Currency Rounding
Currency rounding refers to the process of rounding the cost of a purchase (which is to be paid for in cash) to the nearest multiple of the smallest denomination of currency.
Low denomination coins in some currencies were removed from circulation and are no longer available. Because it may not be possible to make exact change for a cash purchase, amounts must be rounded to the lowest available denomination of coinage. For these currencies, Xstore Point of Service automatically applies rounding rules that enforce the minimum denomination value that can be accepted or refunded.
For example, in Australia, the 5-cent coin is the smallest-valued denomination currently in circulation. Because of this, all transaction amounts using Australian currency must be multiples of 5 cents.
When currency rounding is in use, a Cash Total is displayed below the transaction Subtotal. The Cash Total is rounded to the nearest multiple of the Minimum Cash Denomination Value for the currency.
For example, a tender with a Minimum Cash Denomination Value of 5 cents ($0.05) results in the following totals in a sale transaction:
If the Transaction Total=$161.44, then the Cash Total is $161.45 (rounded up).
If the Transaction Total=$236.51, then the Cash Total is $236.50 (rounded down).
If your system is configured to default to the Amount Due when prompting for a tender amount, the Cash Total amount appears in the Enter Cash Amount text field, where it may be accepted or edited. However, tenders can only be accepted (and refunded in return transactions) in amounts that are even multiples of its Minimum Cash Denomination Value.
These values are also printed on the receipt.
