Configuration Options and Availability Matrix
Configurator is used to create, maintain, and deploy Oracle Retail Xstore Point-of. Service configuration changes selectively, or globally across the entire organization. Not all configuration options are available for all scopes. The following configuration scopes are available:
Global Configurations - Change or deploy the global configuration layer which is the foundation for all locations.
Configuration Overrides - Change or deploy configurations that will override the global layer for specific locations (Profile Groups).
Store Specific Overrides - Change or deploy configurations that will override the global layer for specific stores.
Table 5-1 Configuration Options
| Configuration Options | Scope Availability |
Configure |
Deploy |
View Configuration Changes |
Delete Profile Configuration Changes |
Copy Store Configurations |
