About this Chapter
Where To Look For More Information
A system configuration allows you to turn off and on any of the valid file format types available to be used when viewing/saving reports. You can also select the default format to be selected from the list of enabled file formats.
For instructions on specifying the report formats to be available to the user, see System Management, section Reports Category.
