6 Message Maintenance and Task Management
Messages can be viewed from both the Register Login screen and the Back Office Login screen. You may also be able to view messages from the transaction screens depending on your store configuration.
Task Management is a feature that encompasses tasks assigned to associates in a store for completion as well as tasks that are customer-focused such as appointments. Tasks have workflows associated with them so at any time a manager can easily see the current status of the task. This section also includes instructions on how to use the Black Book feature to view your associate's primary customers.
The following topics are covered:
Creating and Maintaining Messages
Messages are for information purposes only and require no action by the employee. Messages may be downloaded from the corporate office, and messages can also be created and maintained at the store level using the Back Office Message Maintenance menu option.
Messages can be store-based or register-based and provide the ability for both the corporate office and the store managers to share information with all employees.
Messages can be maintained at the corporate office or using the Back Office functions. Only store-created messages can be edited at the store level. Messages from the corporate office cannot be changed or deleted.
Perform the following steps to create and maintain messages:
At the Back Office Main Menu, select the Employee menu option and press Enter.
Figure 6-1 Employee Option - Main Menu
At the Employee menu, select the Message Maintenance menu option and press Enter.
Figure 6-2 Employee Menu
The Employee Messages search form displays. You have the following options on the search form:
Figure 6-3 Employee Messages Search Form
To create a new message, select New Message. See Creating a New Message.
To find an existing message:
Enter the search criteria in the search fields provided and select Process.
Search fields include:
Start Date: The date the message is to be displayed.
End Date: The date the message is to be removed from the message list.
Priority: The message importance: High, Medium, Low.
<OR>
Leave all the search fields blank and select Process to return a list of all active, store-level messages.
See Editing a Message and Deleting a Message.
Messages can be displayed on all registers, or only a specific register. However, all employees can see the messages. Messages cannot be directed to specific employees or employee groups. Any messages created are automatically flagged as Store Created.
At the Employee Messages search form (Figure 6-3), select New Message.
You can also create a new message by selecting the New Message option from the Employee Messages list. See Figure 6-6.
Enter data as required to create a new message:
Figure 6-4 Employee Messages - New Message Form
Register Specific/Register #:
Register Specific: Yes or No - If no, the message is displayed on all registers. If yes, the message is only displayed on a specific register.
Register #: If Register Specific is set to yes, this is the register on which the message is displayed.
Message URL: If applicable, enter a URL address. The URL will appear as an attachment to the message. See Figure 6-5 below.
Message: The message text.
Select Save Changes to create the new message.
Figure 6-5 Register Store Message with URL attachment
Editing a Message
Only messages created at the store level can be edited or deleted. For this reason, any messages downloaded from the corporate office are not displayed in the list of messages returned from a message search.
To find and display the list of store-created messages, refer to step 3
At the Employee Messages list, use the up and down arrow keys to select and highlight a message, then press Enter to display the Employee Messages maintenance form.
Figure 6-6 Employee Messages List
At the Employee Messages maintenance form, select Edit Message to make the fields active and available for editing.
Figure 6-7 Employee Messages Menu Option
At the active Employee Messages maintenance form, make your changes as needed:
Figure 6-8 Employee Messages Maintenance Form - Active View
Register #: The register on which the message is displayed. This only applies if Register Specific is set to Yes.
After making your changes, select Save Changes to apply your edits to the message.
Deleting a Message
Only messages created at the store level can be deleted.
At the Employee Messages list (Figure 6-6), use the up and down arrow keys to select and highlight a message, then press Enter to display the Employee Messages maintenance form.
Figure 6-9 Employee Messages Maintenance Form - Delete Message
At the Employee Messages maintenance form, select Delete Message to delete the message.
At the Delete Message confirmation prompt, select Yes to remove the message. If you do not want to delete the message, select No to return to the Employee Messages search form.
Figure 6-10 Delete Message Confirmation Prompt
Reviewing Task Management Information
Use the My Task screen to review all tasks assigned to associates (see Viewing Task Progress). Use the Black Book to view primary customers assigned to your associates (see Viewing Black Book Customers).
From the Back Office select Associate Tasks > My Tasks.
Use the filter bar to search by Associate, Activity, Status, Start Date, or End Date. To filter:
Select a Heading or Date field from the filter bar:
Figure 6-11 Filter Bar
You can also use the following menu options to filter:
Associate List Filter
Activity List Filter
Status List Filter
If you selected:
Associate - select a value and then select OK.
Figure 6-12 Associate List Filtering
Activity - select a value and then select OK.
Figure 6-13 Activity Filtering
Status- select a value and then select OK.
Figure 6-14 Status Filtering
Start Date - override the default value.
End Date - override the default value.
Figure 6-15 Date Filtering
Xstore Classic displays tasks that meet your filter values.
Figure 6-16 Filtering Results
Table 6-1 Task List Fields
Field Description Priority (P)
The Importance of the task (High (indicated by an exclamation mark), Medium (none), or Low (indicated by a down arrow).
Date
The date the task should be started.
Start Time
The time the task should begin.
Duration
The length of time for the task.
Activity
Type of task.
Description
Detailed description the task.
Customer
The customer assigned to the task.
Note: Select View Customer to view the Tasks tab of the Customer Maintenance screen which displays all tasks assigned to the customer. See description in the Oracle Retail Xstore Point of Service Classic User Guide for more information.
Status
Indicates the progress of the task:
Open - The appointment is open, but not started.
In Progress - The appointment has been started, but not completed.
Cancelled - The appointment has been cancelled and cannot be reopened or edited.
Closed - The appointment has been completed and cannot be reopened or edited.
Associate
The employee or employee group responsible for completing the task.
The Oracle Retail Xstore Point of Service Classic User Guide for editing tasks and adding comments.
Oracle Retail Customer Engagement Cloud Services only
From the Back Office select Associate Tasks > Black Book. The Associate filter prompt displays.
Select an associate and press Enter.
Figure 6-17 Associate List Filtering
Xstore Classic displays the primary customers assigned to the associate you selected.
Figure 6-18 Black Book Screen
Table 6-2 Black Book Fields
Field Description Customer Name
The primary customer's name.
Email
The primary customer's email address.
Phone
The primary customer's phone number.
To view the customer information, select View Customer. The Customer Maintenance screen displays the purchase history. Select Back to return to the Black Book screen.
Refer to step 3 (Purchase History Tab) as well as theOracle Retail Xstore Point of Service Classic User Guide Customer Maintenance chapter.
