28 Maintaining Customer Information
Customer options include activities that relate to entering new customers into the customer database and updating customer information along with the maintenance of customer accounts such as orders, layaways, special orders, gift registry and work orders.
Functionality includes:
  • Balance Inquiry
  • Customer Maintenance
  • Gift Registry
  • Layaway Maintenance (Desktop, Thin Client, and Tablet)
  • Order Options
  • Receipt Reprint Options
  • Special Order Maintenance (Desktop, Thin Client, and Tablet)
  • Work Order Options (Desktop, Thin Client, and Tablet)
This section covers the following topics:
Searching for a Customer Record
When you want to assign a customer to the sale during a transaction, the database is searched to see if the customer record already exists. If the record is found in the database, you may want to view the information or confirm that it is correct. If the record is not found in the customer database, you can create a new customer record and enter the information provided by the customer.
  1. Select Customer from Global Navigation. Then select Customer Maintenance. See Figure 22-3.
    Figure 28-1 Customer Search Criteria
    Enter as much information as possible in the Customer Search form to limit the number of customer records that are returned. You may enter partial names in the Last and First name fields.
    The maximum number of returned records is configurable. If your search results exceed that number, you may see a message indicating there are too many results. Select OK to close the message.
  2. Enter your search criteria and then select Search.
    • Phone Number - Phone number associated with the customer.
    • Email - Email associated with the customer.
    • Last Name - Customer last name.
    • First Name - Customer first name.
    • City - City in the customer's address.
    • State - State in the customer's address.
      Values in this drop-down menu can be changed using Change Country.
    • Postal Code - Postal or zip code.
    • Loyalty Number - Customer loyalty number.
    • Customer Number - Customer ID number.
  3. If the name you want is not listed, select the Back option to return to the Customer Search form and enter the customer's full name or make additional entries in other searchable fields. Select Search to search again.
    If only one name matches the search criteria, the system may automatically display the customer record rather than presenting a list, if your system is set up to do so.
    If more than one customer record matches your search criteria, select a customer from the list by touching the line. If a long hold on the individual line is performed, you are given the option to review, continue, or modify this individual customer detail.
    Figure 28-2 Customer Search List
    The Source field below the header Customer Search indicates the data source from which this information was retrieved. The data source depends upon your system's configuration. If your system is integrated with the Oracle Retail Customer Engagement Cloud Services application and the customers are found there, Customer Engagement is indicated as the source. Customers may also be found in other configurable sources such as the Xstore POS database or Xcenter.
  4. Choose one of these options:
    • Perform a new search by entering different search criteria and then select Search.
    • Select the Customer Overflow Menu and then select, Edit Customer Information to view or edit the customer record.
    • Select New Customer to display a form for adding a new customer record to the customer database. See Adding a New Customer Record.
    • Select a customer from the list to open the Customer Dashboard.
    Figure 28-3 Customer Dashboard
    Customer Dashboard
    A customer record always opens in a read-only mode and cannot be edited unless you change to the editing mode.
  5. Choose one of these options:
    • Back - Returns to the Customer Search form.
    • Edit Customer - Select Edit Customer to activate the fields on the window to allow you to change information in the customer record.
      Select the field you want to change and replace the old entry by typing over it with the new information.
      Any field requires an entry is marked with an asterisk. Any field that has a selectable list of options displays a down arrow on the right side of the field.
    • Customer Dashboard Overflow Menu - The options include:.
      • Select Print Customer to display a list of printers for printing the Customer Dashboard.
      • Select Enroll in Loyalty to start the process of enrolling the customer in to a loyalty program. See Enroll in Loyalty for more information.
      • Tax Exemptions
Edit Customer
  1. Select Edit Customer to open the Customer Information drawer.
  2. Select the field you want to change and replace the old entry by typing over it with the new information.
  3. Select OK to save the information to the database. Select Back if you decide not to keep the changes you made.
Customer Information Consent
Xstore allows retailers to capture a customer's consent for collecting their personal information.
If this functionality is enabled, when creating a new customer record or by accessing the customer record in the transaction, you are automatically prompted with a Consent Preferences pop up. If the customer has already given consent and the terms and conditions are current, then they will not be prompted again. However, if the terms and conditions have been updated, the customer will be prompted to update their consent preferences.
The terms and conditions are provided by the retailer. Xstore provides the ability to configure multiple consent check boxes for the customer to select.
The Customer Information Consent screen is configured to be enabled.
  1. From the Customer Dashboard overflow menu, select Review Customer Consent.
  2. The system displays the Customer Information Consent dialog box.
  3. Review the retailer-provided terms and consent preferences with the customer.
  4. If the customer agrees, select the appropriate consent checkboxes and select Accept.
    After selecting the Accept button, the terms and conditions may be reviewed and signed electronically by the customer.
    • If the customer declines, select Decline to return to the previous screen.
      If the customer declines consent, the consent captured date is cleared and it may impact the ability to perform some specific transaction types depending on the retailer's configurations.
    • If consent has already been accepted or declined, the previous selection is pre-populated.
  5. The system captures the customer’s consent preferences.
  6. The user is navigated to the next screen in the flow.
Customers and employees may ask the retailer to remove their personal information by anonymizing or deleting it from their records. If a customer or associate requests to remove their data, a check is made to ensure that the customer or associate is eligible to be removed from the application. For example, customers with any open transactions would not be eligible for data removal. Open transactions include open orders, a house account balance, or open layaway transactions, and so on.
If you search for a customer name and it is not found in the customer database, you can create a new record for the customer. The system displays a message as shown in the figure below if there is no current record.
Figure 28-4 Customer Not Found Message
  1. Select New Customer to display the Customer Information drawer in edit mode.
    The information you entered in the Customer Search form automatically populates the appropriate fields on the Customer Information drawer.
    If customer information consent functionality is not enabled, continue at step 4.
    If customer information consent functionality is enabled, a terms and conditions screen opens showing consent preferences and requesting that the customer accepts or declines to the terms and conditions listed. See Customer Information Consent for more information.
    Select the relevant check boxes if the customer agrees to accept the terms and conditions, and consent preferences.
    To refuse consent, select Decline to return to the previous screen.
  2. Select Accept. Ask the customer to electronically sign the signature capture on the mobile device to acknowledge they are accepting the terms and conditions displayed on the previous screen.
  3. Select Accept to confirm the customer has acknowledged the terms and conditions and signed the receipt. The customer's acceptance is associated to the customer record.
    A confirmation screen is displayed indicating that the customer's consent selections have been updated in the system. Select OK to continue. The customer maintenance screen opens with editable fields.
  4. Enter customer contact information. Your system may be configured to capture and display the following information on the Contact Information tab. Any of the fields may be designated as a required entry (per your store policy).
    Figure 28-5 Customer Information - Edit Customer
    Any field that requires an entry is marked with an asterisk.
    When you enter a valid postal code for the customer, the system automatically enters the city and state information.
  5. Select OK to save the information to the database. Select Back if you decide not to keep the changes you made.
Enroll in Loyalty
To register a customer to the loyalty program:
Figure 28-6 Customer Dashboard Overflow Menu Options
Customer DashboardOverflow Menu Options
  1. In the Overflow Menu, select Enroll in Loyalty.
    Figure 28-7 Loyalty Registration
  2. Swipe the loyalty card or enter card number.
  3. Select Join Loyalty.
  4. Select Save Changes to save the loyalty card information to the customer's record.
Change Country
To change the states/provinces in the State field (if present) to those of a different country:
  1. The ability to change the country is accessed through the following methods.
    • Customer Lookup
      • From the Home Screen, select Customer. The Customer Lookup screen appears.
      • Select Change Country.
      • OR
    • Customer Information
      • From the Customer Search Results list, select the Overflow Menu located at the end of the row and select Edit Customer Information. The Customer Information screen appears.
      • Select the Header Overflow Menu and then select, Change Country.
      • OR
    • Edit Customer Address
      • From the Shopping Cart, select Customer Options and then select Customer Dashboard.
        Figure 28-8 Customer Options Menu
      • Select Addresses. The Address drawer appears.
        Figure 28-9 Addresses
        Addresses
      • Select the Overflow Menu located at the end of the row and then select, Edit Address. The Edit Customer Address drawer appears.
        Figure 28-10 Edit Address
        Edit Address
      • Select the and then select, Change Country.
        Figure 28-11 Edit Customer Address Screen
  2. Select a Country, or Select Back to return without changing the Country.
    Figure 28-12 Change Country List
    Change Country List
Balance Inquiry
Gift cards and store credit vouchers may be used as a tender until the total value of the account has been used. Since the amount left on a card or voucher cannot be visibly seen, this function electronically checks the account record and tells you about the remaining value on the account. You can also use Balance Inquiry to look up an encoded item's price on a gift receipt.
Use the balance inquiry process to check the amount remaining on a customer's store credit voucher, gift card or gift certificate, and an item's price from a gift receipt.
Depending upon the configuration of your system, this option may be available from several different locations.
  1. Select Balance Inquiry from the Customer Menu to view the inquiry functions available in your store. See Figure 22-3.
    Alternatively, the Balance Inquiry menu can be accessed from the Home screen menu.
    Figure 28-13 Home Screen Menu
    Home Screen Menu
  2. Select the type of inquiry you want to perform by selecting the appropriate option from the Balance Inquiry menu.
    • Gift Card Balance: Show the remaining balance on a gift card.
    • Gift Certificate Balance: Shows the remaining balance on a gift certificate.
    • Gift Receipt Inquiry: To view the encoded item’s price on a gift receipt.
    • Loyalty Balance: Shows the loyalty point balance.
    • Store Credit Balance: Shows the remaining store credit balance.
  3. At the prompt, enter the information as prompted: a card number, account number, or gift receipt information.
    Figure 28-14 Gift Certificate Inquiry Prompt
    Figure 28-15 Store Credit Number Prompt
    Figure 28-16 Gift Receipt Inquiry Prompt
    Figure 28-17 Loyalty Balance Inquiry
    The information required here varies according to the type of balance inquiry you are performing. Enter the applicable information and select OK to continue.
  4. The system retrieves the account balance/gift receipt information and displays the information on the screen.
    • If applicable, select Yes to print a receipt for this balance information.
      <OR>
    • If applicable, select No if you do not need a printed receipt for this balance information.
    • If the option to print a receipt is not available, select OK to close the prompt.
    The system displays a message if the account is closed or cannot be located.
    If a deal or discount was applied to the gift item at the time of purchase, you cannot use Balance Inquiry to look up the price. No item price code is printed on the receipt.
    No item price code receipt
    When a balance inquiry for a store credit or gift certificate is performed, Xstore POS first determines which currency the store credit or gift certificate is in. If this currency is different than your store's local currency, then the foreign tender amount of the store credit or gift certificate is automatically converted to the local tender and amount using the current exchange rate on file. This localization is shown on the screen and on the receipt, if printed.
  5. If you chose to print a receipt, the information shown on the receipt includes the date of this inquiry, the card or account information (masked), and the available balance on the card or account.
    Figure 28-18 Sample Balance Inquiry Receipt
