Log In to Oracle Retail Xstore Point of Service
Use the following steps to log in to Oracle Retail Xstore Point of Service:
At the Register Login screen, scan or key your employee ID number, then press Enter to continue.
Figure 3-1 Register Login ID Prompt
If your system is set up to use a Biometric Fingerprint device, use the device to scan your fingerprint rather than entering your user ID and password. Note: Keyed entry and card scan are also supported here
The system prompts for your password. Type your password and press Enter to continue. For security purposes, your password displays as a row of asterisks.
Figure 3-2 Employee Login Password Prompt
You may be prompted to clock in and select a work code.
