Change Tender Amount
To change a tender amount:
Select Modify Tenders at the tender selection screen (see Selecting Tenders):
Click Modify Tenders.
Use the up and down arrows to highlight Modify Tenders, then press Spacebar.
Click OK.
Select the tender to be modified from the list of modifiable tenders (not all tender types can be modified), then click OK.
Figure 5-61 Changeable Tender List
Select the Change Tender Amount action:
Click Change Tender Amount.
Use the up and down arrows to highlight Change Tender Amount, then press Spacebar.
Click OK.
Figure 5-62 Change Tender Amount
Xstore Point of Service prompts for the new tender amount.
Enter the new amount to apply to the tender.
Xstore Point of Service returns to the tender selection screen. See Selecting Tenders.
