47 Item Transfer
This chapter describes the procedures for transferring items from one inventory bucket to another.
About This Chapter
This chapter contains the following procedures:
Start Item Transfer - Describes how to start an item transfer.
Perform Transfer - Describes the procedure for the item transfer.
Adjust Item - Describes procedures for adjusting items in the transfer.
Additional Options - Describes additional options available in the item transfer screen.
Start Item Transfer
To start the item transfer process:
Figure 47-1 Main Menu - Inventory
Select Inventory in the Main Menu.
Figure 47-2 Handheld Inventory Menu
Select Item Transfer from the Inventory menu.
Continue with Perform Transfer.
Perform Transfer
To perform an item transfer:
Select the location from which the item will be transferred:
Figure 47-3 Inventory Location Selection - From Location
Select the source location for the item.
Select the source bucket for the item.
Select Process.
Select the location to which the item will be transferred:
Figure 47-4 Inventory Location Selection - To Location
Select the destination location for the item.
Select the destination bucket for the item.
Select Process.
Figure 47-5 List of Reason Codes
Select the reason for the transfer.
Figure 47-6 Select an Item
Scan an item or enter an item ID.
Use the Context Menu to:
Figure 47-7 Item Transfer Context Menu
Adjust Item
This section describes how to adjust an item. Select an item to open the Options menu.
Figure 47-8 Item Transfer Options Menu
Two options are available:
Change Qty - See Change Item Quantity.
Void Item - See Void Item.
Additional Options
This section describes additional item transfer options.
Save & Exit
To save the transfer and return to the inventory screen:
Select the Context Menu button.
Select Save & Exit.
Figure 47-10 Confirm Save Transfer
Select Yes.
The item transfer completes. Return to the inventory menu.
Transfer All Items
To include all the items in the list, setting each item to the maximum quantity:
Select Transfer All.
Figure 47-11 Confirm Transfer All Items
Select Yes.
The quantity of every item in the list is set to its maximum value.
Return to the item transfer list screen.
