J Appendix: Data Seeding Process Flows
Data Seeding Process Flows from Merchandising to EICS
The following list shows the Data Seeding Process Flows from Merchandising to EICS with Groups.
Table J-1 Data Seeding Process Flow Dependencies List
| Group# | Process Flow | Notes |
1 |
MerchHier_Fnd_ProcessFlow_From_RMS |
Merchandise Hierarchy foundation data seed from Merchandising Foundation Data System. Run once for initial full data seed. |
1 |
Supplier_Fnd_ProcessFlow_From_RMS |
Supplier foundation data seed from Merchandising Foundation Data System. Run once for initial full data seed. |
1 |
SupplierAddr_Fnd_ProcessFlow_From_RMS |
Supplier address foundation data seed from Merchandising Foundation Data System. |
1 |
Partner_Fnd_ProcessFlow_From_RMS |
Partner foundation data seed from Merchandising Foundation Data System. |
1 |
PartnerAddr_Fnd_ProcessFlow_From_RMS |
Partner address foundation data seed from Merchandising Foundation Data System. |
1 |
Wh_Fnd_ProcessFlow_From_RMS |
Run once for initial full warehouse foundation data seed from Merchandising Foundation Data System. |
1 |
WhAddr_ProcessFlow_From_RMS |
Run once for initial full warehouse address foundation data seed from Merchandising Foundation Data System. |
2 |
PartOrgUnit_Fnd_ProcessFlow_From_RMS |
Run once for initial full partner Org Unit foundation data seed from Merchandising Foundation Data System. |
2 |
ItemHdr_Fnd_ProcessFlow_From_RMS |
Run once for initial full item foundation data seed from Merchandising Foundation Data System. |
2 |
Uda_Fnd_ProcessFlow_From_RMS |
Run once for initial full User Defined Attribute (UDA) foundation data seed from Merchandising Foundation Data System. |
2 |
DiffGrp_Fnd_ProcessFlow_From_RMS |
Run once for initial full foundation data seed from Merchandising Foundation Data System. |
2 |
CodeHead_Fnd_ProcessFlow_From_RMS |
Run once for initial full Code Head foundation data seed from Merchandising Foundation Data System. |
3 |
PckitemBrkout_Fnd_ProcessFlow_From_RMS |
Run once for initial full Pack Item Breakout foundation data seed from Merchandising Foundation Data System. |
3 |
RelatedItem_Fnd_ProcessFlow_From_RMS |
Run once for initial full Related Item foundation data seed from Merchandising Foundation Data System. |
4 |
ItemSupplier_Fnd_ProcessFlow_From_RMS |
Run once for initial full Item Supplier foundation data seed from Merchandising Foundation Data System. |
4 |
ItSupCtryDim_Fnd_ProcessFlow_From_RMS |
Run once for initial full Item Supplier Country Dimension foundation data seed from Merchandising Foundation Data System. |
4 |
ItSupCtry_Fnd_ProcessFlow_From_RMS |
Run once for initial full Item Supplier Country foundation data seed from Merchandising Foundation Data System. |
4 |
ItSupCtryManCtry_Fnd_ProcessFlow_From_RMS |
Run once for initial full Item Supplier Manufacturing Country foundation data seed from Merchandising Foundation Data System. |
4 |
ItemSuppUom_Fnd_ProcessFlow_From_RMS |
Run once for initial full Item Supplier Unit of Measure foundation data seed from Merchandising Foundation Data System. |
5 |
Store_Fnd_ProcessFlow_From_RMS |
Run once for initial full store foundation data seed from Merchandising Foundation Data System. |
5 |
StoreAddr_Fnd_ProcessFlow_From_RMS |
Run once for initial full store address foundation data seed from Merchandising Foundation Data System. |
6 |
ItemLoc_Fnd_ProcessFlow_From_RMS |
Run once for initial full item location foundation data seed from Merchandising Foundation Data System. |
6 |
InvAvailStore_Tx_ProcessFlow_From_RMS |
Run once for initial full store available inventory foundation data seed from Merchandising Foundation Data System. |
7 |
ReplItemLoc_Fnd_ProcessFlow_From_RMS |
Run once for initial full replenishment item location inventory foundation data seed from Merchandising Foundation Data System. |
7 |
PriceHist_Fnd_ProcessFlow_From_RMS |
Run once for initial full item pricing history foundation data seed from Merchandising Foundation Data System. |
8 |
ItemImage_Fnd_ProcessFlow_From_RMS |
Run once for initial full item image foundation data seed from Merchandising Foundation Data System. |
8 |
UomClass_Fnd_ProcessFlow_From_RMS |
Run once for initial full Unit Of Measure foundation data seed from Merchandising Foundation Data System. |
8 |
UdaItemDate_Fnd_ProcessFlow_From_RMS |
Run once for initial full UDA Item Date foundation data seed from Merchandising Foundation Data System. |
8 |
UdaItemFF_Fnd_ProcessFlow_From_RMS |
Run once for initial full UDA Item Free Form foundation data seed from Merchandising Foundation Data System. |
8 |
UdaItemLov_Fnd_ProcessFlow_From_RMS |
Run once for initial full UDA Item LOV foundation data seed from Merchandising Foundation Data System. |
8 |
UdaValues_Fnd_ProcessFlow_From_RMS |
Run once for initial full UDA Values foundation data seed from Merchandising Foundation Data System. |
9 |
CodeDetail_Fnd_ProcessFlow_From_RMS |
Run once for initial full Code Detail foundation data seed from Merchandising Foundation Data System. |
9 |
DeliverySlot_Fnd_ProcessFlow_From_RMS |
Run once for initial full Delivery Slot foundation data seed from Merchandising Foundation Data System. |
9 |
Diff_Fnd_ProcessFlow_From_RMS |
Run once for initial full Differentiators foundation data seed from Merchandising Foundation Data System. |
9 |
UomConversion_Fnd_ProcessFlow_From_RMS |
Run once for initial full UOM Conversion foundation data seed from Merchandising Foundation Data System. |
Data Seeding Mapping Tables between SIOCS and BDI
The table below specifies the Data Seeding Mapping tables Between SIOCS and BDI.
Table J-2 Data Seeding Mapping Tables between SIOCS and BDI
| SIOCS Table | BDI Interface Table |
ADDRESS |
STORE_ADDR_IN PARTNER_ADDR_IN WH_ADDR_IN SUPPLIER_ADDR_IN |
DIFFERENTIATOR |
DIFF_IN |
DIFFERENTIATOR_TYPE |
DIFF_IN |
ITEM |
ITEM_HDR_IN |
ITEM_COMPONENT |
PACKITEM_BREAKOUT_IN |
ITEM_HIERARCHY |
MERCH_HIER_IN |
ITEM_IMAGE |
ITEM_IMAGE_IN |
ITEM_PRICE |
ITEM_LOC_IN (LOC_TYPE = 'S') |
ITEM_PRICE_HISTORY |
PRICE_HIST_IN |
ITEM_UDA |
UDA_ITEM_LOV_IN UDA_ITEM_FF_IN UDA_ITEM_DATE_IN |
PARTNER |
PARTNER_IN |
PARTNER_ITEM |
ITEM_LOC_IN (LOC_TYPE = 'E') |
RELATED_ITEM |
RELATED_ITEM_IN |
RELATED_ITEM_TYPE |
RELATED_ITEM_TYPE |
STORE |
STORE_IN |
STORE_ITEM |
ITEM_LOC_IN (LOC_TYPE = 'S') REPL_ITEM_LOC_IN |
STORE_ITEM_STOCK |
INV_AVAIL_STORE_IN |
STORE_TRANSFER_ZONE |
STORE_IN |
SUPPLIER |
SUPS_IN |
SUPPLIER_ITEM |
ITEM_SUPPLIER_IN |
SUPPLIER_ITEM_COUNTRY |
ITEM_SUPP_COUNTRY_IN |
SUPPLIER_ITEM_COUNTRY_DIM |
ITEM_SUP_CTY_DIM_IN |
SUPPLIER_ITEM_MANUFACTURE |
ITEM_SUP_MAN_CTY_IN |
SUPPLIER_ITEM_UOM |
ITEM_SUPP_UOM_IN |
SUPPLIER_ORGANIZATION |
PARTNER_ORG_UNIT_IN |
UDA |
UDA_IN |
UDA_LOV |
UDA_VALUES_IN |
UOM_CLASS |
UOM_CLASS_IN |
UOM_CONVERSION |
UOM_CONVERSION_IN |
WAREHOUSE |
WH_IN |
WAREHOUSE_ITEM |
ITEM_LOC_IN (LOC_TYPE = 'W') |
