50 Shelf Labels
You can print shelf labels for any item in the current item file. Shelf labels can be printed to a laser report printer if the report printer supports printing multiple labels per page, or to a label printer if using ZPL II communication.
In addition to scanning/entering items in order to print labels, the system also provides an option to print shelf labels for all the items on an entire receiving document at once, and from previously saved batches if using ZPL II communication.
You must load the appropriate label stock into the printer for each label printing job. The system does not perform a check for the correct stock before printing.
Printing Shelf Labels
From the Main Menu, select the Inventory option.
Figure 50-1 Handheld Inventory Menu
Figure 50-2 Inventory Menu - Xstore POS
At the Inventory menu, select the Print Shelf Labels option.
When prompted scan the barcode or manually enter the item ID.
Figure 50-3 Item ID Prompt
If you are using ZPL II communication with a label printer, the Retrieve Batch option is available if you previously defined and saved a named print batch. SeeTo Retrieve a Batch - ZPL II Only.
When prompted for the number of labels you want to print for this item, type the quantity and press OK.
Figure 50-4 Label Quantity Prompt
By default, the system displays the number of items in your on hand inventory.
The next steps depend upon your label printer setup:
If you are not using ZPL II communication with a label printer, continue with step 5 below.
If you are using ZPL II communication with a label printer, skip to ZPL II Label Printers.
Xstore POS adds each Item ID and number of labels to the View Port area of the screen. The item description and unit price are also shown.
Figure 50-5 View Port Displays Items Added for Labels
Select a row to bring up options available To Change an Item.
Figure 50-6 Item Modifiers
Change Quantity - to change the label quantity
Change Price - to change the item label price
Delete Item - to remove an item from the list
Figure 50-7 Print Shelf Label Context Menu
Select the Context Menu to:
Add Receiving Document - To add items from a receiving document, see To Add a Receiving Document.
Print
Item Lookup - To search for an item to add to the list, see To Look Up an Item.
When you have entered and/or edited all the items and label quantities, select the Print option to continue with label setup.
Xstore POS prompts you to select the type of label from the list. Select the label type.
Figure 50-8 Shelf Label Types
Xstore POS shows the number of label sheets you need. When prompted, press OK to acknowledge the message informing you of the number of label sheets required.
Figure 50-9 Print Label Prompt
Xstore POS confirms the request and prints the labels.
Figure 50-10 Sample Labels
If you exit from the Item/Shelf Labels screen without printing the labels, Xstore POS displays a warning message that all current label settings will be lost. Select Yes to return to return to the Inventory Menu or select No to continue working with labels.
...continued from step 4.
If you previously defined and saved a Named Batch, you can retrieve the batch by selecting Retrieve Batch from the Item/Shelf Labels menu. See To Retrieve a Batch - ZPL II Only.
After entering the item ID and label quantity:
If the item you entered is associated with a pre-defined stock label type, the item is automatically added to the view port with the defined label icon
. Go to step
2.
If the item you entered is not associated with a pre-defined stock label type, you are prompted to select a label type from the list. This assigns the selected label type to the item for this instance only not for future label printing and does not affect future label printing.
Select the stock label type.
Select a processing option:
Select Process to associate the stock label type to the item.
<OR> Select Assign To All to assign the selected Stock type to all items in the current list.
All items in the list will print on the same label stock type. However, this selection will not update the pre-defined stock type of the items and will not apply to items that are added after the Assign to All option is selected.
Xstore returns to the Enter/Scan Item ID prompt screen.
The following options are available before printing the labels:
Change Item: To remove an item from the list, change the label quantity, change the item label price, or change an item's stock label type, see To Change an Item.
Item Lookup: To search for an item to add to the list, see To Look Up an Item.
Add Receiving Document: To add items from a receiving document, see To Add a Receiving Document.
Retrieve Batch: To print a previously saved batch, see To Retrieve a Batch - ZPL II Only.
Save Batch: To save this label printing instance as a batch, see To Delete a Batch - ZPL II Only
When you have entered and/or edited all the items and label quantities, select the Process option to continue with label printing.
Before printing, Xstore POS automatically groups the items by stock type and verifies all items are associated with a label stock type. If Xstore POS detects that any of the items do not have an assigned label stock, you are prompted to select a label stock.
Xstore displays the Load Label Type message.
Select Print to print the labels in this stock group. Continue printing all stock groups, making sure you have loaded the appropriate label stock for each. Go to step 5.
<OR>
Select Skip Group if you do not want to print these labels at this time. If there is another stock group, the Load Label Type message displays for the next group. Make sure you have loaded the appropriate label stock for each group. Continue printing all stock groups.
Go to step 5 below.
You can select Back to return to the item entry screen.
If prompted, select Yes to save and name this batch so it can be printed in the future, or select No if you do not want to print this batch again.
If you are not prompted, you can save the batch by selecting the Save Batch option. For more information see To Save a Batch - ZPL II Only and To Retrieve a Batch - ZPL II Only.
To Change an Item
Select the item to edit it. The following options are available from the Change Item menu before you print labels for the items.
Figure 50-11 Item Modifiers
Change Quantity
Select Change Quantity to change the number of labels to be printed.
Select the item.
At the Enter Quantity prompt (see Figure 50-4), enter the number of labels you want to print for the item.
Xstore POS updates the label quantity on the View Port for the item.
Change Price
Select Change Price to change the price that is printed on the label.
Select the item.
At the Enter Price prompt, enter the price of the item to be printed on the label.
Figure 50-12 Enter Price Prompt
Xstore POS updates the label unit price on the View Port for the item.
Delete Item
Select Delete Item to remove an item from the list of item labels to be printed.
Select the item.
There is no confirmation prompt before deleting the item. Be sure you are highlighting the correct item in the View Port display area.
Xstore POS removes the item from the list of item labels to be printed.
Change Label
ZPL II Only. Select Change Label from the Context Menu to specify a different stock label type for the item.
Select the item.
Select Process to associate the Stock Label type to the item.
<OR>
Select Assign To All to assign the selected Stock Label type to all items in the current list.
All items in the list print on the same label stock type. This selection does not update the pre-defined stock type of the items and does not apply to items that are added after the Assign To All option is selected.
To Look Up an Item
Select Item Lookup from the Context Menu to find an item using the item lookup search criteria form. The item can be added to the list of item labels to be printed.
At the Item Lookup form, enter the search criteria and select Process.
Figure 50-13 Item Lookup Form
If more than one item matched the search criteria you entered, select the item from the list and OK. Xstore POS displays the item information.
Select the Add Item option from the Context Menu to include the item on the list of item labels to be printed. If configured, select Exit to Scan to scan the item to add it.
Figure 50-14 Item Lookup Results - Exit to Scan Option
Enter the number of labels to be printed for the item and press OK to add the item to the list of item labels to be printed. By default, the on-hand quantity for the item is shown in the Label Quantity focus bar prompt.
Select Add Receiving Document from the Context Menu to print labels for all the items on a receiving document.
At the Document Search form, scan the barcode for the Receiving Document or enter search criteria to locate the Receiving Document.
Figure 50-15 Document Search Form
Xstore POS displays a list of receiving documents that match the criteria you entered. You may need to scroll through the list if multiple documents are displayed.
Figure 50-16 List of Receiving Documents
Select the receiving document that has the items that need labels. Xstore POS adds all of the items on the Receiving Document to the list of item labels to be printed and displays them in the View Port area of the screen.
By default, a label will be printed for each item/quantity in the shipment. Use the Change Quantity option to edit the number of labels to be printed.
Batch options are only available when using ZPL II. Use this option to assign a name to the current list of items so it can be used again in the future. See To Retrieve a Batch - ZPL II Only below for information about reusing the batch to print labels.
Select Save Batch from the Item/Shelf Labels screen.
When prompted, enter a name for the batch.
Xstore saves the batch information, and it can be retrieved for printing later.
Use this option to retrieve a list of previously save batches. See To Save a Batch - ZPL II Onlyabove for more information about saving a batch for reuse.
Select Retrieve Batch from the Item/Shelf Labels screen.
When prompted, select a Batch from the list.
The items in the batch are shown on the View Port.
Continue with step 2.
Use this option to delete a previously saved batch.
When prompted, select a Batch from the saved Batch List and select Delete Batch.
At the confirmation prompt, select Yes to delete the batch. Selecting No returns to the saved Batch List and the selected batch is not deleted.
Xstore returns to the Saved Batch list and the selected batch is removed from the list.
