Associate Advance
The Associate Advance function allows a payment to an associate in advance of the associate's scheduled payday. Examples of associate advances include cases of emergency or to pay a new employee in a timely manner.
After logging in to the Back Office, select Employee and press Enter.
Figure 4-27 Main Menu - Employee Menu Option
Select Employee Maintenance and press Enter.
Figure 4-28 Employee Maintenance Menu
Select Associate Advance and press Enter.
Figure 4-29 Associate Advance Menu Option
The system prompts you to enter the lookup criteria. Enter the criteria you want to use for finding an employee's record and select Process.
Figure 4-30 Employee Lookup Form
If you enter an Employee ID, Oracle Retail Xstore Point of Service may immediately display a prompt for the cash advance amount.
If you enter search criteria that results in more than one record being found, or if your system is set up to always show a list, you must select the employee you want from the list.
At the prompt, enter the cash advance amount and press Enter to continue.
Figure 4-31 Cash Advance Amount Prompt
The system records the transaction and returns to the Main Menu.
Oracle Retail Xstore Point of Service prints a receipt with the associate's advance information and an employee signature line. Both a store copy and an employee copy are printed.
Figure 4-32 Associate Advance Receipt Example
The cash drawer opens to remove the cash advance.
If the system prompts you to close the cash drawer, press Enter to respond to the prompt.
