Oracle Retail Xstore Office Configuration
Oracle Retail Xstore Office Configuration provides the ability to set up the configuration options that govern how Oracle Retail Xstore Office works. You cannot add or delete Oracle Retail Xstore Office configuration options.
Figure 3-1 Xadmin System Settings
Xadmin System Settings Page
  1. From the Oracle Retail Xstore Office menu, select System Management, then Xadmin Settings, or click the Xadmin Settings link in the System panel.
  2. The Settings page displays, showing the configuration options available for Oracle Retail Xstore Office. The configuration options are arranged by category, in a tree view. Edit the values as needed, then click the Save button to save the changes.
    To find configurations containing specific text, enter the search text in the input box, then press [Enter]. The text typed here can be found anywhere within the configuration label or description. The results are shown in the left panel (folder tree). Only those configurations containing the specified text within the label and/or description are displayed. If needed, click Clear to remove the search criteria and return to the Oracle Retail Xstore Office Configuration page.
    See Oracle Retail Xstore Office Configuration below for detailed information about the Oracle Retail Xstore Office configuration options.
