | 4 |
| Filter Fields | Column(s) to distribute the refresh of result tables. | DEPT, SUPPLIER |
| Result Synonym | Synonym name pointing to the latest result table. | ORCV_MV_SPPP_DASH_PO_NEW |
| Result Table A | Name of _A result table. | ORCV_SPPP_DASH_PO_NEW_A_R |
| Result Table B | Name of _B result table. | ORCV_SPPP_DASH_PO_NEW_B_R |
| Source View | View used to refresh the result tables. | ORCV_V_SPPP_DASH_PO_NEW_R |
| Driving View | View used to distribute the refresh of result tables. | ORCV_V_SPPP_DASH_PO_NEW_RC |
| Result Synonym | Synonym name pointing to the latest result table. | ORCV_MV_SPPP_DASH_PO_PENDING |
| Result Table A | Name of _A result table. | ORCV_SPPP_DASH_PO_PENDING_A_R |
| Result Table B | Name of _B result table. | ORCV_SPPP_DASH_PO_PENDING_B_R |
| Source View | View used to refresh the result tables. | ORCV_V_SPPP_DASH_PO_PENDING_R |
| Driving View | View used to distribute the refresh of result tables. | ORCV_V_SPPP_DASH_PO_PENDING_RC |
| Result Synonym | Synonym name pointing to the latest result table. | ORCV_MV_SPPP_DASH_PO_QTY_L5W |
| Result Table A | Name of _A result table. | ORCV_SPPP_DASH_PO_QTY_L5W_A_R |
| Result Table B | Name of _B result table. | ORCV_SPPP_DASH_PO_QTY_L5W_B_R |
| Source View | View used to refresh the result tables. | ORCV_V_SPPP_DASH_PO_QTY_L5W_R |
| Driving View | View used to distribute the refresh of result tables. | ORCV_V_SPPP_DASH_PO_QTY_L5W_RC |
| Result Synonym | Synonym name pointing to the latest result table. | ORCV_MV_SPPP_DASH_PO_WAIT_ASN |
| Result Table A | Name of _A result table. | ORCV_SPPP_DASH_PO_WAIT_ASN_A_R |
| Result Table B | Name of _B result table. | ORCV_SPPP_DASH_PO_WAIT_ASN_B_R |
| Source View | View used to refresh the result tables. | ORCV_V_SPPP_DASH_PO_WT_ASN_R |
| Driving View | View used to distribute the refresh of result tables. | ORCV_V_SPPP_DASH_PO_WT_ASN_RC |
| Result Synonym | Synonym name pointing to the latest result table. | ORCV_MV_SPPP_DASH_PO_WAIT_DOC |
| Result Table A | Name of _A result table. | ORCV_SPPP_DASH_PO_WAIT_DOC_A_R |
| Result Table B | Name of _B result table. | ORCV_SPPP_DASH_PO_WAIT_DOC_B_R |
| Source View | View used to refresh the result tables. | ORCV_V_SPPP_DASH_PO_WT_DOC_R |
| Driving View | View used to distribute the refresh of result tables. | ORCV_V_SPPP_DASH_PO_WT_DOC_RC |
| Result Synonym | Synonym name pointing to the latest result table. | ORCV_MV_SPPP_DASH_PO_WAIT_REV |
| Result Table A | Name of _A result table. | ORCV_SPPP_DASH_PO_WAIT_REV_A_R |
| Result Table B | Name of _B result table. | ORCV_SPPP_DASH_PO_WAIT_REV_B_R |
| Source View | View used to refresh the result tables. | ORCV_V_SPPP_DASH_PO_WT_REV_R |
| Driving View | View used to distribute the refresh of result tables. | ORCV_V_SPPP_DASH_PO_WT_REV_RC |
| Result Synonym | Synonym name pointing to the latest result table. | ORCV_MV_SPPP_PO_LAST_REV |
| Result Table A | Name of _A result table. | ORCV_SPPP_PO_LAST_REV_A_R |
| Result Table B | Name of _B result table. | ORCV_SPPP_PO_LAST_REV_B_R |
| Source View | View used to refresh the result tables. | ORCV_V_SPPP_PO_LAST_REV_R |
| Driving View | View used to distribute the refresh of result tables. | ORCV_V_SPPP_PO_LAST_REV_RC |
| Filter Fields | Column(s) to distribute the refresh of result tables. | SUPPLIER |
ORCV_MV_SPPP_PO_REJ_CANCEL
| COLUMN | DESCRIPTION | VALUE |
| Result Synonym | Name of the synonym pointing to the result table. | ORCV_MV_SPPP_PO_REJ_CANCEL |
| Result Table A | Name of _A result table. | ORCV_ SPPP_PO_REJ_CANCEL_A_R |
| Result Table B | Name of _B result table. | ORCV_ SPPP_PO_REJ_CANCEL_B_R |
| Source View | The View contains business logic to be used to populate the result table. | ORCV_V_ SPPP_PO_REJ_CANCEL_R |
| Driving View | This field contains the view to distribute the refresh process. | ORCV_ SPPP_PO_REJ_CANCEL_RC |
| Pre-Processor | Name of the pre-process procedure if applicable. |
| Check Function | Name of the check function to validate if there is a need to refresh or if there are any batch dependencies. | NA |
| Restart Indicator | Flag to indicate if to allow restart batch processor or not. | N |
| Max Concurrent Threads | This field contains the maximum concurrent threads that created the record. | 4 |
| Filter Fields | Column name of the view to be used for threading. | SUPPLIER |
ORCV_MV_SPPP_PO_TOTALS
| Result Synonym | Synonym name pointing to the latest result table. | ORCV_MV_SPPP_PO_TOTALS |
| Result Table A | Name of _A result table. | ORCV_SPPP_PO_TOTALS_A_R |
| Result Table B | Name of _B result table. | ORCV_SPPP_PO_TOTALS_B_R |
| Source View | View used to refresh the result tables. | ORCV_V_SPPP_PO_TOTALS_R |
| Driving View | View used to distribute the refresh of result tables. | ORCV_V_SPPP_PO_TOTALS_RC |
| Filter Fields | Column(s) to distribute the refresh of result tables. | ORDER_NO |
Shipments
This section describes the Shipments features.
Procure to Pay, Shipments, will allow retailers and suppliers to create and maintain purchase ASNs.
Status Workflow
Figure 13-5 Shipments Status Workflow
Shipments follow a workflow path, and the status can change depending on:
- The status of the Shipment
Shipment Status:
- New – New is the initial status while creating the Shipment in SPCH, this status is only an interim status and it is not possible to save a shipment in this status.
- Approved – This status is used once a Shipment is submitted and integrated into MFCS. Whenever updates are made to the Shipment it remains in Approved Status.
- Cancelled – Cancelled status is used when the shipment is cancelled in Procure to Pay.
- Received – This status is shown once the Shipment has been received in MFCS.
Figure 13-6 Procure to Pay Shipments Integration Overview
Shipments Java Service integration via RIB-EXT is an optional flow to integrate with SIOCS or WMS that requires enabling from the configuration. For more details on this process, see the Supply Chain Hub Frameworks section.
Configuration
This section describes configurations.
POM Configuration
Other implementation Considerations
This section describes implementation considerations.
Custom Validations
| Group ID | Executed When |
| SPPP_ASN_CANCEL | Shipment is cancelled |
| SPPP_ASN_SUBMIT | Shipment is created or updated |
Materialize Views
Codes
| ASST | Shipment status. |
| ASRC | Shipment reason codes |
Templates
This section describes templates.
Template SPPP ASNIN Data
Table 13-5 Template Key: SPPP_ASNIN_DATA
| Download | ORCV_SPPP_ASN_APPR_JOB |
| Download | ORCV_SPPP_ASN_VIEW_JOB |
| Upload | ORCV_SPPP_ASN_APPR_JOB |
Table 13-6 ASN Worksheet
| Create | New |
Action, ASN, Supplier, To Location Type, To location, Shipment Date, Estimated Arrival Date |
Creates an ASN with approved status. |
| Update | Approve |
The action needs to be “Update” at the ASN Container worksheet even if the update is only at the container or item level. Updates the ASN. |
| Cancel | Approve |
Cancel an ASN. |
Table 13-7 ASN Container Worksheet
| Create | New |
Action, ASN, Container |
Adds container to the ASN. |
| Update | Approve |
The action needs to be “Update” in the ASN worksheet even if the update is only at the container level. Updates the container. |
| Cancel | Approve |
Removes all quantities for the items associated with the container. |
Table 13-8 ASN Items Worksheet
| Create | New |
Action, ASN, Order No, Item, Description, Shipped Quantity, Received Quantity |
Adds items to the ASN. |
| Update | Approve |
The action needs to be “Update” in the ASN worksheet and ASN Container worksheet if the item is associated with a container even if the update is only at the item level. |
| Cancel | Approve |
The item quantity is adjusted to 0. If the remaining quantity for the ASN is null the cancel action should be done at ASN worksheet level. |
Codes
| ASAC | Shipments Actions |
| ASST | Shipment Status |
| Interactive Grid | Grid ID | User Types | Page | Non Based View | Entity Primary Key |
| Shipments Dashboard Grid | P1_IG_SHIPMENTS | Retail Administrator, Retailer User, Supplier Administrator, Supplier User | Home | ORCV_V_SPPP_ASN_NB | ASN_NO |
| Purchase Orders Grid | P3_IG_PO | Retail Administrator, Retailer User, Supplier Administrator, Supplier User | Create or Edit ASN | ORCV_V_SPPP_ASN_NB | ASN_NO |
References
Procure to Pay, Shipments, also uses the Queries module to enable communication between retailer and supplier users, details about Queries are available in the Supply Chain Hub Frameworks section. It also has dependencies from other modules batch jobs listed in POM Configuration that are documented in the Supply Chain Hub Frameworks section.
Operations
This section describes operations.
Figure 13-8 Procure to Pay Shipments Integration by Module
| 1 | Shipments Java Services checks if Procure to Pay has shipments to be published |
| 2 | If there are ASNin to be published, Shipments Java Services sends to MFCS via RIB-EXT REST |
Reference
The Shipments ASNIN integration service will support the integration of ASNINs managed in the Procure to Pay module into MFCS via RIB-EXT REST. For more details on this process, consult the Supply Chain Hub Frameworks section.
This section describes the Materialized Views Refresh Details for Shipments.
ORCV_MV_SPPP_DASH_OVD_SHIP_Q
| Result Synonym | Synonym name pointing to the latest result table. | ORCV_MV_SPPP_DASH_OVD_SHIP_Q |
| Result Table A | Name of _A result table. | ORCV_SPPP_DASH_OVD_SHIP_Q_A_R |
| Result Table B | Name of _B result table. | ORCV_SPPP_DASH_OVD_SHIP_Q_B_R |
| Source View | View used to refresh the result tables. | ORCV_V_SPPP_DASH_OVD_SHIP_Q_R |
| Driving View | View used to distribute the refresh of result tables. | ORCV_V_SPPP_DASH_OVD_SHIP_Q_RC |
ORCV_MV_SPPP_DASH_OVD_UNSHIP
| Result Synonym | Synonym name pointing to the latest result table. | ORCV_MV_SPPP_DASH_OVD_UNSHIP |
| Result Table A | Name of _A result table. | ORCV_SPPP_DASH_OVD_UNSHIP_A_R |
| Result Table B | Name of _B result table. | ORCV_SPPP_DASH_OVD_UNSHIP_B_R |
| Source View | View used to refresh the result tables. | ORCV_V_SPPP_DASH_OVD_UNSHIP_R |
| Driving View | View used to distribute the refresh of result tables. | ORCV_V_SPPP_DASH_OVD_UNSHIP_RC |
Finance Documents
This section describes the Finance Documents features.
Procure to Pay, Purchase Orders, will allow retailers and suppliers to create and maintain financial documents.
Status Workflow
Figure 13-9 Procure to Pay Finance Documents Status Workflow
- New – New is the initial status while creating the Document in SPCH, this status is only an interim status and is not possible to save a Finance Document in this status.
- Approved – This status is used once a Finance Document is submitted and integrated into IMCS.
- Discrepancies – This status is used if any discrepancies are found during the matching process in IMCS.
- Cancelled – Cancelled status is used if the Finance Document is cancelled in IMCS
Configuration
POM Configuration
Custom Validations - Finance Documents
The module performs validations by implementing Custom Validation Groups of the Custom Validations Framework described in the Supply Chain Hub Frameworks section. The groups listed below can be used to add Custom Validations for Finance Documents.
| SPPP_FINDOC_SUBMIT | Financial Document is created |
Codes
| DOCC | Finance Document – Doc types, create mode |
| DOCV | Finance Document – Doc types, view mode |
| FDST | Finance Documents status. |
Templates
Template SPPP Finance Document Data
One of these templates will be active, according to the configuration that exists in the MFCS for the default tax type.
Table 13-9 Templates
| TEMPLATE KEY | STATUS |
| SPPP_DOC_SVAT_DATA |
Active (if MFCS system option for default tax type is SVAT) Inactive (if MFCS system option for default tax type is different than SVAT) |
| SPPP_DOC_SALES_DATA |
Active (if MFCS system option for default tax type is SALES) Inactive (if MFCS system option for default tax type is different than SALES) |
| SPPP_DOC_GTS_DATA |
Active (if MFCS system option for default tax type is GTS) Inactive (if MFCS system option for default tax type is different than GTS) |
Table 13-10 Template Key: SPPP_DOC_SVAT_DATA or SPPP_DOC_SALES_DATA or SPPP_DOC_GTS_DATA
| Upload | ORCV_SPPP_FINDOC_APPR_JOB |
Table 13-11 Template Worksheets
| WORKSHEET KEY | WORKSHEET NAME | SEQUENCE |
| SPPP_DOCS | Documents | 1 |
| SPPP_DOC_REFS | Document References | 2 |
| SPPP_DOC_ITEMS | Document Items | 3 |
| SPPP_DOC_VAT | Document VAT | 4 |
| SPPP_DOC_ITEM_TAX | Document Item Tax | 4 |
In case MFCS default tax type equals ‘SVAT’ the SPPP_DOC_VAT worksheet is used, in case of ‘GTS’ SPPP_DOC_ITEM_TAX is used, otherwise none of the previous worksheets are used.Codes
| FDAC | Finance Document Actions |
| FDOR | Finance Document reference type |
| Invoices Dashboard Grid | P1_IG_INVOICES | Retail Administrator, Retailer User, Supplier Administrator, Supplier User | Home | ORCV_V_SPPP_DOC_NB | DOC_ID, SUPPLIER |
| Purchase Orders Grid | P4_IG_PO | Retail Administrator, Retailer User, Supplier Administrator, Supplier User | Create or Edit Document | ORCV_V_SPPP_ORD_NB | ORDER_NO |
| Purchase Orders/ Return to Vendor Grid | P4_IG_ORDRTV | Retail Administrator, Retailer User, Supplier Administrator, Supplier User | Create or Edit Document | ORCV_V_SPPP_ORD_NB | ORDER_NO |
References
Procure to Pay, Finance Documents, also use the Queries module to enable communication between retailer and supplier users, details about Queries are available in the Supply Chain Hub Frameworks section. It also has dependencies from other modules batch jobs listed in POM Configuration that are documented in the Supply Chain Hub Frameworks section.
Operations
Figure 13-12 Procure to Pay Finance Documents Integration by Module
| 1 | Finance Document Induction Java Services checks if Procure to Pay has documents to be published |
| 2 | Finance Document Induction Java Services sends produced files to Integration File Transfer. |
| 3 | Integration File Transfer publishes files to MFCS File Transfer Services (FTS) or MFCS shared folder (depending on configuration). |
| 4 | Procure to Pay calls Upload Download Java Service to transform files, depending on the request details, Upload Download Java Service might need to callback to Procure to Pay to get more details. |
| 5 | Event Alert Java Service checks if there are alerts to be triggered. |
Reference
The EDI finance document injector service will support the integration of Invoices and Credit Notes managed in the Procure to Pay module into IMCS via induction batch. For more details on this process, please consult the Supply Chain Hub Frameworks section.
