Documentation Conventions
The following explains the conventions used throughout the Oracle Retail Xstore Point of Service Classic User Guide to denote task-related information, highlight information for special emphasis, or to bring your attention to an important point.
Text Conventions
Due to the flexibility of the system, menu options in this guide are not identified by a function key number (for example, [F2] or [F3]). Instead, the name on the button is used throughout the procedures and processes.
Table 2-1 Documentation Conventions in the User Guide
| When you see... | Then... |
Select xxxxx |
Refers to a menu button or list option displayed on the Oracle Retail Xstore Point of Service application screen. The bolded text is the button or menu option text. Since all menu text is configurable, the text you see on your screen may be different than the text used in the procedure. |
Press [xxx] |
Refers to a key on the keyboard. The text inside the brackets is the name of the key. |
Blue text |
Indicates the tagged text is a link to another area of the user document. Click the link to jump to related information. This feature is used when viewing the document online. For printed documents, a page number has also been provided. |
