Customization Management
The Customization Management page allows you to make customizations,
for example, to the Xadmin menu structure, or the Xcenter data model.
From the Oracle Retail Xstore Office menu, select System Management then System Manager, and Customizations or click the System Manager link in the System panel, and then select Customizations.
The Customization Managementpage displays, showing a list of uploaded configuration files.
