4 REST Web Services
Web services are intended for integration to allow a system using those services to control the flow and processing of data within EICS. There are multiple types of data involved in this integration. Data that is managed by other systems and needs to get into our system, but that EICS does not manage. This includes such concepts as item, stores, and point-of-sale transaction. Data that is managed by EICS includes such ideas as inventory adjustments, transfers, deliveries, and stock counts. Some services will provide ability for external data to get into EICS, some are intended to be used real time such as approving, picking, and dispatching shipments.
REST WEB Services Security Considerations
The REST web services provided by EICS are secured using OAuth2 tokens and require SSL.
The supported OAuth2 security requires a token requested for the client_credentials grant with the EICS integration scope (for example, rgbu:siocs:integration).
Note that the scope name differs for each environment.
REST Web Service OAuth2 Requests
This section will describe how to call an EICS web service using the OAuth2 protocol. The target audience is developers who are looking to write code that calls the web service.
Using the OAuth Protocol
The OAuth protocol is relatively straightforward:
  • Get an access token from the authentication provider
  • Pass the access token along with the web service request
In this case, the authentication provider is Oracle Identity Cloud Service (IDCS). Every customer who purchases a subscription to EICS gets a subscription to IDCS as part of their purchase.
Obtaining a Token
REST APIs use OAuth2.0 for authorization.
To generate a token from IDCS, an IDCS application client will need to be created for you to use.
The Customer Administration users must create their own client credential IDCS application using the Oracle Retail Home Cloud Service. For additional details, refer to Oracle® Retail Home Administration Guide- Chapter: Oauth Application Configuration chapter – Section: Creating OAuth Client Applications.
The App name and scope that should be used for IDCS application creation should be environment specific using the format :
App Name- RGBU_SIOCS_<ENV>_EICS_INT
Scope 1 - rgbu:siocs:integration-<ENV>
Scope 2 - rgbu:siocs:security-<ENV>
Please note that the integration scope is the default and other scopes are needed when specified.
Example:
App Name- RGBU_SIOCS_STG1_ EICS_INT
Scope 1 - rgbu:siocs:integration-STG1
Scope 2 - rgbu:siocs:security-STG1
You will need the following information about the IDCS application client to request a token:
  • IDCS URL
  • Client Id
  • Client Secret
  • Scope Name
the application client must be assigned the scope from the EICS IDCS cloud service in order to request the token. This assignment is performed when the application client is created.
The scope name will differ for each environment. Please ensure the correct value is used for your environment.
To generate a token, you will need to invoke the appropriate IDCS REST API. The curl command in Linux that describes the POST that will return a token is as follows:
curl -H 'Authorization: Basic <base64(clientId:clientSecret)>' -H 'Content-Type: application/x-www-form-urlencoded;charset=UTF-8' --request POST <IDCS URL>/oauth2/v1/token -d 'grant_type=client_credentials&scope=<EICS Scope>'
In Windows, use double-quotes, as follows:
curl -H "Authorization: Basic <base64(clientId:clientSecret)>" -H "Content-Type: application/x-www-form-urlencoded;charset=UTF-8" --request POST <IDCS URL>/oauth2/v1/token -d "grant_type=client_credentials&scope=<EICS Scope>"
This is a standard REST POST, with the following details:
  • <IDCS URL> is the IDCS URL the retailer provided
  • Include the Client Id and Client Secret as a Basic Authentication header
  • Specify the Content Type as application/x-www-form-urlencoded;charset=UTF-8
  • Specify the body as grant_type=client_credentials&scope=<EICS Scope>
The service will respond with the following JSON message:
"access_token": "<TOKEN>",
"token_type": "Bearer",
"expires_in": 3600
Note that the response will return how long the token is valid for. You should reuse the same token until it expires in order to minimize calls to IDCS to get a token.
If the token request fails, you will receive the following JSON response:
"error":"<error>",
"error_description":"<error description>",
"ecid":"u….."
The most common errors are:
  • Invalid Client. This means that the client information you send in is not correct. The error description will expand on the reason:
    • Client Authentication Failed means that the client is valid, but the client secret is incorrect.
    • Invalid OAuth Client <CLIENT> means that the client id is not valid, and the invalid client will be listed in the error message.
  • Invalid Request. Some part of the inbound request is not valid. The error description is usually descriptive about what the actual error condition is
Calling the EICS Web Service
To invoke the web service with an OAuth2 token, you must add an Authorization header to the request. The value of the Authorization header must be Bearer <token>, that is:
  • The word Bearer
  • A space
  • A valid token
For a REST service call, the request might look something like this:
curl -X POST -H 'Content-Type: application/json' -H 'Authorization: Bearer <TOKEN>' -i https://CloudServiceURL --data '{PAYLOAD}'
Remember that the token will expire after a specific amount time, and to be more efficient you should always use a token so long as it's valid. It is your responsibility to make sure that you are keeping track of whether the token is still valid. Your pattern should be:
  • Check to see if you have a valid token that has not expired.
  • If not, call to IDCS and get a new token. Store it and its expiration time.
  • Send the request into the web service with the token in the Authorization header as a Bearer token.
REST WEB Services Basic Design Principles
Requests and Responses
When making requests and processing responses from REST web services it is important for the client to handle headers correctly.
The client should always use Accept for the appropriate content type when making requests.
The client should always check the response status code and Content-Type header before processing a response body.
When reading a payload from the response body, the Content-Length header must be used safely and securely along with the Content-Type.
This is important even for error responses. It is possible for errors to occur outside of the REST API layer, which may produce different content for the error. In these cases, it is common to get text or HTML content for the response body.
API Versioning
Accept-Version
The REST end points have an optional API versioning feature allowing the client to specify an API version to be accepted.
This may be used by the client to ensure that no calls may be made to a web service that uses an incorrect version number.
For example: Accept-Version: 22.1.301
If the web service does not support this API version, then the server will produce a 400 Bad Request error response.
Content-Type
application/json
The content type of both REST input and returned output is application/json.
In the case that no content is included, a content type may not be assigned.
When handling REST service responses, the client must always check the returned Content-Type and Content-Length before processing the payload.
JSON Validation
When consuming a REST service end point that requires a request payload as JSON, the client is responsible for verifying that the JSON is valid. If invalid data is sent in a request, there may be a server error processing the JSON or it may ignore some fields if the JSON is valid but does not map correctly to the API payload definition.
Always make sure that the client sends valid JSON that is designed to satisfy the API payload definition.
Synchronous vs Asynchronous
Each service API will be defined as synchronous or asynchronous. Both perform JSON validation as described above. If the API is synchronous, the remaining data validation and live updating of the data will take place immediately and the call will be rejected if any business errors occur. If the API is asynchronous, the data is set aside to be processed later and the REST service is successfully returned noting that the data has been accepted. In the case of asynchronous processing, business error and failed data recovery is monitored and the dealt with outside of the REST web service.
Online Documentation
EICS has exposed Swagger JSON files for customers to download and use with the Swagger application as online documentation. The table below contains the files name for access. The file can be retrieved from on the server at:
https://<external_load_balancer>/<cust_env>/siocs-int-services/public/api/filename.json
activitylock
address
allocation
batch
differentiator
finisher
fts
fulfillmentorder
fulfillmentorderdelivery
fulfillmentorderpick
fulfillmentorderreversepick
inventoryadjustment
item
itembasket
iteminquiry
iteminventory
itemisn
itemprice
itemuda
itemuin
manifest
notification
postransaction
productarea
productgroup
productgroupschedule
purchaseorder
reasoncode
rfid
security
shelfadjustment
shelfreplenishment
shelfreplenishmentgap
shipping
stockcount
store
storeitem
storeorder
storesequence
supplier
ticket
transfer
transferdelivery
transfershipment
translation
vendordelivery
vendorreturn
vendorshipment
warehouse
For external APIs that must be implemented by the customer for EICS to access, the files can be accessed on the server at:
https://<external_load_balancer>/<cust_env>/siocs-int-services/public/api-external/file.json
fulfillmentorderaddress-external
fulfillmentorderstatus-external
inventoryadjustment-external
manifest-external
notification-external
preshipmentnotice-external
shipment-external
stockcountschedule-external
storeorder-external
ticketprint-external
transferdeliverreceipt-external
transferstatus-external
vendordeliveryreceipt-external
vendorreturn-external
Configured System Options In EICS
Web services apply system configuration to the request that are coming in through a web service but assumes that all in-put validation that requires user interaction to confirm has been completed by the third party system prior to accessing the service. It operates as if the user confirmed any activity. However, if a system option is a fixed restriction that does not require user interaction, and the input fails the restriction, this is always considered an error.
Examples of configurations being applied include:
Shipping inventory when inventory is less than 0 can be allowed by a user of EICS. The web services assumes that the application accessing the service did prompt the user or that their business always allows the user to this activity.
Adding a non-ranged item requires both a system configuration option to be enabled and the user to confirm the addition of the item. If the system configuration does not allow it, the web service will block the transaction and return an error (un-less processing asynchronously). If the system configuration does allow adding non-ranged items, it will automatically assume that a user confirmed this addition and processing will allow the addition of the item.
Allowing Receiver Unit Adjustments is dependent on a period of time. If a receiver unit adjustment were to come into EICS after that period of time, it would automatically be rejected, and the web service would return an error regardless of presentation or confirmation of user done by the external system.
External vs Internal Attributes
EICS web services are EICS centric and track information from an internal application point-of-view. This has ramifications on three types of data: identifiers, dates, and users.
Almost all paths and information will contain an identifier. In almost all cases, this will be an EICS internal identifier generated within our system. If external identifiers also exist for the date, they will be defined as such in the information. For example, you might encounter transferId and externalTransferId as attributes. In some cases, an API only takes an internal identifier, and you may need to use lookup APIs to retrieve an internal identifier using an external identifier as search criteria.
Timestamps are captured at the time an event occurs within EICS as part of EICS's internal tracking and state management. For example, we capture the timestamp when a shipment is created, last updated, and when it is dispatched. These timestamps occur at the time this occurred within EICS. When a REST service is called to create a transaction, such as a shipment, the create timestamp of the shipment will be the moment that service is called. If the shipment is dispatched using the web service, the dispatch date will be the moment that service is called. So if an external system dispatched a shipment two days earlier, and is just now calling the web service, it will not capture the external dispatch time. In some places, you will encounter a date that can be entered as part of the input information (for example, an externalDispatchDate, or simple a transactionTimestamp). If it is part of the input information, then it will be captured as that attribute defined in the API.
The user responsible for actions is often captured as part of transaction information with EICS. Some examples might be the user that created the data, the user the last updated it, or perhaps the user that approved it. In these cases, the user is considered an internal user as is assigned the current session user at the time the activity takes place. When accessing the REST service, the user will be fiwed as an “External User” to indicate it came from an external system, and not the user that manipulated the information in an external system. If external users are to be captured by the data, there will be independent attribute fields such as externalCreateUser that capture the identity of a user in an external system.
Activity Locking
An activity lock is a record indicating that a user is currently actively working on a transaction. When using REST services, the accessing application is responsible for the management of activity locks. The Activity Lock REST service allows the finding, creating, and deleting of activity locks.
Developers should create a lock on transactional information prior to performing updating calls and delete those locks when the update is finished. For example, to update Inventory Adjustment 123, the first step is to create an activity lock for Inventory Adjustment 123 using the Activity Lock REST service. The next step is to update the inventory adjustment. Once the inventory adjustment is finished, you can then delete the activity lock for Inventory Adjustment 123. Note that an activity lock is not obtained, then an error may occur when updating the transaction indicating that the update can not happen due to a user currently holding the lock.
An alternate method to handling activity locks is to assume that REST service calls should override any current work a user is performing. Under this design, a delete lock call can be issued just prior to the update. For example, for Inventory Adjustment 123, you can simply delete locks for that transaction just prior to calling the update and this will remove the lock and terminate any work other users are doing on that transaction prior to your update.
Dates In Content
Dates included as part of raw JSON data content (most often as part of a POST) must match the following format example: 2022-04-19T23:59:59-05:00.
The content includes year (4 digit), month, day, hour, minute, second, and timezone offset and allows formatting.
Dates included as a query parameter within the main URL must be in the following format example: 220227152543-0700
The content includes year (2 digit), month, day, hour, minute, second, and timezone offset without any formatting.
Due to URL encoding standards, the query parameter cannot directly contain a “+” symbol for positive shift from UTC timezones and this character will need to replace by its URL encoding. The URL encoding for a “+” symbol is “%2B”, so the actual query parameter for 220227152543+0700 would instead be 220227152543%2B0700.
After the format permissible length, any additional trailing characters will be ignored and the date will still be processed.
Links In Content
JSON information for a data object may include links. These are self-referential APIs that defined other APIs that are available with the information. In the example below, when reading an activity lock, the following links were included that define a path to accomplish other calls. HRef lists the basic reference and the “rel” the remainder of the path. So, when you read activity lock (1), you get a delete reference that maps to /activitylock/1/delete, defining the REST path to delete that lock.
"links" : [ {
"href" : "/activitylocks/1",
"rel" : "self"
"rel" : "delete"
Hypertext Transfer Protocol Status Codes
The following information documents the HTTP status codes that Oracle returns via web services calls.
Success Codes
Successful codes are returned whenever the accessing client call was made without any error in the form or content.
Code Description
200 OK
The information supplied by the customer was in a correct form. This code is returned when reading a resource or querying information about an existing resource or schema. This response code is used when the access is synchronous.
202 Accepted
The information supplied by the customer as in a correct form. This code is returned when access is asynchronous.
204 No Content
The information supplied by the customer was in a correct form. The request was successful but the API itself never provides information as a response.
Client Failure Codes
Client failure codes indicate the client made an error in their service access and must correct their code or its content to fix the failure.
Code Description
400 Bad Request
If this code is returned, it indicates the customer made a call with invalid syntax or violated the defined properties of the input information. Detailed information may be returned that further identifies the error.
401 Unauthorized
403 Forbidden
If either of these codes are returned, it indicates the access to service was denied. This may occur if no OAuth2 token was provided, or the token had expired, or the identity the token was generated for did not have sufficient access.
404 Not Found
If this code is returned, it indicates the customer made an erroneous access call against a resource or schema that is not defined.
405 Method Not Allowed
If this code is returned, it indicates that the wrong HTTP method was used to make the call. Please check the API.
406 Not Acceptable
If this code is returned, it indicates the wrong Accept header value was used to make the call. Please check the API.
409 Too Many Requests
If this code is returned, it indicates that the web service has received too many service requests recently. This may indicate a cloud issue requiring support to address or the client is making too many calls too frequently and a solution may be required to avoid the issue.
System Failure Codes
System failure codes are returned whenever the processing server encounters an unexpected or severe failure.
Code Description
500 Internal Server Code
A server error occurred that did not allow the operation to complete.
502 Bad Gateway
503 Service Unavailable
504 Gateway Timeout
If any of these codes are returned, it indicates an issue with the network or cloud services, which may occur due to either client or cloud networking or infrastructure issues, such as outages.
JSON Error Element and Error Codes
If an error occurs in the form of the content, or during processing of the content, an HTTP response code (400 Bad Request) will be returned along with JSON structure defined by the ErrorList schema.
Schema — ErrorList
This section describes the ErrorList schema.
Table 4-1 ErrorList — Object
Element Name Required Data Type Description
errors NA object
Information about the errors.
The table below describes the information about the error. See the Oracle Retail Enterprise Inventory Cloud Service Administration Guide for further information.
Table 4-2 Error — Object
code
NA
number example: 1
The code error type.
description
NA
string example: AN_ERROR_TOOK_PLACE
A brief description of the error type (an error key).
dataElement
NA
string example: item
The attribute or element that caused the failure.
dataValue
NA
string example: 1234
The value of the attribute or element that failed, or a piece of information about that element.
referenceElement
NA
string example: inventory adjustment
An attribute or element that may help further identify the error. Most often this is a containing element one level above the failed element.
referenceValue
NA
string example: 123
The value of the reference attribute or element, often something to identify the specific reference element.
Example Value
    "errors": [
        "code": 1,
        "description": "AN_ERROR_TOOK_PLACE",
        "dataElement": "item",
        "dataValue": "1234",
        "referenceElement": "inventory adjustment",
        "referenceValue": "123"
Error Attribute Definitions
Code
A numeric code indicates the issue. See Integration Error Codes table.
Description
The name of the error or issue.
DataElement
The name of an attribute or element of the JSON structure that failed.
DataValue
The value of the attribute or element that failed, or a piece of information about the element that failed (such as a maximum value).
ReferenceElement
The name of an attribute or element that will help further identify the data element. Most often the containing element one level above the failed elements (such as a transaction header).
ReferenceValue
The value of the attribute or element that will help further identify the data element.
The following table contains a listing of the error codes that can be found within returned error information.
Code Name Issue
1
Business Error
A business processing error prevent the service from completing.
2
Date Range Error
The date range has a problem (usually indicates end date is earlier than start date in a date range.
3
Duplicate Error
Indicates duplicate element within the data is not permitted.
4
Forbidden
Access is not allowed to the service.
5
Internal Server Error
A severe error occurred with the service attempting to process the request.
6
Invalid Input
Most often this indicates that input was included that is not allowed or not needed, however it also doubles a kind of catch-all category.
7
Invalid Format
An input was in an invalid format (most often a date string in a query parameter not being in a valid date format).
8
Invalid Status
A transaction or entity is not in a valid status to proceed with the request.
9
Missing Path Element
A path element defining the path of the resource URL was not present.
10
Missing Attribute
A required attribute was missing on the input to the service.
11
Not Found
A data element in the input could not be found in the system (most often an invalid identifier).
12
No Data Input
No input exists for a service that requires input.
13
No Query Input
No query input exists at all for a query that requires at least one input.
14
Element Too Large
An input was too large (exceeded maximum count or maximum size).
15
Results Too Large
The results of the service were too large to return.
Error Code Data Elements
The following table contains a listing of likely or possible data elements that would be matched with a code. Data element and value may not be returned in all cases.
Code Name Data Element Data Value
1
Business Error
Business exception name/key
Data Value
2
Date Range Error
Date element name
Value of date
3
Duplicate Error
Duplicate element name
Duplicated Value
4
Forbidden
N/A
5
N/A
6
Invalid Input
Element name
Value of element
7
Invalid Format
Element name
Value of element
8
Invalid Status
Element name
Status of element
9
Missing element
10
Missing Attribute
Required element name
11
Not Found
Element not found
Value of element not found
12
No Data Input
Missing element
13
No Query Input
N/A
14
Element Too Large
Element name
Allowed size limit
15
Results Too Large
N/A
REST Service: Activity Lock
This service allows the creation, removal, and finding of activity locks.
An activity lock is a record indicating the user, time, and apiece of information (a transaction) that should be considered "locked". All server processing validates that the accessing user has a lock on the information before updating, notifying the current user if someone else has modified the information while they were locked and preventing a stale update.
Server Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api
Find Activity Lock
This section describes the Find Activity Lokc API. The Find Activity Lock API searches for up to 10,000 locks based on input criteria. At least one input criteria should be provided.
Method
GET
URL
/activitylocks/find
Request
Table 4-3 Find Activtiy Lock — Request Parameters
Name Required Data Type/Example Description
activityType NA integer($int2) (query)
Include only activity locks with this activity type. Valid devices types are:
1 - Bill of Lading
2 - Direct Delivery Invoice
3 - Fulfillment Order
4 - Fulfillment Order Delivery
5 - Fulfillment Order Pick
6 - Fulfillment Order Reverse Pick
7 - Invnetory Adjustment
8 - Inventory Adjustment Reason
9 - Item Basket
10 - Item Request
11 - POS Transaction Resolution
12 - Price Change
13 - Product Basket
14 - Product Group
15 - Product Group Schedule
16 - Replenishment Gap
17 - Shelf Adjustment
18 - Shelf Replenishment
19 - Shipment Reason
20 - Stock Count Child
21 - Store Order
22 - Ticket
23 - Ticket Format Basket
24 - Transaction Event
25 - Transfer
26 - Transfer Delivery Carton
27 - Transfer Shipment Carton
28 - Vendor Delivery Carton
29 - Vendor Shipment Carton
30 - Vendor Return
Available values : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30
sessionId NA string($text128) (query) Include only activity locks with this session identifier.
deviceType NA integer($int4) (query)
Include only activity locks with this device type. Valid devices types are:
1 - Client
2 - Server
3 - Integration Service
userName NA string($text128) (query) Include only activity locks with this user name.
lockDateFrom NA string($date-time) (query) Include only activity locks created on or after this date.
lockDateTo NA string($date-time) (query) Include only activity locks created on or before this date.
Responses
This section describes the responses of the Find Activity Lock API.
Response Code: 200
The request has been successful.
The media type is application/json.
Example Value
    "lockId": 1111111,
    "sessionId": "1234",
    "activityId": "5555",
    "activityType": 1,
    "deviceType": 1,
    "userName": "userAbc",
    "lockDate": "2025-02-27T13:15:22.775Z"
Schema — ActivityLockIdo
Table 4-4 ActivityLockIdo —Object
Element Name: Required Data Type/Example Description
lockId NA number($int15) example: 1111111 The identifier of an activity lock.
sessionId NA string($text128) example: 1234 The identifier of the session that owns the lock.
activityId NA string($text128) example: 5555 The identifier of the activity that is locked.
activityType NA integer($int4) example: 1
The type of activity that is locked. Valid devices types are:
1 - Bill of Lading
7 - Inventory Adjustment
9 - Item Basket
10 - Item Request
12 - Price Change
13 - Product Basket
14 - Product Group
21 - Store Order
22 - Ticket
25 - Transfer
30 - Vendor Return
Enum:
[ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30 ]
deviceType NA integer($int4) example: 1
The device type that holds the activity lock. Valid types are:
1 - Client
2 - Server
Enum: [ 1, 2, 3 ]
userName NA string($text128) example: userAbc The unique identifier of the user that owns the lock.
lockDate NA string($date-time) The date the activity was locked.
Response Code: 400
Bad request
See the JSON Error Element and Error Codes section.
Read Activity Lock
The Read Activity Lock API retrieves information about an activity lock.
Method
GET
URL
/activitylocks/{activityLockId}
Request
Table 4-5 Read Activity Lock — Request Parameter
activityLockId
Yes
integer($int15) (path)
The activity lock identifier.
Responses
This section describes the responses of the Read Activity Lock API.
Response Code: 200
Example Value
  "lockId": 1111111,
  "activityType": 1,
  "deviceType": 1,
  "lockDate": "2025-02-27T13:47:12.359Z"
Table 4-6 ActivityLockIdo —Object
1 - Bill of Lading
9 - Item Basket
10 - Item Request
12 - Price Change
13 - Product Basket
14 - Product Group
21 - Store Order
22 - Ticket
25 - Transfer
30 - Vendor Return
Enum:
1 - Client
2 - Server
Enum: [ 1, 2, 3 ]
Response Code: 400
Bad request
Create Activity Lock
The Create Activity Lock API creates a new user transaction activity lock. This prevents two users from simultaneously changing the data.
Method
POST
URL
/activitylocks
Request
There are no request parameters.
The request body is appliaction/json.
The activity lock to create.
Example Value
  "activityType": 1
Schema — ActivityLockCreateIdo
Table 4-7 ActivityLockCreateIdo —Object
Element Name Required Data Type/Example Description
sessionId
Yes
activityId
Yes
The identifier of the activity that is locked (this is often a primary identifier of a transaction).
activityType
Yes
1 - Bill of Lading
9 - Item Basket
10 - Item Request
12 - Price Change
13 - Product Basket
14 - Product Group
21 - Store Order
22 - Ticket
25 - Transfer
30 - Vendor Return
Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30 ]
Responses
This section describes the responses of the Create Activity Lock API.
Response Code: 200
Example Value
  "lockId": 1111111
Schema — ActivityLockRefIdo
Table 4-8 ActivityLockRefIdo —Object
lockid
NA
Response Code: 400
Bad request
Delete Activity Lock
This section describes the Delete Activity Lock API. This API removes an activity lock and indicates the activity should no longer be restricted and another user can now being activity on that data. It will remove the lock if it exists and perform no action at all if the lock does not exist. In either case, it returns 204 code.
Method
POST
URL
/activitylocks/{activityLockId}/delete
Request Parameters
Table 4-9 Delete Activity Lock — Request Parameters
Parameter Required Data Type Description
activityLockId
yes
integer($int15)
(path)
Responses
This section describes the responses of the Delete Activity Lock API.
Response Code: 204
No Content
Response Code: 400
Bad request
REST Service: Address
This service integrates address foundation data. Asychronous address integration is processed through staged messages and is controlled by the MPS Work Type: DcsStore.
Server Base URL
Read Address
The Read Address API retrieves information about a single address.
Method
GET
URL
/addresses/{addressId}
Request
Table 4-10 Read Address — Request Parameter
addressId
Yes
The address identifier.
Responses
This section describes the responses of the Read Address API.
Response Code: 200
Example Value
  "addressId": 1111111,
  "entityType": 1,
  "entityId": 5555,
  "addressType": 1,
  "primary": true,
  "addressLine1": "This is line 1.",
  "addressLine2": "This is line 2.",
  "addressLine3": "This is line 3.",
  "city": "City name",
  "state": "ST",
  "countryCode": "USA",
  "postalCode": "10000",
  "county": "County",
  "companyName": "Company name",
  "contactName": "Contact Name",
  "contactPhone": "123-456-7890",
  "contactFax": "123-456-7890",
  "contactEmail": "email@service.com",
  "firstName": "John",
  "lastName": "Smith",
  "phoneticFirstName": "jon",
  "phoneticLastName": "smith",
  "supplierLocation": "Location"
Schema — AddressIdo
Table 4-11 AddressIdo —Object
addressId NA number($int25) example: 1111111 The identifier of the address in an external system.
entityType NA integer($int4) example: 1
Denotes the type of location of the entity. Valid values are:
1 - Bill Of Lading
Enum: [ 1, 2, 3 ]
entityId NA integer($int10) example: 5555 The external identifier of the entity the address belongs to.
addressType NA integer($int4) example: 1
The type of address. Value values are:
1 - Business
2 - Postal
3 - Return
4 - Order
5 - Invoice
6 - Remittance
7 - Billing
8 - Delivery
9 - External
Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9 ]
primary NA boolean example: true True if this is the primary address of the entity.
addressLine1 NA string($text240) example: This is line 1. The first line of the address.
addressLine2 NA string($text240) example: This is line 2. The second line of the address.
addressLine3 NA string($text240) example: This is line 3. The third line of the address.
city NA string($text120) example: City name The city of the address.
state NA string($text3) example: ST The state abbreviation of the address.
countryCode NA string($text3) example: USA The country code of the address (used by supplier).)
postalCode NA string($text30) example: 10000 The postal code of the address.
county NA string($text250) example: County The county name of the address.
companyName NA string($text120) example: Company name A company name associated to the address.
contactName NA string($text120) example: Contact Name A contact name for the address.
contactPhone NA string($text20) example: 123-456-7890 A contact phone number for the address.
contactFax NA string($text20) example: 123-456-7890 A contact fax number for the address.
contactEmail NA string($text100) example: email@service.com A contact email for the address.
firstName NA string($text120) example: John The first name of the contact for the address.
lastName NA string($text120) example: Smith The last name of the contact for the address.
phoneticFirstName NA string($text120) example: jon A phonetic spelling of the first name of a contact for the address.
phoneticLastName NA string($text120) example: smith A phonetic spelling of the last name of a contact for the address.
supplierLocation NA string($text120) example: Location Supplier location information
Response Code: 400
Bad request
Import Address
Imports a series of addresses. This allows up to 1,000 addresses. A forbidden response will occurs if the application is integrated with MFCS or RMS..
Method
POST
URL
/addresses/{addressId}/delete
Request Parameters
Threr are no request parameters.
The request body is application/json.
A list of addresses to import.
Example Value
  "addresses": [
      "entityType": 1,
      "entityId": 5555,
      "addressType": 1,
      "primary": true,
      "state": "ST",
      "county": "County",
Schema - AddressImportListIdo
Table 4-12 AddressImportListIdo —Object
addresses NA object Addresses
Table 4-13 AddressImportIdo —Object
1 - Bill of Lading
Enum: [ 1, 2, 3 ]
1 - Business
2 - Postal
3 - Return
4 - Order
5 - Invoice
6 - Remittance
7 - Billing
8 - Delivery
9 - External
Responses
This section describes the responses of the Import Address API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Delete Address
Deletes an address. A forbidden response will occur if the application is integrated with Oracle merchandising.
Method
POST
URL
Request
Table 4-14 Delete Address — Request Parameter
addressId
Yes
address ID
Responses
This section describes the responses of the Delete Address API.
Response Code: 204
No Content
Response Code: 400
Forbidden
REST Service: Allocation
Allocation documents defined the intent to ship goods from a warehouse to a store. Allocations may be managed by Oracle Merchandising, and if so, then some operations within this service will be blocked.
Service Base URL
The Cloud service base URL follows the format:
Find Allocation
This section describes the Find Allocation API. This API finds up to 5,000 purchase orders headers for the input criteria. No item information is returned.
Method
GET
URL
/allocations
Request Parameters
Table 4-15 Find Allocation — Request Parameters
allocationId
 NA
integer($int12) (query)
Include only allocations with this allocation identifier.
itemId
 NA
string($text25) (query)
Include only allocations for this item.
storeId
NA
integer($int10) (query)
Include only allocations for this store.
warehouseId
 NA
Include only allocations for this warehouse.
deliveryDateFrom
 NA
Include only allocations where the delivery date is on or after this date.
deliveryDateTo
 NA
Include only allocations where the delivery date is on or before this date.
status
NA
Include only allocations in this status. Valid values are:
1 - Approved
2 - Completed
3 - Canceled
Responses
This section describes the responses of the Find Allocation API.
Response Code: 200
Example Value
    "allocationId": 11111,
    "itemId": "100637121",
    "storeId": 5000,
    "warehouseId": 7000,
    "scheduleDate": "2025-01-02T12:38:48.481Z",
    "status": 1,
    "contextId": 14562,
    "contextValue": "Season End",
    "distributionParentId": "19384731",
    "deliverySlotId": 134143,
    "quantityExpected": 20,
    "quantityReceived": 10,
    "quantityDamaged": 10
Schema — AllocationIdo
Table 4-16 AllocationIdo— Object
allocationId
NA
number($int12) example: 11111
The unique identifier of the allocation.
itemId
 NA
string($text25) example: 100637121
The identifier of the item.
storeId
 NA
number($int10) example: 5000
The identifier of the store receiving the goods.
warehouseId
 NA
number($int10) example: 7000
The identifier of the warehouse shipping the goods.
scheduleDate
 NA
string($date-time)
The date the allocation is expected to be delivered.
status
 NA
The current status of the allocation. Valid values are:
1 - Approved
2 - Completed
3 - Canceled
Enum: [ 1, 2, 3 ]
contextId
 NA
number($int18) example: 14562
The identifier of a context associated to the allocation.
contextValue
NA
string($text25) example: Season End
A value associated to the context.
 NA
string($text25) example: 19384731
A unique identifier of a parent allocation document.
deliverySlotId
NA
number($int15) example: 134143
The identifier of the delivery slot of the expected delivery time.
quantityExpected
 NA
number($decimal(20,4)) example: 20
The quantity expected to be delivered.
quantityReceived
 NA
number($decimal(20,4)) example: 10
The quantity of the allocation that has been received.
quantityDamaged
NA
The quantity of the allocation that has been received as damaged.
Response Code: 400
Bad request
Import Allocation
This API imports an allocation order approved in an external system through an asynchronous process. These allocations will be staged as a message for later processing in the MPS queue (DcsAllocation).
Method
POST
URL
/allocations/import
Request Parameters
The allocation details of the allocation to import.
Example Value
  "distributionParentId": 19384731,
  "contextId": 14562,
  "details": [
      "storeId": 5000,
      "deliveryDate": "2025-01-02T13:18:14.085Z",
      "quantity": 20
Schema — AllocationImportIdo
Table 4-17 AllocationImportIdo — Object
allocationId
Yes
itemId
Yes
warehouseId
Yes
The unique identifier of the warehouse shipping the goods.
NA
number($int15) example: 19384731
contextId
NA
contextValue
NA
details
Yes
object
A set of stores and quantities for delivery.
Table 4-18 AllocationImportDetailIdo — Object
storeId
Yes
deliveryDate
NA
string($date-time)
quantity
Yes
The quantity to be delivered.
Responses
This section describes the responses of the Import Allocation API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Complete Allocation
This section describes the Complete Allocation API. This API completes an allocation. This operation will return a forbidden response if the application is integrated with Oracle Merchandising.
Method
POST
URL
/allocations/{allocationId}/complete
Request Parameters
Table 4-19 Complete Allocation — Request Parameters
allocationId
yes
integer($int12)
(path)
The allocation identifier.
Responses
This section describes the responses of the Complete Allocation API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Cancel Allocation
This section describes the Cancel Allocation API. This API cancels an allocation. This operation will return a forbidden response if the application is integrated with Oracle Merchandising.
Method
POST
URL
/allocations/{allocationId}/cancel
Request Parameters
Table 4-20 Cancel Allocation — Request Parameters
allocationId
yes
integer($int12)
(path)
Responses
This section describes the responses of the Cancel Allocation API.
Response Code: 202
Accepted
Response Code: 400
Bad request
REST Service: Batch
This service allows an external system to schedule an adhoc batch job for execution.
Service Base URL
Find Batch
This section describes the Find Batch API. The Find Batch API finds all the batch jobs available to schedule.
Method
GET
URL
/batches
Request
There are no parameters.
Responses
This section describes the responses of the Find Batch API.
Response Code: 200
Example Value
    "jobName": "ShelfReplenishmentClosure_OpsJob",
    "shortDescription": "opsJob.shelfReplenishmentClosure",
    "longDescription": "opsJob.shelfReplenishmentClosure.desc",
    "jobParamHint": "Transaction identifier",
    "jobInterval": 9,
    "batchType": 2,
    "storeRelated": true,
    "enabled": true,
    "lastExecutionTime": "2025-03-04T14:46:45.738Z",
    "updateDate": "2025-03-04T14:46:45.738Z"
Schema — BatchJobIdo
Table 4-21 BatchJobIdo —Object
jobName NA string($text256) example: ShelfReplenishmentClosure_OpsJob The job name used to execute the batch.
shortDescription NA string($text256) example: opsJob.shelfReplenishmentClosure A short description of the batch job.
longDescription NA string($text2000) example: opsJob.shelfReplenishmentClosure.desc A long description of the batch job.
jobParamHint NA string($text1000) example: Transaction identifier Some hint text for what parameter values might be.
jobInterval NA integer($int2) example: 9
The execution interval of the batch job. Valid values are:
1 - 30 Minutes
2 - 1 Hour
3 - 2 Hours
4 - 3 Hours
5 - 4 Hours
6 - 6 Hours
7 - 8 Hours
8 - 12 Hours
9 - 24 Hours
10 - Monthly
Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 ]
batchType NA integer($int4) example: 2
1 - Cleanup
2 - Operation
3 - System
4 - System Cleanup
5 - Data Seed
6 - Archive
Enum: [ 1, 2, 3, 4, 5, 6 ]
storeRelated NA boolean example: true True indicates the batch job requires store level processing.
enabled NA boolean example: true True indicates the batch job is currently enabled and scheduled. This will not prevent batch execution via this service.
lastExecutionTime NA string($date-time) The timestamp of the last execution of the batch job.
updateDate NA string($date-time) The last time this record was updated.
Successful
The media type appliction/json.
Execute Batch Job
Schedules the specific batch job for immediate execution. If parameter date and/or parameter identifier are entered, they are passed as parameters to the batch job identified by the batch name.
Method
POST
URL
/batches
Request
The batch job requested.
Example Value
  "batchName": "11111",
  "storeId": 1234,
  "parameterDate": "2025-03-27T09:32:56.299Z",
  "parameterId": "123"
Schema - BatchRequestIdo
Table 4-22 BatchRequestIdo - Object
batchName NA string($text120) example: 11111 The name of the batch job to execute.
storeId NA number($int10) example: 1234 A store identifier of a store to run the batch for. If included, it will run for this specific store. If not included, it will function for all stores (based on the individual batch functionality description).
parameterDate NA string($date-time) A parameter date passed to the batch job (see adhoc batch documentation).
parameterId NA string($text120) example: 123 A parameter identifier passed to the batch job (see adhoc batch documentation);
Responses
This section describes the responses of the Execute Batch Job API.
Response Code: 202
Accepted
Response Code: 400
Bad request
REST Service: Differentiator
This service integrates differentiator foundation data. Asychronous differentiator integration is processed through staged messages and is controlled by the MPS Work Type: DcsDiff.
Service Base URL
Import Differentiator Type
Imports up to 1,000 differentiator types by writing a staged message and processing asynchronously through the MPS system. A forbidden response will occur if the application is integrated with MFCS or RMS.
Method
POST
URL
/differentiators/types/import
Request
A list of differentiator types to import.
Example Value
  "differentiatorTypes": [
      "differentiatorTypeId": "S",
      "description": "Size"
Schema - DifferentiatorTypeImportListIdo
Table 4-23 DifferentiatorTypeImportListIdo —Object
differentiatorTypes NA object Differentiator Types
Table 4-24 DifferentiatorTypeImportIdo —Object
differentiatorTypeId NA string($text10) example: S The differentiator type identifier.
description NA string($text255) example: Size The differentiator type description.
Responses
This section describes the responses of the Delete Differentiator Type API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Deletes a differentiator type. The processing occurs asynchronously through a MPS staged message.
Method
POST
URL
/differentiators/types/{differentiatorTypeId}/delete
Request
Table 4-25 Delete Differentiator Type — Request Parameters
differentiatorTypeId Yes string($text10)(path)
Differentiator Type ID
Responses
This section describes the responses of the Import Differentiator Type API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Imports up to 1,000 differentiators by writing a s staged message and processing asynchronously through the MPS system. A forbidden response will occur if the application is integrated with MFCS or RMS.
Method
POST
URL
/differentiators/import
Request
The request body is applicattion/json.
A list of differentiators to import.
Example Value
      "differentiatorId": "Color 00",
      "differentiatorTypeId": "C",
      "description": "Assorted Color Pack"
Schema - DifferentiatorImportListIdo
Table 4-26 DifferentiatorImportListIdo - Object
differentiatorTypes NA object Differentiator types
Table 4-27 DifferentiatorImportIdo - Object
differentiatorId NA string($text10) example: Color 00 The differentiator identifier.
differentiatorTypeId NA string($text10) example: C The differentiator type identifier.
description NA string($text255) example: Assorted Color Pack The differentiator description.
Responses
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
Deletes a differentiator. The processing occurs asynchronously through a MPS staged message.
Method
POST
URL
/differentiators/{differentiatorId}/delete
Request
Table 4-28 Delete Differentiator — Request Parameters
differentiatorId Yes string($text10)(path)
Differentiator ID
Responses
This section describes the responses of the Delete Differentiator API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
REST Service: Finisher
This service integrates finisher and finisher item foundation data. Asychronous finisher integration is processed through staged messages and is controlled by the MPS Work Type: DcsPartner. Asynchronous finisher item integration is processed through staged messages and is controlled by the MPS Work Type: DcsItemLocation.
Service Base URL
Import Finisher
Imports a series of up to 500 finishers. A forbidden response will occurs if the application is integrated with MFCS or RMS.
Method
POST
URL
/finishers/import
Request
A list of finishers to import.
Example Value
  "finishers": [
      "finisherId": 1111111,
      "name": "Egravers, Inc.",
      "status": 1,
      "currencyCode": "USD",
      "languageCode": "en",
      "contactName": "John Smith",
      "contactFax": "123-456-7891",
      "contactTelex": "123-456-7892",
      "contactEmail": "address@service.com",
      "manufacturerId": "4321",
      "taxId": "67890",
      "transferEntityId": "88888",
      "paymentTerms": "30 Days",
      "importCountryCode": "USD",
      "importPrimary": false
Schema - FinisherImportListIdo
Table 4-29 FinisherImportListIdo - Object
finishers NA object finishers
Table 4-30 FinisherImportIdo - Object
finisherId Yes number($int10) example: 1111111 The identifier of the finisher.
name NA string($text240) example: Egravers, Inc. The name of the finisher.
status NA integer($int4) example: 1
The current status of the finisher. Valid values are:
1 - Active
2 - Inactive
Enum: [ 1, 2 ]
currencyCode NA string($text3) example: USD ISO currency code assigned to the finisher.
countryCode NA string($text3) example: USA ISO country code assigned to the finisher.
languageCode NA string($text6) example: en ISO language code assigned to the finisher.
contactName NA string($text120) example: John Smith Name of the finisher's representative contact.
contactPhone NA string($text20) example: 123-456-7890 Phone number of the finisher's representative contact.
contactFax NA string($text20) example: 123-456-7891 Fax number of the finisher's representative contact.
contactTelex NA string($text20) example: 123-456-7892 Telex number of the finisher's representative contact.
contactEmail NA string($text100) example:address@service.com Email address of the finisher's representative contact.
manufacturerId NA string($text18) example: 4321 Manufacturer's identification number.
taxId NA string($text18) example: 67890 Tax identifier number of the finisher.
transferEntityId NA string($text20) example: 88888 Identifier of the transfer entity that the finisher belongs to.
paymentTerms NA string($text20) example: 30 Days Payment terms for the partner.
importCountryCode NA string($text3) example: USD The ISO country code of the import authority.
importPrimary NA boolean example: false True indicates the code is the primary import authority of the import country.
Responses
This section describes the responses of the Import Finisher API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
Delete Finisher
Deletes a finisher. A forbidden response will occur if the application is integrated with Oracle merchandising.
Method
POST
URL
/finishers/{finisherId}/delete
Request
Table 4-31 Delete Finisher — Request Parameter
finisherId
Yes
The finisher identifier.
Responses
This section describes the responses of the Delete Finisher API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
Import Finisher Item
Imports up to 5,000 finisher items. A forbidden response will occurs if the application is integrated with MFCS or RMS.
Method
POST
URL
/finishers/{finisherId}/items/import
Request
Table 4-32 Import Finisher Item — Request Parameter
finisherId
Yes
A list of finisher items to import.
Example Value
  "items": [
      "itemId": "1111111",
      "status": 1
Schema - FinisherItemImportListIdo
Table 4-33 FinisherItemImportListIdo - Object
items NA object items
Table 4-34 FinisherItemImportIdo - Object
itemId Yes string($int25) example: 1111111 The identifier of the item.
status Yes integer($int4) example: 1
The status of the item. Valid values are:
1 - Active
2 - Discontinued
3 - Inactive
Enum: [ 1, 2, 3 ]
Responses
This section describes the responses of the Import Finisher Item API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
Delete Finisher Item
Marks up to 5,000 finisher items for later deletion. A forbidden response will occurs if the application is integrated with MFCS or RMS.
Method
POST
URL
/finishers/{finisherId}/items/remove
Request
Table 4-35 Delete Finisher Item — Request Parameter
finisherId
Yes
A list of finisher items to remove.
Example Value
  "itemIds": [
    11111,
    22222
Schema - FinisherItemRemoveListIdo
Table 4-36 FinisherItemRemoveListIdo - Object
itemIds NA string($text25) example: List [ 11111, 22222 ] items IDs
Responses
This section describes the responses of the Delete Finisher Item API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
REST Service: Customer Fulfillment Order
This service defines operations to manage customer fulfillment order information by integration with an external system. A fulfillment order the portion of a customer order to be fulfilled at a particular store. There can be many fulfillment orders for the same customer order.
Service Base URL
Find Fulfillment Order
This section describes the Find Fulfillment Order API. This API finds up to a maximum of 3,0000 fulfillment order headers based on input search criteria.
Method
GET
URL
/fulfillmentorders
Request Parameters
Table 4-37 Find Fulfillment Order — Request Parameters
fulfillmentOrderNumber
NA
Include only fulfillment orders with this external fulfillment order number.
customerOrderNumber
NA
Include only fulfillment orders with this external customer order number.
storeId
NA
Include only fulfillment orders for this store.
orderType
NA
Include only fulfillment orders with this order type. Valid values are:
1 - Layaway
2 - Pickup and Delivery
3 - Customer Order
4 - Pending Purchase
5 - Special Order
6 - Web Order
7 - On Hold
status
NA
Include only fulfillment orders with this status. Value values are:
1 - New
2 - In Progress
3 - Completed
4 - Canceled
5 - Reverse Pick
6 - Pick In Progress
7 - Delivery In Progress
8 - Ready To Ship
9 - Ready For Pickup
10 - Picking Required
11 - Under Review
releaseDateFrom
NA
Include only fulfillment orders with an release date on or after this date.
releaseDateTo
NA
Include only fulfillment orders with an release date on or before this date.
updateDateFrom
NA
Include only fulfillment orders with an update date on or after this date.
updateDateTo
NA
Include only fulfillment orders with an update date on or before this date.
itemId
NA
Include only fulfillment orders containing this item.
Responses
This section describes the responses of the Find Fulfillment Order API.
Response Code: 200
Example Value
    "orderId": 11111,
    "customerOrderId": "222345666",
    "fulfillmentOrderId": "76544400",
    "storeId": 1234,
    "orderType": 1,
    "deliveryType": 1,
    "status": 1,
    "holdLocation": "Pickup Desk"
Schema — FulfillmentOrderHeaderIdo
Table 4-38 FulfillmentOrderHeaderIdo— Object
orderId
NA
The unique identifier of the fulfillment order.
customerOrderId
NA
string($text128) example: 222345666
The customer order number (from the external ordering system).
fulfillmentOrderId
NA
string($text128) example: 76544400
The fulfillment order number (from the external ordering system).
storeId
NA
The identifier of the store at which this order will be fulfilled.
orderType
NA
The current status of the inventory adjustment. Valid values are:
1 - Layaway
3 - Customer Order
5 - Special Order
6 - Web Order
7 - On Hold
Enum: [ 1, 2, 3, 4, 5, 6, 7 ]
deliveryType
NA
The delivery type of the customer order. Valid values are:
1 - Customer Pickup
2 - Ship To Store
Enum: [ 1, 2 ]
status
NA
The current status of the customer order. Value values are:
1 - New
2 - In Progress
3 - Completed
4 - Canceled
5 - Reverse Pick
8 - Ready To Ship
11 - Under Review
Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11 ]
holdLocation
NA
string($text128) example: Pickup Desk
Descripton of where the order is being held for pickup or delivery.
Response Code: 400
Bad request
Read Fulfillment Order
This section describes the Read Fulfillment Order API. This API retrieves all the details about a fulfillment order.
Method
GET
URL
/fulfillmentorders/{orderId}
Request Parameters
Table 4-39 Read Fulfillment Order — Request Parameters
orderId
Yes
number($int12) (path)
The unique SIOCS internal identifier of the fulfillment order.
Responses
This section describes the responses of the Read Fulfillment Order API.
Response Code: 200
Example Value
    "orderId": 11111,
    "storeId": 1234,
    "customerId": "JXA244443",
    "orderType": 1,
    "deliveryType": 1,
    "status": 1,
    "orderDate": "2025-01-15T12:53:31.299Z",
    "releaseDate": "2025-01-15T12:53:31.299Z",
    "deliveryDate": "2025-01-15T12:53:31.299Z",
    "carrierId": 4500674,
    "carrierServiceId": 4500222,
    "allowPartialDelivery": true,
    "deliveryCharge": 12.5,
    "deliveryChargeCurrency": "USD",
    "holdLocation": "Pickup Desk",
    "orderComments": "Customer will arrive by 2pm.",
    "underReview": false,
    "fullFlow": true,
    "deliveryComments1": "First line.",
    "deliveryComments2": "Second line.",
    "deliveryComments3": "Third line.",
    "customerArrivalDate": "2025-01-15T12:53:31.299Z",
    "createDate": "2025-01-15T12:53:31.299Z",
    "updateDate": "2025-01-15T12:53:31.299Z",
    "lineItems": [
        "lineId": 333444,
        "itemId": "55001234",
        "substituteLineId": 5600043,
        "lineNumber": 2,
        "preferredUom": "KG",
        "comments": "Item packaging slightly damaged.",
        "quantityOrdered": 10,
        "quantityPicked": 6,
        "quantityDelivered": 2,
        "quantityCanceled": 2,
        "quantityReserved": 8,
        "allowSubstitution": true,
        "price": 4500674,
        "priceCurrency": "USD",
Schema — FulfillmentOrderIdo
Table 4-40 FulfillmentOrderIdo— Object
orderId
NA
customerOrderId
NA
fulfillmentOrderId
NA
storeId
NA
customerId
NA
string($text14) example: JXA244443
The identifier of the customer for this fulfillment order.
orderType
NA
The order type of the customer order. Valid values are:
1 - Layaway
3 - Customer Order
5 - Special Order
6 - Web Order
7 - On Hold
deliveryType
NA
1 - Customer Pickup
2 - Ship To Store
Enum: [ 1, 2 ]
status
NA
1 - New
2 - In Progress
3 - Completed
4 - Canceled
5 - Reverse Pick
8 - Ready To Ship
11 - Under Review
orderDate
NA
string($date-time)
The date the customer placed the order.
releaseDate
NA
string($date-time)
The date in which the order must be shipped by the store or picked up in the store.
deliveryDate
NA
string($date-time)
The date in which the order is to be delivered.
carrierId
NA
integer($int10) example: 4500674
The identifier of the carrier who will deliver the order.
carrierServiceId
NA
integer($int10) example: 4500222
The identifier of the carrier service used for the delivery.
NA
True indicates delivery can occur without all items being available and ready. False indicates all items must be shipped in the delivery.
deliveryCharge
NA
number($decimal(12,4)) example: 12.5
The cost of shipment of this order.
NA
The current of the delivery charge value.
holdLocation
NA
orderComments
NA
string($text2000) example: Customer will arrive by 2pm.
Comments entered in the external system for the order.
underReview
NA
True indicates that the fulfilling system needs to delay either shipping or fulfilling the order until this flag is cleared.
fullFlow
NA
True indicates this customer order can only be fulfilled using SOCS. If false, it must be fulfilled using JET mobile.
deliveryComments1
NA
string($text128) example: First line.
The first line of delivery comments.
deliveryComments2
NA
string($text128) example: Second line.
The second line of delivery comments.
deliveryComments3
NA
string($text128) example: Third line.
The third line of delivery comments.
customerArrivalDate
NA
string($date-time)
The date that the customer arrived for pickup.
createDate
NA
string($date-time)
The date the fulfillment order was created in SIOCS.
updateDate
NA
string($date-time)
The date the fulfillment order was last updated in SIOCS.
lineItems
NA
object
A collection of line items on the fulfillment order
Table 4-41 FulfillmentOrderLineItemIdo— Object
lineId
NA
number($int12) example: 333444
The unique identifier of the line item.
itemId
NA
string($text25) example: 55001234
The SKU level item identifier.
substituteLineId
NA
number($int12) example: 5600043
The identifier of a line item that this item has been substituted for.
lineNumber
NA
number($int10) example: 2
The line number of the fulfillment order this item is fulfilling.
preferredUom
NA
string($text4) example: KG
The preferred unit of measure the item quantities should be processed or displayed in.
comments
NA
string($text2000) example: Item packaging slightly damaged.
Comments from an external system associated to this item.
quantityOrdered
NA
number($decimal(12,4)) example: 10
The quantity ordered on this line item.
quantityPicked
NA
number($decimal(12,4)) example: 6
The quantity picked for this line item.
quantityDelivered
NA
number($decimal(12,4)) example: 2
The quantity delivered to date on this line item.
quantityCanceled
NA
The quantity canceled on this line item.
quantityReserved
NA
number($decimal(12,4)) example: 8
The quantity reserved for this line item.
allowSubstitution
NA
True indicates a substitution is allowed for this item, false indicates it is not.
price
NA
number($decimal(20,4)) example: 4500674
The amount of the price of the item.
priceCurrency
NA
The currency of the price of the item.
createDate
NA
string($date-time)
The date the order item was created in SIOCS.
updateDate
NA
string($date-time)
The date the order item was last updated in SIOCS.
Response Code: 400
Bad request
Import Fulfillment Order
This section describes the Import Fulfillment Order API. This service operation takes a request to import a collection of new fulfillment orders. All orders passed in must be new orders. The sent will be processed asynchronously. A notification of accepted or rejected status will be published out after the processing is finished to a fulfillment order status service. Duplicate fulfillment orders in a single access will immediately return a bad request error. Duplicate fulfillment orders seperated into different requests will cause the second or later orders to be rejected at a later time with a duplicate order error.
Method
POST
URL
/fulfillmentorders/import
Request Parameters
Table 4-42 Update Delivery — Request Parameters
deliveryId Yes number($int12)(path) The unique identifier of the fulfillment order delivery.
Details about the fulfillment orders to import.
Example Value
  "fulfillmentOrders": [
      "storeId": 1234,
      "deliveryType": 1,
      "deliveryDate": "2025-01-15T13:25:05.331Z",
      "carrierServiceId": 4500674,
      "deliveryCharge": 4500674,
      "lineItems": [
          "lineNumber": 2,
          "price": 4500674,
Schema — FulfillmentOrderImportListIdo
Table 4-43 FulfillmentOrderImportListIdo — Object
fulfillmentOrders
yes
object
A collection of fulfillment orders to import
FulfillmentOrderImportIdo{Jump to path
Table 4-44 FulfillmentOrderImportIdo — Object
customerOrderId
yes
The customer order number (from the external ordering system). The combination of customer order number and fulfillment order number will determine if the order is treated a new or existing.
fulfillmentOrderId
NA
The fulfillment order number (from the external ordering system). The combination of customer order number and fulfillment order number will determine if the order is treated a new or existing.
storeId
yes
The identifier of the store at which this order will be fulfilled. This value is required but will be ignored if the order already exists.
customerId
yes
The identifier of the customer for this fulfillment order. The value is required but will be ignored if the order already exists.
deliveryType
yes
The delivery type of the fulfillment order. This value is required but will be ignored if the order already exists. Valid values are:
1 - Customer Pickup
2 - Ship To Store
Enum: [ 1, 2 ]
deliveryDate
NA
string($date-time)
The date in which the order is to be delivered. This value will be ignored if the order already exists.
carrierId
NA
The identifier of the carrier who will deliver the order. This value will be ignored if the order already exists.
carrierServiceId
NA
The identifier of the carrier service used for the delivery. This value will be ignored if the order already exists.
NA
True indicates delivery can occur without all items being available and ready. False indicates all items must be shipped in the delivery. This value will be ignored if the order already exists.
deliveryCharge
NA
number($decimal(12,4)) example: 4500674
The cost of shipment of this order. This value will be ignored if the order already exists.
NA
The currency of the delivery charge value. This value will be ignored if the order already exists.
holdLocation
NA
Description of where the order is being held for pickup or delivery.
orderComments
NA
lineItems
yes
object
A collection of line items on the fulfillment order.
Table 4-45 FulfillmentOrderImporLineItemtIdo — Object
itemId
yes
lineNumber
NA
preferredUom
NA
comments
NA
quantityOrdered
yes
The quantity ordered on this line itemm.
allowSubstitution
NA
price
NA
priceCurrency
NA
Responses
This section describes the responses of the Import Fulfillment Order API.
Response Code: 204
No content
Response Code: 400
Bad request
Pickup Fulfillment Order
This section describes the Pickup Fulfillment Order API. This service will update an order to indicate a customer is arriving (or has arrived) to pickup the order.
Method
POST
URL
/fulfillmentorders/pickup
Request Parameters
Details about the fulfillment order for pickup.
Example Value
  "storeId": 1234,
  "customerArrivalDate": "2025-01-15T14:20:01.431Z"
Schema — FulfillmentOrderPickupIdo
Table 4-46 FulfillmentOrderPickupIdo — Object
customerOrderId
Yes
fulfillmentOrderId
NA
storeId
Yes
deliveryComments1
NA
deliveryComments2
NA
deliveryComments3
NA
customerArrivalDate
Yes
string($date-time)
Responses
This section describes the responses of the Pickup Fulfillment Order API.
Response Code: 204
No content
Response Code: 400
Bad request
Reject Fulfillment Order
This section describes the Reject Fulfillment Order API. This will cause the store to reject the fulfillment order specified notifying external systems that the fulfillment order has been rejected.
Method
POST
URL
/fulfillmentorders/reject
Request Parameters
Details about the fulfillment order to reject.
Example Value
  "storeId": 1234
Schema — FulfillmentOrderRejectIdo
Table 4-47 FulfillmentOrderRejectIdo— Object
customerOrderId
Yes
fulfillmentOrderId
NA
storeId
Yes
Responses
This section describes the responses of the Reject Fulfillment Order API.
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Fulfillment Order
This section describes the Cancel Fulfillment Order API. This API will cancel all remaining ordered quantities on the fulfillment order.
Method
POST
URL
/fulfillmentorders/cancel
Request Parameters
Details about the fulfillment order to cancel.
Example Value
  "storeId": 1234
Schema — FulfillmentOrderCancelIdo
Table 4-48 FulfillmentOrderCancelIdo— Object
customerOrderId
Yes
fulfillmentOrderId
NA
storeId
Yes
Responses
Response Code: 200
Example Value
    "storeId": 1234,
    "lineItems": [
        "lineNumber": 2,
        "standardUom": "KG",
Schema — FulfillmentOrderCancelStatusIdo
Table 4-49 FulfillmentOrderCancelStatusIdo— Object
customerOrderId
NA
fulfillmentOrderId
NA
storeId
NA
lineItems
NA
object
A collection of line items with the quantities that were cancelled.
Table 4-50 FulfillmentOrderCancelStatusItemIdo— Object
itemId
NA
lineNumber
NA
preferredUom
NA
standardUom
NA
The standard unit of measure for the item.
quantityCanceled
NA
The quantity canceled on this line itemm.
Response Code: 400
Bad request
Cancel Fulfillment Order Quantities
This section describes the Cancel Fulfillment Order Quantities API. This API will cancel quantities on specific line items of a fulfillment order.
Method
POST
URL
/fulfillmentorders/cancelitems
Request Parameters
Details about the fulfillment order items to cancel.
Example Value
  "storeId": 1234,
  "lineItems": [
      "lineNumber": 2,
Schema — FulfillmentOrderItemCancelIdo
Table 4-51 FulfillmentOrderItemCancelIdo— Object
customerOrderId
Yes
fulfillmentOrderId
NA
storeId
Yes
lineItems
NA
object
Table 4-52 FulfillmentOrderItemCancelLineIdo— Object
itemId
Yes
lineNumber
NA
preferredUom
NA
standardUom
NA
quantityCanceled
Yes
Responses
This section describes the responses of the Cancel Fulfillment Order Quantities API.
Response Code: 200
Example Value
    "storeId": 1234,
    "lineItems": [
        "lineNumber": 2,
Table 4-53 FulfillmentOrderCancelStatusIdo— Object
customerOrderId
NA
fulfillmentOrderId
NA
storeId
NA
lineItems
NA
object
Table 4-54 FulfillmentOrderCancelStatusItemIdo— Object
itemId
NA
lineNumber
NA
preferredUom
NA
standardUom
NA
quantityCanceled
NA
Response Code: 400
Bad request
REST Service: Fulfillment Order Delivery
Delivering of a customer order consists of collecting the items that have been picked and then getting them to the customer (shipment or pickup). This might be for a customer pickup or shipping them to the customer.This service integrations a fulfillment order delivery with an external application.
Service Base URL
Find Delivery
Finds up to a maximum of 500 fulfillment order delivery headers based on input search criteria.
Method
GET
URL
/fulfillorderdeliveries
Request Parameters
Table 4-55 Find Delivery - Request Parameters
storeId NA integer($int10) (query) Include only customer deliveries from this store.
orderId NA number($int12) (query) Include only customer deliveries for this SIOCS fulfillment order id.
externalDeliveryId NA string($text25) (query) Included only customer deliveries with this external identifier.
status NA integer($int4) (query)
Include only customer deliveries this status. Valid values are
1 - In Progress
2 - Submitted
3 - Completed
4 - Canceled
Available values: 1, 2, 3, 4
updateDateFrom NA string($date-time) (query) Include only customer deliveries with an update date on or after this date.
updateDateTo NA string($date-time) (query) Include only customer deliveries with an update date on or before this date.
Responses
This section describes the responses of the Find Delivery API.
Response Code: 200
Example Value
    "deliveryId": 11111,
    "orderId": 11111,
    "storeId": 1234,
    "status": 1,
    "submitDate": "2025-04-11T10:06:38.846Z",
    "submitUser": "smith123",
    "dispatchDate": "2025-04-11T10:06:38.846Z",
    "dispatchUser": "smith123",
    "createDate": "2025-04-11T10:06:38.846Z",
    "createUser": "smith123",
    "updateDate": "2025-04-11T10:06:38.846Z",
    "updateUser": "smith123"
Schema — FulfillmentOrderDeliveryHeaderIdo
Table 4-56 FulfillmentOrderDeliveryHeaderIdo— Object
deliveryId NA number (int12) example 11111 The unique identifier of the fulfillment order delivery.
orderId NA number (int12) example 11111 The unique SIOCS identifier of the fulfillment order.
storeId NA number (int10) example 1234 The identifier of the store at which this order will be fulfilled.
status NA integer (int4) example 1
The current status of the customer delivery. Valid values are:
1 - In Progress
2 – Submitted
3 – Completed
4 - Canceled
Enum: 1,2,3, 4
submitDate NA string (date-time) The date the delivery was submitted.
submitUser NA string (text128) example: smith123 The user that submitted the delivery.
dispatchDate NA string (date-time) The date the delivery was dispatched.
dispatchUser NA string (text128) example: smith123 The user that dispatched the delivery.
createDate NA string (date-time) The date the delivery was created
createUser NA string (text128) example: smith123 The user that created the delivery
updateDate NA string (date-time) The date the delivery was updated.
updateUser NA string (text128) example: smith123 The user that last updated the delivery.
Response Code: 400
Bad request
Create Delivery
Creatures a fulfillment order delivery from an order (and responds with the newly created delivery).
Method
POST
URL
Request Parameters
The fulfillment order delivery to create.
Example Value
  "orderId": 11111,
  "carrierRole": 1,
  "carrierId": 112233,
  "carrierServiceId": 445566,
  "alternateAddress": "PO Box 28, Apple Street, Nowhereville",
  "alternateCarrierName": "Speedy Delivery",
  "alternateCarrierAddress": "200 Box Street, Nowhereville",
  "motiveId": 874297,
  "trackingNumber": "ANV343255",
  "cartonSizeId": 9375834,
  "cartonWeight": 12.1,
  "cartonWeightUom": "KG",
  "requestedPickupDate": "2025-04-11T10:16:03.960Z",
  "lineItems": [
      "orderLineId": 11111,
      "quantity": 11111,
      "uins": [
        11111,
        22222
Schema —FulfillmentOrderDeliveryCreateIdo
Table 4-57 FulfillmentOrderDeliveryCreateIdo — Object
orderId Yes number (int12) example: 11111 The unique SIOCS identifier of the fulfillment
carrierRole NA number (int2) example: 1
The type of carrier. Valid values are:
1 – Sender
2 – Received
3 - Third Party
Enum: 1, 2, 3
carrierId NA number (int10) example:112233 The unique identifier of the carrier.
carrierServiceId NA number (int10) example:445566 The unique identifier of the carrier service being used.
alternateAddress NA string (text2000) example: PO Box 28, Apple Street, Nowhereville
An alternate destination address for the delivery.
alternateCarrierName NA string (text240) example: Speedy Delivery
Name of the carrier responsible for the delivery.
alternateCarrierAddress NA string (text2000) example: 200 Box Street, Nowhereville Address of the carrier responsible for the delivery.
motiveId NA number (int18) example:874297 The unique identifier of the motive.
trackingNumber NA string (text128) example: ANV343255 A tracking number for the shipment
cartonSizeId NA number (int12) example: 9375834 The unique identifier of a carton size (dimension) for that store.
cartonWeight NA number (decimal(12,4)) example: 12.1 The weight of the shipment.
cartonWeightUom NA string (text4) example KG The unit of measure of the shipment weight.
requestedPickupDate NA string (date-time) The date that this delivery will be picked up
lineItems Yes object A collection of up to 500 line items on the fulfillment order delivery.
Table 4-58 FulfillmentOrderDeliveryCreateItemIdo - Object
orderLineId Yes number($int12) example: 11111 The unique identifier of the fulfillment order line item being delivered.
quantity Yes number($decimal(20,4)) example: 11111 The quantity being delivered.
uins NA string ($text128) example: List [ 11111, 22222 ] A list of uins (must match the quantity) if serial numbers are being delivered.
Responses
This section describes the responses of the Create Delivery API.
Response Code: 200
Example Value
    "orderId": 11111,
    "storeId": 1234,
    "status": 1,
    "billOfLadingId": 573804,
    "additionalReference": "XDER78393",
    "submitDate": "2025-04-11T15:39:51.433Z",
    "dispatchDate": "2025-04-11T15:39:51.433Z",
    "createDate": "2025-04-11T15:39:51.433Z",
    "updateDate": "2025-04-11T15:39:51.433Z",
    "updateUser": "smith123",
    "lineItems": [
        "lineId": 333444,
        "orderLineId": 4563,
        "quantity": 10,
        "caseSize": 6
Schema - FullfillmentOrderDeliveryIdo
Table 4-59 FulfillmentOrderDeliveryIdo - Object
deliveryId NA number($int12) example: 11111 The unique identifier of the fulfillment order delivery.
orderId NA number($int12) example: 11111 The unique SIOCS identifier of the fulfillment order.
storeId NA number($int10) example: 1234 The identifier of the store at which this order will be fulfilled.
1 - In Progress
2 - Submitted
3 - Completed
4 - Canceled
Enum: [ 1, 2, 3, 4 ]
billOfLadingId NA number($int12) example: 573804 The shipment bill of lading identifier.
additionalReference NA string($text128) example: XDER78393 A government reference identifier from an external system.
submitDate NA string($date-time) The date the delivery was submitted.
submitUser NA string($text128) example: smith123 The user that submitted the delivery.
dispatchDate NA string($date-time) The date the delivery was dispatched.
dispatchUser NA string($text128) example: smith123 The user that dispatched the delivery.
createDate NA string($date-time) The date the delivery was created.
createUser NA string($text128) example: smith123 The user that created the delivery.
updateDate NA string($date-time) The date the delivery was updated.
updateUser NA string($text128) example: smith123 The user that last updated the delivery.
lineItems NA object A collection of line items on the fulfillment order delivery.
Table 4-60 FulfillmentOrderDeliveryLineItemIdo — Object
lineId NA number($int12)example: 333444 The unique identifier of the line item.
orderLineId NA number($int12)example: 4563 The unique identifier of the fulfillment order line item this delivery item is for.
quantity NA number($decimal(12,4))example: 10 The quantity to be delivered.
caseSize NA number($decimal(10,2))example: 6 The case size of this line item.
Response Code: 400
Bad request
Read Delivery
This API retrieves all the details about a fulfillment order delivery.
Method
GET
URL
/fulfillorderdeliveries/{deliveryId}
Request Parameters
Table 4-61 Read Delivery — Request Parameters
deliveryId
Yes
Responses
This section describes the responses of the Read Delivery API.
Response Code: 200
For details about the schema, see the Schema - FullfillmentOrderDeliveryIdo section.
Example Value
    "orderId": 11111,
    "storeId": 1234,
    "status": 1,
    "submitDate": "2025-04-14T06:44:40.769Z",
    "dispatchDate": "2025-04-14T06:44:40.769Z",
    "createDate": "2025-04-14T06:44:40.769Z",
    "updateDate": "2025-04-14T06:44:40.769Z",
    "lineItems": [
        "lineId": 333444,
        "quantity": 10,
        "caseSize": 6
Response Code: 400
Bad request
Update Delivery
This section describes the Update Delivery API. This API updates the details of an order delivery that is currently "In Progress". Detailed information left blank using this service will remove this information from the delivery.
Method
POST
URL
Request Parameters
Table 4-62 Update Delivery — Request Parameters
The fulfillment order delivery to update.
Example Value
  "carrierRole": 1,
  "motiveId": 874297,
  "requestedPickupDate": "2025-04-14T08:49:44.110Z",
  "lineItems": [
      "quantity": 2,
      "uins": [
        11111,
        22222
Schema — FulfillmentOrderDeliveryUpdateIdo
Table 4-63 FulfillmentOrderDeliveryUpdateIdo - Object
carrierRole NA number($int2) example: 1
1 - Sender
2 - Received
3 - Third Party
Enum: [ 1, 2, 3 ]
carrierId NA number($int10) example: 112233 The unique identifier of the carrier.
carrierServiceId NA number($int10) example: 445566 The unique identifier of the carrier service being used.
alternateAddress NA string($text2000) example: PO Box 28, Apple Street, Nowhereville An alternate destination address for the delivery.
alternateCarrierName NA string($text240) example: Speedy Delivery Name of the carrier responsible for the delivery.
alternateCarrierAddress NA string($text2000) example: 200 Box Street, Nowhereville Address of the carrier responsible for the delivery.
motiveId NA number($int18) example: 874297 The unique identifier of the motive.
trackingNumber NA string($text128) example: ANV343255 A tracking number for the shipment.
cartonSizeId NA number($int12) example: 9375834 The unique identifier of a carton size (dimension) for that store.
cartonWeight NA number($decimal(12,4)) example: 12.1 The weight of the shipment.
cartonWeightUom NA string($text4) example: KG The unit of measure of the shipment weight.
requestedPickupDate NA string($date-time) The date that this delivery will be picked up.
lineItems NA object A collection of up to 500 line items on the fulfillment order delivery.
Table 4-64 FulfillmentOrderDeliveryUpdateItemIdo - Object
quantity Yes number($decimal(20,4)) example: 2 The quantity being delivered. If the quantity is reduced to 0, this item will be removed from the delivery.
uins NA string($text128) example: List [ 11111, 22222 ] A list of uins (must match the quantity) if serial numbers are being delivered.
Responses
This section describes the responses of the Update Delivery API.
Response Code: 204
No content
Response Code: 400
Bad request
Submit Delivery
This section describes the Submit Delivery API.This API will submit the delivery and set it to Submitted status. Submit is only available when store configured for Dispatch Validate to Ship Submit. Submitting will set the delivery to a Submitted status and not allow for edits, since there are no updates to inventory at this point. The only step possible will be to cancel Submit or Dispatch.
Method
POST
URL
/fulfillorderdeliveries/{deliveryId}/submit
Request Parameters
Table 4-65 Submit Delivery — Request Parameters
Responses
This section describes the responses of the Submit Delivery API.
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Submit Delivery
This section describes the Cancel Submit Delivery API. This API cancels a fulfillment order delivery submission.
Method
POST
URL
/fulfillorderdeliveries/{deliveryId}/cancelSubmit
Request Parameters
Table 4-66 Cancel Submit Delivery — Request Parameters
Responses
This section describes the responses of the Cancel Submit Delivery API.
Response Code: 204
No content
Response Code: 400
Bad request
Dispatch Delivery
This section describes the Dispatch Delivery API. Dispatch will check if Allow Partial Indicator is set to No, it will validate that the entire order is being delivered together. If not, the system will restrict the user from dispatching. Those users with certain privileges will be able to override this and it will be a warning. If Allow Partial Indicator is set to Yes, the customer order can be delivered partially. If system parameter 'Customer Order Fulfillment Restriction' is set to 'Line Controlled' and Allow Partial Indicator is set to Yes, if an item is getting delivered then it has to be delivered fully. Partial delivery of an item is not allowed. Also, if the store parameter Manifest Customer Order Deliveries is set to No and system parameter Tracking ID Required is set to Yes, the system should check if the Tracking ID has been captured or not, if not captured, an error message will be displayed. Upon dispatch of the delivery the delivery will move to Completed status, and user returns to the Delivery List screen. The stock on hand and customer order reserved quantities will be decremented by the delivered quantities. The customer order fulfillment order will have the delivered and remaining quantity updated. If the entire customer order has been fulfilled, meaning there is no remaining quantity, the customer order will be set to Completed status. If the system is enabled to obtain Fiscal Doc ID/E-way bill ID as part of the shipping process, the delivery cannot be dispatched until the Fiscal Doc ID/E-way bill ID is available. The exception is when the user has ‘Allow dispatch without Fiscal Document ID’ security permission.
Method
POST
URL
/fulfillorderdeliveries/{deliveryId}/dispatch
Request Parameters
Table 4-67 Dispatch Delivery — Request Parameters
Responses
This section describes the responses of the Dispatch Delivery API.
Response Code: 204
No content
Response Code: 400
Bad request
REST Service: Fulfillment Order Pick
The Picking process is a formal process of the system telling the user what items need to be picked and the user going out, physically picking the items, and setting them aside. Once the items are set aside, they will then be used during the fulfillment process for shipping to, or pick up by the customer.The service integrates a fulfillment order pick with an external application.
Service Base URL
Find Pick
Finds up to a maximum of 3,0000 fulfillment order picks based on input search criteria.
Method
GET
URL
/fulfillorderpicks
Request Parameters
Table 4-68 Find Pick — Request Parameters
storeId NA integer($int10) (query) Include only order picks for this store.
orderId NA integer($int12) (query) Include only order picks with this fulfillment order identifier.
itemId NA string($text25) (query) Include only order picks orders containing this item.
1 - New
2 - In Progress
3 - Completed
4 - Canceled
99 - Active
Available values : 1, 2, 3, 4, 99
createDateFrom NA string($date-time) (query) Include only order picks with an create date on or after this date.
createDateTo NA string($date-time) (query) Include only order picks with an create date on or before this date.
Responses
This section describes the responses of the Find Pick API.
Response Code: 200
Example Value
    "orderId": 11111,
    "storeId": 1234,
    "status": 1,
Schema — FulfillmentOrderPickHeaderIdo
Table 4-69 FulfillmentOrderPickHeaderIdo - Object
pickId NA number($int12) example: 11111 The unique identifier of the fulfillment order pick.
storeId NA number($int10) example: 1234 The store this pick will occur at.
type NA integer($int4) example: 1
The type of pick. Valid values are:
1 - Order
2 - Bin
Enum: [ 1, 2 ]
The current status of the order pick. Valid values are:
1 - New
2 - In Progress
3 - Completed
4 - Canceled
Enum: [ 1, 2, 3, 4]
productBasketId NA integer($int12) example: 488552 The identifier of the product basket associated to the pick.
createDate NA string($date-time) The date the order pick was created.
createUser NA string($text128) example: smith123 The user that created the order pick.
completeDate NA string($date-time) The date the order pick was completed.
completeUser NA string($text128) example: smith123 The user the completed the order pick.
Response Code: 400
Bad request
Read Pick
This API retrieves all the details about a fulfillment order pick.
Method
GET
URL
/fulfillorderpicks/{pickId}
Request Parameters
Table 4-70 Read Pick - Request Parameters
pickId Yes number($int12) (path) The unique identifier of the fulfillment order pick.
Responses
This section describes the responses of the Read Pick API.
Response Code: 200
Example Value
    "pickId": 11111,
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "productBasketId": 488552,
    "createDate": "2025-04-14T12:15:59.708Z",
    "completeDate": "2025-04-14T12:15:59.708Z",
    "completeUser": "smith123",
    "lineItems": [
        "lineId": 333444,
        "orderId": 100,
        "orderLineId": 200,
        "caseSize": 10,
        "quantitySuggested": 2,
        "ordinal": 6
Schema — FulfillmentOrderPickIdo
Table 4-71 FulfillmentOrderPickIdo - Object
pickId NA number($int12) example: 11111 The unique identifier of the fulfillment order.
storeId NA number($int10) example: 5000 The store this pick will occur at.
1 - Order
2 - Bin
Enum: Array [ 2 ]
1 - New
2 - In Progress
3 - Completed
4 - Canceled
lineItems NA object A collection of line items on the fulfillment order pick.
Table 4-72 FulfillmentOrderLineItemPickIdo - Object
lineId NA number($int12) example: 333444 The unique identifier of the line item.
itemId NA string($text25) example: 55001234 The SKU level item identifier.
orderId NA number($int12) example: 100 The unique SIOCS identifier of the fulfillment order.
orderLineId NA number($int12) example: 200 The unique SIOCS identifier of the fulfillment order line item.
substituteLineId NA number($int12) example: 5600043 The identifier of another pick line item for which this item is a substitute for.
preferredUom NA string($text4) example: KG The preferred unit of measure in which to pick.
caseSize number($decimal(10,2)) example: 10 The case of this item pick.
quantitySuggested number($decimal(12,4)) example: 2 The suggested quantity to pick for this item.
quantityPicked number($decimal(12,4)) example: 6 The quantity picked for this line item.
ordinal integer($int4) example: 6 The order in which this line should be picked.
Response Code: 400
Bad request
Update Pick
This section describes the Update Pick API. This API updates the fulfillment order pick.
Method
POST
URL
Request Parameters
Table 4-73 Update Pick— Request Parameters
pickId Yes number($int12)(path) The unique identifier of the fulfillment order pick.
Details to update the fulfillment order pick from.
Example Value
  "lineItems": [
      "lineId": 333444,
      "quantity": 2,
      "substituteItems": [
          "itemId": 333444,
          "quantity": 2
Schema — FulfillmentOrderPickUpdateIdo
Table 4-74 FulfillmentOrderPickUpdateIdo - Object
lineItems Yes object A collection of line items on the fulfillment order pick.
Table 4-75 FulfillmentOrderPickUpdateItemIdo - Object
lineId Yes number($int12) example: 333444 The unique identifier of the line item.
quantity Yes number($decimal(12,4)) example: 2 The quantity picked for this item.
substituteItems NA object A collection of line items on the fulfillment order pick.
Table 4-76 FulfillmentOrderPickUpdateSubstituteIdo - Object
itemId Yes number($int12) example: 333444 The SKU number of the item.
Responses
This section describes the responses of the Update Pick API.
Response Code: 204
No content
Response Code: 400
Bad request
The media type is application/json.
Confirm Pick
This section describes the Confirm Pick API. This API confirms the fulfillment order pick.
Method
POST
URL
/fulfillorderpicks/{pickId}/confirm
Request Parameters
Table 4-77 Confirm Pick — Request Parameters
Responses
This section describes the responses of the Confirm Pick API.
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Pick
This section describes the Cancel Pick API. This API cancels the fulfillment order pick.
Method
POST
URL
/fulfillorderpicks/{pickId}/cancel
Request Parameters
Table 4-78 Cancel Pick — Request Parameters
Responses
This section describes the responses of the Cancel Pick API.
Response Code: 204
No content
Response Code: 400
Bad request
See the JSON Error Element and Error Codes section.
Create Pick By Order
Creates new fulfillment order pick within the system by order information. It returns the pick that it created.
Method
POST
URL
/fulfillorderpicks/orders
Request Parameters
Details to generate the fulfillment order pick from.
Example Value
  "orderId": 11111,
Schema - FulfillmentOrderPickByOrderCreateIdo
Table 4-79 FulfillmentOrderPickByOrderCreateIdo - Object
orderId Yes number($int12) example: 11111 The unique SIOCS identifier of the fulfillment order.
productBasketId NA integer($int12) example: 488552 The identifier of the product basket to generate the pick from.
Responses
This section describes the responses of the Create Pick By Order API.
Response Code: 200
The request has been successful.
For details about the schema, see the Schema — FulfillmentOrderPickIdo section.
Example Value
    "pickId": 11111,
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "createDate": "2025-04-14T13:09:21.228Z",
    "completeDate": "2025-04-14T13:09:21.228Z",
    "lineItems": [
        "lineId": 333444,
        "orderId": 100,
        "orderLineId": 200,
        "caseSize": 10,
        "ordinal": 6
Response Code: 400
Bad request
Create Pick By Bin
Creates new fulfillment order pick within the system by bin information. It returns the pick that it created.
Method
POST
URL
/fulfillorderpicks/bins
Request Parameters
There are no request parameters.
Example Value
  "storeId": 5000,
  "numberOfBins": 2,
  "binIds": [
    333000,
    444001
Schema - FulfillmentOrderPickByBinCreateIdo
Table 4-80 FulfillmentOrderPickByBinCreateIdo - Object
Element Name Required Data Type/Example Description
storeId Yes number($int10) example: 5000 The unique identifier of the store.
numberOfBins NA integer($int3) example: 2 The number of bins being picked. This is required if store generation bin option is system generation.
binIds NA string($text128) example: List [ 333000, 444001 ] If manual bin generation is set for the store, this must contain all the bin identifiers. This is required when store generation bin option is manual generation.
Responses
This section describes the responses of the Create Pick By Bin API.
Response Code: 200
Example Value
    "pickId": 11111,
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "createDate": "2025-04-14T13:48:55.269Z",
    "completeDate": "2025-04-14T13:48:55.269Z",
    "lineItems": [
        "lineId": 333444,
        "orderId": 100,
        "orderLineId": 200,
        "caseSize": 10,
        "ordinal": 6
Response Code: 400
Bad request
REST Service: Fulfillment Order Reverse Pick
Canceling of customer orders can come in from an external system, such as an Order Management System. When this happens, a reverse pick list will be generated. If there are items that physically need to be un-picked, the user will action the reverse pick list which will then take the items that were canceled and move the picked quantities back to the appropriate area in the store. If the items that are being canceled are not picked, then the system generated reverse pick will just be created in a Completed status with no action required through the application.A system-generated reverse pick may get created if the user rejects an open customer order.A manual reverse pick might also be necessary. This happens when the user discovers that something which was picked has to be unpicked, maybe because it has been damaged. The manual reverse pick will reverse the pick quantities.This service integrates a fulfillment order reverse pick with an external application.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api
Find Reverse Pick
Finds up to a maximum of 500 order reverse pick headers based on input search criteria.
Method
GET
URL
/fulfillorderreversepicks
Request Parameters
Table 4-81 Find Reverse Pick — Request Parameters
storeId NA integer($int10) (query) Include only reverse picks for this store.
Include only reverse picks orders with this status. Valid values are:
1 - New
2 - In Progress
3 - Completed
4 - Canceled
orderId NA integer($int12) (query) Include only reverse picks for this fulfillment order identifier.
itemId NA string($text25) (query) Include only reverse picks that contain this item.
createDateFrom NA string($date-time) (query) Include only reverse picks with a create date on or after this date.
createDateTo NA string($date-time) (query) Include only reverse picks with a create date on or before this date.
Responses
This section describes the responses of the Find Reverse Pick API.
Response Code: 200
Example Value
    "reversePickId": 1234,
    "storeId": 5000,
    "orderId": 11111,
    "status": 1,
    "createDate": "2025-04-14T14:06:42.816Z"
Schema — FulfillmentOrderReversePickHeaderIdo
Table 4-82 [FulfillmentOrderReversePickHeaderIdo - Object
reversePickId NA number($int12) example: 1234 The identifier of the reverse pick.
storeId NA number($int10) example: 5000 The identifier of the store for this reverse pick.
orderId NA number($int12) example: 11111 The unique identifier of the fulfillment order the reverse pick is for.
The current status of the reverse pick. Valid values are:
1 - New
2 - In Progress
3 - Completed
4 - Canceled
createUser NA string($text128) example: smith123 The user that created the reverse pick.
createDate NA string($date-time) The date the reverse pick was created in SIOCS.
Response Code: 400
Bad request
Create Reverse Pick
This section describes the Create Reverse Pick API. This API will create a new reverse pick within the system. It responds with the reverse pick that it created.
Method
POST
URL
Request Parameters
Details about the reverse pick to create.
Example Value
  "orderId": 222345666,
  "lineItems": [
      "orderLineId": 55001234,
      "quantity": 2
Schema — FulfillmentOrderReversePickCreateIdo
Table 4-83 FulfillmentOrderReversePickCreatedo - Object
orderID Yes number($int12) example: 222345666 The unique SIOCS identifier of the fulfillment order to be reverse picked.
lineItems Yes object A collection of line items to reverse pick.
Table 4-84 FulfillmentOrderReversePickCreateItemIdo - Object
orderLineId Yes number($int12) example: 55001234 The unique identifier of the fulfillment order line item to be reverse picked.
quantity Yes number($decimal(12,4)) example: 2 The quantity to reverse pick.
Responses
This section describes the responses of the Create Reverse Pick API.
Response Code: 200
Example Value
    "storeId": 5000,
    "orderId": 11111,
    "status": 1,
    "createDate": "2025-04-15T08:14:57.283Z",
    "lineItems": [
        "lineId": 333444,
        "caseSize": 10,
        "quantitySuggested": 6,
        "quantityReversePick": 2
Schema — FulfillmentOrderReversePickIdo
Table 4-85 FulfillmentOrderReversePickIdo - Object
1 - New
2 - In Progress
3 - Completed
4 - Canceled
Enum: [ 1, 2, 3, 4
lineItems NA object A collection of line items on the fulfillment order reverse pick.
Table 4-86 FulfillmentOrderReversePickLineItemIdo - Object
orderLineId NA number($int12) example: 55001234 The unique identifier of the fulfillment order line item to be reverse picked.
caseSize NA number($decimal(10,2)) example: 10 The case size of this item reverse pick.
quantitySuggested NA number($decimal(12,4)) example: 6 The system suggested reverse pick quantity.
quantityReversePick NA number($decimal(12,4)) example: 2 The actual quantity that was reverse picked.
Response Code: 400
Bad request
Read Reverse Pick
This API retrieves all the details about a fulfillment order reverse pick.
Method
GET
URL
/fulfillorderreversepicks/{reversePickId}
Request Parameters
Table 4-87 Read Reverse Pick — Request Parameters
reversePickId Yes number($int12) (path) The unique identifier of the fulfillment order reverse pick.
Responses
This section describes the responses of the Read Reverse Pick API.
Response Code: 200
For details about the schema, see the Schema - FulfillmentOrderReversePickIdo section.
Example Value
    "storeId": 5000,
    "orderId": 11111,
    "status": 1,
    "createDate": "2025-04-15T06:35:19.059Z",
    "lineItems": [
        "lineId": 333444,
        "caseSize": 10,
Response Code: 400
Bad request
Update Reverse Pick
This section describes the Update Reverse Pick API. This API updates the fulfillment order reverse pick.
Method
POST
URL
Request Parameters
Table 4-88 Update Reverse Pick— Request Parameters
reversePickId Yes number($int12)(path) The unique identifier of the fulfillment order reverse pick.
The request body is application/json.
Details to update the fulfillment order reverse pick from.
Example Value
  "lineItems": [
      "quantity": 2
Schema — FulfillmentOrderReversePickUpdateIdo
Table 4-89 FulfillmentOrderReversePickUpdateIdo - Object
lineItems Yes object A collection of line items to update.
Table 4-90 FulfillmentOrderReversePickUpdateItemIdo - Object
Responses
This section describes the responses of the Update Reverse Pick API.
Response Code: 204
No content
Response Code: 400
Bad request
Confirm Reverse Pick
This section describes the Confirm Reverse Pick API. This API confirms the fulfillment order reverse pick.
Method
POST
URL
/fulfillorderreversepicks/{reversePickId}/confirm
Request Parameters
Table 4-91 Confirm Pick— Request Parameters
Responses
This section describes the responses of the Confirm Reverse Pick API.
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Reverse Pick
This section describes the Cancel Reverse Pick API. This API cancels the fulfillment order reverse pick.
Method
POST
URL
/fulfillorderreversepicks/{reversePickId}/cancel
Request Parameters
Table 4-92 Cancel Reverse Pick— Request Parameters
Responses
This section describes the responses of the Cancel Reverse Pick API.
Response Code: 204
No content
Response Code: 400
Bad request
REST Service: Inventory Adjustment
Inventory Adjustments allow a user to change the number of units in stock or mark them as non-sellable due to damage. Reason codes are defined on the desktop. When creating a reason code, a disposition is assigned to the reason code and it defines how the stock will be moved. So, adjustments are made to different buckets depending on the reason code's disposition. For example, a reason code of Stock - In has a disposition of + Stock on Hand which moves inventory from Out of the store to Available inventory where as, a Reason if Damaged - Hold has a disposition of + Unavailable that moves inventory from Available to Unavailable. See Reason Codes REST service for the ability to retrieve reason code. The service defines operations to manage inventory adjustment information by integration with an external system.
Service Base URL
The Cloud service base URL follows the format:
Find Inventory Adjustment
This section describes the Find Inventory Adjustment API. This API finds up to a maximum of 10,000 inventory adjustments headers based on input search criteria. No items or detailed information is returned via this search.
Method
GET
URL
/invadjustments
Request
Table 4-93 Find Inventory Adjustment — Request Parameters
referenceId
NA
number ($int12) (query)
Include only records with this reference identifier.
status
NA
integer ($int4) (query)
Include only records with this inventory adjustment status. Valid values are:
1 - In Progress
2 - Completed
3 - Canceled
Available values : 1, 2, 3 --123
adjustmentDateFrom
NA
string ($date-time) (query)
Include only records with an adjustment date on or after this date.
adjustmentDateTo
NA
Include only records with an adjustment date on or before this date.
updateDateFrom
NA
Include only records with an update date on or after this date.
updateDateTo
NA
Include only records with an update date on or before this date.
itemId
NA
string ($text25) (query)
Include only records of adjustments containing this item.
reasonId
NA
Include only records of adjustments containing this reason.
Responses
This section describes responses of the Find Inventory Adjustment API.
Response Code: 200
The response has been successful.
Example Value
    "adjustmentId": 11111,
    "storeId": 1234,
    "referenceId": 7890,
    "externalId": "AB87656",
    "adjustmentDate": "2024-09-11T13:30:40.820Z",
    "status": 1,
    "createDate": "2024-09-11T13:30:40.820Z",
    "updateDate": "2024-09-11T13:30:40.820Z",
    "approveDate": "2024-09-11T13:30:40.820Z"
Schema — InventoryAdjustmentHeaderIdo
This section describes the InventoryAdjustmentHeaderIdo schema.
Table 4-94 InventoryAdjustmentHeaderIdo — Object
adjustmentId
NA
The unique identifier of the inventory adjustment.
storeId
NA
The store identifier of the inventory adjustment.
referenceId
NA
number($int12) example: 7890
Identifier of original adjustment it was copied from.
externalId
NA
string($text120) example: AB87656
A unique identifier of the adjustment in an external system.
adjustmentDate
NA
string($date-time)
The timestamp the inventory if officially considered to have been adjusted.
status
NA
1 - In Progress
2 - Completed
3 - Canceled
Enum: [ 1, 2, 3 ]
createDate
NA
string($date-time)
The date the adjustment was created in EICS.
updateDate
NA
string($date-time)
The date the adjustment was lasted updated in EICS.
approveDate
NA
string($date-time)
The date the adjustment was approved in EICS.
Response Code: 400
Bad request
Create Inventory Adjustment
This section describes the Create Inventory Adjustment API. This API creates a new manual inventory whose status will be "In Progress". If more than 5,000 items are included, an error response will be returned. When adding items to the adjustment a reason code with a disposition associated to it determines stock movement of the item.
Method
POST
URL
/invadjustments
Request
The inventory adjustment to create.
Example Value
  "storeId": 1234,
  "externalUser": "AB87656",
  "adjustmentDate": "2024-09-12T13:07:55.023Z",
  "comments": "This is a comment.",
  "lineItems": [
      "reasonId": 5678,
      "caseSize": 5,
      "quantity": 2,
      "uins": [
        111222333,
        444555666
Schema — InventoryAdjustmentCreateIdo
Table 4-95 InventoryAdjustmentCreateIdo — Object
storeId
Yes
referenceId
NA
externalId
NA
string($text128) example: AB87656
externalUser
NA
A non-EICS user that created the inventory adjustment in an external system.
adjustmentDate
NA
string($date-time)
The timestamp the inventory if officially considered to have been adjusted. If left blank, it will default to the creation date of the record.
comments
NA
string($text2000) example: This is a comment.
Comments associated to the adjustment. Comments will be trimmed down to 2000 characters if the entry is larger.
lineItems
Yes
object
A collection of line items attached to the adjustment.
Table 4-96 InventoryAdjustmentCreateLineItemIdo — Object
itemId
Yes
reasonId
Yes
number($int12) example: 5678
The unique identifier of the reason code associated to the adjustment.
caseSize
NA
number($decimal10,2) example: 5
quantity
Yes
number($decimal20,4) example: 2
The quantity of this line item. For UINS, the quantity must match the number of UINs.
uins
NA
string($text128) example: List [ 111222333, 444555666 ]
The UINs to attach to this line item.
Responses
This section describes the responses of the Create Inventory Adjustment API.
Response Code: 200
Example Value
    "adjustmentId": 1234
Schema — InventoryAdjustmentRefIdo
Table 4-97 InventoryAdjustmentRefIdo— Object
adjustmentId
NA
The newly created inventory adjustment identifier.
Response Code: 400
Bad request
Read Inventory Adjustment
The Read Inventory Adjustment API retrieves all the details about an inventory adjustment.
Method
GET
URL
/invadjustments/{adjustmentId}
Request
Table 4-98 Read Inventory Adjustment — Request Parameters
adjustmentId
Yes
Responses
This section describes the responses of the Read Inventory Adjustment API.
Response Code: 200
Example Value
    "storeId": 1234,
    "adjustmentDate": "2024-09-17T13:47:31.101Z",
    "status": 1,
    "createDate": "2024-09-17T13:47:31.101Z",
    "createUser": "userAbc",
    "updateDate": "2024-09-17T13:47:31.101Z",
    "updateUser": "userAbc",
    "approveDate": "2024-09-17T13:47:31.101Z",
    "approveUser": "userAbc",
    "externalCreateUser": "userAbc",
    "externalUpdateUser": "userAbc",
    "lineItems": [
        "lineId": 1234,
        "reasonId": 5678,
        "caseSize": 5,
        "quantity": 2,
        "uins": [
          111222333,
          444555666
Schema — InventoryAdjustmentIdo
This section describes the InventoryAdjustmentIdo schema.
Table 4-99 InventoryAdjustmentIdo — Object
adjustmentId
NA
storeId
NA
referenceId
NA
externalId
NA
adjustmentDate
NA
string($date-time)
status
NA
The current status of the inventory adjustment. lid values are:
1 - In Progress
2 – Completed
3 – Canceled
Enum: [ 1, 2, 3 ]
comments
NA
createDate
NA
string($date-time)
createUser
NA
string($text128) example: userAbc
The user that created the adjustment in EICS.
updateDate
NA
string($date-time)
updateUser
NA
The user that last updated the adjustment in EICS.
approveDate
NA
string($date-time)
approveUser
NA
The user that approved the adjustment in EICS.
externalCreateUser
NA
A non-EICS user that created the adjustment in an external system.
externalUpdateUser
NA
A non-EICS user that last updated the adjustment in an external system.
lineItems
NA
object
line items
Table 4-100 InventoryAdjustmentLineItemIdo — Object
lineId
NA
itemId
NA
reasonId
NA
caseSize
NA
quantity
NA
uins
NA
The UINs associated to this line item.
Response Code: 400
Bad request
Update Inventory Adjustment
The Update Inventory Adjustment API updates the details of an inventory adjustment that is currently "In Progress".
Method
POST
URL
Request
The inventory adjustment to update.
Table 4-101 Update Inventory Adjustment — Request Parameters
adjustmentId
Yes
Example Value
  "adjustmentDate": "2024-09-18T08:36:13.027Z",
  "lineItems": [
      "reasonId": 5678,
      "caseSize": 5,
      "quantity": 2,
      "uins": [
        111222333,
        444555666
Schema — InventoryAdjustmentUpdateIdo
This section describes the InventoryAdjustmentUpdateIdo schema.
Table 4-102 InventoryAdjustementUpdateIdo — Object
referenceId
NA
externalUser
NA
adjustmentDate
NA
string($date-time)
comments
NA
Comments associated to the adjustment. These comments will replace any previous comments Comments will be trimmed down to 2000 characters if the entry is larger.
lineItems
Yes
object
Table 4-103 InventoryAdjustmentUpdateLineItemIdo — Object
itemId
Yes
The SKU level item identifier. If SKU is already present, its line item will be updated. Otherwise, a new line item will be added.
reasonId
Yes
The unique identifier of the reason code associated to the adjustment. The reason code is not modifiable on an update, but it will be used if a new item is added.
caseSize
NA
quantity
Yes
The quantity of this line item. For UINS, the quantity must match the number of UINs. If the quantity is set to 0, the system will attempt to remove the line item from the adjustment.
uins
NA
Responses
This section describes the responses of the Update Inventory Adjustment API.
Response Code: 204
No content
Response Code: 400
Bad request
Confirm Inventory Adjustment
This section describes the Confirm Inventory Adjustment API. This API confirms an inventory adjustment, finalizing it and processing the inventory movement.
Method
POST
URL
/invadjustments/{adjustmentId}/confirm
Request
Table 4-104 Confirm Inventory Adjustment — Request Parameters
adjustmentId
Yes
Responses
This section describes the responses of the Confirm Inventory Adjustment API.
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Inventory Adjustment
This section describes the Cancel Inventory Adjustment API. This API cancels an inventory adjustment.
Method
POST
URL
/invadjustments/{adjustmentId}/cancel
Request
Table 4-105 Cancel Inventory Adjustment — Request Parameters
adjustmentId
Yes
Responses
This section describes the responses of the Cancel Inventory Adjustment API.
Response Code: 204
No content
Response Code: 400
Bad request
REST Service: Item
This service integrates item foundation data from an external system. For item retrieval or lookup, please see the Item Inquiry REST service..
Service Base URL
Import Item
Imports up to 100 items. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsItem).
Method
POST
URL
/items/import
Request
A list of items to import.
Example Value
  "items": [
      "transactionLevel": 2,
      "itemLevel": 2,
      "status": 1,
      "departmentId": 1000,
      "classId": 2000,
      "subclassId": 3000,
      "shortDescription": "12p-Water",
      "longDescription": "12-Pack of Water",
      "differentiator1": "Color 01",
      "differentiator2": "Size 06",
      "differentiator3": "Flavor 08",
      "differentiator4": "Fruit 04",
      "parentId": "567000333",
      "pack": false,
      "simplePack": false,
      "sellable": true,
      "orderable": true,
      "shipAlone": false,
      "inventoriable": true,
      "notionalPack": false,
      "estimatePackInventory": false,
      "primaryReferenceItem": false,
      "orderAsType": false,
      "standardUom": "EA",
      "packageUom": "a",
      "packageSize": "EA",
      "eachToUomFactor": "a",
      "barcodeFormat": "a",
      "barcodePrefix": "a",
      "wastageType": 1,
      "wastagePercent": 1.5,
      "wastagePercentDefault": 1.5,
      "suggestedRetailCurrency": "USD",
      "suggestedRetailPrice": 9.99,
      "brand": "Brand A",
      "brandDescription": "Brand A Full Description",
      "components": [
          "componentItemId": "1111111",
          "quantity": 2
Schema - ItemImportListIdo
Table 4-106 ItemImportListIdo - Object
Items Yes object items
Table 4-107 ItemImportIdo - Object
itemId Yes string($text25) example: 1111111 The unique item identifier (SKU number).
transactionLevel Yes integer($int1) example: 2 Number indicating which of the three levels transactions occur for this item. Items may only be used on transactions with inventory tracked if the transaction level and item level match.
itemLevel NA integer($int1) example: 2 Number indicating which of the three levels an item resides at. Items may only be used on transactions with inventory tracked if the transaction level and item level match.
status NA integer($int1) example: 1
The status of the item. Value values are:
1 - Active
5 - Auto-Stockable
6 - Non-Ranged
Enum: [ 1, 5, 6 N ]
departmentId Yes number($int12) example: 1000 The merchandise hierarchy department identifier.
classId NA number($int12) example: 2000 The merchandise hierarchy class identifier.
subclassId NA number($int12) example: 3000 The merchandise hierarchy subclass identifier.
shortDescription NA string($text255) example: 12p-Water A short description of the item.
longDescription NA string($text400) example: 12-Pack of Water A long description of the item.
differentiator1 NA string($text10) example: Color 01 The first differentiator identifier.
differentiator2 NA string($text10) example: Size 06 The second differentiator identifier.
differentiator3 NA string($text10) example: Flavor 08 The third differentiator identifier.
differentiator4 NA string($text10) example: Fruit 04 The fourth differentiator identifier.
parentId NA string($text25) example: 567000333 The unique identifier of the item at the next level about this item.
pack NA boolean example: false True if the item is a pack, false otherwise.
simplePack NA boolean example: false True if the item is a simple pack, false otherwise.
sellable NA boolean example: true True if the item is a sellable, false otherwise.
orderable NA boolean example: true True if the item can be ordered from a supplier, false otherwise.
shipAlone NA boolean example: false True if the item must be shipped in separated packaging, false otherwise.
inventoriable NA boolean example: true True if the item is inventoried, false otherwise.
notionalPack NA Boolean example: false True indicates that the inventory is held at the component level, false otherwise. Take special note that all notional packs are automatically marked as invertoriable in SIOCS.
estimatePackInventory NA boolean example: false True if the item allows estimating pack inventory from component positions, false otherwise.
primaryReferenceItem NA boolean example: false True indicates the item is the primary sub-transaction level item.
orderAsType NA boolean example: false True indicates a buyer pack is receivable at the pack level. False indicates it is receivable at the component level.
standardUom NA string($text4) example: EA The unit of measure that inventory is tracked in.
packageUom NA string($text4) example: a The unit of measure associated with the package size.
packageSize NA number($text) example: EA The size of the product printed (or will be printed on the label).
eachToUomFactor NA number($decimal20,10) example: a The multiplication factor to convert 1 EA to the equivalent standard unit of measure.
barcodeFormat NA string($text4) example: a The format of a barcode (used for Type 2 barcode items).
barcodePrefix NA number($int9) example: a The barcode prefix used in association with the Type 2 barcode of this item.
wastageType NA integer($int4) example: 1
The type of wastage. Valid values are:
1 - Sales Wastage
2 - Spoilage Wastage
Enum: [ 1, 2
wastagePercent NA number($decimal12,4) example: 1.5 The wastage percent.
wastagePercentDefault NA number($decimal12,4) example: 1.5 The default wastage percent.
suggestedRetailCurrency NA string($text3) example: USD The currency of the manufacturer suggested retail price.
suggestedRetailPrice NA number($decimal20,4) example: 9.99 The manufacturer suggested retail price.
brand NA string($text30) example: Brand A Brand name of the brand the item belongs to.
brandDescription NA string($text120) example: Brand A Full Description Brand description of the brand the item belongs to.
components NA object A list of components if the item is a pack.
Table 4-108 ItemComponentImportIdo - Object
componentItemId Yes string($text25) example: 1111111 The item identifier of the component item within the pack.
quantity Yes number($decimal) example: 2 The quantity of the component item within the pack.
Responses
This section describes the responses of the Import Item API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
Remove Item
Marks items for removal with a non-active status. They are removed later from the system when item cleanup occurs through batch processing. Asychronous item integration is processed through staged messages and is controlled by the MPS Work Type (DcsItem).
Method
POST
URL
/items/remove
Request
A list of items to remove.
Example Value
  "items": [
      "itemId": "1111111",
      "status": 2
Schema - ItemRemoveListIdo
Table 4-109 ItemRemoveListIdo - Object
Items Yes object A list of items to mark for removal.
Table 4-110 ItemRemoveIdo - Object
status Yes integer($int4) example: 2
The status to assign to the item to mark it for removal. Valid values are:
2 - Discontinued
3 - Inactive
4 - Deleted
Enum: [ 2, 3, 4
Responses
This section describes the responses of the Remove Item API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
Import Item Hierarchy
Imports up to 500 item hierarchies. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsHierarchy).
Method
POST
URL
/items/hierarchies/import
Request
A list of item hierarchies to import.
Example Value
  "hierarchies": [
      "departmentName": "Electronics",
      "classId": 2000,
      "className": "Blu-Ray",
      "subclassId": 3000,
      "subclassName": "Supports 4K"
Schema - ItemHierarchyImportListIdo
Table 4-111 ItemHierarchyImportListIdo - Object
hierarchies Yes Objec A list of item hierarchies to import.
Table 4-112 ItemHierarchyImportIdo - Object
departmentId Yes number($int12) example: 1000 The hierarchy department identifier.
departmentName NA string($text360) example: Electronics The hierarchy department name.
classId NA number($int12) example: 2000 The hierarchy class identifier.
className NA string($text360) example: Blu-Ray The hierarchy class name.
subclassId NA number($int12) example: 3000 The hierarchy subclass identifier.
subclassName NA string($text360) example: Supports 4K The hierarchy subclass name.
Responses
This section describes the responses of the Import Item Hierarchy API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
Remove Item Hierarchy
Marks up to 500 item hierarchies for removal. They are removed later from the system when item cleanup occurs through batch processing. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsHierarchy).
Method
POST
URL
/items/hierarchies/remove
Request
Example Value
  "hierarchies": [
      "classId": 2000,
      "subclassId": 3000
Schema - ItemHierarchyRemoveListIdo
Table 4-113 ItemHierarchyRemoveListIdo - Object
hierarchies Yes object A list of item hierarchies to remove.
Table 4-114 ItemHierarchyRemoveIdo - Object
Responses
This section describes the responses of the Remove Item Hierarchy API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
Import Related Item
Imports up to 500 item relationships records. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsItem).
Method
POST
URL
/items/related/import
Request
A list of related items to import.
Example Value
  "relationships": [
      "relationshipId": 12,
      "relationshipType": 1,
      "name": "Relationship Name",
      "itemId": "300100400",
      "mandatory": true,
      "relatedItems": [
          "itemId": "1000456",
          "effectiveDate": "2025-03-12T12:23:25.195Z",
          "endDate": "2025-03-12T12:23:25.195Z",
          "priorityNumber": 2
Schema - ItemRelationshipImportListIdo
Table 4-115 ItemRelationshipImportListIdo - Object
relationships Yes object A list of item relationships to import.
Table 4-116 ItemRelationshipImportIdo - Object
relationshipId Yes number($text20) example: 12 The identifier of the relationship.
relationshipType Yes integer($int6) example: 1
The relationship type. Valid values are:
1 - Related
2 - Substitute
3 - Up-Sell
4 - Cross-Sell
Enum: [ 1, 2, 3, 4
name NA string($text120) example: Relationship Name The name of the relationship.
itemId Yes string($text25) example: 300100400 The item whose related records are being records.
mandatory Yes boolean example: true True if the relationship is mandatory.
relatedItems Yes object A list of item relationships to import.
Table 4-117 ItemRelationshipDetailIdo - Object
itemId Yes string($text25) example: 1000456 The item that is related to the base item.
effectiveDate NA string($date-time) Date at which this relationship becomes active.
endDate NA string($date-time) Last date at which this relationship is active.
priorityNumber NA integer($int4) example: 2 The item that is related to the base item.
Responses
This section describes the responses of the Import Related Item API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
Delete Related Item
Deletes up to 500 relationships between items. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is controlled by the MPS Work Type (DcsItem).
Method
POST
URL
/items/related/delete
Request
A list of item relationships to remove.
Example Value
  "relationshipIds": [
    11111,
    22222
Schema - ItemRelationshipRemoveListIdo
Table 4-118 ItemRelationshipRemoveListIdo - Object
relationshipIds Yes string($text25) relationship IDs
Responses
This section describes the responses of the Delete Related Item API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
Import Item Image
Imports up to 500 item image URLS associated to the item. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsItem).
Method
POST
URL
/items/images/import
Request
A list of item image URLs to import.
Example Value
  "images": [
      "imageType": 1,
      "storeId": 5000,
      "imageName": "Hat",
      "imageSize": "T",
      "url": "1000456",
      "displaySequence": 2,
      "startDate": "2025-03-12T13:29:07.670Z",
      "endDate": "2025-03-12T13:29:07.670Z"
Schema - ItemImageImportListIdo
Table 4-119 ItemImageImportListIdo - Object
Images Yes object A list of item relationships to import.
Table 4-120 ItemImageImportIdo - Object
itemId Yes string($text25) example: 1000456 The unique SKU number of the item.
imageType Yes integer example: 1
The type of the image. Valid values are:
1 - Image
2 - QR Code
Enum: [ 1, 2 ]
storeId NA number($int10) example: 5000 The store identifier. This attribute is required if the image type is a QR code.
imageName Yes string($text120) example: Hat The name of the image.
imageSize NA string($text6) example: T The size of the image. (T) is the only understood value (which indicates a thumbnail and is treated differently by the system).
url Yes string($text1000) example: 1000456 The universal resource locator of the image.
displaySequence NA integer($int2) example: 2 The sequence the item image should be displayed in.
startDate NA string($date-time) The date the image becomes active.
endDate NA string($date-time) The date the image ceases being active.
Responses
This section describes the responses of the Import Item Image API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
Delete Item Image
Deletes up to 500 item image URLs. They are removed later from the system when item cleanup occurs through batch processing. A forbidden response will occurs if the application is integrated with MFCS or RMS. Asychronous item integration is processed through staged messages and is ccontrolled by the MPS Work Type (DcsItem).
Method
POST
URL
/items/images/delete
Request
A list of item images URLs to delete.
Example Value
  "images": [
      "imageType": 1,
      "imageName": "Hat"
Schema - ItemImageDeleteListIdo
Table 4-121 ItemImageDeleteListIdo - Object
Images Yes Object A list of item images to remove.
Table 4-122 ItemImageRefIdo - Object
1 - Image
2 - QR Code
Enum: [ 1, 2 ]
Responses
This section describes the responses of the Delete Item Image API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Response Code: 403
Forbidden
REST Service: Item Basket
tem Basket is a way of creating a list of items that can be utilized for other things such as line busting, gift registries, and so on. Item Basket allows a user to capture items and their quantities. An item basket that has only items on it is considered static, meaning that the number of items does not change. An item basket that has only hierarchies or hierarchies and items is considered dynamic, meaning that the items on the basket can change based upon the items associated to the hierarchy. This service defines operations to manage transfer delivery information by integration with an external system.
Service Base URL
Find Baskets
This section describes the Find Baskets API. This API finds up to 10,000 item basket headers for the input criteria.
Method
GET
URL
/itembaskets
Request Parameters
This section describes the request parameters.
Table 4-123 Find Baskets — Request Parameters
Parameters Required Data Type/Example Description
referenceId
NA
Include only item baskets with this reference identifier.
alternateId
NA
Include only item baskets with this alternate identifier.
storeId
NA
number($int10) (query)
Include only item baskets with this store identifier.
typeId
NA
number($int18) (query)
Include only item baskets with this item basket type.
status
NA
Include only item baskets with this status. Valid values are
1 - In Progress
2 - Completed
3 - Canceled
updateDateFrom
NA
Include only item baskets with an update date on or after this date.
updateDateTo
NA
Include only item baskets with an update date on or before this date.
itemId
NA
Include only item baskets that contain this item.
Responses
This section describes the responses of the Find Baskets API.
Reason Code: 200
Successful response
Example Value
    "basketId": 11111,
    "referenceId": 211933,
    "alternateId": 83027,
    "storeId": 5000,
    "typeId": 5,
    "description": "Broken item investigation",
    "status": 1,
    "createDate": "2024-10-28T14:18:42.543Z",
    "updateDate": "2024-10-28T14:18:42.543Z",
    "expirationDate": "2024-10-28T14:18:42.543Z"
Schema — ItemBasketHeaderIdo
This section describes the ItemBasketHeaderIdo schema.
Table 4-124 ItemBasketHeaderIdo — Object
basketId
NA
The unique identifier of the item basket.
referenceId
NA
number($int12) example: 211933
An external reference identifier to the item basket.
alternateId
NA
number($int12) example: 83027
An alternate identifier assigned by the user to the item basket.
storeId
NA
A store identifier if the item basket belongs to a particular store. An empty or not-included store identifier indicates it can be used by all stores.
typeId
NA
number($int18) example: 5
The unique identifier of the item basket type.
description
NA
string($text255) example: Broken item investigation
A description of the item basket.
status
NA
The current status of the item basket. Valid values are:
1 - In Progress
2 - Completed
3 - Canceled
Enum:
[ 1, 2, 3 ]
createDate
NA
string($date-time)
The date the item basket was created.
updateDate
NA
string($date-time)
The date the item basket was last updated.
expirationDate
NA
string($date-time)
The date the item basket will expire.
Response Code: 400
Bad request
Create Basket
This section describes the Create Basket API. This API creates an in-progress item basket.
Method
POST
URL
/itembaskets
Request Parameters
There are not request parameters.
Request body is application/json.
The item basket details of the new item basket.
Example Value
  "storeId": 5000,
  "typeId": 5,
  "expirationDate": "2024-10-28T15:00:53.432Z",
  "hierarchies": [
      "classId": 2000,
      "subclassId": 3000
  "lineItems": [
      "itemId": "11111",
      "caseSize": 1,
      "quantity": 20
Schema — ItemBasketCreateIdo
This section describes the ItemBasketCreateIdo schema.
Table 4-125 ItemBasketCreateIdo — Object
alternateId
NA
An alternate identifier assigned by rgw user to the item basket
storeId
NA
typeId
Yes
description
NA
expirationDate
NA
string($date-time)
hierarchies
NA
object
A collection of hierarchies in the basket.
lineItems
NA
object
A collection of items in the basket.
Table 4-126 ItemBasketHierarchyIdo — Object
departmentId
NA
The unique identifier of the department.
classId
NA
The unique identifier of the class.
subclassId
NA
The unique identifier of the subclass.
Table 4-127 ItemBasketCreateItemIdo — Object
itemId
NA
The unique identifier of the item.
caseSize
NA
The case size of the item for this record.
quantity
NA
number($decimal(12,4)) example: 20
The quantity of the item in the basket.
Responses
This section describes the responses of the Create Baskets API.
Reason Code: 200
Successful response
Example Value
    "basketId": 11111,
    "typeId": 5,
    "status": 1
Schema — ItemBasketStatusIdo
This section describes the ItemBasketStatusIdo schema.
Table 4-128 ItemBasketStatusIdo
basketId
NA
typeId
NA
status
NA
1 - In Progress
2 - Completed
3 - Canceled
Enum: [ 1, 2, 3 ]
Response Code: 400
Bad request
Read Basket
This section describes the Read Basket API. This API retrieves all the details about an item basket.
Method
GET
URL
/itembaskets/{basketId}
Request Parameters
Table 4-129 Read Basket — Request Parameters
Parameter Required Data Type/Example Description
basketId
Yes
Responses
This section describes the responses of the Read Baskets API.
Reason Code: 200
Successful response
Example Value
    "basketId": 11111,
    "storeId": 5000,
    "typeId": 5,
    "status": 1,
    "createDate": "2024-10-30T12:43:35.561Z",
    "updateDate": "2024-10-30T12:43:35.561Z",
    "expirationDate": "2024-10-30T12:43:35.561Z",
    "dynamic": true,
    "hierarchies": [
        "classId": 2000,
        "subclassId": 3000
    "lineItems": [
        "lineId": 11111,
        "itemId": "11111",
        "caseSize": 1,
        "quantity": 20
Table 4-130 ItemBasketStatusIdo
basketId
NA
typeId
NA
status
NA
1 - In Progress
2 - Completed
3 - Canceled
Enum: [ 1, 2, 3 ]
Response Code: 400
Bad request
Update Basket
This section describes the Update Basket API. This API updates an item basket.
Method
POST
URL
Request Parameters
Table 4-131 Update Basket — Request Parameters
basketId
Yes
Item basket details to update.
Example Value
  "expirationDate": "2024-10-30T13:17:43.434Z",
  "hierarchies": [
      "classId": 2000,
      "subclassId": 3000
  "lineItems": [
      "itemId": "11111",
      "caseSize": 1,
      "quantity": 20
Schema — ItemBasketUpdateIdo
Table 4-132 ItemBasketUpdateIdo — Object
alternateId
NA
description
NA
expirationDate
NA
string($date-time)
hierarchies
NA
object
lineItems
NA
object
Table 4-133 ItemBasketHierarchyIdo — Object
departmentId
NA
classId
NA
subclassId
NA
Table 4-134 ItemBasketUpdateItemIdo — Object
itemId
NA
caseSize
NA
quantity
NA
Responses
This section describes the responses of the Update Baskets API.
Response Code: 204
no content
Response Code: 400
Bad request
Copy Basket
This section describes the Copy Basket API. This API copies an item basket returning the newly copied basket.
Method
POST
URL
/itembaskets/{basketId}/copy
Request Parameters
Table 4-135 Copy Basket — Request Parameters
basketId
Yes
Responses
This section describes the responses of the Copy Baskets API.
Response Code: 200
The media type os application/json.
Example Value
    "basketId": 11111,
    "storeId": 5000,
    "typeId": 5,
    "status": 1,
    "createDate": "2024-10-30T14:05:24.790Z",
    "updateDate": "2024-10-30T14:05:24.790Z",
    "expirationDate": "2024-10-30T14:05:24.790Z",
    "createUser": "smith123",
    "dynamic": true,
    "hierarchies": [
        "classId": 2000,
        "subclassId": 3000
    "lineItems": [
        "lineId": 11111,
        "itemId": "11111",
        "caseSize": 1,
        "quantity": 20
Table 4-136 ItemBasketStatusIdo
basketId
NA
typeId
NA
status
NA
1 - In Progress
2 - Completed
3 - Canceled
Enum: [ 1, 2, 3 ]
Response Code: 400
Bad request
Confirm Basket
This section describes the Confirm Basket API. This API confirms the item basket making it available for usage.
Method
POST
URL
/itembaskets/{basketId}/confirm
Responses
This section describes the responses of the Confirm Basket API.
Response Code: 204
no content
Response Code: 400
Bad request
Delete Basket
This section describes the Delete Basket API. This API deletes the item basket.
Method
POST
URL
/itembaskets/{basketId}/delete
Request Parameters
Table 4-137 Delete Basket — Request Parameters
basketId
Yes
Responses
This section describes the responses of the Delete Basket API.
Response Code: 204
no content
Response Code: 400
Bad request
Find Basket Types
This section describes the Find Basket Types API. This API finds all the available item basket types for an item basket.
Method
GET
URL
/itembaskets/types
Request Parameters
No parameters
Responses
This section describes the responses of the Find Basket Types API.
Response Code: 200
Example Value
    "typeId": 1,
    "code": "INV",
    "description": "Investigation"
Schema — ItemBasketTypeIdo
This section describes the ItemBasketTypeIdo schema.
Table 4-138 ItemBasketTypeIdo — Object
typeId
NA
number($int18) example: 1
code
NA
string($text6) example: INV
A short code of the item basket type.
description
NA
string($text120) example: Investigation
The description of the item basket type.
Response Code: 400
Bad request
REST Service: Item Inquiry
The service provides an external system the ability to retrieve information about items (with the exception of inventory information).
Service Base URL
Retrieve Items
The Retrieve Items API searches for detailed information about the items using the specified input. If the number of items found exceeds 10,000, a maximum limit error will be returned. Additional limiting input criteria will be required.
Method
POST
URL
/iteminquiries
Request
The store and items to find information for.
Example Value
  "storeId": 5000,
  "itemIds": [
    333000,
    444001
Schema — ItemInquiryCriteriaIdo
Table 4-139 ItemInquiryCriteria — Object
storeId
Yes
integer($int10) example: 5000
The store identifier (if passed in as query parameter).
itemIds
Yes
string($text25) example: List [ 333000, 444001 ]
A list of items to retrieve information for.
Responses
This section describes the responses of the Retrieve Items API.
Response Code: 200
Example Value
    "itemLevel": 2,
    "classId": 2000,
    "subclassId": 3000,
    "pack": false,
    "sellable": true,
    "orderable": true,
    "shipAlone": false,
    "packageUom": "a",
    "wastageType": 1,
    "brand": "Brand A",
    "createDate": "2024-09-18T13:33:41.160Z",
    "updateDate": "2024-09-18T13:33:41.160Z",
    "storeId": 4000,
    "status": 1,
    "primarySupplierId": 40001,
    "storeControlPricing": true,
    "rfid": false,
    "defaultCurrencyCode": "USD",
    "purchaseType": 1,
    "uinType": 1,
    "uinCaptureTime": 1,
    "uinLabelId": 876544,
    "uinExternalCreateAllowed": true,
    "replenishmentMethod": "SO",
    "rejectStoreOrder": false,
    "multipleDeliveryPerDayAllowed": false,
    "nextDeliveryDate": "2024-09-18T13:33:41.160Z",
    "toleranceType": 1,
    "toleranceUnit": 5.5,
    "tolerancePercent": 2
Schema — ItemInquiryIdo
Table 4-140 ItemInquiryIdo — Object
itemId
NA
transactionLevel
NA
itemLevel
NA
departmentId
NA
classId
NA
subclassId
NA
shortDescription
NA
longDescription
NA
differentiator1
NA
differentiator2
NA
differentiator3
NA
differentiator4
NA
parentId
NA
The unique ientifier of the item at the next level about this item.
pack
NA
simplePack
NA
sellable
NA
orderable
NA
shipAlone
NA
inventoriable
NA
notionalPack
NA
NA
True if the item alows estimating pack inventory from component positions, false otherwise.
NA
orderAsType
NA
standardUom
NA
packageUom
NA
packageSize
NA
eachToUomFactor
NA
The multiplication favtor to convert 1 EA to the equivalent standard unit of measure.
barcodeFormat
NA
barcodePrefix
NA
wastageType
NA
The type of wastage. Validate value are:
1 - Sales Wastage
Enum: [ 1, 2 ]
wastagePercent
NA
NA
NA
NA
brand
NA
brandDescription
NA
createDate
NA
string($date-time)
The date the item was created in EICS.
updateDate
NA
string($date-time)
storeId
NA
integer($int10) example: 4000
status
NA
The status of the item. Valid values are:
1 - Active
2 - Discontinued
3 - Inactive
4 - Deleted
5 - Auto-Stockable
Non-Ranged
Enum: [ 1, 2, 3, 4, 5, 6 ]
primarySupplierId
NA
integer($int10) example: 40001
The unique identifier of the primary supplier of the item to this store location.
storeControlPricing
NA
True indicates the item price can be controlled by the store.
rfid
NA
True indicates the item is RFID tagged.
defaultCurrencyCode
NA
The default currency fo the item's price at this store.
purchaseType
NA
integer($int2) example: 1
The purchase type. Valid values are:
1 - Consignment
2 - Concession
Enum: [ 1, 2 ]
uinType
NA
1 - Serial Number
2 - AGSN
Enum: [1, 2 ]
uinCaptureTime
NA
The UIN capture time. Valid values are:
1 - Sale
2 - Store Receiving
Enum: [ 1, 2 ]
uinLabelId
NA
integer($int12) example: 876544
The unique identifier of the UIN label.
NA
True if an external system can create a UIN, false otherwise.
replenishmentMethod
NA
string($text6) example: SO
The replenishment method. (SO) Store Orders has specific processing in the system, otherwise this is any text.
rejectStoreOrder
NA
True indicates store orders must be on or after the next delivery date or should be rejected.
NA
True indicates the itemm allows multiple deliveries per day at the location.
nextDeliveryDate
NA
string($date-time)
The next delivery date of the time based on its replenishment type.
toleranceType
NA
If not include, will default to unit. Valid values are:
1 - Unit
2 - Percent
Enum: [ 1, 2 ]
toleranceUnit
NA
integer($decimal12,4) example: 5.5
The unit tolerance amount.
tolerancePercent
NA
integer($decimal12,4) example: 2
The percent tolerance amount.
Response Code: 400
Bad request
Retrieve Items By Scan
Search for item information by an unknown identifier, most likely a scan. It first searches for the item using the input as a potential item, and if found will return records based on that. It then searches as a UPC, barcode (including GS1), or UIN, in that order, halting if it finds potential matches. An optional store identifier can be included as well.
Method
POST
URL
/iteminquiries/scan
Request
The store and scan to search for.
Example Value
  "searchScan": "333001",
  "storeId": 5000
Schema - ItemScanIdo
Table 4-141 ItemScanIdo - Object
searchScan Yes string($text128) example: 333001 A scan to find matching items for.
storeId NA integer($int10) example: 5000 The store identifier.
Responses
This section describes the responses of the Retrieve Items By Scan API.
Response Code: 200
Example Value
    "type": 1,
    "status": 1,
    "shortDescription": "Shoe",
    "longDescription": "Steel-toed Shoe (two-tone)",
    "classId": 2000,
    "subclassId": 3000,
    "storeId": 5000,
    "ranged": true
Schema - ItemScannedIdo
Table 4-142 ItemScannedIdo - Object
itemId NA string($text25) example: 1111111 The item identifier.
type NA integer($int2) example: 1
The item type. Valid values are:
1 - Item
2 - Simple Pack
3 - Complex Pack
4 - Simple Breakable Pack
5 - Complex Breakable Pack
status NA integer($int2) example: 1
1 - Active
2 - Discontinued
3 - Inactive
4 - Deleted
5 - Auto-Stockable
6 - Non-Ranged
shortDescription NA string($text255) example: Shoe The short description of the item.
longDescription NA string($text400) example: Steel-toed Shoe (two-tone) The long description of the item.
departmentId NA number($int12) example: 1000 The identifier of the department the item belongs to.
classId NA number($int12) example: 2000 The identifier of the class the item belongs to.
subclassId NA number($int12) example: 3000 The identifier of the subclass the item belongs to.
storeId NA integer($int10) example: 5000 The store identifier (only if passed in as query parameter).
ranged NA boolean example: true True if the item is ranged to the requested store, false otherwise.
Response Code: 400
Bad request
Retrieve Items by Search Scan
Search for item information by an unknown identifier, most likely a scan. It first searches for the item using the input as a potential item, and if found will return records based on that. It then searches as a UPC, barcode, or UIN, in that order, halting if it finds potential matches. An optional store identifier can be included as well. This operation is deprecated and should not be used! Use the retrieve items by scan POST version instead.
Method
GET
URL
/iteminquiries/scan/{searchScan}
Request
Table 4-143 Retrieve Items By San Request — Request Parameters
searchScan
Yes
string($text128) (path)
A scan or entered item information.
storeId
NA
The identifier of a store to search within.
Responses
This section describes the responses of the Retrieve Items By Search Scan API.
Response Code: 200
For details about the schema, see the Schema - ItemScannedIdo section.
Example Value
    "type": 1,
    "status": 1,
    "classId": 2000,
    "subclassId": 3000,
    "storeId": 5000,
    "ranged": true
Response Code: 400
Bad request
Retrieve Items by Source
The Retrieve Items by Source API searches for summary information about an item based on search criteria, primarily hierarchy and source location.
Method
GET
URL
/iteminquiries/source
Request
Table 4-144 Retrieve Items By Source — Request Parameters
description
NA
string($text255) (query)
Include only items with description text matching this description.
sourceType
NA
integer($int4) (query)
Include only items available from this source type. Valid values are:
1 - Supplier
2 - Warehouse
3 - Finisher
sourceId
NA
Include only items available from this source. If source id is included, then sourceType is also required.
departmentId
NA
Include only items associated to this merchandise hierarchy department.
classId
NA
Include only items associated to this merchandise hierarchy class.
subclassId
NA
Include only items associated to this merchandise hierarchy subclass.
storeId
NA
Include only items ranged to this particular store.
Responses
This section describes the responses of the Retrieve Items by Source API.
Response Code: 200
Example Value
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "classId": 2000,
    "subclassId": 3000
Schema — ItemSummaryIdo
Table 4-145 ItemSummaryIdo — Object
itemId
NA
storeId
NA
type
NA
1 - Item
2 - Simple Pack
3 - Complex Pack
Enum: [ 1, 2, 3, 4, 5 ]
status
NA
1 - Active
2 - Discontinued
3 - Inactive
4 - Deleted
5 - Auto-Stockable
Non-Ranged
shortDescription
NA
longDescription
NA
departmentId
NA
classId
NA
subclassId
NA
Response Code: 400
Bad request
Retrieve Items by Inventory
This section describes the Retrieve Items by Inventory API. This API searches for summary information about an item based on search criteria, primarily inventory information.
URL
/iteminquiries/inventory
Method
GET
Request
Table 4-146 Retrieve Items by Inventory - Request Parameters
Name Required Data Type Description
available NA boolean (query) Include only items with positive available inventory.
unavailable NA boolean (query) Include only items with positive unavailable inventory.
nonsellableTypeId NA integer($int12) (query) Include only items with this non-sellable quantity type.
departmentId NA integer($int12) (query) Include only items associated to this merchandise hierarchy department.
classId NA integer($int12) (query) Include only items associated to this merchandise hierarchy class.
subclassId NA integer($int12) (query) Include only items associated to this merchandise hierarchy subclass.
storeId NA integer($int10) (query) Include only items ranged to this particular store.
Responses
This section describes the responses of the Retrieve Items by Inventory API.
Response Code: 200
For details about the schema, see the Schema — ItemSummaryIdo section.
Example Value
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "classId": 2000,
    "subclassId": 3000
Response Code: 400
Bad request
Retrieve Items by Relationship
This section describes the Retrieve Items by Relationship API. This API searches for summary information about an item based on search criteria, primarily items associated by relationship.
Method
GET
URL
/iteminquiries/related
Request
Table 4-147 Retrieve Items by Relationship - Request Parameter
itemId NA string($text25) (query) Include only items that have a relationship to this item identifier.
Responses
This section describes the responses of the Retrieve Items by Relationship API.
Response Code: 200
Example Value
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "classId": 2000,
    "subclassId": 3000
Response Code: 400
Bad request
Retrieve Items by UDA
This section descibes the Retrieve Items by UDA API. This API searches for summary information about an item based on search criteria, primarily user defined attributes.
Method
GET
URL
/iteminquiries/uda
Request
Table 4-148 Retrieve Items by UDA - Request Parameter
udaId NA integer($int5) (query) Include only items with this user defined attribute.
udaText NA string($text250) (query) Include only items with this UDA text value.
udaLovId NA string($text25) (query) Include only items with a UDA value matching this list of values identifiers.
udaDateFrom NA string($date-time) (query) Include only items with a date UDA value on or after this date.
udaDateTo NA string($date-time) (query) Include only items with a date UDA value on or before this date.
Responses
This section describes the responses of the Retrieve Items by UDA API.
Response Code: 200
The media type is applicaton/json.
Example Value
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "classId": 2000,
    "subclassId": 3000
Response Code: 400
Bad request
REST Service: Item Inventory
This service retrieves information about item inventory.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/inventory
API Definitions
API Description
Find Available Inventory
Search for available inventory information by multiple items and multiple locations.
Find Inventory
Searches for standard inventory information by multiple items and multiple locations.
Find Expanded Inventory
Searches for expanded inventory information by multiple items at a single store.
Find Future Inventory
Searches for future inventory delivery information by a single item and a single store.
Find Inventory In Buddy Stores
Searches for inventory information at buddy stores by single input store and multiple items.
Find Inventory In Transfer Stores
Searches for inventory information at transfer zone stores by single input store and multiple items.
API: Find Available Inventory
Searches for available inventory quantity about an item in requested locations. Only transaction-level items are processed, and only current available inventory is returned. The multiplied combination of items and locations within the input criteria cannot exceed 10,000. Invalid items or locations will not cause this API to fail. Inventory is returned for any item and locations found and is not returned invalid or not found items or locations.
API Basics
Endpoint URL
{base URL}/available
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
Criteria
Output
List of items
Max Response Limit
10,000
Input Data Definition
Attribute Data Type Required Description
itemIds
List of Strings
Yes
A list of items to retrieve available inventory for.
locationIds
List of Longs
Yes
A list of location identifiers to retrieve available inventory for.
locationType
Integer
Yes
A location type: See Location Type
Example Input
"itemIds": [
"100637156",
"100637172",
"100653105"
"locationIds": [
5000,
5001,
5005
"locationType": 1
Output Data Definition
itemId
String
Yes
locationId
Long
Yes
The location identifier.
locationType
Integer
Yes
The location type: See Location Type.
availableQuantity
BigDecimal
Yes
The amount of available inventory.
unitOfMeasure
String
Yes
The unit of measure of the available inventory.
estimatedPack
Boolean
Yes
True if this is an estimated pack quantity, false otherwise.
Example Output
"itemId": "100637113",
"locationId": 5000,
"locationType": 1,
"availableQuantity": 200.0000,
"unitOfMeasure": "EA",
"estimatedPack": false
"locationId": 5001,
"locationType": 1,
Additional Data Definitions
Location Type
Value Definition
1
Store
2
Warehouse
API: Find Inventory
Query lookup of detailed inventory information about a multiple item in multiple stores. The multiplied combination of items and locations within the input criteria cannot exceed 10,000. Invalid items or locations will not cause this API to fail. Inventory is returned for any item and locations found and is not returned invalid or not found items or locations.
API Basics
Endpoint URL
{base URL}/positions
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
Criteria
Output
List of inventory of item at stores
Max Response Limit
10,000
itemIds
List of Strings
Yes
A list of items to retrieve inventory for.
storeIds
List of Longs
Yes
A list of store identifiers to retrieve inventory for.
sellingUnitOfMeasure
Boolean
True indicates an attempt to use the selling unit of measure of the item, false indicates to use the standard unit of measure. If conversion cannot take place, it defaults back to standard unit of measure.
Example Input
"itemIds": [
"100637156",
"100637172",
"100668091"
"storeIds": [
5000,
5001,
5002
"sellingUnitOfMeasure": true
itemId
String
Yes
storeId
Long
The store identifier if the item is ranged to a store.
ranged
Boolean
Yes
True if the item is ranged to the store, false otherwise.
estimated
Boolean
Yes
True if the quantities are estimated, false otherwise.
unitOfMeasure
String
Yes
The unit of measure of the quantities.
caseSize
BigDecimal
Yes
The default case size of the item.
quantityStockOnHand
BigDecimal
Yes
The stock on hand quantity.
quantityBackroom
BigDecimal
Yes
The quantity located in the back room area.
quantityShopfloor
BigDecimal
Yes
The quantity located on the shop floor.
quantityDeliveryBay
BigDecimal
Yes
The quantity located in the delivery bay.
quantityAvailable
BigDecimal
Yes
The available to sell quantity.
quantityUnavailable
BigDecimal
Yes
The unavailable to sell quantity.
quantityNonSellable
BigDecimal
Yes
The total non-sellable quantity.
quantityInTransit
BigDecimal
Yes
The quantity currently in transit.
quantityCustomerReserved
BigDecimal
Yes
The quantity reserved for customer orders.
quantityTransferReserved
BigDecimal
Yes
The quantity reserved for transfers.
quantityVendorReturn
BigDecimal
Yes
The quantity reserved for vendor returns.
nonSellableQuantities
List of Non-Sellable Quantities
A collection containing the specific quantity in each non-sellable quantity type bucket.
Non-Sellable Quantity Data Definition
nonsellableTypeId
Long
Yes
The non-sellable type unique identifier.
quantity
quantity
Yes
The quantity in this particular non-sellable type bucket.
Example Output
"itemId": "100637156",
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantityStockOnHand": 10.0000,
"quantityBackroom": 10.0000,
"quantityShopfloor": 0.0000,
"quantityDeliveryBay": 0.0000,
"quantityAvailable": 10.0000,
"quantityUnavailable": 0.0000,
"quantityNonSellable": 0.0000,
"quantityInTransit": 0.0000,
"quantityCustomerReserved": 0.0000,
"quantityTransferReserved": 0.0000,
"quantityVendorReturn": 0.0000
"itemId": "100637172",
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantityBackroom": -10.0000,
"quantityAvailable": -10.0000,
"quantityUnavailable": 20.0000,
"quantityNonSellable": 20.0000,
"quantityVendorReturn": 0.0000,
"nonSellableIdos": [
"nonsellableTypeId": 1,
"quantity": 15.0000
"nonsellableTypeId": 2,
"quantity": 5.0000
API: Find Expanded Inventory
Searches for expanded inventory information about multiple items within a single store.
API Basics
Endpoint URL
{base URL}/{storeId}/expanded
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
Criteria
Output
List of inventory of items
Max Response Limit
2,500
Path Parameter Definitions
Attribute Description
storeId
The store identifier of the store to process items for.
itemIds
List of Strings
Yes
A list of items to retrieve expanded inventory for.
Example Input
"itemIds": [
"100637156",
"100637172",
"100695081"
itemId
String
Yes
storeId
Long
ranged
Boolean
Yes
estimated
Boolean
Yes
unitOfMeasure
String
Yes
caseSize
BigDecimal
Yes
quantityStockOnHand
BigDecimal
Yes
quantityBackroom
BigDecimal
Yes
quantityShopfloor
BigDecimal
Yes
quantityDeliveryBay
BigDecimal
Yes
quantityAvailable
BigDecimal
Yes
quantityUnavailable
BigDecimal
Yes
quantityNonSellable
BigDecimal
Yes
quantityInTransit
BigDecimal
Yes
BigDecimal
Yes
BigDecimal
Yes
BigDecimal
Yes
firstReceivedDate
Date
The first date the item was received into stock.
lastReceivedDate
Date
The date the item last received inventory into stock.
lastReceivedQuantity
BigDecimal
Total amount of inventory received on the last date it was received.
openStockCounts
Integer
The number of stock counts open for the item at this store.
lastStockCountType
Integer
The type of stock count (see Additional Data Definition).
lastStockCountApprovedDate
Date
The date this item was last approved on a stock count at this store.
lastStockCountTimeframe
Integer
The stock count timeframe (see Additional Data Definition).
uinProblemLine
Boolean
Yes
True indicates it is UIN problem line item, false otherwise.
lastRequestedQuantity
BigDecimal
The quantity last requested for this item.
lastUpdateDate
Date
Yes
The timestamp of the last time this record was updated.
Collection of Non-Sellable Quantities
The specific quantities in each non-sellable quantity type bucket.
nonsellableTypeId
Long
Yes
quantity
quantity
Yes
Example Output
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantityStockOnHand": 200.0000,
"quantityBackroom": 200.0000,
"quantityAvailable": 200.0000,
"quantityLastReceived": 0.0000,
"quantityLastRequested": 0.0000,
"openStockCounts": 0,
"lastStockCountTimeframe": 3,
"uinProblemLine": false,
"lastUpdateDate": "2022-07-15T06:23:27-05:00"
"itemId": "100637121",
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantityBackroom": 180.0000,
"quantityAvailable": 180.0000,
"lastUpdateDate": "2022-07-15T06:23:27-05:00",
"quantity": 15.0000
"quantity": 5.0000
API: Find Future Inventory
Searches for future delivery records for a single store and single item.
API Basics
Endpoint URL
{base URL}/{storeId}/{itemId}/future
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
None
Output
List of delivery records
Max Response Limit
N/A
storeId
The store identifier to retrieve future inventory for.
itemId
The item identifier to retrieve future inventory for.
itemId
String (25)
Yes
storeId
Long
Yes
deliveries
List of deliveryIds
A list of delivery information if it exists.
Delivery Data Definition
sourceLocationType
Integer
Yes
Item Location Type (see Additional Data Definition).
sourceLocationId
Long
Yes
The unique identifier of the source location of the delivery.
deliveryType
Integer
Yes
Item Delivery Type (see Additional Data Definition).
expectedDate
Date
Yes
The date the inventory is expected to arrive.
quantityInbound
BigDecimal
Yes
Amount of inventory inbound on the delivery.
quantityOrdered
BigDecimal
Yes
Amount of inventory on order.
Example Output
"storeId": 5000,
"deliveryIdos": [
"sourceLocationType": 1,
"sourceLocationId": 5001,
"deliveryType": 3,
"quantityInbound": 30.0000,
"quantityOrdered": 0.0000
Item Delivery Type
Value Definition
1
Allocation
2
Purchase Order
3
Transfer
Item Location Type
Value Definition
1
Store
2
Supplier
3
Warehouse
4
Finisher
API: Find Inventory in Buddy Stores
API Basics
Endpoint URL
{baseUrl}/{storeId}/associated
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
List of items
Output
List of inventory records
Max Response Limit
N/A
storeId
The store identifier to find buddy stores for.
itemIds
List of Strings
Yes
Boolean
Example Input
"itemIds": [
"100637156",
"100637172",
"100668091"
itemId
String
Yes
storeId
Long
ranged
Boolean
Yes
estimated
Boolean
Yes
unitOfMeasure
String
Yes
caseSize
BigDecimal
Yes
quantityStockOnHand
BigDecimal
Yes
quantityBackroom
BigDecimal
Yes
quantityShopfloor
BigDecimal
Yes
quantityDeliveryBay
BigDecimal
Yes
quantityAvailable
BigDecimal
Yes
quantityUnavailable
BigDecimal
Yes
quantityNonSellable
BigDecimal
Yes
quantityInTransit
BigDecimal
Yes
BigDecimal
Yes
BigDecimal
Yes
BigDecimal
Yes
nonsellableTypeId
Long
Yes
quantity
quantity
Yes
Example Output
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantity": 15.0000
"quantity": 5.0000
API: Find Inventory in Transfer Zone Stores
Searches for inventory at transfer zone stores by single input store and multiple items.
API Basics
Endpoint URL
{baseUrl}/{storeId}/transferzone
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
List of items
Output
Max Response Limit
N/A
storeId
The store identifier to find transfer zone stores for.
itemIds
List of Strings
Yes
Boolean
Example Input
"itemIds": [
"100637156",
"100637172",
"100668091"
itemId
String
Yes
storeId
Long
ranged
Boolean
Yes
estimated
Boolean
Yes
unitOfMeasure
String
Yes
caseSize
BigDecimal
Yes
quantityStockOnHand
BigDecimal
Yes
quantityBackroom
BigDecimal
Yes
quantityShopfloor
BigDecimal
Yes
quantityDeliveryBay
BigDecimal
Yes
quantityAvailable
BigDecimal
Yes
quantityUnavailable
BigDecimal
Yes
quantityNonSellable
BigDecimal
Yes
quantityInTransit
BigDecimal
Yes
BigDecimal
Yes
BigDecimal
Yes
BigDecimal
Yes
nonsellableTypeId
Long
Yes
quantity
quantity
Yes
Example Output
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"storeId": 5000,
"ranged": true,
"estimated": false,
"caseSize": 100.00,
"quantity": 15.0000
"quantity": 5.0000
REST Service: Item ISN
This rest service defines operations to manage Item ISN information.
Service Base URL
https://<external_load_balancer>/<cust_env/siocs-int-services>/api/isns
APIs
API
Description
Create ISN
Create a new ISN
Update ISN
Updates an existing ISN
Delete ISN
Delete an existing ISN
Find ISNs
Search for ISNs based on a set of criteria
Read ISN Types
Read all Item ISN types
API: Create ISN
This API will create ISN information.
API Basics
Endpoint URL
{base URL}
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
The ISN
Output
The ISN including ID
Max Response Limit
N/A
Attribute
Type
Req
Definition
isn
String(128)
X
A scan number used to scan the item
isnTypeId
Long(12)
X
The unique identifier of the item ISN type
itemId
String(25)
X
The unique item identifier (sku number)
uin
String(128)
A universal identification number
externalId
String(128)
An identifier from an external system
Example
Input Example
Attribute
Type
Definition
isnId
Long(12)
The unique identifier of the ISN record
isn
String(128)
This is a scan number used to scan the item
externalId
String(128)
API: Update ISN
This API allows the ISN information to be modified. An optional value left blank will update the ISN information to blank for that value.
API Basics
Endpoint URL
{base URL}/isnId
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Input
ISN Update Information
Output
N/A
Max Response Limit
N/A
Path Data Definiton
Attribute
Type
Definition
isnId
Long(12)
The unique identifier of the item ISN.
Attribute
Type
Req
Definition
isnTypeId
Long(12)
X
itemId
String(25)
X
uin
String(128)
externalId
String(128)
Example
Input Example
API: Delete ISN
This API deletes an item ISN.
API Basics
Endpoint URL
{base URL}/{isnId}/delete
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Input
N/A
Output
N/A
Max Response Limit
N/A
Path Data Definition
Attribute
Type
Definition
isinId
Long(12)
API: Find ISNs
This API is used to lookup or find ISNs.
API Basics
Endpoint URL
{base URL}
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
N/A
Output
List of ISNs
Max Response Limit
10,000
Query Parameters
Attribute
Type
Definition
isn
String(128)
Retrieves records containing this ISN, which could be for multiple items.
ItemId
String(25)
Retrieves records associated to this unique item identifier (sku number).
uin
String(128)
Retrieves records associated to this universal identification number.
updateDateFrom
String
Retrieves records on or after this date.
updateDateTo
String
Retrieves records on or before this date.
Attribute
Type
Definition
itemIsnId
Long(12)
The unique identifier of the record
isn
String(128)
ItemId
String(25)
uin
String(128)
itemIsnTypeId
Long(12)
externalId
String(128)
An identifier of this ISN from an external system
createDate
Date
The date this ISN record was first created
createUser
String(128)
The user that created this ISN record
updateDate
Date
The last date this ISN record was updated
updateUser
String(128)
The user that last updated this ISN record.
API: Read ISN Types
This API is used to lookup all the ISN types available for an ISN.
API Basics
Endpoint URL
{base URL}/types
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
N/A
Output
List of ISN Types
Max Response Limit
N/A
Attribute
Type
Definition
isnTypeId
Long(12)
The unique ISN type identifier
labelKey
String(128)
A label for the ISN type (not translated)
restricted
Boolean
Y if this represents secure data, N otherwise.
REST Service: Item Price
This service allows for the search and retrieval of item pricing information stored within EICS.
Service Base URL
The Cloud service base URL follows the format:
https://<external_load_balancer></cust_env>/siocs-int-services/api/prices
API Definitions
API Definitions
API Description
findPrices This API can be used to search for price summary information matching filter criteria.
FindPriceByIds Find extended price information based on a list of potential unique price identifiers.
API: findPrices
At least one input criteria is required or a bad request error will be returned.
API Basics
Endpoint URL {base URL}
Method GET
Success Response 200 OK
Processing Type Synchronous
Input Query Parameters
Output List of Prices
Maximum Results Allowed 10,000
Attribute Data Type Definition
storeId Long(10) Only retrieve item price information for this store.
effectiveDateFrom String Only retrieve item price information on or after this date.
effectiveDateTo String Only retrieve item price information on or before this date.
itemId String(25) Only retrieve item price information for this item.
priceId Long(12) The unique identifier of the price.
itemId String(25) The unique identifier of the item.
storeId Long(10) The unique identifier of the store.
status Integer The status of the price.
priceType Integer The type of the price.
effectiveDate Date The effective date of the price.
endDate Date The end date of the price.
priceValue BigDecimal(20,4) The price amount.
priceCurrency String(3) The price currency.
unitOfMeasure String(4) The item unit of measure associated with the price.
API: findPriceByIds
It will return information only for price identifiers that are found. It will not return errors or fail to process if invalid identifiers occur. It is up to the accessing information to determined prices not found using this API.
API Basics
Endpoint URL {base URL}/find
Method POST
Input ID List
Maximum Input Allowed 5,000
Attribute Type Definition
priceIds List<Long(12)> A list of price identifiers.
Status Integer The status of the price.
externalPriceId Long(12) The unique identifier of the external price or price event.
clearanceId Long(15) The unique identifier of the clearance price change from the pricing engine.
promotionId Long(10) The unique identifier of the promotion.
regularPriceChangeId Long(15) The unique identifier of the regular price change from the pricing engine.
resetClearanceId Long(15) The identifier of the clearance reset.
storeRequested Boolean True indicates it is store requested, false indicates it is not store requested.
sellingUnitPriceChange Boolean True indicates the selling unit retail price has changed, false indicates it has not.
multiUnitPriceChange Boolean True indicates the multi-unit pricing has changed, false indicates it has not.
multiUnitRetail BigDecimal(20,4) The multi-unit retail price.
multiUnitRetailCurrency String(3) The currency type of the multi-unit retail price in the multi-selling unit of measure.
multiUnits BigDecimal(12,4) The number of multi-units.
multiUnitUom String(4) The unit of measure of the multi-unit retail price.
promotionName String(160 The promotion name.
promotionCompDtlId Long(15) The unique identifier of the promotion component detail from the pricing engine.
promotionType Integer Promotion Component Type (See Index)
promotionDurationType Integer Promotion Duration Type (See Index)
promotionCompId Long(10) The unique identifier of the promotion component.
promotionCompName String(160) The promotion component name.
promotionDescription String(640) The promotion description.
updateDate Date The date that the update took place.
Example Input:
"priceIds": [
123,
 456,
 789,
 012
Price Type
ID Status
1 Permanent
2 Promotional
3 Clearance
4 Clearance Reset
Price Status
ID Status
1 New
2 Pending
3 Approved
4 Completed
5 Rejected
6 Ticket List
7 Extract Failed
8 Deleted
99 Default
ID Status
1 Complex Promotion
2 Simple Promotion
3 Threshold Promotion
4 Credit (Finance) Promotion
5 Transaction Promotion
ID Status
1 All Day Promotion
2 Partial Day Promotion
3 Multiple Day Promotion
REST Service: Item UDA
This service integrates user defined attribute foundation data. Asynchronous item UDA integration is processed through staged messages and is controlled by the MPS Work Types.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/udas
API Definitions
API
Description
importUdas
Imports user defined attributes.
deleteUdas
Deletes user defined attributes.
importItemUdas
Imports an association between items and user defined attributes.
deleteItemUdas
Deletes the association between items and user defined attributes.
readItemUdas
Retrieves all the user defined attributes for a particular item.
API: Import Udas
Imports user defined attributes. It is managed by DcsUda work type. If the input exceeds 500 UDAs an input too large exception will be returned.
A "Forbidden" response will occur if application is integrated with MFCS or RMS.
API Basics
Endpoint URL
{base URL}/import
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
UDA import List
Output
None
Max Response Limit
N/A
Attribute
Data Type
Required
Description
udas
List of details
Yes
A list of user defined attributes.
Detail Data Definition
Attribute
Data Type
Required
Description
udaId
Integer (5)
Yes
The user defined attribute identifier.
type
Integer
Yes
See Index: UdaType
description
String (120)
Yes
The description of the user defined attribute.
printTicket
Boolean
True indicates tickets are printed for this user defined attribute.
printLabel
Boolean
True indicates labels are printed for this user defined attribute.
lovId
String (25)
The unique identifier of a list of values UDA.
lovDescription
String (250)
The description of the list of values UDA.
API: Delete Udas
Deletes user defined attributes. It is managed by DcsUda work type. If the input exceeds 500 UDAs an input too large exception will be returned.
API Basics
Endpoint URL
{base URL}/delete
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
UDA delete list
Output
None
Max Response Limit
N/A
Attribute
Data Type
Required
Description
udaIds
List<Long>
Yes
A list of user defined attribute.
API: Import Item Udas
Imports associations between items and user defined attributes. This is controlled by the work type: DcsItem.
If the input exceeds 500 Item UDAs an input too large exception will be returned.
A "Forbidden" response will occur if application is integrated with MFCS.
API Basics
Endpoint URL
{base URL}/items/import
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
Item UDA list
Output
None
Max Response Limit
N/A
Attribute
Data Type
Required
Description
itemUdas
List of details
x
A list of associations between an item and user defined attributes.
Attribute
Data Type
Required
Description
itemId
String
X
udaId
Integer
X
udaDate
Date
Holds the value of the user defined attribute if it is a date.
udaText
String (250)
Holds the value of the user defined attribute if it is text.
udaLovId
String (25)
Holds the unique numeric identifier of the user defined attribute if it is a list of values selection.
print
Boolean
Y indicates printing is done for this item and user defined attribute (which is also controlled by the UDA).
API: Delete Item Udas
Deletes an association between item and user defined attributes. This is controlled by the work type: DcsItem.
API Basics
Endpoint URL
{base URL}/items/delete
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
UDA item delete list
Output
None
Max Response Limit
N/A
Attribute
Data Type
Required
Description
itemUdas
List of details
Yes
A list of associations between item and user defined attribute identifiers.
Attribute
Data Type
Required
Description
itemId
String (25)
Yes
udaId
Integer (5)
Yes
udaDate
Date
udaText
String (250)
udaLovId
String (25)
API: Find Item Udas
It will retrieve UDAs for the inputted items.
API Basics
Endpoint URL
{base URL}/items/find
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
Item list
Output
UDA item list
Max Response Limit
N/A
Attribute
Data Type
Required
Description
itemIds
List<String>
Yes
A list of items to find UDAs for.
Attribute
Data Type
Description
itemId
String
udaId
Integer
type
String
The user defined attribute type: (LV) List of Value, (FF) Free Form Text, DT (Date)
description
String
udaDate
Date
udaText
String
udaLovId
Long
udaLoveDescription
String
Holds the value description of the UDA List of Values selection.
printTicket
Boolean
printLabel
Boolean
UDA Type
Value
Definition
1
Date
2
Free Form Text
3
List of Value
REST Service: Item UIN
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/uins
API Definitions
API Description
createUin Create a new unique identification number.
readUin Reads information about a Universal Identification Number.
findUins Find unique identification number summary information based on search criteria.
findUinLabels This API is used to find all the UIN labels available for a uin items.
findUinHistory This API is used to find UIN historical information based on search criteria.
generateUins This API generates new Type 2 (Auto Generated Serial Numbers) Universal Identification Numbers without changing store inventory positions.
API: createUin
Create a new unique identification number. Note that the combination of store and item determines the administrative information about a UIN (such as UIN Type).
The newly created UIN will be in "Unconfirmed" status and its transaction type will be "UIN Web Service." To move it into inventory, use inventory adjustment or another transaction.
API Basics
Endpoint URL
{base URL}
Method
POST
Success Response
200 OK
Processing Type
Synchronous
Input
UIN information
Output
UIN confirmation information
Payload
Type
Req
Definition
storeId
Long
X
The identifier of the store.
itemId
String
X
The identifier of the item.
uin
String
X
The universal identification number.
Payload
Type
Definition
itemUinId
Long
The unique identifier to the record.
storeId
Long
itemId
String
uin
String
status
Integer
The current status of the UIN. Valid values are in index.
Example
   "storeId": 5000,,
    "itemId": "100700500",
    "uin": "1234"
API: readUin
API Basics
Endpoint URL
{base URL}/items/{itemId}/{uin}
Method
GET
Success Response
200 OK
Processing Type
Synchronous
Input
Path Parameters Item identifier and UIN
Output
UIN information
Payload
Type
Definition
itemUinId
Long
A unique identifier representing the record in the database.
itemId
String
uin
String
type
Integer
The type of UIN. Valid values are: (1) Serial Number, (2) Auto Generated Serial Number
status
Integer
The current status of the UIN. See Index for valid values.
storeId
Long
transactionType
Integer
The business area that last contained the UIN,
transactionId
String
The transaction id of the transaction containing the UIN.
cartonId
String
The identifier of the carton containing the UIN.
nonsellableTypeId
Long
A non-sellable inventory bucket the UIN was within.
previousStatus
Integer
The previous status of the UIN. Valid values are in index.
previousStoreId
Long
The previous store identifier associated with the previous status.
previousTransactionType
Integer
The previous business area that contained the UIN for that previous status.
previousTransactionId
String
The transaction id of the transaction that previously contained the UIN for that previous status.
previousCartonId
String
The identifier of the carton that previously container the UIN for that previous status.
previousNonsellableTypeId
Long
A non-sellabable inventory bucket the UIN was last within for that previous status.
damaged
Boolean
True if the UIN is damaged, N otherwise.
createDate
Date
The date the UIN was first inserted into the system.
updateDate
Date
The last date the UIN was updated.
createUser
String
The user that first inserted the UIN into the system.
updateUser
String
The user that last updated the UIN in the system.
API: findUins
API Basics
Endpoint URL
{base URL}
Method
GET
Success Response
200 OK
Processing Type
Synchronous
Input
Query Parameters
Output
List of UINs (see ReadUIN API for Data Output)
10,000
Attribute
Type
Definition
storeId
Long
Include only UINs for this store identifier.
itemId
String
Include only UINS for this item
status
Integer
Include only UINs with this current status.
updateDateFrom
Date/String
Include only UINs updated on or after this date.
updateDateTo
Date/String
Include only UINs updated on or before this date.
API: findUinLabels
API Basics
Endpoint URL
{base URL}/labels
Method
GET
Success Response
200 OK
Processing Type
Synchronous
Input
N/A
Output
List of labels
Attribute
Type
Definition
labelId
Long
The unique identifier of the record.
labelCode
String
A unique code that defines the label.
description
String
The description or label associated to the code (not translated).
API: findUinHistory
API Basics
Endpoint URL
{base URL}/histories
Method
GET
Success Response
200 OK
Processing Type
Synchronous
Input
Query parameters
Output
List of UIN history records
10,000
Attribute
Type
Definition
itemId
String
Include only UIN history for this item.
uin
Integer
Include only UIN history for this UIN.
createDateFrom
Date/String
Include only UIN history created on or after this date.
createDateTo
Date/String
Include only UIN history created on or before this date.
Payload
Type
Definition
itemId
String
uin
String
type
Integer
status
Integer
storeId
Long
transactionType
Integer
transactionId
String
cartonId
String
nonsellableTypeId
Integer
createDate
Date
updateDate
Date
createUser
String
updateUser
String
API: generateUins
If the UIN administrative data for the item and store used do not indicate Type 2, an error will be returned.
The new UINs generated will have a status of “Unconfirmed”.
API Basics
Endpoint URL
{base URL}/generate
Method
POST
Success Response
200 OK
Processing Type
Synchronous
Input
UIN generation information
Output
N/A
Payload
Type
Req
Definition
itemId
String
X
storeId
Long
X
quantity
Integer
X
The amount of universal identification numbers to generate.
transactionType
Integer
X
See Index: UIN Functional Area
transactionId
String
A transaction reference identifier.
Example
   "storeId": 5000,
   "itemId": "100663071",
   "uin": "1234",
  "quantity": 5,
    "transactionType": 13
UIN Type
ID
Description
1
Serial Number
2
Auto-Generated Serial Number
UIN Status
ID
Description
1
In Stock
2
Sold
3
Shipped To Warehouse
4
Shipped To Store
5
Reserved For Shipping
6
Shipped To Vendor
7
Removed From Inventory
8
Unavailable
9
Missing
10
In Receiving
11
Customer Order Reserved
12
Customer Order Fulfilled
13
Shipped To Finisher
99
Unconfirmed
UIN Functional Area
ID
Description
1
Warehouse Delivery Receipt
2
Direct Delivery Receipt
3
Create Transfer
4
Dispatch Transfer
5
Receive Transfer
6
Receipt Adjustment
7
Create Return
8
Dispatch Return
9
Inventory Adjustment
10
Stock Count
11
Stock Recount
12
Stock Count Authorized
13
Manual
14
POS Sale
15
POS Return
16
POS Sales Void
17
POS Return Void
18
UIN Web Service
19
Customer Order
20
Direct Delivery ASN Inbound
21
Transfer ASN Inbound
22
Transfer Shipment
REST Service: Manifest
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/manifests
API Definitions
API Description
Close Manifest
Call this method to close all manifested shipments matching the input criteria.
API: Close Manifest
Call this method to close all manifested shipments for the carrier code and carrier services. A processing message is sent to the internal message processing system and the services returns an “Accepted” response. The closing of the manifest will occur later when the message is processed.
API Basics
Endpoint URL
{base URL}/close
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
Criteria
Output
None
Max Response Limit
Attribute
Data Type
Required
Description
carrierCode
String (4)
Yes
A carrier code.
carrierServiceCode
String (6)
Yes
A carrier service code.
trackingNumber
List of Strings (120)
Yes
A list of tracking numbers associated to the contents of the manifest.
shipDate
Date
Indicates all items manifested prior to this date for the carrier have been shipped.
Example Input
        "carrierCode": "O",
        "carrierServiceCode": "O",
        "trackingIds": ["7861","45722"],
        "shipDate":"2022-04-19T23:59:59-05:00"
REST Service: Notification
This page captures the service APIs related to accepting notification from an external system.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/notifications
APIs
API
Description
findNotifications
Find notifications
createNotifications
Create a series of notifications
API: findNotifications
API is used to search for notifications.
Table 4-149 API Basics
Endpoint URL
{base URL}
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
Query parameters
Output
Collection of notifications
Max Response Limit
20,000
Table 4-150 Query Parameters
Attribute
Type
Definition
storeId
Long(10)
Include only records with this store identifier.
notificationType
Integer(4)
Include only records with this notification type.
transactionType
Integer(4)
Include only records with this transaction type.
status
Integer(4)
Include only records with this status.
createDateFrom
Date
Include only records with a create date on or after this date.
createDateTo
Date
Include only records with a create date on or before this date.
Attribute
Type
Definition
notificationId
Long(15)
The unique identifier of the notification.
notificationType
Integer(4)
The type of notification. See Index.
storeId
Long(10)
subject
String(400)
The title or subject of the notification.
message
String(2000)
The message text of the notification.
status
Integer(4)
The current status of the notification.
transactionType
Integer(4)
The type of a transaction associated to the notification. See Index.
transactionId
Long(15)
The identifier of a transaction associated to the notification.
createDate
Date
The date the notification was originally created.
createUser
String(128)
The user that created the notification.
API: createNotifications
Create one or more notifications within the system.
Payload
Type
Req
Definition
notifications
Collection
X
The list of notifications to create.
Table 4-151 Notification
Attribute
Type
Req
Definition
storeId
Long(10)
X
notificationType
Integer(4)
X
subject
String(400)
X
message
String(2000)
X
transactionType
Integer(4)
X
transactionId
Long(15)
X
createDate
Date
The date the notification was originally created. This will default to current date if not supplied.
createUser
String(128)
The user that created the notification. This will default to integration user if not supplied.
Example
Example
Index
Table 4-152 Notification Type
ID
Description
1
Customer Order (New)
2
Customer Order Reauthorization
3
Customer Order Pick Reminder
4
Customer Order Pickup
5
Customer Order Receipt
6
Customer Order Reminder
7
Fulfillment Order Reverse Pick (New)
8
UIN Items on Incoming ASN Failed
9
Return To Vendor Expiration Approaching
10
Transfer Delivery Damaged
11
Transfer Delivery Receiving Discrepancy
12
Transfer Delivery Carton Misdirected
13
Transfer Delivery Overdue
14
Transfer Delivery UIN Discrepancy (From Finisher)
15
16
Transfer Delivery Auto-Receive Failure (From Finisher)
17
Transfer Delivery Auto-Receive Failure (From Warehouse)
18
Transfer Delivery Auto-Receive Failure (From Store)
19
Transfer Request Approved
20
Transfer Request Quantity Unavailable
21
Transfer Request Expiration Approaching
22
Transfer Request Submitted
23
Transfer Request Rejected
24
UIN Store Unexpectedly Altered
25
Vendor Delivery Over Received Quantity
26
Vendor Return Quantity Unavailable
Table 4-153 Transaction Type
ID
Description
1
Customer Order
2
Customer Order Pick
3
Customer Order Delivery
4
Customer Order Reverse Pick
5
Direct Store Delivery Receiving
6
7
Item Basket
8
Return To Vendor
9
Return To Vendor Shipment
10
Shelf Adjustment
11
Shelf Replenishment
12
Shelf Replenishment Gap
13
Stock Count
14
Store Order
15
Transfer
16
Transfer Shipment
17
Transfer Receiving
Table 4-154 Notification Status
ID
Description
1
Unread
2
Read
REST Service: POS Transaction
EICS integrates with POS systems and Sales Audit systems to ensure that the inventory positions are accurate. This is especially important where accurate up-to-date inventory positions are required to reduce customer disappointment when trying to locate items that appear in inventory or delays in filling customer orders. POS is the primary source of sales, returns, void, and some customer order transaction information to EICS. ReSA sends only modified or new POS transaction records to EICS. This service processes the information asynchronously so a short delay may occurs before inventory is updated. As part of the sales processing, EICS updates the inventory depending on the nature of the transaction. The following are the supported transaction types for the sales processing Sale, Return, and Post Void of these transactions. The audit system should not modify the post void transactions. A change to a void is not supported by EICS. Please refer to Sales Integration in the integration guide for more information. Duplicate transactions are prevented by scanning for unique instances of transactions by id, date, and register id. However, it is the responsibility of the calling application to make sure that duplicate transactions are not sent. Even in the case of REST call that fails, any retry or attempt to resend the transaction should have a delayed time period to make sure multiple attempts to transmit or retransmit a transaction does not occur simultaneously.
Service Base URL
The Cloud Service base URL follows the format:
Import POS Transaction
Point-Of-Sale systems may integration transactions to EICS using this service, which imports and processes point-of-sale transactions through an asynchronous process. The service has a default limit of 1,000 total items, though they may be distrubted across any number of transactions. Only one store is allowed across all the transactions sent in a single request. The web service is optimized for speed at greater than 400 items and less than 500 items per service call. The further above or below this optimized point, processing speed will be reduced, and it may take longer for the sales to be recorded in inventory. Since this import is asynchronous, only the basic form of the input is validated prior to the data being captured and processed.
Method
POST
URL
/postransactions
Request
There are no request parameters.
The request body is application/json.
An array of transactions.
Example Value
  "transactions": [
      "storeId": 1234,
      "transactionId": "444-555",
      "transactionTimestamp": "2024-09-11T12:10:53.145Z",
      "custOrderId": "44444",
      "customerOrderComment": "Customer attrived late.",
      "externalUser": "Employee A",
      "items": [
          "itemId": "10000345",
          "quantity": 4,
          "uin": "14000567000",
          "epc": "urn:epc:tag:sgtin-96:1.012345.67890.10478932",
          "reasonCode": 1,
          "dropShip": true,
          "fulfillmentOrderId": "7000",
          "fulfillOrderLineNumber": 2,
          "reservationType": 1,
          "transactionCode": 1,
          "comments": "Item packaging is slightly damaged."
Schema — PosTransactionListIdo
This section describes the POSTransactionListIdo schema.
Table 4-155 PosTransactionListIdo — Object
Element Name Required Data Type/Example Description
transaction
Yes
object
transaction
Table 4-156 PosTransactionIdo — Object
storeId
Yes
number($int10) example: 1234
The unique identifier of the store that is the source of the transaction.
transactionId
Yes
string($text128) example: 444-555
A unique identifier of this point-of-sale transaction. In order for the sales audit process to match and audit a POS transaction that was previously received, the transactionId attribute of the POS transaction must use the same data elements and format as the sales audit file. The sales audit file concatenates the THEAD file line id value, plus a dash separator, plus the THEAD transaction number value. For example, it will appear as 111-222. The transactionId attribute of the imported point-of-sale record must match that value and format.
Yes
string($date-time)
The date and time of the sale transaction.
custOrderId
NA
string($text128) example: 44444
An external customer order identifier. This attribute is required for customer order releated point-of-sale transactions.
NA
string($text512) example: Customer attrived late.
A comment associated with the customer order.
externalUser
NA
string($text128) example: Employee A
User information from the external point-of-sale system.
items
Yes
object
Items
Table 4-157 PosTransactionItemIdo — Object
itemId
Yes
string($text25) example: 10000345
The transaction-level SKU number of the item.
quantity
Yes
number($dec12.4) example: 4
The quantity of the item transacted.
unitOfMeasure
Yes
string($text4) example: EA
The unit of measure of the quantity.
uin
NA
string($text128) example: 14000567000
A unique identifaction number. If not empty, the quantity will be modified to 1.
epc
NA
string($text256) example: urn:epc:tag:sgtin-96:1.012345.67890.10478932
The complete SGTIN-96 Electronic Product Code of the item.
reasonCode
NA
integer($int4) example:1
Reason code associated to the item transaction. This field is required if unavailable sub-buckets system configuration is active and you wish to move unavailable inventory.
dropShip
Yes
Boolean example:true
True if this item is drop ship, false if it is not. Drop ship sales will not impact stock positions.
fulfillmentOrderId
NA
string($text128) example: 7000 If the transaction is associated to a customer order, this is the external fulfillment order identifier.
NA
number($int15) example:2
If the transaction is for a customer order, this is the line number on the order that this item transactions aligns with.
reservationType
NA
If the transaction is a custoemr order, this is the type of reservation. Valid values are:
1 - Web Order
2 - Special Order
3 - Pickup or Delivery
4 - Layaway
5 - On Hold
Enum:[ 1, 2, 3, 4, 5 ]
transactionCode
Yes
integer($int4) example: 1
A code that indicates the transaction event that took place on item. Valid values are:
1 - Sale
2 - Return
3 - Void Sale
4 - Void Return
5 - Order New
6 - Order Fulfill
7 - Order Cancel
Enum: [ 1, 2, 3, 4, 5, 6, 7 ]
comments
NA
string($text512) example: Item packaging is slightly damaged.
Comments associated to this line item of the transaction.
Responses
This section describes the responses of the Import POS Transaction API.
Response Code: 200
Accepted
Response Code: 400
Bad request
The media type is application/json.
See the JSON Error Element and Error Codes section.
REST Service: Product Area
A product area consists of an item basket (group of items) associated to a group of stores. Areas are used within customer order picking and to manage store order restrictions.
Service Base URL
Find Product Areas
This section describes the Find Product Areas API. This API finds up to 1000 product areas for the input criteria.
Method
GET
URL
/productareas
Request Parameters
Table 4-158 Find Product Areas — Request Parameters
Parameter Required Data Type Description
itemBasketId
NA
number($int12) (query)
Include only product areas that are associated to this item basket.
description
NA
Include only product areas with this description.
status
NA
Include only product areas with this status. Valid values are:
1 - In Progress
2 - Completed
3 - Canceled
Available values : 1, 2, 3
type
NA
integer($int2) (query)
Include only product areas with this type. Valid values are
1 - Customer Order Picking
updateDateFrom
NA
Include only product areas with an update date on or after this date.
updateDateTo
NA
Include only product areas with an update date on or before this date.
Responses
This section describes the responses of the Find Product Areas API.
Response Code: 200
The request has been successful.
Example Value
    "productAreaId": 11111,
    "itemBasketId": 211933,
    "description": "Cold Items",
    "status": 1,
    "type": 1,
    "createStoreId": 5000,
    "updateDate": "2024-11-04T14:16:17.231Z",
    "updateUser": "john.smith"
Schema — ProductAreaHeaderIdo
Table 4-159 ProductAreaHeaderIdo — Object
productAreaId
NA
number($int12) example: 11111
The unique identifier of the product area.
itemBasketId
NA
number($int12) example: 211933
The identifier of an item basket associated to the product area.
description
NA
string($text255) example: Cold Items
A description of the product area.
status
NA
The current status of the product area. Valid values are
1 - In Progress
2 - Completed
3 - Canceled
Enum: [ 1, 2, 3 ]
type
NA
The type of the product area. Valid values are:
Enum: [ 1 ]
createStoreId
NA
number($int10) example: 5000
The identifier of the store that created the product area.
updateDate
NA
string($date-time)
The date the product area was last updated.
updateUser
NA
string($text128) example: john.smith
The user that last updated the product area.
Response Code: 400
Bad request
Create Product Area
This section describes the Create Product Area API. This API creates an in-progress product area.
Method
POST
URL
/productareas
Request Parameters
There are no parameters.
Example Value
  "type": 1,
  "stores": [
    5000,
    5001
Schema — ProductAreaCreateIdo
Table 4-160 ProductAreaCreateIdo — Object
itemBasketId
NA
description
NA
type
Yes
Enum:
Array [ 1 ]
createStoreId
Yes
stores
NA
example: List [ 5000, 5001 ]
The stores associated to this product area.
Responses
This section describes the responses of the Create Product Areas API.
Response Code: 200
Example Value
    "status": 1,
    "type": 1
Schema — ProductAreaStatusIdo
Table 4-161 ProductAreaStatusIdo — Object
productAreaId
NA
status
NA
1 - In Progress
2 - Completed
3 - Canceled
Enum:
Array [ 3 ]
type
NA
Enum: Array [ 1 ]
Response Code: 400
Bad request
Read Product Area
This section describes the Read Product Area API. This API retrieves all the details about a product area.
Method
GET
URL
/productareas/{areaId}
Request Parameters
Table 4-162 Read Product Area — Request Parameters
areaId
Yes
number($int12) (path)
Responses
This section describes the responses of the Read Product Areas API.
Response Code: 200
Example Value
    "status": 1,
    "type": 1,
    "createDate": "2024-11-05T11:49:20.419Z",
    "updateDate": "2024-11-05T11:49:20.419Z",
    "updateUser": "smith123",
    "stores": [
      5000,
      5001
Schema — ProductAreaIdo
Table 4-163 ProductAreaIdo — Object
productAreaId
NA
itemBasketId
NA
description
NA
status
NA
1 - In Progress
2 - Completed
3 - Canceled
Enum: [ 1, 2, 3 ]
type
NA
Enum: Array [ 1 ]
createStoreId
NA
createDate
NA
string($date-time)
The date the product area was created.
createUser
NA
string($text128) example: smith123
The user that created the product area.
updateDate
NA
string($date-time)
updateUser
NA
stores
NA
number($int10)] example: List [ 5000, 5001 ]
Response Code: 400
Bad request
Update Product Area
This section describes the Update Product Area API. This API updates a product area.
Method
POST
URL
Request Parameters
Table 4-164 Update Product Area — Request Parameters
areaId
Yes
Item basket details to update.
Example Value
  "stores": [
    5000,
    5001
Schema — ProductAreaUpdateIdo
Table 4-165 ProductAreaUpdateIdo — Object
description
NA
stores
NA
Responses
This section describes the responses of the Update Product Area API.
Response Code: 204
No content.
Response Code: 400
Bad request
Cancel Product Area
This section describes the Cancel Product Area API. This API cancels a product area.
Method
POST
URL
/productareas/{areaId}/cancel
Request Parameters
Table 4-166 Cancel Product Area — Request Parameters
areaId
Yes
Responses
This section describes the responses of the Cancel Product Area API.
Response Code: 204
No content.
Response Code: 400
Bad request
Confirm Product Area
This section describes the Confirm Product Area API. This API confirms the product area making it available for usage.
Method
POST
URL
/productareas/{areaId}/confirm
Request Parameters
Table 4-167 Confirm Product Area — Request Parameters
areaId
Yes
Responses
This section describes the responses of the Confirm Product Area API.
Response Code: 204
No content.
Response Code: 400
Bad request
REST Service: Product Group
This service allows for the integration of product group with external systems.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/productgroups
APIs
API
Description
findProductGroups
Searches for product group summary headers based on input criteria.
readProductGroup
Reads the details about a specific product group.
createProductGroup
Creates a new product group including its components.
updateProductGroup
Modifies an existing product group including its components.
cancelProductGroup
Cancels an existing product group.
API: findProductGroup
This API is used to search for a product group summary using input criteria.
Table 4-168 API Basics
Endpoint URL
{base URL}
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
Query parameters
Output
Collection of product groups
Max Response Limit
5,000
Table 4-169 Query Parameters
Query
Type
Definition
storeId
Long(10)
Returns only product groups that match this store (which includes all store product groups).
type
Integer(3)
Returns only product groups that match this product group type. See Index for types.
description
String(100)
Returns only products groups that contain this text in its description.
itemId
String(25)
Returns only product groups that contain this individual sku number in its single items list.
departmentId
Long(12)
Returns only product groups that contain this hierarchy department identifier.
classId
Long(12)
Returns only product groups that contain this hierarchy class identifier.
subclassId
Long(12)
Returns only product groups that contain this hierarchy subclass identifier.
updateDateFrom
String
Returns only product groups updated on or after this date.
updateDateTo
String
Returns only product groups updated on or before this date.
Table 4-170 Output Data Definitions
Payload
Type
Definition
productGroupId
Long(12)
The unique product group identifier.
description
String(100)
A description of the product group.
storeId
Long(10)
The store identifier or blank if the product group is for all stores.
type
Integer(3)
Indicates the type of product group. See Index.
status
Integer(1)
Indicates the status of the product group. See Index.
updateDate
Date
The date the product group was last updated.
API: readProductGroup
This API is used to read a product group.
Table 4-171 API Basics
Endpoint URL
{base URL}/{productGroupId}
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Path Parameter
The identifier of the product group.
Output
Max Response Limit
5,000
Table 4-172 Output Data Definition
Payload
Type
Definition
productGroupId
Long(12)
The unique identifier of the product group.
description
String(100)
storeId
Long(10)
The unique identifier of a store associated to the product group. This will be blank/null if the product group is for all stores.
type
Integer(3)
status
Integer(1)
unitOfMeasureMode
Integer(4)
Unit of measure type for pick list product groups. See Index.
allItemGroup
Boolean
True indicates the product group is for all items. If set to true, then hierarchies and items will not be present.
updateDate
Date
stockCountDetail
Object
Details about a stock count product group (used for all three stock count types). This will only be populated if the product group type is for a stock count.
replenishmentDetail
Object
Details about a replenishment product group. This will only be populated if the product group type is for replenishment.
storeOrderDetail
Object
Details about a store order product group. This will only be populated if the product group type is for store orders.
autoAdjustmentDetail
Object
Details about an auto inventory adjustment product group. This will only be populated if the product group type is for auto adjustments.
autoTicketPrintDetail
Object
Details about an auto ticket print product group. This will only be populated if the product group type is for auto ticket print.
hierarchies
List<Object>
A list of merchandise item hierarchies that belong to the group.
itemIds
List<String(25)>
A list of item SKU numbers associated to the product group.
Table 4-173 Stock Count Detail
Payload
Type
Definition
countingMethod
Integer
The method of counting a stock count: See Index (StockCountingMethod)
breakdownType
Integer
The method of breaking a stock count down into child counts: See Index (StockCountBreakdownType)
varianceCount
Integer(8)
The number of units in standard unit of measure considered discrepant on a stock count.
variancePercent
BigDecimal(12,4)
The percentage of units in standard unit of measure considered discrepant on a stock count.
varianceValue
BigDecimal(12,4)
The value of units considered discrepant on a stock count. This will only be populated for unit and amount stock count product group type.
performRecount
Boolean
True indicates the stock count should be recounted if discrepancies are found.
autoAuthorize
Boolean
True indicates the stock count should be automatically authorized after count.
activeItems
Boolean
True indicates active items should be included on the stock count.
inactiveItems
Boolean
True indicates inactive items should be included on the stock count.
discontinuedItems
Boolean
True indicates discontinued items should be included on the stock count.
deletedItems
Boolean
True indicates deleted items should be included on the stock count.
zeroStockOnHand
Boolean
True indicates items with 0 stock on hand should be included on the stock count.
positiveStockOnHand
Boolean
True indicates items with positive stock on hand should be included on the stock count.
negativeStockOnHand
Boolean
True indicates items with negative stock on hand should be included on the stock count.
problemLineNegativeAvailable
Boolean
True indicates to include items with negative available quantities. This will only be populated if the product group type is for a problem line stock count.
problemLinePickLessSuggested
Boolean
True indicates to include pick lists less than suggested amount. This will only be populated if the product group type is for a problem line stock count.
problemLineReplenishLessSuggested
Boolean
True indicates to include shelf replenishments that are less than the suggested amount. This will only be populated if the product group type is for a problem line stock count.
problemLineUinDiscrepancy
Boolean
True indicates UIN discrepancies should be included in the stock count. This will only be populated if the product group type is for a problem line stock count.
Table 4-174 Replenishment Detail
Payload
Type
Definition
autoReplenishment
Boolean
True indicates that the product group is eligible for automatic replenishment through a scheduled batch run.
differentiatorMode
Integer(3)
The display type of the diffentiator. See Index.
Table 4-175 Store Order Detail
Payload
Type
Definition
daysBeforeDelivery
Integer(3)
The date calculated from the creation date that the user wants the store order delivery by.
storeOrderAddItems
Boolean
True indicates items can be added to the store order after it has been generated by the system.
storeOrderItemsOnly
Boolean
Y indicates the store order can only include items that are marked as store order replenishment.
restrictSupplierId
Long(12)
Limits the creation of a store order from this product group to only this supplier.
restrictWarehouseId
Long(12)
Limits the creation of a store order from this product group to only this warehouse.
restrictHierarchyId
Long(12)
Limits the creation of a store order from this product group to only this merchandise hierarchy.
restrictAreaId
Long(12)
Limits the creation of a store order from this product group to only this store sequence area.
Table 4-176 Auto Adjustment Detail
Payload
Type
Definition
adjustmentQuantity
BigDecimal(20,4)
The quantity that should be automatically adjusted by this product group.
adjustmentPercent
BigDecimal(20,4)
The percentage of quantity that should be automatically adjusted by this product group.
adjustmentReasonCode
Long(12)
The unique identifier of a reason code associated to this product group.
updateToZero
Boolean
Update stock to zero when generating adjustment with this product group.
Table 4-177 Auto Ticket Print Detail
Payload
Type
Definition
refreshTicketQuantity
Boolean
True if the ticket quantity should be refreshed prior to printing.
Table 4-178 Item Hierarchy Detail
Payload
Type
Definition
departmentId
Long(12)
The department identifier
classId
Long(12)
The class identifier
subclassId
Long(12)
The subclass identifier
API: createProductGroup
This API is used to create a new product group that will be in progress status.
Table 4-179 API Basics
Endpoint URL
{base URL}
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
Product Group
Output
Product Group Status
Max Response Limit
5,000
Table 4-180 Input Data Definition
Payload
Type
Req
Definition
description
String(100)
X
type
Integer(3)
X
storeId
Long(10)
allItems
Boolean
True if the product group is for all items, false otherwise. If all items, any hierarchies and items included will be ignored.
unitOfMeasureMode
Integer
Unit of measure type for pick lists. See Index..
Object
Details about an auto inventory adjustment product group. This is only processed and is required if the type is auto inventory adjustment type.
Object
Details about an auto ticket print product group. This is only processed and is required if the type is auto ticket print.
replenishmentDetail
Object
Details about a replenishment product group. This is only processed and is required if the type is a shelf replenishment type..
storeOrderDetail
Object
Details about a store order product group. This is only processed and is required if the type is the store order type.
unitCountDetail
Object
Details about a unit stock count product group. This is only processed and is required if the type is a stock count type.
unitAmountCountDetail
Object
Details about a unit and amount stock count product group. This is only processed and is required if the type is a stock count type.
problemLineCountDetail
Object
Details about a problem line stock count product group. This is only processed and is required if the type is a stock count type.
hierarchies
List<Object>
A list of up to 5,000 unique merchandise item hierarchies that belong to the group (avoid duplicate or overlapping hierarchies).
itemIds
List<String(25)>
A list of up to 5,000 unique item SKU numbers on the product group.
Table 4-181 Unit Count Detail
Payload
Type
Req
Definition
countingMethod
Integer
X
breakdownType
Integer
X
The method of breaking a stock count down into child counts: See Index (StockCountBreakdownType). Must be "Location" for guided counts.
varianceCount
Integer(8)
The number of units in standard unit of measure considered discrepant on a stock count. Variance count and percent cannot both be empty.
variancePercent
BigDecimal(12,4)
The percentage of units in standard unit of measure considered discrepant on a stock count. Variance count and percent cannot both be empty.
performRecount
Boolean
True indicates the stock count should be recounted if discrepancies are found. This cannot be set to true if the counting method is "Third Party.
autoAuthorize
Boolean
activeItems
Boolean
True indicates active items should be included on the stock count. At least one item status choice is required as true.
inactiveItems
Boolean
True indicates inactive items should be included on the stock count. At least one item status choice is required as true.
discontinuedItems
Boolean
True indicates discontinued items should be included on the stock count. At least one item status choice is required as true.
deletedItems
Boolean
True indicates deleted items should be included on the stock count. At least one item status choice is required as true.
zeroStockOnHand
Boolean
True indicates items with 0 stock on hand should be included on the stock count. At least one stock choice is required as true.
positiveStockOnHand
Boolean
True indicates items with positive stock on hand should be included on the stock count. At least one stock choice is required as true.
negativeStockOnHand
Boolean
True indicates items with negative stock on hand should be included on the stock count. At least one stock choice is required as true.
Table 4-182 Unit and Amount Count Detail
Payload
Type
Req
Definition
countingMethod
Integer
X
breakdownType
Integer
X
varianceCount
BigDecimal(12,4)
The number of units in standard unit of measure considered discrepant on a stock count. Count, percent, and value cannot all be empty.
variancePercent
BigDecimal(12,4)
The percentage of units in standard unit of measure considered discrepant on a stock count. Count, percent, and value cannot all be empty.
varianceValue
BigDecimal(12,4)
The value of units considered discrepant on a stock count. Count, percent, and value cannot all be empty.
performRecount
Boolean
True indicates the stock count should be recounted if discrepancies are found. This cannot be set to true if the counting method is "Third Party".
autoAuthorize
Boolean
zeroStockOnHand
Boolean
Table 4-183 Problem Line Count Detail
Payload
Type
Req
Definition
countingMethod
Integer
X
The method of counting a stock count: See Index (StockCountingMethod).
breakdownType
Integer
X
autoReplenishment
Boolean
differentiatorMode
Integer(3)
The display type of the differentiator. See Index.
varianceCount
BigDecimal(12,4)
variancePercent
BigDecimal(12,4)
performRecount
Boolean
True indicates the stock count should be recounted if discrepancies are found. This cannot be set to true if the counting method is "Third Party."
autoAuthorize
Boolean
negativeStockOnHand
Boolean
negativeAvailable
Boolean
pickLessSuggested
Boolean
replenishLessSuggested
Boolean
uinDiscrepancy
Boolean
Table 4-184 Store Order Detail
Payload
Type
Req
Definition
daysBeforeDelivery
Integer(3)
storeOrderAddItems
Boolean
storeOrderItemsOnly
Boolean
Y indicates can only include items that are marked as store order replenishment.
restrictSupplierId
Long(12)
restrictWarehouseId
Long(12)
restrictHierarchyId
Long(12)
restrictAreaId
Long(12)
Table 4-185 Auto Adjustment Detail
Payload
Type
Req
Definition
adjustmentQuantity
BigDecimal(20,4)
The quantity that should be automatically adjusted by this product group. Either quantity or percent is required.
adjustmentPercent
BigDecimal(20,4)
The percentage of quantity that should be automatically adjusted by this product group. Either quantity or percent is required.
Long(12)
X
updateToZero
Boolean
Table 4-186 Auto Ticket Print Detail
Payload
Type
Req
Definition
Boolean
Table 4-187 Item Hierarchy Detail
Payload
Type
Req
Definition
departmentId
Long(12)
X
classId
Long(12)
subclassId
Long(12)
Table 4-188 Output Data Definition
Attribute
Type
Definition
productGroupId
Long(12)
The product group identifier.
status
Integer(1)
Indicates the status of the product group: (0) Active, (1) Canceled
Figure 4-1 Example input unitCountDetail
Figure 4-2 Example input unitAmountCountDetail:
Figure 4-3 Example input problemLineCountDetail:
Example Input problemLineCountDetail
Figure 4-4 Example input autoAdjustmentDetail:
Figure 4-5 Example input autoTicketPrintDetail:
Figure 4-6 Example input replenishmentDetail:
Figure 4-7 Example input storeOrderDetail:
API: updateProductGroup
This API is used to modify a product group.
See API createProductGroup for the data definition of the product group type data objects.
API Basics
Table 4-189 API Basics
Endpoint URL
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Path Parameter
Input
Product Group
Output
Payload
Type
Req
Definition
storeId
Long(10)
The unique identifier of a store associated to the product group. This will be blank/null if the product group is for all stores. If this is altered for a unit and amount group already assigned to schedules, it may return a validate error that it can no longer be altered.
description
String(100)
X
allItems
Boolean
True if the product group is for all items, false otherwise. If all items, any hierarchies and items included will be ignored. Unit of measure type for pick lists. See Index.
unitOfMeasureMode
Integer
ProductGroupAdjustmentIdo
ProductGroupTicketPrintIdo
replenishmentDetail
ProductGroupReplenishmentIdo
storeOrderDetail
ProductGroupStoreOrderIdo
unitCountDetail
ProductGroupUnitCountIdo
ProductGroupUnitAmountCountIdo
ProductGroupProblemLineCountIdo
hierarchies
ProductGroupHierarchyIdo
A list of up to 5,000 unique merchandise item hierarchies that belong to the group (avoid duplicates or overlapping hierarchies).
itemIds
List<String(25)>
Figure 4-8 Example Input unitCountDetail:
Figure 4-9 Example Input unitAmountCountDetail:
Figure 4-10 Example Input problemLineCountDetail:
Example Input problenLineCountDetail
Figure 4-11 Example Input autoAdjustmentDetail:
Figure 4-12 Example Input autoTicketPrintDetail:
Figure 4-13 Example Input replenishmentDetail:
Figure 4-14 Example Input storeOrderDetail:
API: cancelProductGroup
Cancels the product group.
Table 4-190 API Basics
Endpoint URL
{base URL}/{productGroupId}/cancel
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Path Parameter
Index
Table 4-191 Product Group Type
ID
Description
1
Stock Count: Unit
2
Stock Count: Unit and Amount
3
Stock Count: Problem Line
4
Auto Inventory Adjustment
5
Auto Ticket Print
6
Shelf Replenishment
7
Store Order
Table 4-192 Product Group Status
ID
Description
1
Active
2
Canceled
Table 4-193 Unit of Measure Mode
ID
Description
1
Standard
2
Cases
3
Preferred
Table 4-194 Shelf Replenishment Differentiator Mode
ID
Description
1
Differentiator 1
2
Differentiator 2
3
Differentiator 3
4
Differentiator 4
Table 4-195 Stock Counting Method
ID
Description
1
Guided
2
Unguided
3
Third Party
4
Auto
Table 4-196 Stock Count Breakdown Type
ID
Description
1
Department
2
Class
3
Subclass
4
Location
5
None
REST Service: Product Group Schedule
A product group schedule allows the customer to schedule different kinds of product groups for work. A product group can be scheduled for a date range where the start date must be greater than today. For unit and amount counts, the start date must be greater than today plus the configured stock count lockout days. Schedules are setup daily, weekly, monthly, or yearly. Schedules may be assigned to execute for all stores or created for selected specific stores. Once a product group schedule is created, it becomes available for the system batches to pick up and execute. This service defines operations to manage product group schedule information by integration with an external system.
Service Base URL
Find Schedules
This section describes the Find Schedules API. This API finds up to a maximum of 5,000 schedule summary headers based on input search criteria.
Method
GET
URL
/productgroupschedules
Request Parameters
Table 4-197 Find Schedules — Request Parameters
productGroupId
NA
integer($int10) (query)
Include only schedules associated to this product group.
description
NA
string($text250) (query)
Include only schedules that contain this text in its description.
type
NA
integer($int3) (query)
Include only schedules that match this schedule type. Valid values are:
1 - Daily
2 - Daily By Weekday
3 - Weekly
4 - Monthy by Day
5 - Monthly By Week
6 - Yearly By Day
7 - Yearly By Week
Available values : 1, 2, 3, 4, 5, 6, 7
status
NA
Include only schedules that match this status. Valid values are:
1 - Open
2 - Closed
updateDateFrom
NA
string($date-time) (query)
Include only schedules with an update date on or after this date.
updateDateTo
NA
Include only schedules with an update date on or before this date.
Responses
This section describes the responses of the Find Schedules API.
Response Code: 200
Example Value
    "scheduleId": 11111,
    "productGroupId": 223343,
    "description": "Test Schedule",
    "type": 1,
    "status": 1,
    "startDate": "2024-11-07T11:17:51.016Z",
    "endDate": "2024-11-07T11:17:51.016Z",
    "updateDate": "2024-11-07T11:17:51.016Z"
Schema — ProductGroupScheduleHeaderIdo
Table 4-198 ProductGroupScheduleHeaderIdo — Object
scheduleId
NA
integer($int8) example: 11111
The unique identifier of the schedule.
productGroupId
NA
number($int12) example: 223343
The unique identifier of the product group the schedule is for.
description
NA
string($text250) example: Test Schedule
A description of the schedule.
type
NA
The type of schedule. Valid values are:
1 - Daily
3 - Weekly
4 - Monthly by Day
5 - Monthly By Week
6 - Yearly By Day
7 - Yearly By Week
status
NA
The current status of the schedule. Valid values are:
1 - Open
2 - Closed
Enum: [ 1, 2 ]
startDate
NA
string($date-time)
The date the schedule becomes active.
endDate
NA
string($date-time)
The date the schedule terminates.
updateDate
NA
string($date-time)
The date the schedule was last updated.
Response Code: 400
Bad request
Create Schedule
This section describes the Create Schedule API. This API creates a new open schedule.
Method
POST
URL
Request Parameters
Details about the schedule to create.
Example Value
  "type": 1,
  "startDate": "2024-11-07T11:44:35.142Z",
  "endDate": "2024-11-07T11:44:35.142Z",
  "dailySchedule": {
    "dailyFrequency": 3
  "dailyByWeekSchedule": {
    "weeklyFrequency": 3,
    "sunday": false,
    "monday": false,
    "tuesday": false,
    "wednesday": false,
    "thursday": false,
    "friday": false,
    "saturday": false
  "weeklySchedule": {
    "sunday": false,
    "monday": false,
    "tuesday": false,
    "wednesday": false,
    "thursday": false,
    "friday": false,
    "saturday": false
  "monthlyByDaySchedule": {
    "monthlyFrequency": 6,
    "dayOfMonth": 10
  "monthlyByWeekSchedule": {
    "weekOfTheMonth": 1,
    "dayOfTheWeek": 7
  "yearlyByDaySchedule": {
    "monthOfTheYear": 1,
    "dayOfTheMonth": 20
  "yearlyByWeekSchedule": {
    "dayOfTheWeek": 7
  "stores": [
    333,
    444
Schema — ProductGroupScheduleCreateIdo
Table 4-199 ProductGroupScheduleCreateIdo — Object
productGroupId
yes
description
yes
type
yes
The type of schedule. Only the data set matching this type needs to be included. Valid values are
1 - Daily
3 - Weekly
4 - Monthly by Day
5 - Monthly By Week
6 - Yearly By Day
7 - Yearly By Week
startDate
NA
string($date-time)
The date the schedule becomes active. This must be greater than today.
endDate
NA
string($date-time)
dailySchedule
object
daily schedule
dailyByWeekSchedule
object
daily schedule
weeklySchedule
object
weekly schedule
object
monthly by day schedule
object
monthly by week schedule
yearlyByDaySchedule
object
yearly by day schedule
object
yearly by week schedule
stores
yes
number($int15)] example: List [ 333, 444 ]
A list of store identifiers the schedule applies to.
Table 4-200 ScheduleDailyIdo — Object
dailyFrequency
yes
number ($int12) example: 3
The number of days between occurrences of the schedule.
Table 4-201 ScheduleDailyByWeekIdo — Object
weeklyFrequency
yes
number($int12) example: 3
The number of weeks between occurrences of the schedule.
sunday
NA
boolean example: false
True if scheduled on Sunday.
monday
NA
True if scheduled on Monday.
tuesday
NA
True if scheduled on Tuesday.
wednesday
NA
True if scheduled on Wednesday.
thursday
NA
True if scheduled on Thursday.
friday
NA
True if scheduled on Friday.
saturday
NA
True if scheduled on Saturday.
Table 4-202 ScheduleDailyByWeekIdo — Object
weeklyFrequency
yes
sunday
NA
monday
NA
tuesday
NA
wednesday
NA
thursday
NA
friday
NA
saturday
NA
Table 4-203 ScheduleWeekIyIdo — Object
weeklyFrequency
yes
sunday
NA
monday
NA
tuesday
NA
wednesday
NA
thursday
NA
friday
NA
saturday
NA
Table 4-204 ScheduleMonthlyByDayIdo — Object
monthlyFrequency
yes
number($int12) example: 6
The number of months between occurrences.
dayOfMonth
yes
number($int2) example: 10
The day of the month to execute the schedule on. Valid values are 1-31
Table 4-205 ScheduleMonthlyByWeekIdo— Object
monthlyFrequency
yes
The number of months between occurences.
weekOfTheMonth
yes
The week of the month to execute the schedule on. Valid values are 1-5.
dayOfTheWeek
yes
number($int2) example: 7
The day of the week to execute the schedule on. Valid values are 1-7.
Table 4-206 ScheduleYearlyByDayIdo— Object
monthOfTheYear
yes
The month of the year to execute the schedule on. Valid values are 1-12.
dayOfTheMonth
yes
number($int2) example: 20
The day of the month to execute the schedule on. Valid values are 1-31.
Table 4-207 ScheduleYearlyByWeekIdo — Object
monthOfTheYear
yes
weekOfTheMonth
yes
dayOfTheWeek
yes
Responses
This section describes the responses of the Create Schedules API.
Response Code: 200
Example Value
    "type": 1,
    "status": 1,
Table 4-208 ProductGroupScheduleHeaderIdo — Object
scheduleId
NA
productGroupId
NA
description
NA
type
NA
1 - Daily
3 - Weekly
4 - Monthly by Day
5 - Monthly By Week
6 - Yearly By Day
7 - Yearly By Week
status
NA
1 - Open
2 - Closed
Enum: [ 1, 2 ]
startDate
NA
string($date-time)
endDate
NA
string($date-time)
updateDate
NA
string($date-time)
Response Code: 400
Bad request
Read Schedule
This section describes the Read Schedules API. This API retrieves all the details about a product group schedule.
Method
GET
URL
/productgroupschedules/{scheduleId}
Request Parameters
Table 4-209 Read Schedule — Request Parameters
scheduleId
yes
integer($int12) (path)
Responses
This section describes the responses of the Read Schedule API.
Response Code: 200
Example Value
    "type": 1,
    "status": 1,
    "startDate": "2024-11-11T12:49:09.159Z",
    "endDate": "2024-11-11T12:49:09.159Z",
    "updateDate": "2024-11-11T12:49:09.159Z",
    "dailySchedule": {
      "dailyFrequency": 3
      "sunday": false,
      "monday": false,
      "tuesday": false,
      "wednesday": false,
      "thursday": false,
      "friday": false,
      "saturday": false
    "weeklySchedule": {
      "sunday": false,
      "monday": false,
      "tuesday": false,
      "wednesday": false,
      "thursday": false,
      "friday": false,
      "saturday": false
      "dayOfMonth": 10
      "dayOfTheWeek": 7
      "dayOfTheMonth": 20
      "dayOfTheWeek": 7
    "stores": [
        "storeId": 5000,
        "lastExtractedDate": "2024-11-11T12:49:09.159Z"
Schema — ProductGroupScheduleIdo
Table 4-210 ProductGroupScheduleIdo — Object
scheduleId
NA
productGroupId
NA
description
NA
type
NA
1 - Daily
3 - Weekly
4 - Monthly by Day
5 - Monthly By Week
6 - Yearly By Day
7 - Yearly By Week
Enum:
status
NA
1 - Open
2 - Closed
Enum: [ 1, 2 ]
startDate
NA
string($date-time)
endDate
NA
string($date-time)
updateDate
NA
string($date-time)
The date the schedule was lasted updated.
dailySchedule
NA
object
daily schedule
dailyByWeekSchedule
NA
object
daily by week schedule
weeklySchedule
NA
object
weekly schedule
NA
object
NA
object
yearlyByDaySchedule
NA
object
NA
object
stores
NA
object
A list of stores associated to the schedule.
Table 4-211 ScheduleDailyIdo — Object
dailyFrequency
yes
Table 4-212 ScheduleDailyByWeekIdo — Object
weeklyFrequency
yes
sunday
NA
monday
NA
tuesday
NA
wednesday
NA
thursday
NA
friday
NA
saturday
NA
Table 4-213 ScheduleWeeklyIdo — Object
weeklyFrequency
yes
sunday
NA
monday
NA
tuesday
NA
wednesday
NA
thursday
NA
friday
NA
saturday
NA
Table 4-214 ScheduleMonthlyByDayIdo — Object
weeklyFrequency
yes
dayOfMonth
yes
Table 4-215 ScheduleMonthlyByWeekIdo — Object
weeklyFrequency
yes
weekOfTheMonth
yes
dayOfTheWeek
yes
Table 4-216 ScheduleYearlyByDayIdo — Object
weeklyFrequency
yes
dayOfTheMonth
yes
Table 4-217 ScheduleYearlyByWeekIdo — Object
monthOfTheYear
yes
weekOfTheMonth
yes
dayOfTheWeek
yes
Table 4-218 ProductGroupScheduleStoreIdo — Object
storeId
NA
lastExtractedDate
NA
string($date-time)
The date the schedule was lasted extracted for this store.
Response Code: 400
Bad request
Update Schedule
This section describes the Update Schedule API. This API updates the details of an open schedule.
Method
POST
URL
Request Parameters
Table 4-219 Update Schedule — Request Parameters
scheduleId
yes
Details to update within the schedule.
Example Value
  "type": 1,
  "endDate": "2024-11-11T14:08:23.049Z",
  "dailySchedule": {
    "dailyFrequency": 3
    "sunday": false,
    "monday": false,
    "tuesday": false,
    "wednesday": false,
    "thursday": false,
    "friday": false,
    "saturday": false
  "weeklySchedule": {
    "sunday": false,
    "monday": false,
    "tuesday": false,
    "wednesday": false,
    "thursday": false,
    "friday": false,
    "saturday": false
    "dayOfMonth": 10
    "dayOfTheWeek": 7
    "dayOfTheMonth": 20
    "dayOfTheWeek": 7
  "stores": [
    333,
    444
Schema — ProductGroupScheduleUpdateIdo
Table 4-220 ProductGroupScheduleUpdateIdo — Object
description
yes
type
yes
1 - Daily
3 - Weekly
4 - Monthly by Day
5 - Monthly By Week
6 - Yearly By Day
7 - Yearly By Week
endDate
NA
string($date-time)
It must be greater than the start date.
dailySchedule
NA
object
daily schedule
dailyByWeekSchedule
NA
object
weeklySchedule
NA
object
weekly schedule
NA
object
NA
object
yearlyByDaySchedule
NA
object
NA
object
yearly by week scheulde
stores
yes
Table 4-221 ScheduleDailyIdo — Object
dailyFrequency
yes
Table 4-222 ScheduleDailyByWeekIdo — Object
weeklyFrequency
yes
sunday
NA
monday
NA
tuesday
NA
wednesday
NA
thursday
NA
friday
NA
saturday
NA
Table 4-223 ScheduleWeeklyIdo — Object
weeklyFrequency
yes
sunday
NA
monday
NA
tuesday
NA
wednesday
NA
thursday
NA
friday
NA
saturday
NA
Table 4-224 ScheduleMonthlyByDayIdo — Object
weeklyFrequency
yes
dayOfMonth
yes
Table 4-225 ScheduleMonthlyByWeekIdo — Object
weeklyFrequency
yes
weekOfTheMonth
yes
dayOfTheWeek
yes
Table 4-226 ScheduleYearlyByDayIdo — Object
weeklyFrequency
yes
dayOfTheMonth
yes
Table 4-227 ScheduleYearlyByWeekIdo — Object
monthOfTheYear
yes
weekOfTheMonth
yes
dayOfTheWeek
yes
Responses
This section describes the responses of the Update Schedule API.
Response Code: 204
No content
Response Code: 400
Bad request
Delete Schedule
This section describes the Delete Schedule API. This API deletes a schedule from the system.
Method
DELETE
URL
Request Parameters
Table 4-228 Delete Schedule — Request Parameters
scheduleId
yes
Responses
This section describes the responses of the Delete Schedule API.
Response Code: 204
No content
Response Code: 400
Bad request
REST Service: Purchase Order
A purchase order is a document that indicates items and quantities that have been ordered for delivery to the store within a specific timeframe. The order can be created by the supplier or store user on the fly or alternatively by corporate users. These are used for Direct Store Delivery (or vendor/supplier deliveries). This service allows the direct integration of customer orders from a third party system as well as some management of the order with the system.
Service Base URL
The Cloud service base URL follows the format:
Find Orders
This section describes the Find Orders API. This API finds up to 5,000 purchase orders headers for the input criteria. No item information is returned.
Method
GET
URL
/purchaseorders
Request Parameters
Table 4-229 Find Orders — Request Parameters
orderNumber
NA
string($text128) (query)
Include only purchase orders associated to this external order number.
storeId
NA
number($int10) (query)
Include only purchase orders for this store.
supplierId
NA
Include only purchase orders for this supplier.
status
NA
integer($int4) (query)
Include only purchase orders in this status. Valid values are:
1 - Approved
2 - In Progress
3 - Canceled
4 - Completed
99 - Active
Available values : 1, 2, 3, 4, 99
updateDateFrom
NA
Include only purchase orders with an update date on or after this date.
updateDateTo
NA
Include only purchase orders with an update date on or before this date.
Responses
This section describes the responses of the Find Orders API.
Response Code: 200
Example Value
    "purchaseOrderId": 11111,
    "orderNumber": "4823534",
    "storeId": 5000,
    "supplierId": 5101,
    "status": 1,
    "customerOrderId": "799003",
    "fulfillmentOrderId": "7994203",
    "notBeforeDate": "2025-01-02T09:18:14.032Z",
    "notAfterDate": "2025-01-02T09:18:14.032Z",
    "updateDate": "2025-01-02T09:18:14.032Z",
    "completeDate": "2025-01-02T09:18:14.032Z"
Schema — PurchaseOrderHearderIdo
Table 4-230 PurchaseOrderHearderIdo— Object
purchaseOrderId
NA
The unique identifier of the purchase order.
orderNumber
NA
string($text128) example: 4823534
The non-unique order number of the purchase order in an external system.
storeId
NA
The identifier of the store receiving the inventory.
supplierId
NA
number($int10) example: 5101
The identifier of the supplier shipping the goods.
status
NA
The current status of the purchase order. Valid values are:
1 - Approved
2 - In Progress
3 - Canceled
4 - Completed
Enum: [ 1, 2, 3, 4 ]
customerOrderId
NA
string($text128) example: 799003
A customer order identifier if associated to a customer order.
fulfillmentOrderId
NA
string($text128) example: 7994203
A fulfillment order identifier if associated to a customer order.
notBeforeDate
NA
string($date-time)
 Earliest date that the inventory should arrive at the store for this order.
notAfterDate
NA
string($date-time)
Latest date that the inventory can arrive at the store for this order.
updateDate
NA
string($date-time)
The date the purchase order was last updated.
completeDate
NA
string($date-time)
The date the purchase order was completed.
Response Code: 400
Bad request
Read Order By ID
This section describes the Read Order By ID API. This API reads a store level purchase order by its unique system identifier. This operation retrieves the full information of the purchase order within the context of the store including items and quantities.
Method
GET
URL
/replenishgaps/{gapId}
Request Parameters
Table 4-231 Read Order By ID — Request Parameters
purchaseOrderId
yes
The unique EICS identifier of the purchase order.
Responses
This section describes the responses of the Read Order By ID API.
Response Code: 200
Example Value
    "storeId": 5000,
    "supplierId": 5101,
    "status": 1,
    "externalStatus": 1,
    "notBeforeDate": "2025-01-02T09:59:21.146Z",
    "notAfterDate": "2025-01-02T09:59:21.146Z",
    "comments": "Summer product pre-order",
    "source": "POXD",
    "createUser": "smith123",
    "createDate": "2025-01-02T09:59:21.146Z",
    "updateDate": "2025-01-02T09:59:21.146Z",
    "completeDate": "2025-01-02T09:59:21.146Z",
    "lineItems": [
        "lineId": 11111,
        "itemId": "11111",
        "supplierCountryCode": "US",
        "supplierCaseSize": 5,
        "quantityOrdered": 20,
        "quantityReceived": 20,
        "unitCostCurrency": "USD",
        "unitCostValue": 10,
        "preferredUom": "LBS",
        "published": true
Schema — PurchaseOrderIdo
Table 4-232 PurchaseOrderIdo — Object
purchaseOrderId
 NA
orderNumber
NA
storeId
NA
supplierId
 NA
status
NA
1 - Approved
2 - In Progress
3 - Canceled
4 - Completed
externalStatus
 NA
The current status of the purchase order in the originating system. Valid values are:
1 - Worksheet
2 - Submitted
3 - Approved
4 - Closed
notBeforeDate
 NA
string($date-time)
notAfterDate
NA
string($date-time)
comments
 NA
string($text2000) example: Summer product pre-order
Comments associated to the purchase order.
customerOrderId
 NA
fulfillmentOrderId
NA
source
NA
string($text25) example: POXD
Text indicating the system that originated the purchase order.
createUser
 NA
The user that created the purchase order within the system.
createDate
NA
string($date-time)
The date the purchase order was created within the system.
updateDate
 NA
string($date-time)
completeDate
NA
string($date-time)
lineItems
NA
object
A collection of line items on the purchase order.
Table 4-233 PurchaseOrderLineItemIdo — Object
lineId
 NA
number($int15) example: 11111
The unique identifier of the line item record.
itemId
 NA
string($text25) example: 11111
The unique identifier of the item.
supplierCountryCode
 NA
string($text3) example: US
The country code of the supplier country of origin.
supplierCaseSize
 NA
number($decimal(10,2)) example: 5
The case size coming from the supplier.
quantityOrdered
NA
number($decimal(20,4)) example: 20
The number of units (in standard unit of measure) expected to be delivered to the store.
quantityReceived
 NA
The number of units (in standard unit of measure) received to date against the order.
unitCostCurrency
 NA
string($text3) example: USD
The unit cost ISO currency code.
unitCostValue
NA
number($decimal(12,4)) example: 10
The unit cost value of the line item.
preferredUom
NA
string($text4) example: LBS
The preferred unit of measure of the line item.
published
 NA
boolean example: true
True indicates the line item has been published out to an exteral system, false otherwise. This is used when the purchase order originates within EICS.
Response Code: 400
Bad request
Read Order
This section describes the Read Order API. This API reads a store level purchase order by its external identifier. This operation retrieves the full information of the purchase order within the context of the store including items and quantities.
Method
GET
URL
/purchaseorders/{orderNumber}/{storeId}
Request Parameters
Table 4-234 Read Order — Request Parameters
orderNumber
yes
string($text128) (path)
The external identifier of the purchase order.
storeId
yes
number ($int10) (path)
The store identifier of the purchase order.
Responses
This section describes the responses of the Read Order API.
Response Code: 200
Example Value
    "storeId": 5000,
    "supplierId": 5101,
    "status": 1,
    "notBeforeDate": "2025-01-02T10:32:05.695Z",
    "notAfterDate": "2025-01-02T10:32:05.695Z",
    "source": "POXD",
    "createDate": "2025-01-02T10:32:05.695Z",
    "updateDate": "2025-01-02T10:32:05.695Z",
    "completeDate": "2025-01-02T10:32:05.695Z",
    "lineItems": [
        "lineId": 11111,
        "itemId": "11111",
        "published": true
Table 4-235 PurchaseOrderIdo — Object
purchaseOrderId
 NA
orderNumber
NA
storeId
NA
supplierId
 NA
status
NA
1 - Approved
2 - In Progress
3 - Canceled
4 - Completed
externalStatus
 NA
1 - Worksheet
2 - Submitted
3 - Approved
4 - Closed
notBeforeDate
 NA
string($date-time)
notAfterDate
NA
string($date-time)
comments
 NA
customerOrderId
 NA
fulfillmentOrderId
NA
source
NA
createUser
 NA
createDate
NA
string($date-time)
updateDate
 NA
string($date-time)
completeDate
NA
string($date-time)
lineItems
NA
object
Table 4-236 PurchaseOrderLineItemIdo — Object
lineId
 NA
itemId
 NA
supplierCountryCode
 NA
supplierCaseSize
 NA
quantityOrdered
NA
quantityReceived
 NA
unitCostCurrency
 NA
unitCostValue
NA
preferredUom
NA
published
 NA
Response Code: 400
Bad request
Close Order
This section describes the Close Order API. This API closes an existing purchase order. An already closed order will ignore the request and successfully return. If a store is not managed and the system is not configured to override, the request will also be ignored. If quantities are already received, the purchase order will go to completed status, otherwise it will be cancelled. A forbidden error response will occur if the application is integrated with Oracle Merchandising.
Method
POST
URL
/purchaseorders/{orderNumber}/close
Request Parameters
Table 4-237 Close Order— Request Parameters
orderNumber
yes
The external order number of the purchase order.
Responses
This section describes the responses of the Close Order API.
Response Code: 204
No content
Response Code: 400
Bad request
Import Order
This section describes the Import Order API. This API imports of approved purchase orders ared is staged and processed asynchronously by the MPS work queue DcsOrder. If the order number exists already, the order will be treated as an update. If the order number does not exist, a new order will be created. If a record for item and store combination is found for an item, then the item will be updated, otherwise a new line item will be created for the item-store combination. Items cannot be removed from already existing purchase orders, however, their ordered quantity can be reduced to zero. If the system is integrated with Oracle Merchandising, then this operation will return a Forbidden response. As an asynchronous service, minimal validation will be done prior to submitting the information for later processing. Business validation that fails during asynchronous processing can be found along with the processing message in the MPS staged message table.
Method
POST
URL
/purchaseorders/{orderNumber}/import
Request Parameters
Table 4-238 Import Order— Request Parameters
orderNumber
yes
Example Value
  "supplierId": 5101,
  "notBeforeDate": "2025-01-02T11:14:26.297Z",
  "notAfterDate": "2025-01-02T11:14:26.297Z",
  "unitCostCurrency": "799003",
  "source": "POXD",
  "lineItems": [
      "itemId": "11111",
      "storeId": 5000,
      "unitCost": 10,
      "published": true
Schema — PurchaseOrderImportIdo
Table 4-239 PurchaseOrderImportIdo — Object
supplierId
Yes
externalStatus
Yes
1 - Worksheet
2 - Submitted
3 - Approved
4 - Closed
notBeforeDate
 NA
string($date-time)
notAfterDate
 NA
string($date-time)
unitCostCurrency
Yes
string($text3) example: 799003
The currency code of the unit costs of the items on this purchase order.
customerOrderId
NA
A customer order identifier if associated to a customer order. This is only accepted only when the purchase order is originally created and will not be modified on an update.
fulfillmentOrderId
 NA
A fulfillment order identifier if associated to a customer order. This is accepted only when the purchase order is originally created and will not be modified on an update.
source
 Yes
Text indicating the system that originated the purchase order. This is only used when the purchase order is originally created and will not be modified on an update.
comments
 NA
lineItems
Yes
object
Table 4-240 PurchaseOrderImportItemIdo — Object
itemId
Yes
storeId
 Yes
supplierCountryCode
 Yes
The country code of the supplier country of origin. This value will be ignored on an update of the item/store combination.
supplierCaseSize
NA
quantityOrdered
 Yes
unitCost
 NA
preferredUom
NA
published
NA
Responses
This section describes the responses of the Import Order API.
Response Code: 202
Accepted
Response Code: 400
Bad request
REST Service: Reason Code
This service allows and external system to retrieve available reason codes. Reason codes are attached to inventory adjustments or shipments.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/ reasoncodes
API Definitions
API Description
Find Adjustment Reason Codes
Finds reason codes available for inventory adjustments.
Find Shipment Reason Codes
Finds reason codes available for shipments.
API: Find Adjustment Reason Codes
This API is used to find reason codes available for inventory adjustments.
API Basics
Endpoint URL
{base URL} /adjustments
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
None
Output
List of inventory adjustment reasons
Max Response Limit
N/A
Attribute
Data Type
Description
reasonId
Long
The unique identifier of the inventory adjustment reason code.
reasonCode
Integer
Unique reason code associated to external systems.
description
String
A description of the inventory reason code.
dispositionCode
Integer
The inventory disposition associated to the code.
dispositionDescription
String
A description of the inventory disposition associated to the code (not translated).
fromNonSellableType
Long
From unavailable sub-bucket (indicates the sub-bucket of disposition of stock movement)
fromNonSellableTypeDescription
String
The description of the from unavailable sub-bucket (not translated).
toNonSellableType
Long
To unavailable sub-bucket (indicates the sub-bucket of disposition of stock movement)
toNonSellableTypeDescription
String
The description of the to unavailable sub-bucket (not translated).
systemRequired
Boolean
True indicates the reason code is required for the system to function. A system required reason code cannot be deactivated.
displayable
Boolean
True indicates the reason code can be used by a transactional inventory adjustment created by an entity other than EICS internal service.
publish
Boolean
True indicating inventory movements with this reason code should be published to external systems
Example Input
"reasonId": 1,
"reasonCode": 1,
"description": “invAdjReason.1",
"dispositionCode": 4,
"dispositionDescription": "inventoryDisposition.ATS-DIST",
"systemRequired": true,
"displayable": false,
"publish": true
"reasonId": 2,
"reasonCode": 81,
"description": "invAdjReason.81",
"systemRequired": false,
"displayable": true,
"publish": true
API: Find Shipment Reason Codes
Finds all the reason codes in the system available for any type of shipment. You can use properties of the reason code to determine if it is available for usage on a particular transaction.
API Basics
Endpoint URL
{base URL} /shipments
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
None
Output
List of reasons codes
Max Response Limit
N/A
Attribute
Data Type
Description
reasonId
Long
reasonCode
String
description
String
A description of the inventory reason code (not translated).
type
Integer
The Shipment Reason Code Type: See the Shipment Reason Code Type.
A reason code can only be used on a transaction that matches its type. For example, 3 – Warehouse can only be used on a store to warehouse shipment.
useAvailable
Boolean
True if it must use available inventory, false indicates it must use unavailable inventory. The reason code will need to match the type of inventory being shipped.
nonSellableTypeId
Long
An identifier of associated unavailable sub-bucket (indicates the sub-bucket of disposition of stock movement)
Example Input
"reasonId": 1,
"reasonCode": "F",
"description": "shipmentReason.4.F",
"type": 4,
"useAvailable": true
“reasonId": 2,
"reasonCode": "O",
"description": "shipmentReason.4.O",
"type": 4,
"reasonId": 3,
"reasonCode": "U",
"description": "shipmentReason.4.U",
"type": 4,
"useAvailable": false,
"nonSellableTypeId": 1
Additional Data Definitions
Value
Definition
1
Store
2
Supplier
3
Warehouse
4
Finisher
5
Customer
RFID
If the point-of-sale record for an item includes an RFID tag, the tag will be moved to a SOLD status indicating it should be out-of-store.
Service Base URL
Find Zones
This section describes the Find Zones API. This API finds RFID zones by location type and identifier.
Method
GET
URL
/rfids/zones
Request Parameters
Table 4-241 Find Zones — Request Parameters
locationType
NA
Include only zones with this location type. Valid values are:
1 — Store
2 —Warehouse
locationId
NA
Include only zones within this locaiton.
Responses
This section describes the responses of the Find Zones API.
Response Code: 200
Example Value
    "zoneId": 11111,
    "locationType": 1,
    "locationId": 5000,
    "externalId": 789012,
    "zoneType": 1,
    "description": "Front Sale Counter"
Schema —RfidZoneIdo
Table 4-242 RfidZoneIdo — Object
zoneId
NA
The unique identifier of the zone.
locationType
 NA
integer($int2) example: 1
The type of location of the zone. Valid values are:
1 - Store
2 - Warehouse
Enum: [ 1, 2 ]
locationId
 NA
The unique identifier of the location.
externalId
 NA
number($int15) example: 789012
A unique identifier of the zone in an extrenal system.
zoneType
 NA
The zone type. Valid values are:
1 - Shopfloor
2 - Backroom
3 - None
Enum: [ 1, 2, 3 ]
description
 NA
string($text255) example: Front Sale Counter
A description of the RFID scanning zone.
Response Code: 400
Bad request
Create Zone
This section describes the Create Zone API. This API create a new RFID zone.
Method
POST
URL
/rfids/zones
Request Parameters
The details of the new zone.
Example Value
  "locationType": 1,
  "locationId": 5000,
  "zoneType": 1,
Schema — RfidZoneIdo
Table 4-243 RfidZoneCreateIdo — Object
locationType
Yes
1 - Store
2 - Warehouse
Enum: [ 1, 2 ]
locationId
Yes
externalId
 NA
A unique identifier of the zone in an external system.
zoneType
Yes
1 - Shopfloor
2 - Backroom
3 - None
Enum: [ 1, 2, 3 ]
description
 NA
Responses
This section describes the responses of the Create Zone API.
Response Code: 200
Example Value
    "zoneId": 11111,
    "locationType": 1,
    "locationId": 5000,
    "zoneType": 1,
Schema —RfidZoneIdo
Table 4-244 RfidZoneIdo — Object
zoneId
NA
locationType
 NA
1 - Store
2 - Warehouse
Enum: [ 1, 2 ]
locationId
 NA
externalId
 NA
zoneType
 NA
1 - Shopfloor
2 - Backroom
3 - None
Enum: [ 1, 2, 3 ]
description
 NA
Response Code: 400
Bad request
Update Zone
This section describes the Update Zone API. This API updates an existing RFID zone.
Method
POST
URL
/rfids/zones/{zoneId}
Request Parameters
Table 4-245 Update Zone — Request Parameters
zoneId
yes
The unique identifier of the RFID zone.
The details to update about the zone.
Example Value
  "zoneType": 1,
Schema — RfidZoneUpdateIdo
Table 4-246 RfidZoneUpdateIdo — Object
externalId
NA
zoneType
yes
1 - Shopfloor
2 - Backroom
3 - None
Enum: [ 1, 2, 3 ]
description
NA
Responses
This section describes the responses of the Update Zone API.
Response Code: 204
No content
Response Code: 400
Bad request
Delete Zone
This section describes the Delete Zone API. This API deletes an RFID zone.
Method
DELETE
URL
/rifds/zones/{zoneId}/delete
Request Parameters
Table 4-247 Delete Zone — Request Parameters
zoneId
yes
Responses
This section describes the responses of the Delete Zone API.
Response Code: 204
No content
Response Code: 400
Bad request
Import Events
This section describes the Import Events API. This API processes up to 1,500 Radio Frequency Identification based events. This processing will update the tag information based on the event as well as the stock on hand positions for the item. Events should be sent in groups of 50-100 at a time for optimal processing speed..
Method
POST
URL
/rfids/events
Request Parameters
The request type is application/json.
Details about the events to import.
Example Value
  "events": [
      "locationType": 1,
      "locationId": 5000,
      "itemId": "100637120",
      "epc": "8347492243434",
      "zoneId": 11111,
      "eventType": "OBSERVE",
      "eventDate": "2024-11-12T10:28:01.725Z"
Schema — RfidEventListIdo
Table 4-248 RfidEventListIdo — Object
events
yes
object
Events
Table 4-249 RfidEventIdo — Object
locationType
yes
1 - Store
2 - Warehouse
Enum: [ 1, 2 ]
locationId
yes
itemId
yes
string($text25) example: 100637120
The identifier of the item on the RFID tag.
epc
yes
string($text255) example: 8347492243434
The electronic product code (SGTIN-96) of the RFID tag.
zoneId
NA
The unique identifier of the zone the tag is in.
eventType
yes
string($text7) example: OBSERVE
The type of the event. Valid values are:
ADD - Indicates a new tag at the facility
DELETE - Indicates deactivation at a facility
OBSERVE - Indicates tag is present at the facility
eventDate
yes
string($date-time)
The date and time the scan event occurred.
Responses
This section describes the responses of the Import Event API.
Response Code: 204
No content
Response Code: 400
Bad request
REST Service: Security
This service provides an end point for the management of security information within SIOCS.
Service Base URL
Scope To Be Used
Security services are protected by the security scope, so to obtain a token use this scope - rgbu:siocs:security-<ENV>.
API Definitions
Table 4-250 Security API Definitions
API
Description
Import Users
Imports a collection of user security information changes and processes them synchronously. This allows up to 2,000 users.
Delete Users
Deletes security information for the specified users within SIOCS.
API: Import Users
Table 4-251 API Basics
Endpoint URL
/security/import/users
Method
POST
Successful Response
202 Accepted
Processing Type
synchronous
Input
Query parameters
Output
N/A
Max Response
2000
Table 4-252 Input Data Definition
Parameter
Format
Required
Definition
users
array
No
A list of security changes to import. See below:
Security Changes to Import
userName
string(text128)
Yes
The user name of the user.
addedStores
array[Integer](int10)
No
The stores to be added to the user.
removedStores
No
The stores to be removed from the user.
addedRoles
array
No
The roles to be assigned to the user:
roleName — The name of the role, string(text128), required
storeId — The identifier of the store for a specific store assignment, or no value for assignment applying to all allowed stores., BigDecimal(int10), optional
startDate — The date the role assignment should start to be allowed., date-time, optional
endDate — The date the role assignment should stop being allowed., date-time, optional
removedRoles
array
No
The role assignments to be removed from the user:
Example Input ImportUsers
  "users": [
      "userName": "abc",
      "addedStores":[1000, 2000],
      "removedStores":[1001, 2001],
      "addedRoles": [
          "roleName": "role_a",
          "storeId": 3000,
          "endDate": "2032-11-19T23:59:59-05:00"
          "roleName": "role_c",
          "startDate": "2022-11-19T23:59:59-05:00"
          "roleName": "role_e",
      "removedRoles": [
          "storeId": 3001
          "roleName": "role_d"
Table 4-253 Responses
Code
Description
202
Accepted
400
Bad Request
Example:
    "errors": [
        "code": 1,
        "description": "AN_ERROR_TOOK_PLACE",
        "dataElement": "item",
        "dataValue": "1234",
        "referenceElement": "store",
        "referenceValue": "123"
API: Delete Users
Table 4-254 API Basics
Endpoint URL
/security/users/delete
Method
POST
Successful Response
202 Accepted
Processing Type
Input
Query parameters
Output
N/A
Max Response
Table 4-255 Query Parameter Definitions
Property
Format
Required
Definition
userNames
string(text128)
Yes
A list of user names to delete information for.
Example:
  "userNames": [
    "user123",
    "user456"
Table 4-256 Responses
Code
Description
202
Accepted
400
Bad Request
Example:
    "errors": [
        "code": 1,
REST Service: Shelf Adjustment
A shelf adjustment moves quantities between locations within the store. A shelf adjustment to move to back room will move quantities from the shop floor to the back room. A shelf adjustment to update the shop floor will update the shop floor positions with the adjustment quantity. A shelf adjustment to update the backroom will adjust the back room quantities.
Service Base URL
Find Adjustment
This section describes the Find Adjustment API. This API finds up to 1,500 shelf adjustments headers for the input criteria.
Method
GET
URL
/shelfadjustments
Request Parameters
Table 4-257 Find Adjustment — Request Parameters
storeId
NA
Include only adjustments for this store.
status
NA
Include only adjustments with this status. Valid values are:
1 - In Progress
2 - Complete
type
NA
Include only adjustments with this type. Valid values are:
1 - Move To Backroom
2 - Update Shopfloor
3 - Update Backroom
itemId
NA
string($text25) (query)
Include only shelf adjsutments with this item.
userName
NA
Include only shelf adjsutments with this username.
updateDateFrom
NA
Include only adjustments with an update date on or after this date.
updateDateTo
NA
Include only adjustments with an update date on or before this date.
Responses
This section describes the responses of the Find Adjustment API.
Response Code: 200
Example Value
    "adjustmentId": 11111,
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "userName": "smith123",
    "createDate": "2025-01-03T13:12:18.180Z",
    "updateDate": "2025-01-03T13:12:18.180Z"
Schema — ShelfAdjustmentHeaderIdo
Table 4-258 ShelfAdjustmentHeaderIdo— Object
Element Name Required Data Type/Example Description
adjustmentId
 NA
The unique identifier of the shelf adjustment.
storeId
 NA
The store of the shelf adjustment.
type
 NA
integer($int4) example: 1
The type of shelf adjustment. Valid values are
3 - Update Backroom
Enum: [ 1, 2, 3 ]
status
 NA
The current status of the shelf adjustment. Valid values are
1 - In Progress
2 - Complete
Enum:
[ 1, 2 ]
userName
NA
The name of the user that last updated the shelf adjustment.
createDate
 NA
string($date-time)
The date the shelf adjustment was created.
updateDate
 NA
string($date-time)
The date the shelf adjustment was last updated.
Response Code: 400
Bad request
The media type is application/json.
See the JSON Error Element and Error Codes section.
Create Adjustment
This API creates an in progress shelf adjustment.
Method
POST
URL
/shelfadjustments
Request Parameters
There are no request parameters.
The request body is application/json.
The details of the new shelf adjustment.
Example Value
  "storeId": 5000,
  "type": 1,
  "lineItems": true
Schema — ShelfAdjustmentCreateIdo
Table 4-259 ShelfAdjustmentCreateIdo — Object
storeId
Yes
type
Yes
The type of shelf adjustment. Valid values are:
3 - Update Backroom
Enum: [ 1, 2, 3 ]
lineItems
Yes
object
A collection of line items on the shelf adjustment.
Table 4-260 ShelfAdjustmentCreateItemIdo — Object
itemId
Yes
caseSize
NA
number($decimal(10,2)) example: 1
The case size of the item for this record.
quantity
Yes
number($decimal(12,4)) example: 20
The quantity to adjust.
Responses
This section describes the responses of the Create Adjustment API.
Response Code: 200
The request has been successful.
Example Value
    "storeId": 5000,
    "type": 1,
    "status": 1
Schema — ShelfAdjustmentStatusIdo
Table 4-261 ShelfAdjustmentStatusIdo — Object
adjustmentId
NA
storeId
NA
type
NA
3 - Update Backroom
Enum: [ 1, 2, 3 ]
status
The current status of the shelf adjustment. Valid values are:
1 - In Progress
2 – Complete
Enum: [ 1, 2 ]
Response Code: 400
Bad request
Read Adjustment
This API retrieves all the details about a shelf adjustment.
Method
GET
URL
/shelfadjustments/{adjustmentId}
Request Parameters
Table 4-262 Read Adjustment— Request Parameters
Parameter Required Data Type Description
adjustmentId
Yes
number ($int15)
(path)
Responses
This section describes the responses of the Read Adjustment API.
Response Code: 200
Example Value
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "createDate": "2025-01-08T11:10:30.977Z",
    "updateDate": "2025-01-08T11:10:30.977Z",
    "lineItems": [
        "lineId": 11111,
        "itemId": "11111",
        "caseSize": 1,
        "quantity": 20
Table 4-263 ShelfAdjustmentStatusIdo — Object
adjustmentId
NA
storeId
NA
number($int10) example: 5000
type
NA
3 - Update Backroom
Enum: [ 1, 2, 3 ]
status
1 - In Progress
2 – Complete
Enum: [ 1, 2 ]
Response Code: 400
Bad request
Update Adjustment
This section describes the Update Adjustment API. This API updates an active shelf adjustment.
Method
POST
URL
Request Parameters
Table 4-264 Update Adjustment— Request Parameters
adjustmentId
yes
integer($int15)
(path)
Shelf adjustment details to update.
Responses
This section describes the responses of the Update Adjustment API.
Response Code: 204
No Content
Response Code: 400
Bad request
Confirm Adjustment
This section describes the Confirm Adjustment API. This API confirms a shelf adjustment updating the appropriate quantities of inventory position depending on the type of shelf adjustment.
Method
POST
URL
/shelfadjustments/{adjustmentId}/confirm
Request Parameters
Table 4-265 Confirm Adjustment — Request Parameters
adjustmentId
yes
integer($int12)
(path)
Responses
This section describes the responses of the Confirm Adjustment API.
Response Code: 204
No Content
Response Code: 400
Bad request
Delete Adjustment
This section describes the Delete AdjustmentAPI. This API deletes a shelf adjustment.
Method
POST
URL
/shelfadjustments/{adjustmentId}/delete
Request Parameters
Table 4-266 Delete Adjustment — Request Parameters
adjustmentId
yes
integer($int12)
(path)
Responses
This section describes the responses of the Delete Adjustment API.
Response Code: 204
No Content
Response Code: 400
Bad request
REST Service: Shelf Replenishment
The replenishment process attempts to ensure that the shop floor inventory is set at a level best suited for enticing customers to buy a product and to prevent empty shelves. Shelf replenishment functionality within the mobile application is related to the movement of goods from the back room to the shop floor and shop floor to back room. For example, when a certain soda quantity is low, you can initiate a replenishment process so that more of the soda is moved from the back room. Similarly, if there is excess stock on the shop floor, the mobile application supports processes to move inventory to the back room. Some of the processes require capacity setup and some form of plan-o-gram sequenced data, while others do not. See user's guide for additional information. This service provides the ability to manage shelf replenishment through public interfaces.
Service Base URL
Find Replenishment
This section describes the Find Replenishment API. This API finds up to 10,000 shelf replenishment headers for the input criteria.
Method
GET
URL
/shelfreplenishments
Request Parameters
Table 4-267 Find Replenishment — Request Parameters
storeId
NA
Include only replenishments with this store identifier.
type
NA
integer($int2) (query)
Include only replenishments with this type. Valid values are:
1 - Capacity
2 - Display
3 - Gap
4 - Sales
status
 NA
Include only replenishments with this status. Valid values are:
1 - New
2 - In Progress
3 - Complete
4 - Canceled
mode
NA
Include only replenishments with this mode. Valid values are:
1 - End of Day
2 - Within Day
productGroupId
 NA
number($int12) (query)
Include only replenishments with this product group.
departmentId
NA
number($int15) (query)
Include only replenishments with this department.
replenishmentGapId
NA
Include only replenishments with this replenishment gap.
statusDateFrom
 NA
Include only replenishments with a status date on or after this date.
statusDateTo
 NA
Include only replenishments with a status date on or before this date.
createDateFrom
 NA
Include only replenishments with an create date on or after this date.
createDateTo
 NA
Include only replenishments with an create date on or before this date.
itemId
NA
Include only shelf replenishments with this item.
Responses
This section describes the responses of the Find Replenishment API.
Response Code: 200
Example Value
    "replenishmentId": 11111,
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "statusDate": "2025-01-03T10:08:47.605Z",
    "mode": 1,
    "createDate": "2025-01-03T10:08:47.605Z"
Schema — ShelfReplenishmentHeaderIdo
Table 4-268 ShelfReplenishmentHeaderdo— Object
replenishmentId
NA
The unique identifier of the shelf replenishment.
storeId
NA
The store of the shelf replenishment.
type
NA
The type of shelf replenishment. Valid values are:
1 - Capacity
2 - Display
3 - Gap
4 - Sales
status
NA
The current status of the shelf replenishment. Valid values are:
1 - New
2 - In Progress
3 - Complete
4 - Canceled
statusDate
NA
string($date-time)
string($date-time) The date the last time the status of the shelf replenishment was altered.
mode
NA
1 - End of Day
2 - Within Day
Enum: [ 1, 2 ]
createUser
NA
string($text128) example: smith123
The name of the user that created the shelf replenishment.
createDate
NA
string($date-time)
The date the shelf replenishment was created.
Response Code: 400
Bad request
Create Replenishment
This API creates an in progress shelf replenishment.
Method
POST
URL
Request Parameters
The details of the new shelf replenishment..
Example Value
  "storeId": 5000,
  "type": 1,
  "checkAvailableStockOnHand": true,
  "productGroupId": 5683232,
  "replenishmentGapId": 5834134,
  "departmentId": 1000,
  "classId": 2000,
  "subclassId": 3000,
  "mode": 1
Schema — ShelfReplenishmentCreateIdo
Table 4-269 ShelfReplenishmentCreateIdo — Object
storeId
Yes
type
Yes
1 - Capacity
2 - Display
3 - Gap
4 - Sales
NA
True indicates that items with no available stock will not be placed on the replenishment list. If false, they will be included.
productGroupId
NA
number($int12) example: 5683232
The identifier of an associated product group.
replenishmentGapId
NA
number($int15) example: 5834134
The identifier of an associated replenishment gap.
departmentId
NA
number($int12) example: 1000
The identifier of a department.
classId
NA
number($int12) example: 2000
The identifier of a class within the department.
subclassId
NA
number($int12) example: 3000
The identifier of a subclass within the class.
mode
NA
The mode of the shelf replenishment. Valid values are:
1 - End of Day
2 - Within Day
Enum: [ 1, 2 ]
Responses
This section describes the responses of the Import Allocation API.
Response Code: 200
Example Value
    "storeId": 5000,
    "type": 1,
    "status": 1
Schema — ShelfReplenishmentStatusIdo
Table 4-270 ShelfReplenishmentStatusIdo — Object
replenishmentId
NA
storeId
NA
type
NA
1 - Capacity
2 - Display
3 - Gap
4 - Sales
status
NA
1 - New
2 - In Progress
3 - Complete
4 - Canceled
Response Code: 400
Bad request
Read Replenishment
This API retrieves all the details about a shelf replenishment.
Method
GET
URL
/shelfreplenishments/{replenishmentId}
Request Parameters
Table 4-271 Read Replenishment— Request Parameters
replenishmentId
Yes
number ($int15)
(path)
Responses
This section describes the responses of the Read Replenishment API.
Response Code: 200
Example Value
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "statusDate": "2025-01-03T11:46:50.199Z",
    "mode": 1,
    "classId": 2000,
    "subclassId": 3000,
    "transactionEventId": 23894134,
    "transactionEventDescription": "Flash Sale",
    "createDate": "2025-01-03T11:46:50.199Z",
    "lineItems": [
        "lineId": 11111,
        "itemId": "200167123",
        "pickFromArea": 1,
        "pickFromRequest": 20,
        "pickAount": 10,
        "caseSize": 1,
        "unitOfMeasure": "LBS",
        "substituteLineId": 3243
Response Code: 400
Bad request
Update Replenishment
This section describes the Update Replenishment API. This API updates an active shelf replenishment.
Method
POST
URL
Request Parameters
Table 4-272 Update Replenishment — Request Parameters
replenishmentId
yes
integer($int15)
(path)
Shelf replenishment details to update.
Responses
This section describes the responses of the Update Replenishment API.
Response Code: 204
No Content
Response Code: 400
Bad request
Confirm Replenishment
This section describes the Confirm Replenishment API. This API confirms a shelf replenishment moving the inventory.
Method
POST
URL
/shelfreplenishments/{replenishmentId}/confirm
Request Parameters
Table 4-273 Confirm Replenishment — Request Parameters
replenishmentId
yes
integer($int15)
(path)
Responses
This section describes the responses of the Confirm Replenishment API.
Response Code: 204
No Content
Response Code: 400
Bad request
Cancel Replenishment
This section describes the Cancel Replenishment API. This API cancels a shelf replenishment.
Method
POST
URL
/shelfreplenishments/{replenishmentId}/cancel
Request Parameters
Table 4-274 Cancel Replenishment — Request Parameters
replenishmentId
yes
integer($int15)
(path)
Responses
This section describes the responses of the Cancel Replenishment API.
Response Code: 204
No Content
Response Code: 400
Bad request
REST Service: Shelf Replenishment Gap
The gap scanning method is the easiest method of all the various types of shelf replenishment. With this method, you scan the goods that need replenishment and a replenishment list is created from the units scanned. The system uses this replenishment list to move the goods from the back room to the shop floor based on back room availability. The reason to have a separate process between scanning and generating is that one user can create a list and another user can execute the shelf replenishment allowing for distribution of workload. Since this process does not have a dependency with either sales or capacity, it gives an advantage to the retailer to move goods without any complex setup.
Service Base URL
Find Gap
This section describes the Find Gap API. This API finds up to 10,000 replenishment gap summary headers for the input criteria.
Method
GET
URL
/replenishgaps
Request Parameters
Table 4-275 Find Gap — Request Parameters
storeId
NA
Include only replenishment gaps for this store.
status
NA
Include only replenishment gaps with this status. Valid values are:
1 - In Progress
2 - Complete
type
NA
Include only replenishment gaps with this type. Valid values are:
1 - Display Scan
2 - Gap Scan Backroom
itemId
NA
Include only replenishment gaps with this item.
updateDateFrom
NA
Include only replenishment gaps with an update date on or after this date.
updateDateTo
NA
Include only replenishment gaps with an update date on or before this date.
Responses
This section describes the responses of the Find Gap API.
Response Code: 200
Example Value
    "gapId": 11111,
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "createDate": "2024-11-12T11:27:17.130Z",
    "updateDate": "2024-11-12T11:27:17.130Z"
Schema — ShelfReplenishmentGapHearderIdo
Table 4-276 ShelfReplenishmentGapHearderIdo — Object
gapId
NA
The unique identifier of the replenishment gap.
storeId
NA
The store identifier of the replenishment gap.
type
NA
The type of replenishment gap. Valid values are:
1 - Display Scan
2 - Gap Scan
Enum: [ 1, 2 ]
Enum: [ 1, 2 ]
status
NA
The current status of the replenishment gap. Valid values are:
1 - In Progress
2 - Complete
userName
NA
The name of the user that last updated the replenishment gap.
createDate
NA
string($date-time)
The date the replenishment gap was created.
updateDate
NA
string($date-time)
The date the replenishment gap was last updated.
Response Code: 400
Bad request
Create Gap
This section describes the Create Gap API. This API creates an in progress shelf replenishment gap.
Method
POST
URL
/replenishgaps
Request Parameters
The details of the new shelf replenishment gap.
Example Value
  "storeId": 5000,
  "type": 1,
  "lineItems": [
      "itemId": "11111",
      "caseSize": 1,
      "suggestedQuantity": 20
Schema — ShelfReplenishmentGapCreateIdo
Table 4-277 ShelfReplenishmentGapCreateIdo — Object
storeId
yes
The store of the replenishment gap.
type
yes
1 - Display Scan
2 - Gap Scan
Enum: [ 1, 2 ]
lineItems
yes
object
A collection of line items on the shelf replenishment gap.
Table 4-278 ShelfReplenishmentGapCreateItemIdo — Object
itemId
yes
caseSize
NA
suggestedQuantity
yes
The quantity suggested to repelnish for the item.
Responses
This section describes the responses of the Create Gap API.
Response Code: 200
Example Value
    "gapId": 11111,
    "storeId": 5000,
    "type": 1,
    "status": 1
Schema — ShelfReplenishmentGapStatusIdo
Table 4-279 ShelfReplenishmentGapStatusIdo — Object
gapId
NA
storeId
NA
type
NA
1 - Display Scan
2 - Gap Scan
Enum: [ 1, 2 ]
status
NA
1 - In Progress
2 - Complete
Enum: [ 1, 2 ]
Response Code: 400
Bad request
Read Gap
This section describes the Read Gap API. This API retrieves all the details about a shelf replenishment gap.
Method
GET
URL
Request Parameters
Table 4-280 Read Gap — Request Parameters
gapId
yes
number($int15) (path)
Responses
This section describes the responses of the Read Gap API.
Response Code: 200
Example Value
    "gapId": 11111,
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "createDate": "2024-11-14T13:43:09.417Z",
    "updateDate": "2024-11-14T13:43:09.417Z",
    "lineItems": [
        "lineId": 11111,
        "itemId": "11111",
        "caseSize": 1,
Schema — ShelfReplenishmentGapIdo
Table 4-281 ShelfReplenishmentGapIdo — Object
gapId
NA
storeId
NA
type
NA
1 - Display Scan
2 - Gap Scan
Enum: [ 1, 2 ]
status
NA
2 - Complete
1 - In Progress
Enum: [ 1, 2 ]
userName
NA
createDate
NA
string($date-time)
updateDate
NA
string($date-time)
lineItems
NA
object
A collection of line items on the replenishment gap.
Table 4-282 ShelfReplenishmentGapLineItemIdo — Object
lineId
NA
itemId
NA
caseSize
NA
suggestedQuantity
NA
The quantity suggested to replenish for the item.
Response Code: 400
Bad request
Update Gap
This section describes the Update Gap API. This API updates an active shelf replenishment gap.
Method
POST
URL
Request Parameters
Table 4-283 Update Gap — Request Parameters
gapId
yes
The unique identifier of the shelf replenishment gap.
Shelf replenishment gap details to update.
Example Value
  "lineItems": true
Schema — ShelfReplenishmentGapUpdateIdo
Table 4-284 ShelfReplenishmentGapUpdateIdo — Object
lineItems
yes
object
Table 4-285 ShelfReplenishmentGapUpdateItemIdo — Object
itemId
Yes
caseSize
NA
suggestedQuantity
Yes
The quantity suggested for the item. Setting the quantity to zero will remove the line item.
Responses
This section describes the responses of the Update Gap API.
Response Code: 204
No content
Response Code: 400
Bad request
Delete Gap
This section describes the Delete Gap API. This API deletes a shelf replenishment gap.
Method
POST
URL
/replenishgaps/{gapId}/delete
Request Parameters
Table 4-286 Delete Gap — Request Parameters
GapId
yes
Responses
This section describes the responses of the Delete Gap API.
Response Code: 204
No content
Response Code: 400
Bad request
REST Service: Shipping
This service integrates various shipping support information with an external application. This is primarily various lookups of shipping data such as carriers and package sizes to use within shipping transactions.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/shipping
APIs
Table 4-287 APIs
API
Description
findCarriers
Finds all the carriers available for shipping.
findCarrierServices
Finds all the carrier services available for shipping.
findCartonSizes
Finds the available sizes of cartons for shipping.
findWeightUoms
Finds all the various units of measurement of the carton measurements.
findMotives
Finds all the motives available for a shipping type.
API: findCarriers
This API is used to find all the carriers available for shipping.
Table 4-288 API Basics
Endpoint URL
/carriers
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Output
Collection of carriers
Table 4-289 Output Data Definition
Attribute
Type
Definition
carrierId
Long(10)
The unique identifier of the carrier.
code
String(4)
A unique character code for the carrier.
description
String(128)
A description or name of the carrier.
manifestType
Integer(1)
The carrier delivery manifest type (see Additional Data Definitions)
API: findCarrierServices
This API is used to find all the carrier services available for shipping.
Table 4-290 API Basics
Endpoint URL
/carrierservices
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Output
Table 4-291 Output Data Definition
Attribute
Type
Definition
carrierServiceId
Long(10)
The unique identifier of the carrier service.
code
String(6)
A unique character code for the carrier service.
description
String(128)
A description or name of the carrier service.
averageDeliveryDays
Integer(4)
The average number of days it takes to deliver using this service.
carrierId
Long(10)
The unique identifier of the carrier this service is used with.
defaultService
Boolean
True is this is the default service type for the carrier, false otherwise.
weightRequired
Boolean
True is weight is required for this carrier service, false otherwise.
cartonSizeRequired
Boolean
True if dimensions/size is required for this carrier service, false otherwise.
API: findCartonSizes
This API is used to find all the carton services available for shipping at the particular store.
Table 4-292 API Basics
Endpoint URL
/cartonsizes/{storeId}
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Path Parameter
The store identifier of the store to retrieve carton sizes for.
Output
Collection of carton sizes
Table 4-293 Output Data Definition
Attribute
Type
Definition
cartonSizeId
Long(12)
A unique identifier of this particular carton size definition.
storeId
Long(10)
The store identifier the carton size is used at.
description
String(120)
A description of the carton size.
height
BigDecimal(12,4)
The height of the carton in units of measure.
width
BigDecimal(12,4)
The width of the carton in units of measure.
length
BigDecimal(12,4)
The length of the carton in units of measure.
unitOfMeasure
String(4)
The unit of measure of the height, width, and length.
API: findWeightUoms
This API is used to find all the weight unit of measures available for shipping.
Table 4-294 API Basics
Endpoint URL
/weightuoms
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Output
Collection of shipping weight units of measure
Attribute
Type
Definition
uom
String(4)
The unit of measure
description
String(120)
The unit of measure description
API: findMotives
This API is used to find all the motives available for a shipping type. See index for available shipment types.
Table 4-295 API Basics
Endpoint URL
/motives/(shipmentType}
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Path Parameter
The shipment type to retrieve motives for (see Additional Data Definitions)
Output
Table 4-296 Output Data Definition
Attribute
Type
Definition
id
Long(18)
The unique identifier of the shipping motive
code
String(6)
The external code of the shipping motive
description
String(120)
A description of the motive
sequence
Long
The sequence in which the motive should appear in a list
Index
ID
Description
1
Parcel
2
Home Fleet
3
Other
ID
Description
1
Fulfillment Order
2
Store Transfer
3
Vendor Return
REST Service: Stock Count
Stock Counts allow the user to count the inventory in the store, determine discrepancy of items, and authorize new inventory positions triggering adjustments to bring the inventory into alignment. There are four main types of stock counts: ad hoc, unit, problem line, and unit-amount. Ad Hoc stock counts are not schedule, but rather performed at random times when a user decides to correct inventory. Unit stock counts must be secheduled. They can be scheduled and executed the same day. A problem line stock count features items that have inventory positions issues, such as having negative inventory. A problem line is also scheduled and follow the same overall workflows as unit counts. Unit and amount counts must be scheduled for a single specific date. These stock counts must be scheduled at least one day ahead of time. When the count is scheduled, it is sent to the merchandising system so that it can also create a corresponding stock count. The service defines operations to manage stock count information by integration with an external system.
Service Base URL
Find Stock Counts
This section describes the Find Stock Counts API. This API finds up to 1,000 stock counts matching the input criteria.
Method
GET
URL
/stockcounts
Request Parameters
Table 4-297 Find Stock Counts — Request Parameters
storeId
NA
Include only stock counts for this store.
scheduleDate
NA
Include only stock counts that are scheduled to be executed on this date.
phase
NA
Include only stock counts in this phase. Valid values are:
1 - Count
2 - Recount
3 - Authorize
4 - Future
status
NA
Include only stock counts in this status. Valid values are:
1 - New
2 - Count Scheduled
3 - Count In Progress
4 - Count Complete
5 - Recount Scheduled
6 - Recount In Progress
7 - Recount Complete
 8 - Approval Scheduled
9 - Approval In Progress
10 - Approval Processing
11 - Approval Authorized
12 - Approval Complete
13 - Canceled
Available values : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13
departmentId
NA
Include only stock counts associated to this department.
classId
NA
Include only stock counts associated to this class. A department is required if this attribute is used.
subclassId
NA
Include only stock counts associated to this subclass. A class is required if this attribute is used.
Responses
This section describes the responses of the Find Stock Counts API.
Response Code: 200
Example Value
    "stockCountId": 11111,
    "storeId": 5000,
    "description": "Weekly Department Count",
    "productGroupId": 966400,
    "productGroupDescription": "Clothing Department",
    "productGroupScheduleId": 966400,
    "type": 1,
    "status": 1,
    "phase": 1,
    "scheduleDate": "2025-01-16T13:19:10.243Z",
    "startDateTime": "2025-01-16T13:19:10.243Z",
    "updateDateTime": "2025-01-16T13:19:10.243Z",
    "totalItemCount": 2000,
    "totalLeftToCount": 950
Schema — StockCountHeaderIdo
Table 4-298 StockCountHeaderIdo— Object
stockCountId
NA
number($int12) example: 11111
The unique identifier of the stock count.
storeId
NA
The identifier of the store.
description
NA
string($text255) example: Weekly Department Count
A description of the stock count.
productGroupId
NA
number($int12) example: 966400
The identifier of the product group
NA
string($text100) example: Clothing Department
The description of the product group.
NA
The identifier of the product group schedule.
type
NA
The type of the stock count. Valid values are:
1 - Unit
2 - Unit and Amount
3 - Problem Line
4 - Adhoc
status
NA
The current status of the stock count. Valid values are:
1 - New
2 - Count Scheduled
4 - Count Complete
13 - Canceled
Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 ]
phase
NA
The current phase of the stock count. Valid values are:
1 - Count
2 - Recount
3 - Authorize
4 - Future
Enum: [ 1, 2, 3, 4
scheduleDate
NA
string($date-time)
The date the stock count is scheduled to be executed on.
startDateTime
NA
string($date-time)
The time stamp when the stock count was started.
updateDateTime
NA
string($date-time)
The time stamp when the stock count was last updated.
totalItemCount
NA
The total number of items on the stock count.
totalLeftToCount
NA
number($int12) example: 950
The total number of items left to count.
Response Code: 400
Bad request
Read Stock Count
This section describes the Read Stock Count API. This API reads information about a stock count. It includes the information for the stock count header as well as the header information for each stock count child. It does not include the item detail. To retrieve detailed information, the stock count child must be read individually.
Method
GET
URL
/stockcounts/{stockCountId}
Request Parameters
Table 4-299 Read Stock Count — Request Parameters
stockCountId
Yes
number($int12) (path)
The stock count identifier.
Responses
This section describes the responses of the Read Stock Count API.
Response Code: 200
Example Value
    "storeId": 5000,
    "type": 1,
    "status": 1,
    "phase": 1,
    "scheduleDate": "2025-01-16T13:48:59.866Z",
    "startDateTime": "2025-01-16T13:48:59.866Z",
    "updateDateTime": "2025-01-16T13:48:59.866Z",
    "exportUser": "smith123",
    "totalLeftToCount": 950,
    "stockCountTimeframe": 1,
    "varianceCount": 5,
    "variancePercent": 2.5,
    "varianceValue": 2.5,
    "countingMethod": 1,
    "breakdownType": 1,
    "recountRequired": true,
    "autoAuthorize": false,
    "includeAllItems": true,
    "includeActiveItems": false,
    "includeDiscontinuedItems": true,
    "includeDeletedItems": true,
    "includeSohZero": false,
    "includeSohPositive": true,
    "includeSohNegative": false,
    "problemLinePickLessSuggested": true,
    "problemLineReplenishLessSuggested": true,
    "problemLineReplenishNegativeAvailable": false,
    "problemLineReplenishDiscrepantUin": true,
    "adhocItemLock": false,
    "childCounts": [
        "childCountId": 1223465,
        "locationId": "738429",
        "locationArea": 45,
        "description": "Frozen Foods",
        "breakdownDescription": "123 - Pies",
        "phase": 1,
        "status": 1,
        "countUser": "smith123",
        "recountUser": "smith123",
        "authorizeUser": "jones123",
        "countSnapshotDate": "2025-01-16T13:48:59.866Z",
        "recountSnapshotDate": "2025-01-16T13:48:59.866Z",
        "authorizedDate": "2025-01-16T13:48:59.866Z"
Schema — StockCountIdo
Table 4-300 StockCountIdo— Object
stockCountId
NA
storeId
NA
description
NA
productGroupId
NA
The identifier of the product group.
NA
NA
type
NA
1 - Unit
2 - Unit and Amount
3 - Problem Line
4 - Adhoc
status
NA
1 - New
2 - Count Scheduled
4 - Count Complete
13 - Canceled
phase
NA
1 - Count
2 - Recount
3 - Authorize
4 - Future
scheduleDate
NA
string($date-time)
startDateTime
NA
string($date-time)
updateDateTime
NA
string($date-time)
exportUser
NA
The user that exported the stock count.
totalItemCount
NA
totalLeftToCount
NA
stockCountTimeframe
NA
integer($int1) example: 1
1 - Before Store Open
2 - After Store Closed
3 - None
Enum: [ 1, 2, 3 ]
varianceCount
NA
The amount in standard unit of measure that the count can vary before being considered discrepant.
variancePercent
NA
number($decimal(12,4)) example: 2.5
The percent in standard unit of measure that the count can vary before being considered discrepant.
varianceValue
NA
The value variance allowed before the count is considered discrepant.
countingMethod
NA
1 - Guided
2 - Unguided
3 - Third Party
4 - Auto
breakdownType
NA
1 - Department
2 - Class
3 - Subclass
4 - Location
5 - None
Enum: [ 1, 2, 3, 4, 5 ]
recountRequired
NA
True indicates stock count should be recounted.
autoAuthorize
NA
boolean example: false
True indicates stock count should automatically authorize after count.
includeAllItems
NA
True indicates stock count should include all items.
includeActiveItems
NA
True indicates stock count should include active items.
NA
True indicates stock count should include inactive items.
includeDeletedItems
NA
True indicates stock count should include deleted items.
includeSohZero
NA
True indicates stock count should include zero stock on hand items.
includeSohPositive
NA
True indicates stock count should include positive stock on hand items.
includeSohNegative
NA
True indicates stock count should include negative stock on hand items.
NA
True indicates stock count should include pick lists less than suggested amounts.
NA
True indicates stock count should include shelf replenishments that are less than the suggested amount.
NA
True indicates stock count should include items with negative available quantities.
NA
True indicates stock count should include UIN discrepancies.
adhocItemLock
NA
True indicates an ad-hoc count is locked and new items can no longer be added.
childCounts
NA
object
A list of child stock counts that organize the items for counting.
Table 4-301 StockCounChildHeadertIdo— Object
childCountId
NA
number($int12) example: 1223465
The unique identifier of the stock count child.
locationId
NA
string($text128) example: 738429
The unique identifier of the sequence location being counted.
locationArea
NA
integer($int9) example: 45
An area number associated with the location.
description
NA
string($text1000) example: Frozen Foods
The description of the stock count location.
NA
string($text30) example: 123 – Pies
The description of a breakdown sub-location within the stock count location.
phase
NA
1 - Count
2 - Recount
3 - Authorize
4 - Future
status
NA
1 - New
2 - Count Scheduled
4 - Count Complete
13 - Canceled
countUser
NA
The user that performed the count in this location.
recountUser
NA
The user that performed the recount in this location.
authorizeUser
NA
string($text128) example: jones123
The user that performed the authorization in this location.
totalItemCount
NA
The total number of items in the location.
totalLeftToCount
NA
The items remaining to be counted in the location.
countSnapshotDate
NA
string($date-time)
The time stamp when this child had its count snapshot taken.
recountSnapshotDate
NA
string($date-time)
The time stamp when this child had its recount snapshot taken.
authorizedDate
NA
string($date-time)
The time stamp when this child was authorized.
Response Code: 400
Bad request
Snapshot Stock Count
Snapshots a stock count capturing the current stock on hand quantity as a snapshot quantity for each item on the count. The process of doing a snapshot first determines whether or not the stock count needs a snapshot and only snapshots a stock count or stock count childs that need a snapshot. However, if the stock count or stock count child does not need a snapshot, the service is still considered successful as the snapshot exists.
Method
POST
URL
/stockcounts/{stockCountId}/snapshot
Request Parameters
Table 4-302 Snapshot Stock Count — Request Parameters
stockCountId
Yes
Responses
This section describes the responses of the Snapshot Stock Count API.
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Stock Count
This section describes the Cancel Stock Count API. This API cancels a stock count if it has not begun approval processing. If a unit and amount stock count is canceled, it will notify merchandising of the cancellation.
Method
POST
URL
/stockcounts/{stockCountId}/cancel
Request Parameters
Table 4-303 Cancel Stock Count — Request Parameters
stockCountId
Yes
Responses
This section describes the responses of the Cancel Stock Count API.
Response Code: 204
No content
Response Code: 400
Bad request
Read Stock Count Child
This section describes the Read Stock Count Child API. This API reads information about a stock count child, including all its items.
Method
GET
URL
/stockcounts/childs/{stockCountChildId}
Request Parameters
Table 4-304 Read Stock Count Child — Request Parameters
stockCountChildId
Yes
The stock count child identifier.
Responses
This section describes the responses of the Read Stock Count Child API.
Response Code: 200
Example Value
    "locationArea": 45,
    "phase": 1,
    "status": 1,
    "countSnapshotDate": "2025-01-16T14:34:40.120Z",
    "recountSnapshotDate": "2025-01-16T14:34:40.120Z",
    "authorizedDate": "2025-01-16T14:34:40.120Z",
    "lineItems": [
        "lineId": 1223465,
        "itemId": "20045673",
        "departmentId": 2000,
        "classId": 3000,
        "subclassId": 4000,
        "primaryLocation": true,
        "multiLocated": false,
        "discrepant": true,
        "breakableComponent": false,
        "countSnapshot": 100,
        "recountSnapshot": 110,
        "quantityCounted": 99,
        "quantityRecounted": 101,
        "quantityAuthorized": 101,
        "quantityCountedTotal": 99,
        "quantityRecountedTotal": 99,
        "countedDateTime": "2025-01-16T14:34:40.120Z",
        "recountedDateTime": "2025-01-16T14:34:40.120Z",
        "authorizedDateTime": "2025-01-16T14:34:40.120Z",
        "snapshotDateTime": "2025-01-16T14:34:40.120Z",
        "priceType": 1,
        "priceCurrency": "USD",
        "priceValue": 12.99,
        "uins": [
            "uin": "200456734823",
            "uinId": 1223465,
            "snapshotStatus": 1
        "epcs": [
            "epc": "2004435813456734700",
            "scanDateTime": "2025-01-16T14:34:40.120Z"
Schema — StockCountChildIdo
Table 4-305 StockCountChildIdo— Object
childCountId
NA
locationId
NA
locationArea
NA
description
NA
NA
phase
NA
1 - Count
2 - Recount
3 - Authorize
4 - Future
status
NA
1 - New
2 - Count Scheduled
4 - Count Complete
13 - Canceled
countUser
NA
recountUser
NA
authorizeUser
NA
totalItemCount
NA
totalLeftToCount
NA
countSnapshotDate
NA
string($date-time)
recountSnapshotDate
NA
string($date-time)
authorizedDate
NA
string($date-time)
lineItems
NA
object
The items counted within this location.
Table 4-306 StockCountLineItemIdo — Object
lineId
NA
itemId
NA
string($text128) example: 20045673
departmentId
NA
The unique identifier of the department.
classId
NA
The unique identifier of the class.
subclassId
NA
number($int12) example: 4000
The unique identifier of the subclass.
primaryLocation
NA
True indicates this is the primary stock count child for the item.
multiLocated
NA
True indicates this item is located within multiple stock count child records.
discrepant
NA
True indicates the item count is discrepant.
breakableComponent
NA
True indicates this is a component of a breakable (notional) pack.
countSnapshot
NA
number($decimal(12,4)) example: 100
The stock on hand at the time the count snapshot was executed.
recountSnapshot
NA
number($decimal(12,4)) example: 110
The stock on hand at the time the recount snapshot was executed.
quantityCounted
NA
number($decimal(12,4)) example: 99
The amount in standard unit of measure counted during the initial stock counting phase.
quantityRecounted
NA
number($decimal(12,4)) example: 101
The amount in standard unit of measure counted during the recount of stock.
quantityAuthorized
NA
The amount in standard unit of measure to be approved during authorization.
NA
The amount in standard unit of measure counted during the initial stock counting phase for this item across all children in which it appears.
NA
The amount in standard unit of measure counted during the recount for this item across all children in which it appears.
countedDateTime
NA
string($date-time)
The time stamp when counting began for the item.
recountedDateTime
NA
string($date-time)
The time stamp when recounting began for the item.
authorizedDateTime
NA
string($date-time)
The time stamp when the item was authorized.
snapshotDateTime
NA
string($date-time)
The time stamp when the snapshot was last taken for this item.
priceType
NA
integer($int3) example: 1
1 - Permanent
2 - Promotional 3 - Clearance
Enum: [ 1, 2, 3 ]
priceCurrency
NA
The price currency at the time of the snapshot.
priceValue
NA
number($decimal(20,4)) example: 12.99
The price amount at the time of the snapshot.
uins
NA
object
The UINs associated to this item on the count.
epcs
NA
object
The EPCs associated to this item on the count.
Table 4-307 StockCountLineItemUinIdo — Object
uin
NA
string($text128) example: 200456734823
The unique identifier number.
uinId
NA
The record identifier of the UIN.
snapshotStatus
NA
number($int2) example: 1
1 - In Stock
2 - Sold
3 - Shipped To Warehouse
4 - Shipped To Store
5 - Reserved For Shipping
6 - Shipped To Vendor
7 - Remove From Inventory
8 - Unavailable
9 - Missing
10 - In Receiving
11 - Customer Reserved
12 - Customer Fulfilled
13 - Shipped To Finisher
99 - Unconfirmed
Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 99 ]
Table 4-308 StockCountLineItemEpcIdo — Object
epc
NA
string($text256) example: 2004435813456734700
The Electronic Product Code
scanDateTime
NA
string($date-time)
Snapshot of the last time the EPC was scanned.
Response Code: 400
Bad request
Update Stock Count Child
This section describes the Update Stock Count Child API. This API updates a child count's quantities based on the current phase of counting. Counted quantity is updated in count phase, recounted quantity for recount phase, and authorization quantity for authorization phase. A maximum of 10,000 line items is allowed per update.
Method
POST
URL
Request Parameters
Table 4-309 Update Stock Count Child — Request Parameters
stockCountChildId
Yes
Details of the stock count child to update.
Example Value
  "lineItems": [
      "lineId": 456333,
      "quantity": 12.4,
      "timestamp": "2025-01-16T15:10:31.345Z",
      "uins": [
        111222333,
        444555666
Schema — StockCountChildUpdateIdo
Table 4-310 StockCountChildUpdateIdo— Object
lineItems
Yes
object
Information about the items that were counted.
Table 4-311 StockCountChildUpdateItemIdo— Object
lineId
Yes
number($int12) example: 456333
The unique identifier of the line item record being updated.
quantity
Yes
number($decimal(12,4)) example: 12.4
The quantity to assign to the line item based on the current phase of the stock count. If UINs are enabled for the store and this is a UIN item, the quantity value will be overwritten by the sum of the UINs on the line item.
timestamp
NA
string($date-time)
The timestamp when the quantity was counted, recounted, or authorized. If the item does not yet have a timestamp, this value will be assigned to the item. If left blank, current timestamp of processing will be used instead.
uins
Yes
string($text128)] example: List [ 111222333, 444555666 ]
The UINs to attach to this line item.
Responses
This section describes the responses of the Update Stock Count Child API.
Response Code: 204
No content
Response Code: 400
Bad request
Complete Stock Count Child
This section describes the Complete Stock Count Child API. This API completes the count or recount of a stock count child moving it to the next phase of stock count processing if possible. Many factors may cause a child count to be pending until further counting is completed in other child counts. If the child has not yet been counted, it can still be completed and will follow the business rules and configurations for uncounted items.
Method
POST
URL
/stockcounts/childs/{stockCountChildId}/complete
Request Parameters
Table 4-312 Complete Stock Count Child — Request Parameters
stockCountChildId
Yes
Responses
This section describes the responses of the Complete Stock Count Child API.
Response Code: 204
No content
Response Code: 400
Bad request
REST Service: Store
This service integrates the store foundation data with an external application. Store integration is controlled by the MPS Work Type: DcsStore.
Service Base URL
The Cloud service base URL follows the format:
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/stores
API Definitions
API Description
Import Stores
Imports a collection of stores.
Delete Store
Deactivate a single store.
Read Store
Read store information based on an identifier (or link)
Find Stores
Lookup store information based on a collection of store identifiers.
Find Associated Stores
Lookup store associated to the specified input store.
Find Auto Receive Stores
Lookup stores that are allowed to auto receive from the specified input store.
Find Transfer Zone Stores
Lookup stores that are in the same transfer zone as the specified input store.
API: Import Stores
Imports a collection of stores. This allows 1,000 stores per input call. All imported stores will be inventory-holding regular stores.
A "Forbidden" response will occur if application is integrated with MFCS or RMS.
API Basics
Endpoint URL
{base URL}/import
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of Store to Import
Output
None
Max Response Limit
1000
Attribute
Data Type
Required
Description
stores
List of stores to import
Yes
A collection of up to 1000 stores to import.
Stores Data Definition
Attribute
Data Type
Required
Description
storeId
Long(10)
Yes
storeName
String(150)
Yes
The name of the store.
languageCode
String(3)
The language code of the store.
countryCode
String(3)
The country code of the store.
currencyCode
String(3)
The currency code of the store.
timezone
String(80)
The timezone of the store.
transferZoneId
String(128)
Yes
The transfer zone identifier of the store.
organizationUnitId
String(15)
The organization unit identifier of the store.
managedStore
Boolean
True indicates that EICS manages the inventory, false indicates it does not.
customerOrdering
Boolean
True indicates this store can take customer orders, false indicates it does not.
Example Output
"stores": [
"storeId": 5002,
"storeName": "Leamington Spa",
"languageCode": "EN",
"countryCode": "US",
"currencyCode": "USD",
"timezone": "America/Los_Angeles",
"transferZoneId": "1000",
"organizationUnitId": "1111",
"managedStore": true,
"allowsCustomerOrders": false
"storeId": 5003,
API: Delete Store
Delete a store. Prior to placing the request to delete into the MPS queue, it validates that the store exists and that the store contains no items ranged to it.
API Basics
Endpoint URL
{base URL}/{storeId}/delete
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
None
Output
None
Max Response Limit
N/A
Path Parameter Definitions
Attribute
Definition
storeId
The internal identifier of the store.
API: Read Store
Retrieve information about a store based on a single unique store identifier or link.
API Basics
Endpoint URL
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
None
Output
Store
Max Response Limit
N/A
Attribute
Definition
storeId
Attribute
Data Type
Description
storeId
Long
storeName
String
languageCode
String
countryCode
String
currencyCode
String
timezone
String
transferZoneId
String
organizationUnitId
String
managedStore
boolean
customerOrdering
boolean
Example Output
    "links": [
            "href": "/stores/5000",
            "rel": "self"
            "href": "/stores/5000/delete",
            "rel": "delete"
    "storeId": 5000,
    "storeName": "Solihull",
    "timezone": "America/Chicago",
API: Find Stores
Find stores based on a list of potential unique store identifiers. It allows a maximum of 1500 store identifiers.
API Basics
Endpoint URL
{base URL}/find
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
List of stores ids
Output
List of stores
Max Response Limit
1500
Attribute
Data Type
Required
Description
stores
List of stores Ids
Yes
A collection of up to 1500 stores to read.
Example Input
"storeIds": [
5000,
5001
Attribute
Data Type
Description
Stores
List of Stores
A collection containing the store information
Attribute
Data Type
Required
Description
storeId
Long
Yes
storeName
String
languageCode
String
countryCode
String
currencyCode
String
timezone
String
transferZoneId
String
organizationUnitId
String
managedStore
boolean
customerOrdering
boolean
Example Output
        "links": [
                "rel": "self"
                "rel": "delete"
        "storeId": 5000,
        "links": [
                "href": "/stores/5001",
                "rel": "self"
                "href": "/stores/5001/delete",
                "rel": "delete"
        "storeId": 5001,
        "storeName": "Nottingham",
        "timezone": "America/New_York",
API: Find Associated Stores
Find potential associated stores (buddy stores) to the specified input store.
API Basics
Endpoint URL
{base URL}/{storeId}/associated
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
None
Output
List of stores
Max Response Limit
N/A
Attribute
Definition
storeId
Attribute
Data Type
Required
Description
Stores
List of Stores Ids
Yes
A collection containing the store Ids
Attribute
Data Type
Required
Description
storeId
Long
Yes
Example Output
"links": [
"rel": "self"
"rel": "delete"
"storeId": 5001
"links": [
"href": "/stores/5002",
"rel": "self"
"href": "/stores/5002/delete",
"rel": "delete"
"storeId": 5002
API: Find Auto Receive Stores
Find stores that are allowed to auto receive from the specified input store.
API Basics
Endpoint URL
{base URL}/{storeId}/autoreceive
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
None
Output
List of stores
Max Response Limit
N/A
Attribute
Definition
storeId
Example Output
"links": [
"rel": "self"
"rel": "delete"
"storeId": 5001
"links": [
"rel": "self"
"rel": "delete"
"storeId": 5002
API: Find Transfer Zone Stores
Find stores that are available within the transfer zone of the input store.
API Basics
Endpoint URL
{base URL}/{storeId}/transferzone
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
None
Output
List of stores
Max Response Limit
N/A
Attribute
Definition
storeId
Attribute
Data Type
Required
Description
Stores
List of Stores Ids
Yes
Attribute
Data Type
Require d
Description
storeId
Long
Yes
Example Output
"links": [
"rel": "self"
"rel": "delete"
"storeId": 5001
"links": [
"rel": "self"
"rel": "delete"
"storeId": 5002
REST Service: Store Item
This service integrates the store item foundation data with an external application. Store integration is controlled by the MPS Work Type: DcsItemLocation.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/storeitems
API Definitions
API
Description
Import Store Items
Imports items at a store location.
Remove Store Items
Deactivate items at a store location.
Import Replenishment Items
Imports replenishment item information.
Remove Replenishment Items
Deactivate replenishment item information.
API: Import Store Items
Imports store items into the system.
If more than 10,000 items are included in a single call, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/import
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of store Items to Import
Output
None
Max Response Limit
10,000
Attribute
Data Type
Required
Description
items
List of stores items to import
Yes
A collection of up to 10,000 stores items to import.
Stores Items Data Definition
Attribute
Data Type
Required
Description
itemId
String(25)
Yes
The unique item identifier (sku number).
shortDescription
String(255)
A short description of the item at this store.
longDescirption
String(400)
A long description of the item at this store.
status
String
Yes
See Index (Item Status)
primarySupplierId
Long(10)
The unique identifier of the primary supplier of the item to this store location.
storeControlPricing
Boolean
True indicates the item price can be controlled by the store.
rfid
Boolean
True indicates the item is RFID tagged.
defaultCurrencyCode
String(3)
The default currency of the item's price at this store.
purchaseType
Long
See Index (Purchase Type)
uinType
Integer
See Index (UIN Type)
uinCaptureTime
Integer
See Index (UIN Capture Time)
uinLabelCode
Long
The UIN label unique identifier.
uinExternalCreateAllowed
Boolean
True if an external system can create a UIN, false otherwise.
Example Input
"items": [
"itemId": "100637121",
"defaultCurrencyCode": "USB",
"longDescription": "TestDescriptionAA",
"primarySupplierId": 1,
"purchaseType": 1,
"rfid": true,
"shortDescription": "TestShortAA",
"status": 1,
"storeControlPricing": false,
"uinCaptureTime": 1,
"uinExternalCreateAllowed": true,
"uinLabelCode": "SN",
"uinType": 1
Item Status
Value
Definition
1
Active
2
Discontinued
3
Inactive
4
Auto Stockable
Purchase Type
Value
Definition
1
Normal Merchandise
2
Consignment Stock
3
Concession Items
UIN Capture Time
Value
Definition
1
Sale
2
Store Receiving
UIN Type
Value
Definition
1
Serial Number
2
Auto-Generated Serial Number
API: Remove Store Items
This will mark items as no longer usable. When all data is cleared out of transactions that reference this data, later batch jobs will eventually delete the material.
If more than 1000 items are included in a single call, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/{storeId}/remove
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
None
Output
None
Max Input Limit
1000
Attribute
Definition
storeId
Attribute
Data Type
Required
Description
items
List of items to remove
Yes
A collection of up to 1000 items to remove.
Example Input
"itemIds": [
"100637121",
"100637113"
API: Import Replenishment Items
Imports item replenishment information for an item at a store location.
API Basics
Endpoint URL
{base URL}/{storeId}/replenish/import
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
None
Output
List of Items Replenishment to import
Max Input Limit
1000
Attribute
Definition
storeId
Attribute
Data Type
Required
Description
items
List of Item Replenishment Import
Yes
The item replenishment information to import.
Item Replenishment Import Data Definition
Attribute
Data Type
Required
Description
itemId
String (25)
Yes
replenishmentMethod
String(6)
A code representing the replenishment method. (SO indicates Store Order).
rejectStoreOrder
Boolean
True indicates store orders must be on or after the next delivery date or should be rejected.
multipleDeliveryPerDayAllowed
Boolean
True indicates the item allows multiple deliveries per day at the location.
nextDeliveryDate
Date
The next delivery date of the time based on its replenishment type.
Example Input
"items": [
"replenishmentMethod": "AB",
"rejectStoreOrder": false,
"multipleDeliveryPerDayAllowed": false,
"nextDeliveryDate": "2022-11-19T23:59:59-05:00"
API: Remove Replenishment Items
Clears the replenishment item information from within the store item setting the replenishment properties to empty, null, or default flag settings.
API Basics
Endpoint URL
{base URL}/replenish/remove
Method
POST
Successful Response
200 OK
Processing Type
Asynchronous
Input
List of item ids
Output
None
Max Input Limit
1000
Attribute
Data Type
Required
Description
Items
List of item Ids
Yes
A collection of up to 1000 items to read.
Example Input
"itemIds": [
"100637121",
"100637113"
REST Service: Store Order
Store orders allow a store to request items to be ordered to the store. The items being requested may come from a supplier or warehouse. Store orders allows a user to capture items and their quantities to be ordered as well as restrictions for the store order. The inventory will be sourced to the store based on the corporate replenishment setup. This can be either a delivery from a warehouse or a drop ship from the supplier. The actual sourcing, delivery timings, and final quantities remain a function of the external replenishment system.
Service Base URL
Find Store Order
This section describes the Find Store Order API. This API finds up to a maximum of 5,000 store orders for the input criteria.
Method
GET
URL
/storeorders
Request Parameters
Table 4-313 Find Store Order — Request Parameters
storeId
NA
integer($int10) (query)
Include only store orders with this store identifier.
externalReference
NA
string($text128) (query)
Include only store orders with this external reference number.
externalTransferId
NA
Include only store orders with this external transfer identifier.
externalPurchaseOrderId
NA
Include only store orders with this external purchase order identifier.
status
NA
integer($int4) (query)
1 - New
2 - In Progress
3 - Approved
4 - Canceled
5 - Submitted
itemId
NA
Include only store orders containing this item.
updateDateFrom
NA
string($date-time) (query)
Include only store orders with an update date on or after this date.
updateDateTo
NA
Include only store orders with an update date on or before this date.
Responses
This section describes the responses of the Find Store Order API.
Response Code: 200
Example Value
    "storeOrderId": 11111,
    "storeId": 1234,
    "externalTransferId": "7000",
    "externalPurchaseOrderId": "8000",
    "externalReference": "9000",
    "description": "Need more inventory",
    "status": 1,
    "requestedDeliveryDate": "2025-01-21T14:44:31.735Z",
    "updateDate": "2025-01-21T14:44:31.735Z"
Schema — StoreOrderHeaderIdo
Table 4-314 StoreOrderHeaderIdo— Object
storeOrderId
NA
integer($int12) example: 11111
The unique identifier of the store order.
storeId
NA
number($int10) example: 1234
The store identifier of the store order.
externalTransferId
NA
string($text128) example: 7000
An external transfer identifier that this store order is associated to.
NA
string($text128) example: 8000
An external purchase order identifier that this store order is associated to.
externalReference
NA
string($text128) example: 9000
A reference to this store order in an external system.
description
NA
string($text2000) example: Need more inventory
A description of the store order or cause of the store order.
status
NA
1 - New
2 - In Progress
3 - Approved
4 - Canceled
5 - Submitted
NA
string($date-time)
The date the store request the delivery arrive by.
updateDate
NA
string($date-time)
The date the store order was lasted updated within the system.
Response Code: 400
Bad request
Create Store Order
This operation will cause the system to generate a new inventory request to an external system which will then generate a new transfer or purchase order to fulfill the inventory request.
Method
POST
URL
/storeorders
Request Parameters
Details about the store order to request.
Example Value
  "storeId": 1234,
  "requestedDeliveryDate": "2025-01-21T15:26:24.751Z",
  "contextTypeId": 1234,
  "restrictToSupplierId": 1111,
  "restrictToWarehouseId": 2222,
  "restrictToAreaId": 4444,
  "restrictToDepartmentId": 1000,
  "restrictToClassId": 1000,
  "restrictToSubclassId": 1000,
  "storeOrderOnly": false,
  "lineItems": [
      "itemId": "55001234",
      "quantity": 2,
      "caseSize": 5,
      "deliverySlotId": 55555
Schema — StoreOrderCreateIdo
Table 4-315 StoreOrderCreateIdo — Object
storeId
Yes
description
NA
NA
string($date-time)
contextTypeId
NA
integer($int18) example: 1234
A context identifier associated to the store order.
NA
Only allow items on the store order that are associated to this supplier.
NA
integer($int12) example: 2222
Only allow items on the store order that are associated to this warehouse.
restrictToAreaId
NA
integer($int12) example: 4444
Only allow items on the store order that are associated to this store sequence area.
NA
integer($int15) example: 1000
Only allow items that are within this department.
restrictToClassId
NA
Only allow items that are within this class. If included, department must also be included.
NA
Only allow items that are within this subclass. If included, class must also be included.
storeOrderOnly
NA
If true, only store order replenishment items can be added to the order.
lineItems
Yes
object
The items to request inventory for.
Table 4-316 StoreOrderCreateItemIdo — Object
itemId
Yes
string($text25) example: 55001234
The SKU level item identifier.
quantity
Yes
number($decimal(20,4)) example: 2
The quantity of the item to be requested from an external system.
caseSize
NA
number($decimal(10,2)) example: 5
The case size of this line item.
deliverySlotId
NA
integer($int15) example: 55555
The unique identifier of the delivery time.
Responses
This section describes the responses of the Create Store Order API.
Response Code: 200
Example Value
    "storeId": 1234,
    "status": 1
Schema — StoreOrderStatusIdo
Table 4-317 StoreOrderStatusIdo — Object
storeOrderId
NA
storeId
NA
status
NA
1 - New
2 - In Progress
3 - Approved
4 - Canceled
5 - Submitted
Response Code: 400
Bad request
Read Store Order
This section describes the Read Store Order API. This API retrieves all the details about a store order.
Method
GET
URL
/storeorders/{storeOrderId}
Request Parameters
Table 4-318 Read Store Order — Request Parameters
storeOrderId
Yes
The unique identifier of the store order..
Responses
This section describes the responses of the Read Store Order API.
Response Code: 200
Example Value
    "storeId": 1234,
    "parentReference": 1111,
    "status": 1,
    "origin": 1,
    "requestedDeliveryDate": "2025-01-21T15:43:39.415Z",
    "autoApproveDate": "2025-01-21T15:43:39.415Z",
    "addItemsAllowed": true,
    "replenishmentItemsOnly": false,
    "deliverySlotId": 4565,
    "productGroupId": 5678,
    "productGroupDescription": "Bi-Weekly Restock",
    "restrictToHierarchyId": 3333,
    "externalCreateDate": "2025-01-21T15:43:39.415Z",
    "createDate": "2025-01-21T15:43:39.415Z",
    "createUser": "userAbc",
    "updateDate": "2025-01-21T15:43:39.415Z",
    "approvedDate": "2025-01-21T15:43:39.415Z",
    "approvedUser": "userAbc",
    "lineItems": [
        "lineId": 1234,
        "approvedQuantity": 2,
        "suggestedQuantity": 2,
        "caseSize": 5,
        "unitCostCurrency": "USD",
        "unitCostAmount": 5.5,
Schema — StoreOrderIdo
Table 4-319 StoreOrderIdo— Object
storeOrderId
NA
storeId
NA
externalTransferId
NA
NA
externalReference
NA
parentReference
NA
Reference to a parent transfer or order.
description
NA
status
NA
1 - New
2 - In Progress
3 - Approved
4 - Canceled
5 - Submitted
origin
NA
1 - External
2 - Manual
3 - System
Enum: [ 1, 2, 3 ]
NA
string($date-time)
The date the store requested the delivery arrive by.
autoApproveDate
NA
string($date-time)
The date the record was automatically approved in the system.
addItemsAllowed
NA
boolean example: true
True indicates new items can be added to the store order.
NA
True indicates only store order replenishment items can be added to the store order.
contextTypeId
NA
deliverySlotId
NA
integer($int15) example: 4565
The unqiue identifer of a delivery time.
productGroupId
NA
integer($int12) example: 5678
The unique identifier of a product group associated to the order.
NA
string($text250) example: Bi-Weekly Restock
The description of the product group associated to the order.
NA
NA
NA
integer($int12) example: 3333
Only allow items on the store order that belong to this merchandise hierarchy.
restrictToAreaId
NA
Only allow items on teh store order that are associated to this store sequence area.
externalCreateDate
NA
string($date-time)
The date the store order was created in an external system.
createDate
NA
string($date-time)
The date the store order was created in the system.
createUser
NA
string($text128) example: userAbc
The user that created the store order in the system.
updateDate
NA
string($date-time)
The date the store order was lasted updated in the system.
approvedDate
NA
string($date-time)
The date the store order was approved in the system.
approvedUser
NA
The user that approved the store order in the system.
lineItems
NA
object
A list of items on the store order.
Table 4-320 StoreOrderItemIdo— Object
lineId
NA
number($int12) example: 1234
The unique system identifier of the line item.
itemId
NA
approvedQuantity
NA
The quantity of the item approved to order.
suggestedQuantity
NA
The quantity of the item ordered from an external system.
caseSize
NA
unitCostCurrency
NA
string($text3) example: USD
The currency of the unit cost.
unitCostAmount
NA
number($decimal(12,4)) example: 5.5
The value of the unit cost.
deliverySlotId
NA
Response Code: 400
Bad request
Update Store Order
This section describes the Update Store Order API. This operation update the information on a store order before store order approval.
Method
POST
URL
Request Parameters
Table 4-321 Update Store Order — Request Parameters
storeOrderId
yes
integer($int12)
(path)
Details to update on the store order.
Example Value
  "requestedDeliveryDate": "2025-01-22T11:09:54.923Z",
  "lineItems": [
      "quantity": 2,
      "caseSize": 5,
Schema — StoreOrderUpdateIdo
Table 4-322 StoreOrderUpdateIdo— Object
Element Name Required Data Type/Example Description
description
NA
NA
string($date-time)
contextTypeId
NA
lineItems
NA
object
A list of line items to update on the store order.
Table 4-323 StoreOrderUpdateItemIdo— Object
itemId
Yes
quantity
Yes
If the store order originated internally, then this modifies the quantity to be requested from the external system. If the store order originated in an external system, then this defines the approved amount of the original order.
caseSize
NA
deliverySlotId
NA
Responses
This section describes the responses of the Update Store Order API.
Response Code: 204
No Content
Response Code: 400
Bad request
The media type is application/json.
See the JSON Error Element and Error Codes section.
Approve Store Order
This section describes the Approve Store Order API. This operations will approve a store order. It may be either a new request for inventory or the approval of an already existing transfer or purchase order. Either way, the store is approved and a notification sent to external systems, either a request to create a new transfer/purchase order or notification of an approval of an existing transfer/purchase order.
Method
POST
URL
/storeorders/{storeOrderId}/approve
Request Parameters
Table 4-324 Approve Store Order — Request Parameters
storeOrderId
yes
integer($int12)
(path)
Responses
This section describes the responses of the Approve Store Order API.
Response Code: 204
No Content
Response Code: 400
Bad request
Cancel Store Order
This section describes the Cancel Store Order API. This operation will cancel the store order.
Method
POST
URL
/storeorders/{storeOrderId}/cancel
Request Parameters
Table 4-325 Cancel Store Order — Request Parameters
Parameter Required Data Type Description
storeOrderId
yes
integer($int12)
(path)
Responses
This section describes the responses of the Cancel Store Order API.
Response Code: 204
No Content
Response Code: 400
Bad request
Import Store Order
This operation will import store orders from an external system. These store orders are already transfers or purchase orders that are being planned and require store approval before proceeding.
Method
POST
URL
/storeorders
Request Parameters
There are no request parameters.
The request body is application/json.
Details about the store order.
Example Value
  "orderNumber": "7000",
  "storeId": 1234,
  "locationType": 1,
  "locationId": 4500,
  "requestedDeliveryDate": "2025-01-22T11:41:05.395Z",
  "comments": "Automated department replenishment",
  "lineItems": [
      "quantity": 2,
      "caseSize": 5,
Schema — StoreOrderImportIdo
Table 4-326 StoreOrderImportIdo — Object
orderNumber
Yes
The original transfer or purchase order identifier of the store order from an external system.
storeId
Yes
locationType
Yes
integer($int4) example: 1
1 - Supplier
2 - Warehouse
Enum: [ 1, 2 ]
locationId
Yes
integer($int18) example: 4500
The identifier the location shipping the goods.
parentReference
NA
NA
string($date-time)
The date the store requests the delivery arrive by.
contextTypeId
NA
deliverySlotId
NA
currencyCode
NA
integer($int15) example: USD
The currency code of cost values on the order.
comments
NA
string($text2000) example: Automated department replenishment
Comments associated to the store order.
lineItems
Yes
object
The items to import on the store order.
Table 4-327 StoreOrderImportItemIdo — Object
itemId
NA
quantity
NA
number($decimal20,4) example: 2
The quantity of the suggested item order generated from an external system.
caseSize
NA
number($decimal10,2) example: 5
unitCostAmount
NA
The value of the unit cost in the currency of the order.
Responses
This section describes the responses of the Import Store Order API.
Response Code: 200
The request has been successful.
Example Value
    "storeId": 1234,
    "status": 1
Table 4-328 StoreOrderStatusIdo — Object
storeOrderId
NA
storeId
NA
status
NA
1 - New
2 - In Progress
3 - Approved
4 - Canceled
5 - Submitted
Response Code: 400
Bad request
Find Order Timeslots
This section describes the Find Order Timeslots. This API retrieves all the store order delivery timeslots.
Method
GET
URL
/storeorders/timeslots
Request Parameters
Responses
This section describes the responses of the Find Order Timeslots API.
Response Code: 200
Example Value
    "id": 1,
    "code": "Morn",
    "description": "Morning",
    "sequence": 1,
    "publish": true
Schema — StoreOrderTimeslotIdo
Table 4-329 StoreOrderTimeslotIdo — Object
id
NA
number($int15) example: 1
The unique identifier of the delivery slot.
code
NA
string($text15) example: Morn
The external code of the delivery time slot.
description
NA
string($text240) example: Morning
The description of the time slot.
sequence
NA
number($int8) example: 1
The order the time slot should appear in a list.
publish
NA
True if the delivery time slot should be published, false otherwise.
Response Code: 400
Bad request
Find Order Context Types
This section describes the Find Order Context Types. This API retrieves all the context type available for a store order
Method
GET
URL
/storeorders/contexts
Request Parameters
Responses
This section describes the responses of the Find Order Context Types API.
Response Code: 200
Example Value
    "id": 11111,
    "code": "CS",
    "description": "Consumables",
    "sequence": 1
Schema — StoreOrderContextTypeIdo
Table 4-330 StoreOrderContextTypeIdo — Object
id
NA
number($int18) example: 11111
The identifier of the context type.
code
NA
string($text6) example: CS
The identification code of the context type.
description
NA
string($text1) example: Consumables
The description of the context type.
sequence
NA
number($int3) example: 1
This number indicates the order the context type should appear in a list.
Response Code: 400
Bad request
Find Order Areas
This section describes the Find Order Areas. This API retrieves all the order areas available for a store order.
Method
GET
URL
/storeorders/areas/{storeId}
Request Parameters
Table 4-331 Find Order Areas— Request Parameters
storeId
yes
integer($int10)
(path)
The store to retrieve completed product areas for.
Responses
This section describes the responses of the Find Order Areas API.
Response Code: 200
Example Value
    "areaId": 13413513443,
    "itemBasketId": 34134134,
    "description": "11111"
Schema — StoreOrderAreaIdo
Table 4-332 StoreOrderAreaIdo — Object
areaId
NA
integer($int12) example: 13413513443
The unique identifier of the product area.
itemBasketId
NA
integer($int12) example: 34134134
The unique identifier of an item basket associated to the area.
description
NA
string($text255) example: 11111
The description of the store order product area.
Response Code: 400
Bad request
REST Service: Store Sequencing
This service defines operations to manage Store Sequence information.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/sequences
APIs
API
Description
Find Sequence Areas
Finds sequence area header based on search criteria.
Read Sequence Area
Reads the details of a sequence area.
Create Sequence Area
Create a sequence area along with all its details.
Update Sequence Area
Replace the entire sequence area including all its details (a complete sequence area must be sent).
Delete Sequence Area
Delete a sequenced area and all its details.
Create Sequence Item
Create a single sequence item in a sequence area.
Update Sequence Item
Updates a single sequence item from a sequence area.
Delete Sequence Item
Removes a single sequence item from a sequence area.
API: Find Sequence Areas
This API is used to search for sequence area headers. No items or detailed information is returned by this API. At least one criteria is required in order to search.
API Basics
Table 4-333 API Basics
Endpoint URL
{base URL}
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
Query Parameters
Output
Collection of Sequence Areas
Max Response Limit
15,000
Query Parameters
Table 4-334 Query Parameters
Attribute
Type
Definition
storeId
Long(12)
Include only records for this store.
areaType
Integer(9)
Area Type (see Index).
departmentId
Long(12)
The unique identifier of a department associated to the area.
classId
Long(12)
The unique identifier of a class within the department associated to the area.
itemId
String(25)
Include only records with this item on them.
Table 4-335 Output Data Definition
Attribute
Type
Definition
sequenceAreaId
Long(10)
The unique identifier of the sequence area.
storeId
Long(10)
The unique identifier of the store.
description
String(255)
A description of this store sequence.
areaType
Integer(9)
departmentId
Long(12)
classId
Long(12)
sequenceOrder
Long(20
The order of this store sequence compared to other store sequences at the store.
unsequenced
Boolean
True indicates that this is a default sequence area that contains all the items that have not been sequenced within a different area.
API: Read Sequence Area
This API is used to read an entire sequence area including its details.
API Basics
Table 4-336 API Basics
Endpoint URL
{base URL}/{sequenceAreaId}
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
N/A
Output
Sequence Area
Max Response Limit
N/A
Table 4-337 Path Parameter Definition
Attribute
Type
Definition
sequenceAreaId
Long(10)
Table 4-338 Output Data Definition
Attribute
Type
Definition
sequenceAreaId
Long(10)
storeId
Long(10)
description
String(255)
areaType
Integer(9)
departmentId
Long(12)
classId
Long(12)
sequenceOrder
Long(20
unsequenced
Boolean
Items
Collection
Contains all the items in the area (see Store Sequence Item)
Store Sequence Item
Table 4-339 Store Sequence Item
Payload
Type
Definition
sequenceItemId
Long(12)
The unique area item identifier.
itemId
String(25)
The unique identifier of the item
sequenceOrder
Long(20)
The order of the item within its sequence.
capacity
BigDecimal(11,2)
The amount of the item that can be contained in the area for that item at the unit of measure.
width
Long(12)
The number of items that can fit across the width of the shelf.
uomMode
Integer(2)
The mode of display of the unit of measure of the item.
primaryLocation
Boolean
Y indicates this is the primary sequence for the item.
ticketQuantity
BigDecimal(11,2)
The quantity of tickets that need to be printed for the item inventory area.
ticketFormatId
Long(10)
The unique identifier of the ticket format used to print the tickets.
API: Create Sequence Area
API Basics
Endpoint URL
{base URL}
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
Sequence Area Create Info
Output
Sequence Area Reference Info
Max Response Limit
1,000 items in the area
Input Data Definition
Attribute
Type
Req
Definition
storeId
Long(10)
X
description
String(255)
areaType
Integer(9)
X
departmentId
Long(12)
classId
Long(12)
sequenceOrder
Long(20)
X
The order of this store sequence compared to other store sequences at the store. The sequence order must be unique for the set of areas within the store.
items
Collections
X
All the items that belong to this sequence area (see Sequence Area Item Create)
Store Sequence Area Item Create
Payload
Type
Req
Definition
itemId
String(25)
X
sequenceOrder
Long(20)
X
capacity
BigDecimal(11,2)
X
width
Long(12)
uomMode
Integer(2)
X
primaryLocation
Boolean
ticketQuantity
BigDecimal(11,2)
ticketFormatId
Long(10)
Attribute
Type
Definition
sequenceAreaId
Long(12)
The newly created adjustment identifier.
storeId
Long(10)
The store identifier.
Example
Create Sequence Area Input Example
API: Update Sequence Area
This API is used to update a sequence area within a store.
This API will replace the entire sequence area with the new data passed to the API. Only the area identifier and store identifier will be preserved from previous data.
API Basics
Table 4-340 API Basics
Endpoint URL
{base URL}
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Input
Sequence Area Update Info
Output
N/A
Max Response Limit
Table 4-341 Path Parameter Definition
Attribute
Type
Definition
sequenceItemId
Long(12)
Table 4-342 Input Data Definition
Attribute
Type
Req
Definition
description
String(255)
areaType
Integer(9)
X
departmentId
Long(12)
classId
Long(12)
sequenceOrder
Long(20)
X
items
Collections
X
All the items that belong to this sequence area (see Sequence Area Item Update)
Store Sequence Area Item Update
Table 4-343 Store Sequence Area Item Update
Payload
Type
Req
Definition
itemId
String(25)
X
sequenceOrder
Long(20)
X
capacity
BigDecimal(11,2)
X
width
Long(12)
uomMode
Integer(2)
X
primaryLocation
Boolean
ticketQuantity
BigDecimal(11,2)
ticketFormatId
Long(10)
Example
Store Sequence Area Item Update Example
API: Delete Sequence Area
This API is used to delete a sequence area and all its items. This will not delete a sequence area currently being used by a sequenced stock count.
API Basics
Table 4-344 API Basics
Endpoint URL
{base URL}
Method
DELETE
Successful Response
204 No Content
Processing Type
Synchronous
Input
N/A
Output
N/A
Max Response Limit
N/A
API: Create Sequence Item
This API is used to create a new sequence item within a sequence area.
API Basics
Table 4-345 API Basics
Endpoint URL
{base URL}/{sequenceAreaId}/items
Method
POST
Successful Response
200 No Content
Processing Type
Synchronous
Input
Store Sequence Item Create
Output
Store Sequence Item
Max Response Limit
N/A
Table 4-346 Input Data Definition
Payload
Type
Req
Definition
itemId
String(25)
X
sequenceOrder
Long(20)
X
capacity
BigDecimal(11,2)
X
width
Long(12)
uomMode
Integer(2)
X
The mode of display of the unit of measure of the item. (see Index)
primaryLocation
Boolean
ticketQuantity
BigDecimal(11,2)
ticketFormatId
Long(10)
Example
Example: Create Sequence Item
API: Update Sequence Item
This API is used to update a sequence item within a sequence area.
API Basics
Table 4-347 API Basics
Endpoint URL
{base URL}/{sequenceAreaId}/items/{itemId}
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Input
N/A
Output
N/A
Max Response Limit
N/A
Table 4-348 Path Parameter Definition
Attribute
Type
Definition
sequencerAreaId
Long(12)
The unique sequence area identifier.
itemId
String(25)
The item to be deleted from the sequence.
Table 4-349 Input Data Definition
Payload
Type
Req
Definition
sequenceOrder
Long(20)
X
capacity
BigDecimal(11,2)
X
width
Long(12)
uomMode
Integer(2)
X
primaryLocation
Boolean
ticketQuantity
BigDecimal(11,2)
ticketFormatId
Long(10)
Example
Example: Update Sequence Item
API: Delete Sequence Item
This API is used to delete a sequence item from an area.
API Basics
Table 4-350 API Basics
Endpoint URL
Method
DELETE
Successful Response
204 No Content
Processing Type
Synchronous
Input
N/A
Output
N/A
Max Response Limit
N/A
Table 4-351 Path Parameter Definition
Attribute
Type
Definition
sequencerAreaId
Long(12)
itemId
String(25)
Sequence Area Type
Table 4-352 Sequence Area Type
ID
Status
1
Shopfloor
2
Backroom
3
None
Sequence UOM Mode
Table 4-353 Sequence UOM Mode
ID
Status
1
Units
2
Cases
REST Service: Supplier
This service integrates supplier and supplier item foundation data.
Asynchronous supplier integration is processed through staged messages and is controlled by the MPS Work Type: DcsSupplier.
Asynchronous supplier item integration is processed through staged messages and is controlled by the MPS Work Type: DcsSupplierItem.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/suppliers
API Definitions
API
Description
Import Suppliers
Imports supplier.
Delete Supplier
Deletes a supplier.
Import Items
Imports items for a supplier.
Delete Items
Deletes items from a supplier.
Import Item UOMs
Imports units of measure for a supplier item.
Delete Item UOMs
Deletes units of measure from a supplier item.
Import Item Countries
Imports countries for a supplier item.
Delete Item Countries
Deletes countries from a supplier item.
Import Item Dimensions
Imports items dimensions for a supplier item country.
Delete Item Dimensions
Deletes dimensions from a supplier item country.
Import Item Manufacturers
Imports manufacturers for a supplier item country.
Delete Item Manufacturers
Deletes manufacturers from a supplier item country.
API: Import Suppliers
Imports a list of suppliers.
If the import contains more than 500 suppliers, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/import
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of suppliers to Import
Output
None
Max Response Limit
500
Attribute
Data Type
Required
Description
suppliers
List of details
Yes
A collection of up to 500 suppliers to import.
Detail Data Definition
Attribute
Data Type
Required
Description
supplierId
Long (10)
Yes
The supplier identifier.
name
String (240)
The supplier's name.
status
Integer
Yes
The supplier’s status: See Supplier Status
dunsNumber
String (9)
The nine-digit number assigned and maintained by Dun and Bradstreet.
taxId
String (18)
The tax identification number of the supplier.
parentId
Long (128)
The parent supplier's identifier.
countryCode
String (3)
The 2-3 character ISO code of the country.
languageCode
String (3)
The 2-3 character ISO code of the language.
currencyCode
String (3)
The 2-3 character ISO code of the currency.
returnAllowed
Boolean
True is return is allowed to the supplier, N otherwise.
authorizationRequired
Boolean
True indicates an authorization number is required when merchandise is return to this supplier.
orderCreateAllowed
Boolean
True indicates at a purchase order can be created for the supplier when processing deliveries from that supplier.
vendorCheck
Boolean
True indicates that orders from this supplier requires vendor control.
vendorCheckPercent
BigDecimal
Indicates the percentage of items per receipt that will be marked for vendor checking.
quantityLevel
Integer
Yes
The Quantity Level: See Quantity Level
deliveryDiscrepancy
Integer
Yes
The delivery discrepancy: See Supplier Delivery Discrepancy Type
organizationUnitIds
List<Long>
Yes
A complete list of organization unit identifiers for the supplier.
Example Input
"suppliers": [
"supplierId": 5000,
"status": 1,
"quantityLevel": 1,
"deliveryDiscrepancy": 1,
"organizationUnitIds": [ 1 ]
"supplierId": 5001,
"status": 1,
"returnAllowed": false,
"quantityLevel": 1,
Value
Definition
1
Allow Any Discrepancy
2
Allow Overage But Not Short Receipts
3
Discrepancy Not Allowed
Supplier Status
Value
Definition
1
Active
2
Inactive
Quantity Level
Value
Definition
1
Eaches
2
Cases
API: Delete Supplier
Deletes a supplier.
API Basics
Endpoint URL
{base URL}/{supplierId}/delete
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
None
Output
None
Max Response Limit
1000
Attribute
Definition
supplierId
The internal identifier of the supplier.
API: Import Items
Imports supplier items. Later during asynchronous processing, it validates that both the supplier and item exist before inserting new records.
If the import contains more than 500 supplier items, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/items
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of Supplier Items to import
Output
None
Max Response Limit
500
Attribute
Definition
supplierId
Attribute
Data Type
Required
Description
items
List of details
Yes
The supplier item information to import.
Attribute
Data Type
Required
Description
supplierId
Long (10)
Yes
itemId
String (25)
Yes
The item identifier.
vendorProductNumber
String (256)
Vendor product number.
primary
Boolean
True indicates this supplier is the primary supplier for the item at all locations.
Example Input
"items": [
"supplierId": 5000,
"itemId": "163715121",
"vendorProductNumber": "abc"
"supplierId": 5001,
"vendorProductNumber": "def"
API: Delete Items
Deletes supplier items.
If the delete contains more than 500 supplier items, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/items/delete
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of supplier items
Output
None
Max Response Limit
500
Attribute
Data Type
Required
Description
items
List of details
Yes
The supplier item information to delete.
Attribute
Data Type
Required
Description
supplierId
Long (10)
Yes
itemId
String (15)
Yes
Example Input
"items":
"supplierId":"9002",
"itemId": "100637130"
"itemId": "100637148"
API: Import Item UOMs
Imports supplier item unit of measure information.
If the import contains more than 500 supplier item units of measure, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/uoms
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of supplier items UOMs to import
Output
None
Max Response Limit
500
Attribute
Data Type
Required
Description
uoms
List of details
Yes
The UOMs to import.
Attribute
Data Type
Required
Description
supplierId
Long (10)
Yes
itemId
String (25)
Yes
unitOfMeasure
String (4)
Yes
The unit of measure.
Value
BigDecimal
Yes
Equivalent item/supplier shipping carton value in unit of measure
Example Input
"uoms": [
"supplierId": 5000,
"unitOfMeasure": "KG",
"value": "1.0"
"supplierId": 5001,
"value": "1.0"
API: Delete Item UOMs
Deletes supplier item unit of measure information.
If the delete contains more than 500 supplier item units of measure, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/uoms/delete
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of supplier items UOMs to delete
Output
None
Max Response Limit
500
Attribute
Data Type
Required
Description
uoms
List of details
Yes
The UOMs to delete.
Attribute
Data Type
Required
Description
supplierId
Long (10)
Yes
itemId
String (25)
Yes
unitOfMeasure
String (4)
Yes
Example Input
"uoms":
"itemId": "100637130",
"unitOfMeasure":"EA"
"itemId": "100637148",
API: Import Item Countries
Imports supplier item country information. If the imported supplier item country is for the primary supplier of the item, the item's case size will be updated on the item master to reflect the imported case size.
If the import contains more than 500 supplier item countries, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/countries
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of supplier items country to import
Output
None
Max Response Limit
500
Attribute
Data Type
Required
Description
countries
List of details
Yes
The countries to import.
Attribute
Data Type
Required
Description
supplierId
Long (10)
Yes
itemId
String (25)
Yes
countryCode
String (3)
Yes
The ISO country code of the supplier that produces the item.
caseSize
BigDecimal
Yes
Number of items with a case from the supplier.
unitCostCurrency
String (3)
The unit cost currency for that item and supplier in that country.
unitCostValue
BigDecimal
The unit cost of the item and supplier in that country.
Example Input
    "countries": [
            "supplierId": 5100,
            "caseSize":7
            "supplierId": 5200,
            "caseSize":8
API: Delete Item Countries
Deletes supplier item country information.
If the delete contains more than 500 supplier item countries, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/countries/delete
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of supplier items country to remove
Output
None
Max Response Limit
500
Attribute
Data Type
Required
Description
countries
List of details
Yes
The countries to remove.
Attribute
Data Type
Required
Description
supplierId
Long (10)
Yes
itemId
String (25)
Yes
countryCode
String (3)
Yes
Example Input
"countries":
"countryCode":"US"
API: Import Item Dimensions
Imports supplier item country dimension information.
If the import contains more than 500 supplier item dimensions, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/dimensions
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of supplier items dimensions to import
Output
None
Max Response Limit
500
Attribute
Data Type
Required
Description
dimensions
List of details
Yes
The dimensions to import.
Attribute
Data Type
Required
Description
supplierId
Long (10)
Yes
itemId
String (25)
Yes
countryCode
String (3)
Yes
dimensionName
String (6)
Yes
Dimension name
presentationMethod
String (6)
Describes the packaging method
Length
BigDecimal
The length in dimension unit of measure.
Width
BigDecimal
The width in dimension unit of measure.
Height
BigDecimal
The height in dimension unit of measure.
dimensionUom
String (4)
The unit of measure of the dimensions.
Weight
BigDecimal
The weight of the object in weight unit of measure.
netWeight
BigDecimal
The net weight of the goods without packaging in weight unit of measure.
weightUom
String (4)
The weight unit of measure.
liquidVolume
BigDecimal
The liquid value or capacity of the object.
liquidVolumeUom
String (4)
The liquid volume unit of measure.
statisticalCube
BigDecimal
A statistical value of the object’s dimensions used for shipment loading purposes.
Example Input
"dimensions": [
"supplierId": 5100,
"dimensionName": "Hello"
"supplierId": 7100,
"dimensionName": "Bye"
API: Delete Item Dimensions
Deletes supplier item country dimension information.
API Basics
Endpoint URL
{base URL}/dimensions/delete
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of supplier items dimensions to remove
Output
None
Max Response Limit
500
Attribute
Data Type
Required
Description
Dimensions
List of details
Yes
The dimensions to remove.
Supplier Items Dimensions Data Definition
Attribute
Data Type
Required
Description
supplierId
Long (10)
Yes
itemId
String (25)
Yes
countryCode
String (3)
Yes
dimensionName
String (6)
Yes
Dimension name
Example Input
"dimensions":
"countryCode":"US",
"dimensionName":"Dimen1"
"countryCode":"US",
"dimensionName":"Dimen2"
API: Import Item Manufacturers
Import supplier item country manufacturer information.
If the import contains more than 500 supplier item manufacturers, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/manufacturers
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of supplier items manufacturer to import
Output
None
Max Response Limit
500
Attribute
Data Type
Required
Description
manufacturers
List of details
Yes
The manufacturers to import.
Attribute
Data Type
Required
Description
supplierId
Long (10)
Yes
itemId
String (25)
Yes
countryCode
String (3)
Yes
primary
Boolean
True indicates it is primary country of manufacture.
Example Input
"manufacturers": [
"supplierId": 5100,
"primary": true
"supplierId": 7100,
"primary": true
API: Delete Item Manufacturers
Deletes supplier item country manufacturer information.
If the delete contains more than 500 supplier item manufacturers, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/manufacturers/delete
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of supplier items manufacturers to remove
Output
None
Max Response Limit
500
Attribute
Data Type
Required
Description
manufacturers
List of details
Yes
The manufacturers to remove.
Attribute
Data Type
Required
Description
supplierId
Long (10)
Yes
itemId
String (25)
Yes
countryCode
String (3)
Yes
Example Input
"manufacturers":
"countryCode":"US"
"countryCode":"US"
REST Service: Ticket
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/tickets
API Definitions
API
Description
readTicket
This API reads a current actively ticket by its identifier.
findTickets
API is used to find summarized ticket headers for a set of criteria.
readArchivedTicket
This API reads a previously printed and archived ticket by its identifier.
findArchivedTickets
API is used to find archived ticket summaries.
createTickets
Creates new tickets within the system.
updateTickets
Updates current tickets within the system.
printTickets
Prints the requested tickets.
findTicketFormats
Reads all the available ticket formats.
findTicketPrinters
Finds the printers available to print tickets.
API: readTicket
API Basics
Endpoint URL
{base URL}/{ticketId}
Method
GET
Success Response
200 OK
Processing Type
Synchronous
Input
The ticket identifier
Output
The ticket
Column
Type
Definition
ticketId
Long(12)
The unique ticket identifier.
itemId
String(25)
storeId
Long(10)
originType
Integer(2)
The origin type (See Index)
ticketFormatId
Long(12)
The identifier of the ticket format used for printing.
ticketFormatDescription
String(100)
The description of the ticket format associated to the ticket.
ticketFormatType
Integer(4)
The type of the ticket format associated to the ticket.
ticketFormatReference
String(255)
The format reference used to print the ticket.
ticketFormatZplId
Long(12)
The ZPL format file identifier.
ticketCount
Integer(3)
The number of instances of this ticket to print.
ticketSequence
Integer(3)
The sequence number of a ticket within a ticket grouping.
printQuantity
BigDecimal(12,4)
The quantity to be printed on the ticket.
printDate
Date
The date the ticket should be printed.
groupId
Long(12)
An internal EICS grouping identifier that groups the tickets.
groupIdExternal
String(128)
An external system grouping identifier that groups the tickets.
autoPrint
Boolean
True if the ticket should automatically print, false if the ticket requires manual printing.
autoRefeshQuantity
Boolean
True indicates the ticket count gets refreshed with SOH at the time of printing, false it prints as is.
countryOfManufacture
String(3)
A two letter country code denoting the country of manufacture for the item.
shortDescription
String(255)
The short description of the item.
longDescription
String(400)
The long description of the item.
shortDescriptionLanguage
String(255)
The short description of the item in the language of the store.
longDescriptionLanguage
String(400)
The long description of the item in the language of the store.
differentiatorType1
String(10)
The description of the differentiator type for differentiator 1.
differentiatorType2
String(10)
The description of the differentiator type for differentiator 2.
differentiatorType3
String(10)
The description of the differentiator type for differentiator 3.
differentiatorType4
String(10)
The description of the differentiator type for differentiator 4.
differentiatorDescription1
String(255)
The description of differentiator 1 of the item.
differentiatorDescription2
String(255)
The description of differentiator 2 of the item.
differentiatorDescription3
String(255)
The description of differentiator 3 of the item.
differentiatorDescription4
String(255)
The description of differentiator 4 of the item.
departmentId
Long(12)
The department identifier of the item.
departmentName
String(360)
The department name of the item.
classId
Long(12)
The class identifier of the item.
className
String(360)
The class name of the item.
subclassId
Long(12)
The subclass identifier of the item.
subclassName
String(360)
The subclass name of the item.
primaryUpc
String(25)
The primary Unique Product Code for the item.
priceCurrency
String(3)
The currency code of the ticket price.
priceAmount
BigDecimal(12,4)
The amount of the ticket price.
priceType
Integer(3)
The type of the ticket price. (See Index)
priceUom
String(4)
The unit of measure of the ticket price.
priceActiveDate
Date
The date the ticket price became active.
priceExpireDate
Date
The date the ticket price expires.
mutliUnitPriceCurrency
String(3)
The currency code of the ticket's multi-unit price.
multiUnitPriceAmount
BigDecimal(12,4)
The amount of the ticket's multi-unit price.
multiUnitPriceUom
String(4)
The unit of measure of the ticket's multi-unit price.
multiUnitQuantity
BigDecimal(12,4)
The multi-unit quantity associated to the price.
overridePriceCurrency
String(3)
The override price currency code.
overridePriceAmount
BigDecimal(20,4)
The override price amount.
previousPriceCurrency
String(3)
The currency code of the previous price.
previousPriceAmount
BigDecimal(12,4)
The amount of the previous price.
previousPriceType
Integer(3)
The price type of the previous price.
lowestMonthlyPriceCurrency
String(3)
The currency code of the lowest monthly price.
lowestMonthlyPriceAmount
BigDecimal(12,4)
The amount of the lowest monthly price.
lowestMonthlyPriceType
Integer(3)
The price type of the lowest monthly price.
printedDate
Date
The date that the ticket was printed.
printedUser
String(128)
The user that printed the ticket.
createDate
Date
The date the ticket was created.
createUser
String(128)
The user that created the ticket.
updateDate
Date
The date the ticket was last updated.
updateUser
String(128)
The user that last updated the ticket.
udas
Collection
A group of associated user defined attributes.
UDA
Column
Type
Definition
name
String
The name of the user defined attribute.
value
String
The value of the user defined attributes.
API: findTickets
If maximum results are exceeded, additional or more limiting input criteria will be required.
API Basics
Endpoint URL
{base URL}
Method
GET
Success Response
200 OK
Processing Type
Synchronous
Input
Query Parameters
Output
List of Ticket Headers
Maximum Results Allowed
5,000
Attribute
Type
Definition
itemId
String(25)
Include only records with this item identifier.
storeId
Long(10)
Include only records with this store identifier.
ticketFormatId
Long(12)
Include only records with this ticket format identifier.
groupId
Long(12)
Include only records with this EICS group identifier.
groupIdExternal
String(128)
Include only records with this external system group identifier.
printDateFrom
String
Include only records on or after this scheduled print date and time.
printDateTo
String
Include only records on or before this scheduled print date and time.
updateDateFrom
String
updateDateTo
String
Column
Type
Definition
ticketId
Long(12)
itemId
String(25)
storeId
Long(10)
originType
Integer(2)
ticketFormatId
Long(12)
ticketSequence
Integer(3)
groupId
Long(12)
groupIdExternal
String(128)
autoPrint
Boolean
printDate
Date
printQuantity
BigDecimal(12,4)
updateDate
Date
API: readArchivedTicket
API Basics
Endpoint URL
{base URL}/archives/{ticketId}
Method
GET
Success Response
200 OK
Processing Type
Synchronous
Input
Output
The ticket details
See readTicket() for the output data definition of this API.
API: findArchivedTickets
If the number of tickets found exceeds the limit, additional or more limiting input criteria will be required.
API Basics
Endpoint URL
{base URL}/archives
Method
GET
Success Response
200 OK
Processing Type
Synchronous
Input
Query Parameters
Output
5,000
Attribute
Type
Definition
itemId
String(25)
storeId
Long(10)
ticketFormatId
Long(12)
groupId
Long(12)
groupIdExternal
String(128)
printedDateFrom
String
Include only records that were printed on or after this date and time.
printedDateTo
String
Include only records that were printed on or before this date and time.
Column
Type
Definition
ticketId
Long(12)
itemId
String(25)
storeId
Long(10)
originType
Integer(2)
ticketFormatId
Long(12)
ticketSequence
Integer(3)
groupId
Long(12)
groupIdExternal
String(128)
printedDate
Date
The date the ticket was printed.
printQuantity
BigDecimal(12,4)
The quantity printed on the ticket.
priceCurrency
String(3)
The currency of the price of the ticket.
priceAmount
BigDecimal(12,4)
The amount of the price of the ticket.
API: createTickets
API Basics
Endpoint URL
{base URL}
Method
POST
Success Response
200 OK
Processing Type
Synchronous
Input
Ticket group
Output
List of ticket identifying information
Maximum Input Allowed
2,000 tickets within the group
Payload
Type
Req
Definition
storeId
Long(10)
X
groupIdExternal
String(128)
printDate
Date
X
autoPrint
Boolean
True if the ticket should automatically print, false if the ticket requires manual printing. Defaults to false.
autoRefeshQuantity
Boolean
True indicates the ticket count gets refreshed with SOH at the time of printing, false it prints as is. Defaults to false.
tickets
Collection
X
The tickets to create.
Ticket
Payload
Type
Req
Definition
itemId
String(25)
X
originType
Integer(2)
X
ticketFormatId
Long(12)
X
ticketCount
Integer(3)
X
ticketSequence
Integer(3)
X
printQuantity
BigDecimal(12,4)
X
String(3)
The override price currency code. Required if an amount is entered.
overridePriceAmount
BigDecimal(20,4)
String(3)
Payload
Type
Definition
ticketId
Long(12)
storeId
Long(10)
ticketFormatId
Long(12)
Example Input
    "storeId": 5000,
    "groupIdExternal": "123456",
    "printDate": "2023-01-10T23:59:59-05:00",
    "autoPrint": false,
    "autoRefreshQuantity": false,
    "tickets": [
            "originType": 1,
            "ticketFormatId": 1,
            "ticketCount": 2,
            "ticketSequence": 3
            "itemId": "100637113",
            "originType": 2,
            "ticketFormatId": 2,
            "ticketCount": 4,
            "ticketSequence": 5
API: Update Tickets
If a field that is not required contains an empty or null value, the ticket will be updated to that empty or null value.
API Basics
Endpoint URL
{base URL}/update
Method
POST
Success Response
204 No Content
Processing Type
Synchronous
Processing Type
Synchronous
Input
Tickets
Output
N/A
2,000 tickets
Payload
Type
Req
Definition
ticketId
Long(12)
X
originType
Integer(2)
X
ticketCount
Integer(3)
X
ticketSequence
Integer(3)
X
printQuantity
BigDecimal(12,4)
X
printDate
Date
X
autoPrint
Boolean
autoRefeshQuantity
Boolean
String(3)
overridePriceAmount
BigDecimal(20,4)
String(3)
Example Input
    "tickets": [
            "ticketId": 8,
            "originType": 2,
            "ticketCount": 22,
            "ticketSequence": 33
            "ticketId": 9,
            "originType": 1,
            "ticketCount": 44,
            "ticketSequence": 55
API: printTickets
Prints the requested tickets. This can print both current tickets and previously printed tickets.
It is assumed that the calling system will have verified or retrieved the ticket ids prior. The ticket ids and archived ticket ids will not be validated.
This service operation will simply print any tickets that are found that match identifiers passed in and ignore any identifiers for which tickets are not found.
Depending on printing configuration with the system, the printing may occur synchronous and real-time or the tickets may be staged and sent asynchronously to another system after a short delay.
API Basics
Endpoint URL
{base URL}/print
Method
POST
Success Response
204 No Content
Processing Type
Synchronous/Asynchronous
Input
Ticket identifiers
Output
N/A
100 total ticket ids
Payload
Type
Req
Definition
printerId
Long
X
The identifier of the printer to print the tickets on.
refreshQuantity
Boolean
If true, the quantities of all the tickets will be refreshed prior to printing. If false, they will not.
ticketIds
List<Long>
A list of ticket identifiers of the tickets to print. If this is null or empty, then archived ticket ids must contain a value. Not validated.
archivedTicketIds
List<Long>
A list of archived ticket identifiers of tickets to print. If this is null or empty, then ticket ids must contain a value. Not validated.
API: findTicketFormats
API Basics
Endpoint URL
{base URL}/formats
Method
GET
Success Response
200 OK
Processing Type
Synchronous
Input
Query parameters
Output
List of ticket formats
Column
Type
Definition
storeId
Long(10)
Include only ticket formats available at this store.
Column
Type
Definition
formatId
Long(12)
The unique format identifier.
storeId
Long(10)
description
String(100)
A description of the ticket (possibly from ticket format).
type
Integer(4)
The type of ticket format. (See Index)
zplTemplateId
Long(12)
The unique identifier to the ZPL template to be used for printing.
formatReference
String(255)
A reference to the format content to use for this format.
defaultFormat
Boolean
True if this is the default form for the type, False otherwise.
defaultPrinterId
Long(6)
Teh default printer identifier for the format.
createDate
Date
The date the format was created.
createUser
String(128)
The user that created the format.
updateDate
Date
The date the format was last updated.
updateUser
String(128)
The user that last updated the format.
API: findTicketPrinters
API Basics
Endpoint URL
{base URL}/printers
Method
GET
Success Response
200 OK
Processing Type
Synchronous
Input
Query parameters
Output
List of printers
Query Params
Column
Type
Definition
storeId
Long(10)
Include only ticket printers available at this store.
Column
Type
Definition
printerId
Long(6)
The unique identifier of the printer.
storeId
Long(10)
The identifier of the store the printer is assigned to.
printerType
Integer(3)
The print type of the printer (see Index).
printerDescription
String(200)
A description of the printer.
printerUri
String(300)
The URI address of the printer.
printerName
String(128)
The logical name of the printer.
defaultManifest
Boolean
True if the printer is the default printer at the store for manifest printing.
defaultPreshipment
Boolean
True if the printer is the default printer at the store for preshipment printing.
Additional Data Definitions
Ticket Format Type
ID
Description
1
Item Basket
2
Shelf Label
Price Type
ID
Description
1
Permanent
2
Promotional
3
Clearance
4
Clearance Reset
Printer Type
ID
Description
1
Item Ticket
2
Shelf Label
3
Postscript
Ticket Origin Type
ID
Description
1
External
2
Price Change
3
Foundation
4
Manual
5
Promotional Price Change
6
Clearance Price Change
7
Permanent Price Change
8
Reset Price Change
REST Service: Transfer
Transfers define the movement of goods between internal entities or trading partners. Requests from corporate or other stores for shipping inventory out can be auto-approved without human interaction and it is possible to transfer unavailable inventory between entities with a store as a starting or ending point of the transaction. A transfer defines the logical movement of goods and are often created at corporate offices. They define the intent of what needs to be shipped. Some validations and features to consider include transfer zone restrictions may be enforced, shipping network restrictions may be enforced, auto receiving may be active, and non-inventory items may be transferred. A transfer request is a transfer that is initiated by the receiving location and is awaiting approval from the sending location. Once approved, it can be shipped. A transfer can be initiated by the sending location without any request or input from the receiving location. Once approved, it can be shipped. This service defines operations to manage transfer information by integration with an external system.
Server Base URL
Find Transfer
This section describes the Find Transfer API. The Find Transfer API finds up to 10,000 summary header records of both transfers and transfer requests that match the search criteria.
Method
GET
URL
/transfers
Request
Table 4-354 Find Transfer — Request Parameters
externalTransferId
NA
Include only transfers with this external transfer identifier.
sourceLocationId
NA
Include only transfers with this source location identifier.
sourceLocationType
NA
Include only transfers with this source location type. Valid values are:
1 - Store
2 - Warehouse
3 - Finisher
Available values : 1, 2, 3
destinationLocationId
NA
Include only transfers with this destination location identifier.
destinationLocationType
NA
Include only transfers with this desintation location type. Valid values are:
1 - Store
2 - Warehouse
3 - Finisher
status
NA
Include only shipments with this delivery status. Valid values are:
1 - New Request
2 - Requeste
3 - Request In Progress
4 - Rejected Request
5 - Canceled Request
6 - Transfer In Progress
7 - Approved
8 - In Shipping
9 - Completed Transfer
10 - Canceled Transfer
99 - Active
Available values : 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 99
itemId
NA
string($text25) (query)
Include only transfers that contain this item.
updateDateFrom
NA
Include only transfers with an update date on or after this date.
updateDateTo
NA
Include only transfers with an update date on or before this date.
Responses
This section describes the responses of the Find Transfer API.
Response Code: 200
Example Value
    "transferid": 11111,
    "externalTransferId": "AX57684",
    "sourceLocationType": 1,
    "sourcelocationId": 4000,
    "desintationLocationType": 1,
    "destinationLocationId": 5000,
    "status": 1,
    "originType": 1,
    "notAfterDate": "2024-09-19T09:10:14.140Z",
    "createDate": "2024-09-19T09:10:14.140Z",
    "updateDate": "2024-09-19T09:10:14.140Z",
    "requestDate": "2024-09-19T09:10:14.140Z",
    "approvalDate": "2024-09-19T09:10:14.140Z"
Schema — TransferSummaryIdo
Table 4-355 TransferSummaryIdo —Object
transferid
NA
integer($int15) example: 11111
The unique identifier of the transfer.
externalTransferId
NA
string($text128) example: AX57684
An identifier supplied from an external system.
sourceLocationType
NA
The type of the source location of the transfer. Valid values are:
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
sourcelocationId
NA
integer($int10) example: 4000
The identifier of the source location of the transfer.
NA
The type of the destination location of the transfer. Valid values are:
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
NA
integer($int10) example: 5000
The identifier of the destination location of the transfer.
status
NA
The current status of the transfer. Valid values are:
1 - New Request
2 - Request
7 - Approved
8 - In Shipping
Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 ]
originType
NA
The origin type of the transfer. Valid values are:
1 - External
2 - Internal
3 - Adhoc
Enum: [ 1, 2, 3 ]
notAfterDate
NA
string($date-time)
A date after which the transfer should not be shipped.
createDate
NA
string($date-time)
The date the transfer was created.
updateDate
NA
string($date-time)
The date the transfer was last updated.
requestDate
NA
string($date-time)
The date the transfer was requested.
approvalDate
NA
string($date-time)
The date the transfer was approved.
Response Code: 400
Bad request
Create Transfer
The Create Transfer API creates a new transfer from a source store that does not need involvement or approval from a receiving location. The transfer will be created as in progress and must be approved before shipping can begin.
Method
POST
URL
/transfers
Request
The request body is appliaction/json.
Details about the transfer to create.
Example Value
  "sourceStoreId": 5000,
  "destinationLocationType": 1,
  "notAfterDate": "2025-01-10T12:45:31.430Z",
  "authorizationCode": "1111",
  "contextTypeId": 400000,
  "contextValue": "Repair Needed",
  "useUnavailableInventory": false,
  "allowPartialDelivery": true,
  "lineItems": [
      "itemId": "10045600",
      "quantity": 100,
      "caseSize": 3
  "notes": [
    "Transfer needs to be rushed.",
    "Items are in the back room."
Schema — TransferCreateIdo
Table 4-356 TransferCreateIdo —Object
sourceStoreId
Yes
The identifier of the store that will be shipping the goods.
Yes
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
Yes
notAfterDate
NA
string($date-time)
authorizationCode
NA
string($text12) example: 1111
An authorization code assigned to the transfer.
contextTypeId
NA
number($int18) example: 400000
Unique identifier of a context associated to the transfer.
contextValue
NA
string($text25) example: Repair Needed
A value or some information related to the context associated to the transfer.
NA
boolean example: false
True if the transfer is for unavailable inventory, false otherwise.
NA
True indicates that a partial delivery is allowed for the transfer, false indicates it is not.
lineItems
Yes
object
A collection of up to 5,000 items to be added to the transfer.
notes
NA
string($text2000) example: List [ "Transfer needs to be rushed.", "Items are in the back room." ]
A collection of notes that will be added to the transfer notes.
Table 4-357 TransferCreateLineItemIdo —Object
itemId
Yes
string($text25) example: 10045600
The unique identifier of the SKU item.
quantity
Yes
number($decimal(20,4)) example: 100
The quantity that is requested.
caseSize
NA
number($decimal(10,2)) example: 3
The case size of this record.
Responses
This section describes the responses of the Create Transfer API.
Response Code: 200
Example Value
    "transferId": 11111,
    "sourceLocationId": 4000,
    "status": 1,
    "originType": 1,
    "notAfterDate": "2025-01-08T12:56:00.798Z",
    "createDate": "2025-01-08T12:56:00.798Z",
    "updateDate": "2025-01-08T12:56:00.798Z",
    "requestDate": "2025-01-08T12:56:00.798Z",
    "approvalDate": "2025-01-08T12:56:00.798Z"
Table 4-358 TransferSummaryIdo —Object
transferid
NA
externalTransferId
NA
sourceLocationType
NA
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
sourcelocationId
NA
NA
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
NA
status
NA
1 - New Request
2 - Request
7 - Approved
8 - In Shipping
originType
NA
1 - External
2 - Internal
3 - Adhoc
Enum: [ 1, 2, 3 ]
notAfterDate
NA
string($date-time)
createDate
NA
string($date-time)
updateDate
NA
string($date-time)
requestDate
NA
string($date-time)
approvalDate
NA
string($date-time)
Response Code: 400
Bad request
Read Transfer
The Read Transfer API retrieves all the details about a transfer or transfer request.
Method
GET
URL
/transfers/{transferId}
Request
Table 4-359 Read Transfer — Request Parameter
transferId
Yes
number($int12) (path)
Responses
This section describes the responses of the Read Transfer API.
Response Code: 200
Example Value
    "distroNumber": "440213",
    "status": 1,
    "originType": 1,
    "contextTypeCode": "CNTXA",
    "customerOrderNumber": "67008700",
    "fulfillmentOrderNumber": "67008711",
    "useAvailable": true,
    "notAfterDate": "2025-01-08T13:34:27.151Z",
    "createDate": "2025-01-08T13:34:27.151Z",
    "createUser": "smith123",
    "updateDate": "2025-01-08T13:34:27.151Z",
    "updateUser": "smith123",
    "requestDate": "2025-01-08T13:34:27.151Z",
    "requestUser": "smith123",
    "approvalDate": "2025-01-08T13:34:27.151Z",
    "approvedUser": "smith123",
    "importId": "smith123",
    "lineItems": [
        "lineId": 2222222,
        "caseSize": 3,
        "quantityRequested": 100,
        "quantityApproved": 90,
        "quantityShipping": 50,
        "quantityShipped": 40,
        "quantityReceived": 20,
        "quantityDamaged": 20,
        "preferredUom": "EA"
Schema — TransferIdo
Table 4-360 TransferIdo — Object
transferid
NA
externalTransferId
NA
distroNumber
NA
string($text128) example: 440213
A distribution number( used for integration with other systems). It is another type of external identifier.
sourceLocationType
NA
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
sourcelocationId
NA
NA
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
NA
status
NA
1 - New Request
2 - Requeste
7 - Approved
8 - In Shipping
originType
NA
1 - External
2 - Internal
3 - Adhoc
Enum: [ 1, 2, 3 ]
contextTypeId
NA
contextTypeCode
NA
integer($int4) example: CNTXA
An external code of a context associated to the transfer.
contextValue
NA
customerOrderNumber
NA
string($text128) example: 67008700
External system identifier of a customer order.
NA
string($text128) example: 67008711
External system identifier of a fulfillment order.
NA
True indicates that parial delivery is allowed for the transfer, false indicates it is not.
useAvailable
NA
True indicates the transfer must use available stock, false indicates it uses unavailable stock.
authorizationCode
NA
notAfterDate
NA
string($date-time)
createDate
NA
string($date-time)
createUser
NA
string($text128) example: smith123
The user that created this transfer.
updateDate
NA
string($date-time)
updateUser
NA
The user that last updated this transfer.
requestDate
NA
string($date-time)
requestUser
NA
The user that requested this transfer.
approvalDate
NA
string($date-time)
approvedUser
NA
The user that approved this transfer.
importId
NA
An identifier from an original data seed import.
lineItems
object
Line items
Table 4-361 TransferLineItemIdo — Object
lineId
NA
integer($int15) example: 2222222
The unique identifier of the line record.
itemId
NA
caseSize
NA
quantityRequested
NA
The quantity that was requested.
quantityApproved
NA
number($decimal(20,4)) example: 90
The quantity that was approved.
quantityShipping
NA
number($decimal(20,4)) example: 50
The quantity that is currently in shipping.
quantityShipped
NA
number($decimal(20,4)) example: 40
The quantity that has shipped.
quantityReceived
NA
number($decimal(20,4)) example: 20
The quantity that was received into stock.
quantityDamaged
NA
The quantity that was received as damaged.
preferredUom
NA
string($text4) example: EA
The preferred unit of measure of this line item.
Response Code: 400
Bad request
Update Transfer
The Update Transfer API updates a transfer request that has been requested or updates a newly created transfer that is prior to being approved. It allows the approved quantities to be updated until the transfer becomes approved.
Method
POST
URL
Request
Table 4-362 Update Transfer — Request Parameter
transferId
Yes
Details about the transfer to update.
Example Value
  "notAfterDate": "2025-01-10T12:58:44.635Z",
  "lineItems": [
      "quantity": 100,
      "caseSize": 3
  "notes": [
Schema — TransferRequestUpdateIdo
Table 4-363 TransferRequestUpdateIdo— Object
sourceStoreId
Yes
destinationStoreId
Yes
contextTypeId
NA
contextValue
NA
NA
notAfterDate
NA
string($date-time)
lineItems
Yes
object
Up to 5,000 Items to update on the transfer.
Table 4-364 TransferRequestUpdatweLineItemIdo— Object
notes
NA
string($text2000)] example: List [ "Transfer needs to be rushed.", "Items are in the back room." ]
Responses
This section describes the responses of the Update Transfer API.
Response Code: 200
Example Value
    "status": 1,
    "originType": 1,
    "notAfterDate": "2025-01-08T13:54:30.666Z",
    "createDate": "2025-01-08T13:54:30.666Z",
    "updateDate": "2025-01-08T13:54:30.666Z",
    "requestDate": "2025-01-08T13:54:30.666Z",
    "approvalDate": "2025-01-08T13:54:30.666Z",
    "lineItems": [
        "lineId": 2222222,
        "caseSize": 3,
Table 4-365 TransferIdo — Object
transferid
NA
externalTransferId
NA
distroNumber
NA
sourceLocationType
NA
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
sourcelocationId
NA
NA
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
NA
status
NA
1 - New Request
2 - Requeste
7 - Approved
8 - In Shipping
originType
NA
1 - External
2 - Internal
3 - Adhoc
Enum: [ 1, 2, 3 ]
contextTypeId
NA
contextTypeCode
NA
contextValue
NA
customerOrderNumber
NA
NA
NA
useAvailable
NA
authorizationCode
NA
notAfterDate
NA
string($date-time)
createDate
NA
string($date-time)
createUser
NA
updateDate
NA
string($date-time)
updateUser
NA
requestDate
NA
string($date-time)
requestUser
NA
approvalDate
NA
string($date-time)
approvedUser
NA
importId
NA
lineItems
object
Line items
Table 4-366 TransferLineItemIdo — Object
lineId
NA
itemId
NA
caseSize
NA
quantityRequested
NA
quantityApproved
NA
quantityShipping
NA
quantityShipped
NA
quantityReceived
NA
quantityDamaged
NA
preferredUom
NA
Response Code: 400
Bad request
Create Request
The Create Request API creates a new store-to-store transfer request. The transfer must be released in order to be available to the sending store to later approve or reject. EICS will be the originator of this transfer request, not the external system. To import transfers from an external system, see Import Transfer.
Method
POST
URL
/transfers/requests
Request
Example Value
  "sourceStoreId": 4000,
  "destinationStoreId": 5000,
  "notAfterDate": "2025-01-08T14:01:57.301Z",
  "lineItems": [
      "quantity": 100,
      "caseSize": 3
  "notes": [
Schema — TransferRequestCreateIdo
Table 4-367 TransferRequestCreateIdo— Object
sourceStoreId
Yes
destinationStoreId
Yes
contextTypeId
NA
contextValue
NA
NA
notAfterDate
NA
string($date-time)
lineItems
Yes
object
A collection of up to 5,000 items that will be added to the transfer.
notes
NA
Table 4-368 TransferRequestCreateLineItemIdo— Object
itemId
Yes
string($text25) example: 10045600q
quantity
Yes
caseSize
NA
Responses
This section describes the responses of the Create Request API.
Response Code: 200
Example Value
    "status": 1
Schema — TransferStatusIdo
Table 4-369 TransferStatusIdo — Object
transferId
NA
externalTransferId
 NA
status
 NA
1 - New Request
2 - Requeste
7 - Approved
8 - In Shipping
Response Code: 400
Bad request
Update Request
The Update Request API updates requested quantities on a store-to-store request while it is still in new status, prior to being released to the shipping store.
Method
POST
URL
/transfers/requests/{transferId}
Request
Table 4-370 Update Transfer — Request Parameter
transferId
Yes
Example Value
  "notAfterDate": "2025-01-08T14:41:38.414Z",
  "lineItems": [
      "quantity": 100,
      "caseSize": 3
  "notes": [
Table 4-371 TransferRequestUpdateIdo— Object
sourceStoreId
Yes
destinationStoreId
Yes
contextTypeId
NA
contextValue
NA
NA
notAfterDate
NA
string($date-time)
lineItems
Yes
object
Table 4-372 TransferRequestUpdatweLineItemIdo— Object
notes
NA
Responses
This section describes the responses of the Update Request API.
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Request
The Cancel Request API cancels a new request before it is released to the sending store for approval. This is done when the receiving location decides the transfer is not needed prior to finishing their request. The status must be new request in order to cancel.
Method
POST
URL
/transfers/requests/{transferId}/cancel
Request
Table 4-373 Cancel Request — Request Parameter
transferId
Yes
number($int15) (path)
Responses
This section describes the responses of the Cancel Request API.
Response Code: 204
No content
Response Code: 400
Bad request
Release Request
The Release Request API finalizes the request of the transfer at the receiving location and begins the approval process at the sending location.
Method
POST
URL
Request
Table 4-374 Release Request — Request Parameter
transferId
Yes
Responses
This section describes the responses of the Release Request API.
Response Code: 204
No content
Response Code: 400
Bad request
Approve Request
The Approve Request API approves a transfer request created by a receiving store and released to the sending store. The transfer request must be in requested or request in progress status in order to approve.
Method
POST
URL
/transfers/requests/{transferId}/approve
Request
Table 4-375 Approve Request — Request Parameter
transferId
Yes
Responses
This section describes the responses of the Approve Request API.
Response Code: 204
No content
Response Code: 400
Bad request
Reject Request
The Reject Request API rejects a transfer request from a receiving store closing out the transfer. This is done when the shipping store decides it will not fulfill it. The status must be requested or request in progress in order for it to be rejected.
Method
POST
URL
/transfers/requests/{transferId}/reject
Request
Table 4-376 Reject Request — Request Parameter
transferId
Yes
Responses
This section describes the responses of the Reject Request API.
Response Code: 204
No content
Response Code: 400
Bad request
Approve Transfer
The Approve Transfer API approves a transfer created by the sending store moving it to the shipping stage. The status of the transfer must be transfer in progress in order to approve it.
Method
POST
URL
/transfers/{transferId}/approve
Request
Table 4-377 Approve Transfer — Request Parameter
transferId
Yes
Responses
This section describes the responses of the Approve Transfer API.
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Transfer
The Cancel Transfer API cancels a transfer created by a sending store that has yet to be approved. The status must be transfer in progress in order to cancel the transfer.
Method
POST
URL
/transfers/{transferId}/cancel
Request
Table 4-378 Cancel Transfer — Request Parameter
transferId
Yes
Responses
This section describes the responses of the Cancel Transfer API.
Response Code: 204
No content
Response Code: 400
Bad request
Close Transfer
The Close Transfer API closes a transfer that has been approved. It can close a request that currently is in requested or request in progress status, but only if the shipping location is a store. It can close a transfer that is in shipping status so long as it does not have shipping quantities (this can happen if a previous partial shipment has already shipped).
Method
POST
URL
/transfers/{transferId}/close
Request
Table 4-379 Close Transfer — Request Parameter
transferId
Yes
Responses
This section describes the responses of the Close Transfer API.
Response Code: 204
No content
Response Code: 400
Bad request
Find Transfer Contexts
The Find Transfer Contexts API reads all the available contexts for a transfer.
Method
GET
URL
/transfers/contexts
Request
Responses
This section describes the responses of the Find Transfer Contexts API.
Response Code: 200
Example Value
    "contextId": 1234,
    "code": "CNTXIA",
    "description": "Repair",
    "sequence": 2
Schema — TransferContextIdo
Table 4-380 TransferContextIdo — Object
Element Name Required Data Type/Example Description
contextId
NA
number($int18) example: 1234
The unqiue identifier of the context record.
code
NA
string($text6) example: CNTXIA
A short code associated to the context.
description
NA
string($text120) example: Repair
A description of the context.
sequence
NA
integer($int6) example: 2
The order it should be sequenced in.
Import Transfer
The Import Transfer API imports a transfer (stock order) that is managed by an external system. This is an asynchronous process where minimal validation is performed on input and the message is staged in MPS for later processing. The message is managed by the MPS work queue (DcsTransfer). If Oracle Merchandising is enabled in the system, this service operation is not allowed.
Method
POST
URL
/transfers/import
Request
Example Value
  "deliveryDate": "2025-01-10T12:19:54.491Z",
  "notAfterDate": "2025-01-10T12:19:54.491Z",
  "useUnavailableInventory": true,
  "lineItems": [
      "quantity": 100,
Schema — TransferImportIdo
Table 4-381 TransfeImportIdo — Object
externalTransferId
Yes
sourceLocationType
Yes
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
sourceLocationId
Yes
Yes
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
Yes
contextTypeId
 NA
contextValue
NA
deliveryDate
NA
string($date-time) .
The date in which the transfer delivery should take place
notAfterDate
NA
customerOrderNumber
NA
NA
NA
boolean example: true
NA
lineItems
Yes
object
A collecton of up to 5,000 line items on the transfer.
Table 4-382 TransfeImportLineItemIdo — Object
itemId
Yes
quantity
Yes
preferredUom
NA
Responses
This section describes the responses of the Import Transfer API.
Response Code: 202
Accepted
Response Code: 400
Bad request
The media type is application/json.
See the JSON Error Element and Error Codes section.
Delete Transfer Import
The Delete Transfer Import API deletes a transfer request or trasnfer (stock order) if it has not yet become active.
Method
DELETE
URL
/transfers/import/{externalTransferId}
Request
Table 4-383 Delete Transfer Import — Request Parameter
externalTransferId
Yes
The unique identifier of the transfer from the external system.
Responses
This section describes the responses of the Delete Transfer Import API.
Response Code: 202
Accepted
Response Code: 400
Bad request
REST Service: Transfer Delivery
A transfer delivery is the physical accounting of receiving goods from a store, warehouse, or external finisher. Deliveries consists of containers that hold items. Containers may be received blind, without knowing the expected quantities. The containers can also be for unavailable inventory. Transfer deliveries allow for receiving by Advance Shipment Notice (ASN), container, item level, or the entire delivery. Damages may be recorded during the receiving. This service defines operations to manage transfer delivery information by integration with an external system.
Server Base URL
Find Delivery
This section describes the Find Delivery API. This API finds up to 10,000 delivery headers for the input criteria.
Method
GET
URL
/tsfdeliveries
Request
Table 4-384 Find Delivery — Request Parameters
storeId
NA
number($int10) (query)
Include only deliveries from this store.
asn
NA
string($text128) (query)
Include only deliveries with this ASN.
status
NA
integer($int4) (query)
Include only deliveries with this status. Valid values are
1 - New
2 - In Progress
3 - Received
updateDateFrom
NA
string($date-time) (query)
Include only deliveries with an update date on or after this date.
updateDateTo
NA
Include only deliveries with an update date on or before this date.
Responses
This section describes the responses of the Find Delivery API.
Response Code: 200
The request has been successful.
Example Value
    "deliveryId": 11111,
    "storeId": 5000,
    "sourceType": 1,
    "sourceId": 5101,
    "asn": "789012",
    "status": 1,
    "receiptNumber": "799003",
    "carrierName": "Speedy, Inc.",
    "expectedDate": "2025-01-10T13:35:33.734Z",
    "receivedDate": "2025-01-10T13:35:33.734Z",
    "createDate": "2025-01-10T13:35:33.734Z",
    "updateDate": "2025-01-10T13:35:33.734Z"
Schema — TransferDeliveryHeaderIdo
Table 4-385 TransferDeliveryHeaderIdo —Object
deliveryId
NA
number($int15) example: 11111
The unique identifier of the transfer delivery.
storeId
NA
number($int10) example: 5000
The identifier of the store receiving the inventory.
sourceType
integer($int4) example: 1
The type of location that is shipping the goods. Valid values are:
1 - Store
2 - Warehouse
3 - Finisher
Enum: Array [ 3 ]
sourceId
NA
number($int10) example: 5101
The identifier of the location shipping the goods.
asn
NA
string($text128) example: 789012
The advanced shipping notification number.
status
NA
The current status of the delivery. Valid values are:
1 - New
2 - In Progress
3 - Received
Enum: [ 1, 2, 3 ]
receiptNumber
NA
string($text128) example: 799003
The receipt number of the delivery.
carrierName
NA
string($text128) example: Speedy, Inc.
The name of the carrier of the delivery.
expectedDate
NA
string($date-time)
The date the delivery is epxected to be received.
receivedDate
NA
string($date-time)
The date the delivery was received.
createDate
NA
string($date-time)
The date the delivery was created.
updateDate
NA
string($date-time)
The date the delivery was last updated.
Response Code: 400
Bad request
Create Delivery
Creates a new transfer delivery as if SIOCS was the originator of the delivery. For integration of ASN deliveries originating from an external system, please see import delivery operation.
Method
POST
URL
/tsfdeliveries
Request
There are no request parameters.
The delivery details of the new delivery.
Example Value
  "storeId": 5000,
  "sourceType": 1,
  "sourceId": 5101,
  "asn": "789012",
  "billOfLadingId": "BOL884455",
  "carrierType": 1,
  "carrierCode": "SPI",
  "sourceAddress": "Solid Supplies",
  "licensePlate": "ABX100",
  "freightId": "666234522",
  "expectedDate": "2025-01-10T14:25:34.133Z",
  "cartons": [
      "externalCartonId": "GH124000",
      "referenceId": "3461353",
      "damagedReason": "Vehicle Accident",
      "serialCode": 3333600,
      "trackingNumber": "346139384726043",
      "damagedRemaining": true,
      "receiveAtShopFloor": false,
      "qualityControl": true,
      "lineItems": [
          "itemId": "11111",
          "documentId": 222222,
          "documentType": 1,
          "documentDate": "2025-01-10T14:25:34.133Z",
          "customerOrderNumber": "1444923",
          "fulfillmentOrderNumber": "11123412",
          "caseSize": 1,
          "quantityExpected": 20,
          "uins": [
              "uin": "11123412",
              "shipped": true,
              "received": true,
              "damaged": true
Schema — TransferDeliveryCreateIdo
Table 4-386 TransferDeliveryCreateIdo —Object
storeId
Yes
sourceType
Yes
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
sourceId
Yes
asn
Yes
billOfLadingId
NA
string($text128) example: BOL884455
A bill of lading identifier from an external system.
carrierType
NA
The carrier type of the carrier. Valid values are:
1 - Corporate
2 - Third Party
Enum: [ 1, 2 ]
carrierName
NA
carrierCode
NA
string($text4) example: SPI
A unique code that identifies the carrier.
sourceAddress
NA
string($text1000) example: Solid Supplies
The address of the source location that shipped the inventory.
licensePlate
NA
string($text128) example: ABX100
A license plate number of the delivery vehicle.
freightId
NA
string($text128) example: 666234522
A freight identifier associated to the delivery.
expectedDate
NA
string($date-time) The date the delivery is epxected to be received.
cartons
Yes
object
A collection of up to 500 cartons on the delivery.
Table 4-387 TransferDeliveryCreateCartonIdo —Object
externalCartonId
NA
string($text128) example: GH124000
A carton identifier from an external system.
referenceId
NA
string($text128) example: 3461353
A reference identifier (another way to identify the carton).
damagedReason
NA
string($text128) example: Vehicle Accident
A reason for the container damage.
serialCode
NA
number($int15) example: 3333600
A serial code associated to the container.
trackingNumber
NA
string($text128) example: 346139384726043
A tracking number associated to the container.
damagedRemaining
NA
True indicates all remaining unreceived quantities should be marked as damaged on the final receipt.
receiveAtShopFloor
NA
True indicates the container is to be received on the shopfloor, false indicates it should not.
qualityControl
NA
True indicates the container requires quality control, false indicates it does not.
lineItems
Yes
object
A collection of up to 2,000 items on the container.
Table 4-388 TransferDeliveryCreateLineItemIdo —Object
itemId
Yes
string($text25) example: 11111
The unique identifier of the item.
documentId
Yes
number($int15) example: 222222
The unique identifier of the transfer or allocation document.
documentType
Yes
The type of the document. Valid values are:
1 - Transfer
2 - Allocation
Enum: [ 1, 2 ]
documentDate
Yes
string($date-time)
The date the document was created.
customerOrderNumber
NA
string($text128) example: 1444923
The customer order identifier if a customer order is associated to the item.
NA
string($text128) example: 11123412
The fulfillment order identifier if a customer order is associated to the item.
useAvailable
NA
True indicates to use available inventory, false indicuates to use unavailable inventory.
caseSize
NA
number($decimal(10,2)) example: 1
The case size of the item for this record.
quantityExpected
NA
The quantity expected to be received.
quantityReceived
NA
The quantity received as good.
quantityDamaged
NA
The quantity received as damaged.
uins
NA
object
A collection of UINs on the line item.
Table 4-389 TransferDeliveryUinIdo —Object
uin
Yes
The unique identification number.
shipped
 NA
True, if the UIN is shipped, false otherwise.
received
NA
True, if the UIN is received, false otherwise.
damaged
NA
True if the UIN is received as damaged, false otherwise.
Responses
This section describes the responses of the Create Delivery API.
Response Code: 200
Example Value
    "status": 1
Schema — TransferDeliveryStatusIdo
Table 4-390 TransferDeliveryStatusIdo —Object
deliveryId
NA
status
NA
1 - New
2 - In Progress
3 - Received
Enum: [ 1, 2, 3 ]
Response Code: 400
Bad request
Read Delivery
The Read Delivery API retrieves all the details about an transfer delivery.
Method
GET
URL
/tsfdeliveries/{deliveryId}
Request
Table 4-391 Read Delivery — Request Parameter
deliveryId
Yes
Responses
This section describes the responses of the Read Delivery API.
Response Code: 200
Example Value
    "storeId": 5000,
    "sourceType": 1,
    "sourceId": 5101,
    "status": 1,
    "asn": "789012",
    "carrierType": 1,
    "fiscalDocumentRequestId": 100234,
    "fiscalDocumentReferenceId": 63452277,
    "fiscalDocumentNumber": "84478274",
    "expectedDate": "2025-01-10T14:36:21.974Z",
    "receivedDate": "2025-01-10T14:36:21.974Z",
    "receivedUser": "smith123",
    "createDate": "2025-01-10T14:36:21.974Z",
    "updateDate": "2025-01-10T14:36:21.974Z",
    "importId": "3461353",
    "cartons": [
        "cartonId": 11111,
        "misdirectedId": 3461353,
        "discrepant": true,
        "externalCreate": true,
        "adjusted": false,
        "copied": true,
        "status": 1,
        "customerOrderRelated": 1,
        "lineItems": [
            "lineId": 11111,
            "itemId": "11111",
            "documentType": 1,
            "documentDate": "2025-01-10T14:36:21.974Z",
            "caseSize": 1,
            "quantityPreviousReceived": 20,
            "quantityPreviousDamaged": 20,
            "uins": [
                "uin": "11123412",
                "itemUinId": 8475,
                "shipped": true,
                "received": true,
                "damaged": true
Schema — TransferDeliveryIdo
Table 4-392 TransferDeliveryIdo — Object
deliveryId
NA
storeId
NA
sourceType
NA
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
sourceId
NA
status
NA
1 - New
2 - In Progress
3 - Received
Enum: [ 1, 2, 3 ]
asn
NA
receiptNumber
NA
carrierName
NA
carrierType
NA
1 - Corporate
2 - Third Party
Enum: [ 1, 2, 3 ]
carrierCode
NA
sourceAddress
NA
licensePlate
NA
freightId
NA
A freight identifier associated to the shipment.
NA
number($int20) example: 100234
The identifier of the request for a fiscal document.
NA
number($int20) example: 63452277
The unique identifier of the fiscal document record.
NA
string($text255) example: 84478274
The fiscal document number.
billOfLadingId
NA
An external bill of lading identifier.
expectedDate
NA
string($date-time)
  The date the delivery is expected to be received.
receivedDate
NA
string($date-time)
receivedUser
NA
The user that received the delivery.
createDate
NA
string($date-time)
createUser
NA
The user that created the delivery.
updateDate
NA
string($date-time)
updateUser
NA
The user that last updated the delivery.
importId
NA
An original import identifier if the data was imported through data-seeding.
cartons
NA
object
A collection of cartons on the delivery.
Table 4-393 TransferDeliveryCartonIdo — Object
cartonId
NA
The unique identifier of the transfer delivery carton.
externalCartonId
NA
referenceId
NA
misdirectedId
NA
number($int15) example: 3461353
A misdirected container identifier (if this is copy of a another container).
discrepant
NA
True indicates the container is discrepant, false indicates it is not.
receiveAtShopFloor
NA
externalCreate
NA
True indicates the container was externally created, false indicates it was created internally.
adjusted
NA
True indicates the container has been adjusted, false indicates it has not.
qualityControl
NA
copied
NA
True indicates the container has been copied as a misdirected container, false means it has not.
damagedRemaining
NA
damagedReason
NA
serialCode
NA
trackingNumber
NA
status
NA
The status of the container. Value values are
1 - New
2 - In Progress
3 - Damaged
4 - Received
5 - Missing
Enum: [ 1, 2, 3, 4, 5 ]
NA
Indicates if the carton is related to a customer order. Valid values are
1 - Yes
2 - Mix
3 - No
Enum: [ 1, 2, 3 ]
createUser
NA
The user that created the container.
updateDate
NA
string($date-time)
The date the container was last updated.
updateUser
NA
The user that last updated the container.
receivedDate
NA
string($date-time)
The date the container was received.
receivedUser
NA
string($text128)
example: smith123
lineItems
NA
object
A collection of items in the container.
Table 4-394 TransferDeliveryLindeItemIdo — Object
lineId
NA
The unique identifier of the line item record.
itemId
NA
documentId
NA
documentType
NA
The type of the document. Value values are
1 - Transfer
2 - Allocation
Enum: [ 1, 2 ]
documentDate
NA
string($date-time)
customerOrderNumber
NA
A customer order identifier if a customer order is associated to the delivery.
NA
The fulfillment order identifier if a customer order is associated to the delivery.
useAvailable
NA
True indicates to use available inventory, false indicates to use unavailable inventory.
caseSize
NA
quantityExpected
NA
quantityReceived
NA
quantityDamaged
NA
NA
The quantity last received as good.
NA
The quantity last received as damaged.
uins
NA
object
 A collections of UINs on the line item.
Table 4-395 TransferDeliveryLindeItemUinIdo — Object
uin
NA
itemUinId
NA
number($int14) example: 8475
The unique identifier of the item UIN record.
shipped
NA
True if the UIN is shipped, false otherwise.
received
NA
True if the UIN is received, false otherwise.
damaged
NA
Response Code: 400
Bad request
Update Delivery
The Update Delivery API update the header portion of a delivery.
Method
POST
URL
Request
Table 4-396 Update Delivery — Request Parameter
deliveryId
Yes
The request body is application/json.
Delivery header details to update.
Example Value
  "carrierType": 1,
  "expectedDate": "2025-01-10T15:43:51.438Z"
Schema — TransferDeliveryUpdateIdo
Table 4-397 TransferDeliveryUpdateIdo— Object
billOfLadingId
NA
carrierType
NA
1 - Corporate
2 - Third Party
Enum: [ 1, 2 ]
carrierName
NA
carrierCode
NA
sourceAddress
NA
licensePlate
NA
freightId
NA
expectedDate
NA
string($date-time)
Responses
This section describes the responses of the Update Delivery API.
Response Code: 204
No content
Response Code: 400
Bad request
Receive Delivery
The Receive Delivery API receives the transfer delivery. The quantities will be updated to the expected quantity value (if no quantity has been recorded previously, including recording 0 previously) and the delivery will be set to in progress stats. To finalize the delivery, use the confirm operation.
Method
POST
URL
/tsfdeliveries/{deliveryId}/receive
Request
Table 4-398 Receive Delivery — Request Parameter
deliveryId
Yes
Responses
This section describes the responses of the Receive Delivery API.
Response Code: 204
No content
Response Code: 400
Bad request
Confirm Delivery
The Confirm Delivery API confirms the delivery finalizing the movement of inventory and closing the delivery.
Method
POST
URL
/tsfdeliveries/{deliveryId}/confirm
Request
Table 4-399 Confirm Delivery — Request Parameter
deliveryId
Yes
Responses
This section describes the responses of the Confirm Delivery API.
Response Code: 204
No content
Response Code: 400
Bad request
Open Delivery
The Open Delivery API opens the delivery for additional receiving but leaves all the cartons in their current state.
Method
POST
URL
/tsfdeliveries/{deliveryId}/open
Request
Table 4-400 Open Delivery — Request Parameter
deliveryId
Yes
Responses
This section describes the responses of the Open Delivery API.
Response Code: 204
No content
Response Code: 400
Bad request
Create Carton
The Create Carton Delivery API adds a new container to a new or in progress shipment.
Method
POST
URL
/tsfdeliveries/{deliveryId}/cartons
Request
Table 4-401 Create Carton — Request Parameter
deliveryId
Yes
The unique identifier of the delivery.
Details about the carton to add to the shipment.
Example Value
  "lineItems": [
      "itemId": "11111",
      "documentType": 1,
      "documentDate": "2025-01-13T12:33:47.167Z",
      "caseSize": 1,
      "uins": [
          "uin": "11123412",
          "shipped": true,
          "received": true,
          "damaged": true
Schema — TransferDeliveryCreateCartonIdo
Table 4-402 TransferDeliveryCreateCartonIdo— Object
externalCartonId
NA
referenceId
NA
damagedReason
NA
serialCode
NA
trackingNumber
NA
damagedRemaining
NA
receiveAtShopFloor
NA
qualityControl
NA
lineItems
Yes
object
Table 4-403 TransferDeliveryCreateLineItemIdo —Object
itemId
Yes
documentId
Yes
documentType
Yes
1 - Transfer
2 - Allocation
Enum: [ 1, 2 ]
documentDate
Yes
string($date-time)
customerOrderNumber
NA
NA
useAvailable
NA
caseSize
NA
quantityExpected
NA
quantityReceived
NA
quantityDamaged
NA
uins
NA
object
Table 4-404 TransferDeliveryUinIdo —Object
uin
Yes
shipped
 NA
received
NA
damaged
NA
Responses
This section describes the responses of the Create Carton API.
Response Code: 200
Example Value
    "cartonId": 24680,
    "status": 1
Schema — TransferDeliveryCartonStatusIdo
Table 4-405 TransferDeliveryICartonStatusdo — Object
deliveryId
NA
cartonId
NA
number($int15) example: 24680
externalCartonId
NA
status
NA
The status of the container. Valid values are
1 - New
2 - In Progress
3 - Damaged
4 - Received
5 - Missing
Response Code: 400
Bad request
Update Carton
The Update Carton API Updates a previously existing carton that is in a new or in progress state, on a delivery that is also new or in progress.
Method
POST
URL
/tsfdeliveries/cartons/{cartonId}
Request
Table 4-406 Update Carton — Request Parameter
cartonId
Yes
The unique identifier of the delivery carton.
Details about the carton update.
Example Value
  "lineItems": [
      "itemId": "11111",
      "documentType": 1,
      "documentDate": "2025-01-13T13:33:02.273Z",
      "caseSize": 1,
      "uins": [
          "uin": "11123412",
          "shipped": true,
          "received": true,
          "damaged": true
Schema — TransferDeliveryCartonUpdateIdo
Table 4-407 TransferDeliveryCartonUpdateIdo — Object
externalCartonId
NA
referenceId
NA
receiveAtShopFloor
NA
qualityControl
NA
damagedRemaining
NA
damagedReason
NA
serialCode
NA
trackingNumber
NA
lineItems
NA
object
A collection of up to 2,000 items in the container.
Table 4-408 TransferDeliveryCartonUpdateItemIdo — Object
itemId
Yes
documentId
Yes
documentType
Yes
1 - Transfer
2 - Allocation
Enum: [1, 2]
documentDate*
Yes
string($date-time)
caseSize
NA
quantityReceived
NA
quantityDamaged
NA
uins
NA
object
Table 4-409 TransferDeliveryUinIdo — Object
uin
Yes
shipped
 NA
received
NA
damaged
NA
Responses
This section describes the responses of the Update Carton API.
Response Code: 204
No content
Response Code: 400
Bad request
Receive Carton
The Receive Carton API receives the container. The quantities will be updated to the expected quantity value (if no quantity has been previously entered, including 0) and the container will be moved to in progress. Use the confirm operation to finalize the carton.
Method
POST
URL
/tsfdeliveries/cartons/{cartonId}/receive
Request
Table 4-410 Receive Carton — Request Parameter
cartonId
Yes
Responses
This section describes the responses of the Receive Carton API.
Response Code: 204
No content
Response Code: 400
Bad request
Confirm Carton
The Confirm Carton API confirms the container finalizing its status as received or damaged.
Method
POST
URL
/tsfdeliveries/cartons/{cartonId}/confirm
Request
Table 4-411 Confirm Carton — Request Parameter
cartonId
Yes
Responses
This section describes the responses of the Confirm Carton API.
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Carton
The Cancel Carton API cancels the container indicating it will not be received as part of the delivery.
Method
POST
URL
/tsfdeliveries/cartons/{cartonId}/cancel
Request
Table 4-412 Cancel Carton — Request Parameter
cartonId
Yes
Responses
This section describes the responses of the Cancel Carton API.
Response Code: 204
No content
Response Code: 400
Bad request
Open Carton
The Open Carton API re-opens a confirmed container, placing it back into in progress state in order to adjust and confirm again.
Method
POST
URL
/tsfdeliveries/cartons/{cartonId}/open
Request
Table 4-413 Open Carton — Request Parameter
cartonId
Yes
Responses
This section describes the responses of the Open Carton API.
Response Code: 204
No content
Response Code: 400
Bad request
Import ASN Delivery
The Import ASN Delivery API imports a transfer delivery (ASN) managed by an external system that is notifying SIOCS of an ASN creation or modification that took place. This request is staged and processed asynchronously, and is controlled by the MPS message type DcsAsn.
Method
POST
URL
/tsfdeliveries/imports
Request
Details about the delivery to import.
Example Value
  "asn": "789012",
  "storeId": 5000,
  "sourceType": 1,
  "sourceId": 5101,
  "carrierType": 1,
  "expectedDate": "2025-01-13T14:21:38.692Z",
  "cartons": [
      "lineItems": [
          "itemId": "11111",
          "documentType": 1,
          "documentDate": "2025-01-13T14:21:38.692Z",
          "caseSize": 1,
          "quantity": 20
Schema — TransferDeliveryImportIdo
Table 4-414 TransferDeliveryImportIdo— Object
asn
Yes
storeId
Yes
sourceType
Yes
1 - Store
2 - Warehouse
3 - Finisher
Enum: [ 1, 2, 3 ]
sourceId
Yes
carrierType
NA
1 - Corporate
2 - Third Party
Enum: [ 1, 2 ]
carrierName
NA
carrierCode
NA
sourceAddress
NA
licensePlate
NA
freightId
NA
NA
The fiscal document number of an associated fiscal document.
billOfLadingId
NA
expectedDate
NA
string($date-time) The date the delivery is expected to be received.
cartons
Yes
object
Table 4-415 TransferDeliveryImporCartontIdo— Object
externalCartonId
Yes
referenceId
NA
serialCode
NA
trackingNumber
NA
qualityControl
NA
Boolean example: true
lineItems
Yes
object
Table 4-416 TransferDeliveryImportItemtIdo— Object
itemId
Yes
documentId
Yes
documentType
Yes
1 - Transfer
2 - Allocation
Enum: [ 1, 2 ]
documentDate
Yes
string($date-time)
useAvailable
NA
caseSize
NA
Quantity
Yes
Responses
This section describes the responses of the Import ASN Delivery API.
Response Code: 202
Accepted
Response Code: 400
Bad request
Import ASN Delete Delivery
A transfer delivery in new status can be deleted from the system. A transfer delivery that has progressed past the point cannot. This request is staged and processed asynchronously, and is controlled by the MPS message type DcsAsn.
Method
POST
URL
/tsfdeliveries/imports/delete
Request
Details about the delivery to delete.
Example Value
  "asn": "789012",
  "storeId": 5000
Schema — TransferDeliveryDeleteImportIdo
Table 4-417 TransferDeliveryDeleteImportIdo— Object
asn
Yes
storeId
Yes
Responses
This section describes the responses of the Import ASN Delete Delivery API.
Response Code: 202
Accepted
Response Code: 400
Bad request
REST Service: Transfer Shipment
This service allows the creation, modification, and cancellation of transfer shipments from an external application.
Service Base URL
The Cloud service base URL follows the format:
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/tsfshipments
API Definitions
API
Definition
readShipment
Reads the transfer shipment. This does not include containers or items.
findShipments
Finds transfer shipment header information based on a set of criteria.
submitShipment
Submits the transfer shipment.
cancelSubmitShipment
Cancels the submission of a transfer shipment.
dispatchShipment
Dispatches a transfer shipment.
cancelShipment
Cancels a transfer shipment.
confirmCarton
Confirms a container for shipment.
cancelCarton
Cancels a container, removing it from the shipment.
openCarton
Opens a confirmed container so that it can be modified again.
createShipment
Creates a shipment.
updateShipment
Updates shipment header information.
createCarton
Adds a carton to the shipment.
updateCarton
Updates a carton on the shipment.
API: Read Shipment
Read a transfer shipment.
Table 4-418 API Basics
Endpoint URL
/{shipmentId}
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
None
Output
Transfer Shipment
Table 4-419 Path Parameter Definitions
Parameter
Definition
shipmentId
The internal identifier of the transfer shipment header.
Table 4-420 Output Data Definition
Column
Type
Definition
shipmentId
Long(15)
The unique internal identifier of the transfer shipment.
storeId
Long(10)
The unique store identifier that is the source of the shipment.
destinationType
Integer(2)
The location type of the destination. See Additional Data Definitions-Destination Type.
destinationId
Long(10)
The unique identifier of the destination.
asn
String(128)
The advance shipment notification number.
status
Integer(2)
The current status of the shipment. See Additional Data Definitions: Status
authorizationCode
String(12)
An authorization code associated to the shipment.
billOfLadingId
Long(12)
The unique identifier of the bill of lading.
adhocDocumentId
Long(15)
An adhoc transfer document identifier associated to the shipment.
billOfLadingId
Long(15)
The bill of lading number.
alternateAddress
String(2000)
An alternate destination address.
carrierRole
Integer(2)
The type of carrier for the shipment. See Additional Data Definitions
carrierId
Long(10)
A unique identifier of a carrier for the shipment.
carrierServiceId
Long(10)
A unique identifier of a carrier service for the shipment.
alternateCarrierName
String(240)
The name of a third-party shipping company.
alternateCarrierAddress
String(2000)
The address of a third-party shipping company.
motive
String(120)
A motive for the shipment.
taxId
String(18)
The tax identifier of the supplier it is being shipped to.
trackingNumber
String(128)
A tracking number associated to the shipment.
dimensionId
Long(12)
The identifier of a dimension associated to the shipment.
weight
BigDecimal(12,4)
The weight of the shipment.
weightUom
String(4)
The unit of measure of the weight of the shipment.
requestedPickupDate
Date
The requested pickup date.
Long(20)
Long(20)
The unique identifier of the fiscal document.
String(255)
fiscalDocumentStatus
Integer(4)
The status of the fiscal document.
fiscalDocumentRejectReason
String(255)
A reason the fiscal document was rejected.
fiscalDocumentUrl
String(255)
A URL to the fiscal document.
createUser
String(128)
The user that created the shipment record.
createDate
Date
The date the shipment record was created.
updateUser
String(128)
The user that last updated the shipment.
updateDate
Date
The last date the shipment was updated.
submitUser
String(128)
The user that submitted the shipment record.
submitDate
Date
The date the shipment was submitted within EICS.
dispatchUser
String(128)
The user that dispatched the shipment.
dispatchDate
Date
The date the shipment was dispatched within EICS.
cartons
Collection
A collection of cartons on the shipment.
Table 4-421 Output Data Definition (Cartons)
Column
Type
Definition
cartonId
Long(10)
The unique identifier of the record.
externalCartonId
String(128)
A container identifier from an external system.
status
Integer(4)
The current status of the container.
dimensionId
Long(10)
The shipment container dimension identifier.
weight
BigDecimal(12,4)
The weight of the container.
weightUom
String(4)
The unit of measure of the weight of the container.
trackingNumber
String(128)
A tracking number for the container.
useAvailableInventory
Boolean
True indicates use only available inventory, False indicates use non-available inventory.
restrictionLevel
Integer(4)
A hierarchy restriction level for items in the container.
Integer(4)
The customer order related value (see Additional Data Definitions).
createUser
String(128)
The user that created the container in EICS.
createDate
Date
The date the container was created in EICS.
updateUser
String(128)
The user that last updated the container in EICS.
updateDate
date
The date the container was last updated in EICS.
approvalUser
String(128)
The user that approved the container in EICS.
approvalDate
Date
The date the container was approved in EICS.
lineItems
Collection
The line items in the container.
Table 4-422 Output Data Definition (Line Item)
Column
Type
Definition
lineId
Long(15)
itemId
String(25)
caseSize
BigDecimal(10,2)
The case size of this line item.
quantity
BigDecimal(20,4)
The quantity being shipped.
transferId
Long(12)
The unique identifier of the associated transfer.
externalTransferId
Long(15)
The external system identifier of the associated transfer.
customerOrderNumber
String(128)
The customer order number if line item is for a customer order.
String(128)
The fulfillment order number if line item is for a customer order.
preferredUom
String(4)
The preferred unit of measure for the shipment quantity.
shipmentReasonId
Long(15)
A unique identifier of a shipment reason associated to this item.
uins
List<String>
A list of UINs that are shipped. The number of UINs must match the quantity attribute.
Example
Figure 4-15 Example
Example
Figure 4-16 Example, continued
Example, continued
API: Find Transfer Shipment
Search for shipments based on a set of criteria.
If more than 10,000 shipments are found a "Results Too Large" response is returned and search criteria will need to be more restrictive.
Table 4-423 API Basics
Endpoint URL
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
Query Parameters
Output
List of Transfer Shipments Headers
Table 4-424 Query Parameter Definitions
Attribute
Type
Definition
storeId
Long(10)
Include only transfer shipments from this store.
destinationType
Integer(2)
Include only transfer shipments to this destination type.
destinationId
Long(10)
Include only transfer shipments to this destination identifier.
asn
String(128)
Include only transfer shipments with this ASN.
status
Integer(2)
Include only transfer shipments in this status.
updateDateFrom
String
Include only transfer shipments last updated on or after this date.
updateDateTo
String
Include only transfer shipments last updated on or before this date.
Table 4-425 Output Data Definition
Column
Type
Definition
shipmentId
Long(15)
storeId
Long(10)
destinationType
Integer(2)
The location type of the destination. See Additional Data Definitions: Destination Type.
destinationId
Long(10)
The unique identifier of the destination location.
asn
String(128)
status
Integer(4)
createDate
Date
updateDate
Date
submitDate
Date
dispatchDate
Date
API: Submit Shipment
Submits the transfer shipment moving it to a noneditable state while it is waiting to be dispatched.
Table 4-426 API Basics
Endpoint URL
/{shipmentId}/submit
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Input
None
Output
None
Table 4-427 Path Parameter Definitions
Parameter
Definition
shipmentId
API: Cancel Submit Shipment
Cancels the submissions of the transfer shipment return it to an in progress and editable state.
Table 4-428 API Basics
Endpoint URL
/{shipmentId}/cancelsubmit
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Input
None
Output
None
Table 4-429 Path Parameter Definitions
Parameter
Definition
shipmentId
API: Dispatch Shipment
Dispatches the transfer shipment updating all the inventory positions and closing the shipment.
Table 4-430 API Basics
Endpoint URL
/{shipmentId}/dispatch
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Input
None
Output
None
Table 4-431 Path Parameter Definitions
Parameter
Definition
shipmentId
API: Cancel Shipment
Cancels the transfer shipment reversing any reserved inventory currently picked.
Table 4-432 API Basics
Endpoint URL
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Input
None
Output
None
Table 4-433 Path Parameter Definitions
Parameter
Definition
shipmentId
API: Confirm Carton
Confirms a transfer shipment container, completing the container and making it non-editable and awaiting dispatch.
Table 4-434 API Basics
Endpoint URL
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Input
None
Output
None
Table 4-435 Path Parameter Definitions
Parameter
Definition
cartonId
The internal identifier of the transfer shipment carton.
API: Cancel Carton
Cancels a transfer shipment container.
Table 4-436 API Basics
Endpoint URL
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Input
None
Output
None
Table 4-437 Path Parameter Definitions
Parameter
Definition
cartonId
API: Open Carton
Opens a transfer shipment container.
Table 4-438 API Basics
Endpoint URL
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Input
None
Output
None
Table 4-439 Path Parameter Definitions
Parameter
Definition
cartonId
API: createShipment
This API is used to create a new transfer shipment whose status is "In Progress."
Container item/reason combination cannot be duplicated within the container.
Table 4-440 API Basics
Endpoint URL
{base URL}
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
Transfer Shipment
Output
Transfer Shipment Status
Maximum Input Limit
1,000 overall line items on shipment
Table 4-441 Input Data Definition
Attribute
Type
Req
Definition
storeId
Long(10
X
The identifier of the store shipping the goods.
destinationType
Integer(2)
X
The location type of the destination (see Index).
destinationId
Long(10)
X
The location identifier of the destination
asn
String(15)
The advance shipping number from an external system.
authorizationCode
String(12)
A vendor authorization code. It may be required for some suppliers.
displayCartons
Boolean
True if cartons should be displayed, otherwise false.
addressType
Integer
The type of return address. See Index.
carrierRole
Integer(2)
X
The type of carrier for the shipment. See Index
carrierId
Long(10)
carrierServiceId
Long(10)
alternateAddress
String(2000)
String(240)
String(2000)
motiveId
Long(18)
The unique identifier of a bill of lading motive.
taxId
taxId
trackingNumber
String(128)
dimensionId
Long(12)
weight
BigDecimal(12,4)
weightUom
String(4)
requestedPickupDate
Date
cartons
Collection
X
A group of cartons to create along with the shipment.
notes
Collections of Strings
A collection of up to 100 notes.
Table 4-442 Shipment Carton Data Definition
Payload
Type
Req
Definition
externalCartonId
String(128)
trackingNumber
String(128)
The tracking number of the container.
restrictionLevel
Integer(4)
cartonSizeId
Long(10)
weight
Long(12,4)
weightUom
String(4)
Boolean
True indicates available inventory will be used, false indicates unavailable inventory should be used.
lineItems
Collection
X
A collection of line items to create along with the carton.
Table 4-443 Shipment Lien Item Data Definition
Payload
Type
Req
Definition
itemId
String(25)
X
transferId
Long(12)
X
The unique identifier of a transfer this item is being shipped for.
reasonId
Long(15)
The unique identifier of the shipment reason associated to this line item. It is not allowed for available inventory and required for unavailable inventory.
quantity
BigDecimal(12,4)
X
The quantity to ship.
caseSize
BigDecimal(10,2)
The case size of the item for this particular shipment.
uins
Collecton<String>
A collection of UINs to ship. This number of UINs must match the quantity.
Table 4-444 Output Data Definition
Attribute
Type
Definition
shipmentId
Long(15)
The unique identifier of the shipment.
storeId
Long(10)
The store identifier of the store shipping the goods.
asn
String(15)
The Advancing Shipping Number.
status
Integer(2)
The shipment status. See Index.
Figure 4-17 Example Code
Example Code
API: updateShipment
This API is used to update to the header portion of a shipment as well as its bill of lading information.
The shipment header cannot be updated while containers/cartons are currently confirmed for shipping.
Table 4-445 API Basics
Endpoint URL
{base URL}/{shipmentId}
Method
POST
Successful Response
204 No Content
Processing Type
Synchronous
Path Parameter
The identifier of the transfer shipment
Input
Transfer Shipment
Table 4-446 Input Data Definition
Column
Type
Definition
authorizationCode
String(12)
displayCartons
Boolean
addressType
Integer(2)
carrierRole
Integer(2)
The type of carrier for the shipment. See Index.
carrierId
Long(10)
carrierServiceId
Long(10)
alternateAddress
String(2000)
String(240)
String(2000)
motiveId
Long(18)
taxId
String(18)
trackingNumber
String(128)
dimensionId
Long(12)
weight
BigDecimal(12,4)
weightUom
String(4)
requestedPickupDate
Date
notes
Collection(String)
A collection of up to 100 notes to add to the notes associated to the shipment.
Figure 4-18 Code Example
Code Example
API: createCarton
This API is used to add a new carton/container to a "New" or "In Progress" shipment.
Table 4-447 API Basics
Endpoint URL
{base URL}/{shipmentId}/cartons
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Path Parameter
Input
Transfer Shipment Carton
Output
Transfer Shipment Carton Status
Maximum Input Limit
1,000 overall line items on carton
Table 4-448 Input Data Definition
Column
Type
Req
Definition
externalCartonId
String(128)
A carton identifier or barcode label from an external system.
cartonSizeId
Long(10)
weight
BigDecimal(12,4)
weightUom
String(4)
trackingNumber
String(128)
Boolean
restrictionLevel
Integer(4)
lineItems
Collection
X
Table 4-449 Shipment Line Item Data Definition
Column
Type
Req
Definition
itemId
String(25)
X
caseSize
BigDecimal(10,2)
quantity
BigDecimal(20,4)
X
The quantity to be shipped.
transferId
Long(12)
X
reasonId
Long(15)
A unique identifier of a shipment reason associated to this item. It is not allowed for available inventory and required for unavailable inventory.
uins
List<String>
A list of UINs to be shipped. This must match the quantity.
Table 4-450 Output Data Definition
Attribute
Type
Definition
shipmentId
Long(15)
cartonId
Long(15)
The unique identifier of the new carton.
externalId
String(128)
The external identifier or barcode label of the container.
status
Integer(2)
The carton status. See Index.
Figure 4-19 Code Example
Code Example
API: updateCarton
This API is used to update an existing carton that is in "New" or "In Progress" shipment.
Table 4-451 API Basics
Endpoint URL
{base URL}/cartons/{cartonId}
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Path Parameter
The identifier of the carton
Input
Output
Maximum Input Limit
Table 4-452 Input Data Definition
Payload
Type
Req
Definition
externalCartonId
String(128)
trackingNumber
String(128)
restrictionLevel
Integer(4)
cartonSizeId
Long(10)
weight
Long(12,4)
weightUom
String(4)
lineItems
Collection
A collection of up to 1,000 line items to update or add within the carton. See TransferShipmentUpdateCartontemIdo.
Payload
Type
Req
Definition
itemId
String(25)
X
transferId
Long(12)
X
reasonId
Long(15)
quantity
BigDecimal(12,4)
X
The quantity shipped. Reducing this to 0 will remove the line item from the shipment.
caseSize
BigDecimal(10,2)
uins
Collection<String>
The UINs associated to the item quantities. The number of UINS must match the quantity shipped.
Figure 4-20 Code Example
Code Example
Index
Table 4-453 Destination Type
Value
Description
1
Store
2
Warehouse
3
Finisher
Table 4-454 Status
Value
Description
1
New
2
In Progress
3
Submitted
4
Shipped
5
Canceled
Table 4-455 Customer Order Related
Value
Description
1
Yes
2
Mixed
3
No
REST Service: Translations
This page captures the service APIs related to retrieving translations. It allows the translation of such things as labels and item descriptions.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/translations
API Definitions
API
Description
Find Locales
Finds all locales that can be used to translation a series of text keys.
Find Translations
Finds the translations for a series of text keys, translating into text for the locale if it is available.
Find Item Descriptions
Finds the translations for item descriptions, translating it to the text of the locale if it is available.
API: Find Locales
Finds all locales available for use in translation.
API Basics
Endpoint URL
{base URL}/locales
Method
GET
Successful Response
200 OK
Processing Type
Synchronous
Input
Criteria
Output
List of locales
Max Response Limit
N/A
Attribute
Data Type
Description
localeId
Long
The SIOCS internal unique identifier of the record.
language
String
A code representing a language (ISO 639 alpha-2 or alpha-3 language code).
country
String
A code representing a country of the language (ISO 3166 alpha-2 country code or UN M.49 numeric-3 area code. )
variant
String
A code representing a variant of the country of the language (an arbitrary value indication the variant).
description
String
A description of the locale.
Example Output
"localeId": 1,
"language": "en",
"description": "English"
"localeId": 2,
"language": "de",
"description": "German"
"localeId": 3,
"language": "fr",
"description": "French"
API: Find Translations
Searches for translations for text keys and a given locale.
API Basics
Endpoint URL
{base URL}/find
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
Criteria
Output
A map of translation key and its translation
Max Response Limit
N/A
Attribute
Data Type
Required
Description
localeId
Long(12)
Yes
Unique identifier of the Locale to translate keys for (see find Locales).
keys
List<String(600)>
Yes
A list of text keys to attempt to translate.
Example Input
"localeId": 1,
"keys": [
"invAdjReason.1",
"invAdjReason.2"
Attribute
Data Type
Description
values
Map<String, String>
A map where the key is the translation key and the value is the translation value.
Example Output
"invAdjReason.2": "Shrinkage",
"invAdjReason.1": "Wastage"
API: Find Items Descriptions
API Basics
Endpoint URL
{base URL}/items
Method
POST
Successful Response
200 OK
Processing Type
Synchronous
Input
Criteria
Output
A list of translation items
Max Response Limit
N/A
Attribute
Data Type
Required
Description
LocaleId
Long (12)
Yes
Unique identifier of the Locale to translate descriptions for (see findLocales).
itemIds
List<String(25)>
Yes
A list of items to get descriptions for within the locale.
Example Input
"localeId": 1,
"itemIds": [
"100637121",
"100637113"
Attribute
Data Type
Required
Description
itemId
String
The item identifier.
shortDescription
String
The short description in the locale's text if available.
longDescription
String
The long description in the locale's text if available.
Example Output
"itemId": "100637121",
"shortDescription": "translation value for 100637121",
"longDescription": "translation value for 100637121"
"itemId": "100637113",
"shortDescription": "translation value for 100637113",
"longDescription": "translation value for 100637113"
REST Service: Vendor Delivery
A direct store delivery (or vendor delivery) is a delivery in which the supplier drops off merchandise directly as the store. These deliveries can be against a planned delivery, an existing purchase order (PO) raised by corporate or by the store, or a purchase order created on the fly. The delivery supports containers coming in directly with Advanced Shipment Notice (ASN) or the system will create a container when the ASN is loaded into the system. Even for receipts without ASN, the system will allow the creation of containers. The four main types of deliveries are a delivery against a purchase order with an advance shipment notice, a delivery against a purchase order without an advance shipment notice, a delivery without a purchase order, and a DEX/NEX or Direct Exchange delivery. This service defines operations to manage vendor delivery information by integration with an external system.
Service Base URL
Find Delivery
Method
GET
URL
/dsds
Request Parameters
Table 4-456 Find Delivery — Request Parameters
Parameter Required Data Type Description
storeId
NA
Include only records where the delivery is to this store.
asn
NA
Include only records for this advanced shipping notification.
originType
NA
Include only records with this delivery origin type. Valid values are:
1 - Advanced Shipping Notification
2 - Purchase Order
3 - DEX-NEX
4 - Manual/On The Fly
Available values : 1, 2, 3, 4
status
NA
Include only records with this delivery status. Valid values are:
1 - New
2 - In Progress
3 - Received
4 - Canceled
5 - Rejected
99 - Active
Available values: 1, 2, 3, 4, 5, 99
customerOrderNumber
NA
Include only deliveries for this customer order number.
NA
Include only deliveries for this fulfillment order number.
invoiceNumber
NA
Include only deliveries for this invoice number.
supplierId
NA
integer($int10) (query)
Include only deliveries for this supplier.
purchaseOrderNumber
NA
string($text12) (query)
Include only deliveries for this purchase order number.
updateDateFrom
NA
updateDateTo
NA
Responses
Response Code: 200
Example Value
    "storeId": 5000,
    "supplierId": 5101,
    "status": 1,
    "originType": 1,
    "purchaseOrderId": 789012,
    "receiptNumber": 90000,
    "asn": "784562",
    "invoiceId": "10056",
    "customerOrderId": "45000",
    "fulfillmentOrderId": "45001",
    "createDate": "2025-01-22T14:55:02.719Z",
    "updateDate": "2025-01-22T14:55:02.719Z",
    "expectedDate": "2025-01-22T14:55:02.719Z",
    "invoiceDate": "2025-01-22T14:55:02.719Z",
    "receivedDate": "2025-01-22T14:55:02.719Z"
Schema — VendorDeliveryHeaderIdo
Table 4-457 VendorDeliveryHeaderIdo— Object
deliveryId
NA
number($int12) example: 11111
The unique identifier of the vendor delivery.
storeId
NA
supplierId
NA
The identifier of the supplier shipping the inventory.
status
NA
The current status of the vendor delivery. Valid values are:
1 - New
2 - In Progress
3 - Received
4 - Canceled
5 - Rejected
originType
NA
The origin type of the vendor delivery. Valid values are:
2 - Purchase Order
3 - DEX-NEX
Enum: [ 1, 2, 3, 4 ]
purchaseOrderId
NA
number($int12) example: 789012
The purchase order that the delivery is associated to (at header level).
receiptNumber
NA
integer($int12) example: 90000
The global receipt number of the delivery, used to identify the receipt across applications through integration.
asn
NA
string($text128) example: 784562
The advanced shipping notification.
invoiceId
NA
string($text128) example: 10056
The unique identifier of the invoice.
customerOrderId
NA
string($text128) example: 45000
The identifier of a customer order associated to the delivery.
fulfillmentOrderId
NA
string($text128) example: 45001
The identifier of a fulfillment order associated to the delivery.
createDate
MA
string($date-time)
updateDate
NA
string($date-time)
expectedDate
NA
string($date-time)
The expected delivery date of the delivery.
invoiceDate
NA
string($date-time)
The date of the delivery invoice.
receivedDate
NA
string($date-time)
The date the delivery was actually received.
Response Code: 400
Bad request
Create Delivery
This API creates a new vendor delivery as if SIOCS was the originator of the delivery. To create a ASN-based delivery where an external system manages the delivery as the originator, see the import delivery operation.
Method
POST
URL
/dsds
Request Parameters
Example Value
  "storeId": 5000,
  "supplierId": 5101,
  "originType": 1,
  "billOfLadingId": "55601",
  "carrierName": "Speedy Delivery",
  "carrierType": 1,
  "carrierCode": "SPDE",
  "sourceAddress": "200 Apple Street, Coolsville, WI, 55555",
  "licensePlate": "ABC-123",
  "freightId": "882211",
  "countryCode": "US",
  "currencyCode": "USD",
  "invoiceNumber": "10056",
  "invoiceDate": "2025-03-27T12:01:04.024Z",
  "invoiceAmount": 999.99,
  "cartons": [
      "externalCartonId": "444200301",
      "referenceId": "200440012",
      "damageReason": "Dropped",
      "serialCode": 337654,
      "trackingNumber": "AZB12743D",
      "damageRemaining": false,
      "qualityControl": false,
      "lineItems": [
          "itemId": "10045600",
          "caseSize": 10,
          "quantityReceived": 3,
          "quantityDamaged": 2,
          "unitCostOverrideAmount": 17.5,
          "purchaseOrderId": 500678,
          "uins": [
              "uin": "14532B12",
              "received": true,
              "damaged": false
Schema — VendorDeliveryCreateIdo
Table 4-458 VendorDeliveryCreateIdo — Object
storeId
Yes
supplierId
Yes
purchaseOrderId
NA
The purchase order that the delivery is being shipped for (if the shipment is for a single purchase order).
originType
Yes
2 - Purchase Order
3 - DEX-NEX
Enum: [ 2, 3, 4 ]
billOfLadingId
NA
string($text128) example: 55601
An external identifier of a bill of lading record.
carrierName
NA
string($text128) example: Speedy Delivery
The name of the carrier.
carrierType
NA
The carrier type of the vendor delivery. Valid values are:
1 - Corporate
2 - Third Party
Enum: [ 1, 2]
carrierCode
NA
string($text4) example: SPDE
sourceAddress
NA
string($text1000) example: 200 Apple Street, Coolsville, WI, 55555
The address of the source shipping location sending the delivery.
licensePlate
NA
string($text128) example: ABC-123
The license plate of the delivery vehicle.
freightId
NA
string($text128) example: 882211
countryCode
NA
string($text3) example: US
A country code of the country of the bill of lading.
currencyCode
NA
string($text3) example: USD
The currency code of the invoice cost.
invoiceNumber
NA
The unique identifier of the invoice associated to the delivery.
invoiceDate
NA
string($date-time)
invoiceAmount
NA
number($decimal(12,4)) example: 999.99
The value of the invoice cost.
cartons
Yes
object
The cartons present on the delivery.
Table 4-459 VendorDeliveryCreateCartonIdo — Object
externalCartonId
NA
string($text128) example: 444200301
The external identifier of the carton.
referenceId
NA
string($text128) example: 200440012
A reference identifier to the carton.
damageReason
NA
string($text128) example: Dropped
A reason for the carton damage that took place.
serialCode
NA
number($int18) example: 337654
A serial code for the carton.
trackingNumber
NA
string($text128) example: AZB12743D
A tracking number for the carton.
damageRemaining
NA
boolean example: false
True indicates all remaining unaddressed quantities should be marked damaged on final receipt.
receiveAtShopFloor
NA
True if it should receive inventory to the shop floor, false otherwise.
qualityControl
NA
True indicates the carton requires detailed receiving.
lineItems
Yes
object
The items contained within the carton.
Table 4-460 VendorDeliveryCreateItemIdo — Object
itemId
Yes
The unique identifier of the SKU item.
caseSize
NA
number($decima(10,2)) example: 10
The case size of the item.
quantityReceived
NA
number($decimal(20,4)) example: 3
The amount received on the delivery.
quantityDamaged
NA
number($decimal(20,4)) example: 2
The amount received as damaged on the delivery.
NA
number($decimal(20,4)) example: 17.5
The override unit cost value of this delivery.
purchaseOrderId
NA
integer($int12) example: 500678
The unique identifier of the purchase order for this item.
uins
NA
object
The UINs associated to this item.
Table 4-461 VendorDeliveryUinIdo — Object
uin
NA
string($text128) example: 14532B12
The Universal Identification Number.
received
NA
True if the UIN is received as part of the delivery, false otherwise.
damaged
NA
True if the UIN is received as damaged as part of the delivery, false otherwise.
Responses
Response Code: 200
Example Value
    "storeId": 5000,
    "supplierId": 5101,
    "status": 1
Schema — VendorDeliveryStatusIdo
Table 4-462 VendorDeliveryStatusIdo — Object
deliveryId
NA
storeId
NA
supplierId
NA
status
NA
1 - New
2 - In Progress
3 - Received
4 - Canceled
5 - Rejected
Response Code: 400
Bad request
Read Delivery
This section describes the Read Delivery API. This API retrieves all the details about a vendor delivery.
Method
GET
URL
/dsds/{deliveryId}
Request Parameters
Table 4-463 Read Delivery — Request Parameters
deliveryId
Yes
number($int12) (path)
Responses
Response Code: 200
Example Value
    "storeId": 5000,
    "supplierId": 5101,
    "status": 1,
    "originType": 1,
    "asn": "784562",
    "invoiceCurrency": "USD",
    "displayCartonInfo": true,
    "fiscalDocumentRequestId": 22233344455566,
    "fiscalDocumentReferenceId": 77788899100,
    "fiscalDocumentNumber": "128745",
    "createDate": "2025-03-27T12:03:25.084Z",
    "updateDate": "2025-03-27T12:03:25.084Z",
    "expectedDate": "2025-03-27T12:03:25.084Z",
    "invoiceDate": "2025-03-27T12:03:25.084Z",
    "receivedDate": "2025-03-27T12:03:25.084Z",
    "createUser": "smith123",
    "updateUser": "smith123",
    "cartons": [
        "cartonId": 100200300,
        "status": 1,
        "uinRequired": false,
        "externalCreate": false,
        "adjusted": false,
        "lineItems": [
            "lineId": 2222222,
            "caseSize": 10,
            "quantityExpected": 5,
            "quantityReceivedOverage": 3,
            "quantityDamagedOverage": 2,
            "quantityPreviouslyReceived": 3,
            "quantityPreviouslyDamaged": 2,
            "unitCostCurrency": "USD",
            "unitCostAmount": 14.5,
            "unitCostOverrideCurrency": "USD",
            "purchaseOrderNumber": "DX4600",
            "customerOrderNumber": "CO100000",
            "fulfillmentOrderNumber": "FO12",
            "vendorProductNumber": "147800",
            "uins": [
                "uin": "14532B12",
                "shipped": true,
                "received": true,
                "damaged": false
Schema — VendorDeliveryIdo
Table 4-464 VendorDeliveryIdo— Object
deliveryId
NA
storeId
NA
supplierId
NA
status
NA
1 - New
2 - In Progress
3 - Received
4 - Canceled
5 - Rejected
originType
NA
2 - Purchase Order
3 - DEX-NEX
purchaseOrderId
NA
receiptNumber
NA
asn
NA
invoiceNumber
NA
invoiceCurrency
NA
invoiceAmount
NA
customerOrderId
NA
fulfillmentOrderId
NA
displayCartonInfo
NA
True if carton information should be displayed in the UI, false otherwise.
billOfLadingId
NA
carrierName
NA
carrierCode
NA
countryCode
NA
sourceAddress
NA
licensePlate
NA
freightId
NA
NA
number($int20) example: 22233344455566
NA
number($int20) example: 77788899100
NA
string($text255) example: 128745
createDate
NA
string($date-time)
updateDate
NA
string($date-time)
expectedDate
NA
string($date-time)
invoiceDate
NA
string($date-time)
receivedDate
NA
string($date-time)
createUser
NA
string($text128) example: smith123
The user that created the delivery record.
updateUser
NA
The user that last updated the delivery record.
receivedUser
NA
The user that received the delivery record.
cartons
NA
object
The containers belonging to this delivery.
Table 4-465 VendorDeliveryCartonIdo— Object
cartonId
NA
integer($int12) example: 100200300
The unique identifier of the carton record.
externalCartonId
NA
referenceId
NA
A reference identifier for the carton.
status
NA
The current status of the carton. Valid values are:
1 - New
2 - In Progress
3 - Submitted
4 - Received
5- Damaged
6 - Missing
7 - Canceled
Enum: [ 1, 2, 3, 4, 5, 6, 7 ]
damageReason
NA
serialCode
NA
trackingNumber
NA
damageRemaining
NA
True indicates all remaining quantities should be marked damaged on final receipt.
uinRequired
NA
True if a UIN item exists within the carton, false otherwise.
receiveAtShopFloor
NA
True if delivery should receive inventory to the shop floor, false otherwise.
qualityControl
NA
externalCreate
NA
True indicates the carton was externally created, false indicates it was created by EICS.
adjusted
NA
True indicates the carton has been adjusted.
NA
Defines whether or not the items within the carton are related to customer orders. Valid values are:
1 - Yes
2 - Mix
3 - No
Enum: [ 1, 2, 3 ]
createDate
NA
string($date-time)
The date the carton was created.
updateDate
NA
string($date-time)
The date the carton was last updated.
receivedDate
NA
string($date-time)
The date the carton was received.
createUser
NA
The user that created the carton record.
updateUser
NA
The user that last updated the carton record.
receivedUser
NA
The user that received the carton record.
lineItems
NA
object
The items belonging to the carton.
Table 4-466 VendorDeliveryLineItemIdo— Object
lineId
NA
integer($int12) example: 2222222
The unique identier of the line item record.
itemId
NA
string($text25) example: 10045600
caseSize
NA
number($decimal(10,2)) example: 10
A case size of the item in this container.
quantityExpected
NA
number($decimal(20,4)) example: 5
The total amount expected on the delivery.
quantityReceived
NA
The total amount received on the delivery.
quantityDamaged
NA
The total amount received as damaged on the delivery.
NA
Amount of received inventory over expected quantities.
NA
Amount of received as damaged inventory over expected quantities.
NA
Units previously received (captured at time container is re-opened after receipt).
NA
Units previously received as damaged (captured at time container is re-opened after receipt).
unitCostCurrency
NA
The currency of the unit cost of this delivery.
unitCostAmount
NA
number($decimal(20,4)) example: 14.5
The unit cost value of this delivery.
NA
The currency of the override unit cost of this delivery.
NA
purchaseOrderId
NA
purchaseOrderNumber
NA
string($text128) example: DX4600
The external purchase order number for this item.
customerOrderNumber
NA
string($text128) example: CO100000
The unique external customer order identifier this item is fulfilling.
NA
string($text3) example: FO12
The unique external fulfillment order identifier this item is fulfilling.
vendorProductNumber
NA
string($text256) example: 147800
The vendor product number of the item.
uins
NA
object
The UINs being received as part of this item.
Table 4-467 VendorDeliveryLineItemUinIdo— Object
uin
NA
shipped
NA
True if the UIN was shipped from the supplier as part of the delivery, false otherwise.
received
NA
damaged
NA
Response Code: 400
Bad request
Update Delivery
This section describes the Update Delivery API. This API update the header portion of a delivery.
Method
POST
URL
/dsds/{deliveryId}
Request Parameters
Table 4-468 Update Delivery — Request Parameters
deliveryId
Yes
Example Value
  "carrierType": 1,
  "invoiceDate": "2025-01-28T13:22:31.457Z",
  "expectedDate": "2025-01-28T13:22:31.457Z"
Schema — VendorDeliveryUpdateIdo
Table 4-469 VendorDeliveryUpdateIdo — Object
billOfLadingId
NA
carrierName
NA
carrierType
NA
1 - Corporate
2 - Third Party
Enum: [ 1, 2 ]
carrierCode
NA
sourceAddress
NA
licensePlate
NA
freightId
NA
countryCode
NA
currencyCode
NA
invoiceNumber
NA
The number or identifier of the invoice associated to the delivery.
invoiceDate
NA
string($date-time)
invoiceAmount
NA
expectedDate
NA
string($date-time)
Responses
Response Code: 204
No content
Response Code: 400
Bad request
Receive Delivery
This section describes the Receive Delivery API. This API updates the received quantities to the quantities that were expected so that it is ready to be confirmed. This will place the delivery into the "In Progress" state if that is not already its current state.
Method
POST
URL
/dsds/{deliveryId}/receive
Request Parameters
Table 4-470 Receive Delivery — Request Parameters
deliveryId
Yes
Responses
Response Code: 204
No content
Response Code: 400
Bad request
Confirm Delivery
This section describes the Confirm Delivery API. This API confirms the vendor delivery and receives the goods into inventory.
Method
POST
URL
/dsds/{deliveryId}/confirm
Request Parameters
Table 4-471 Confirm Delivery — Request Parameters
deliveryId
Yes
Responses
Response Code: 204
No content
Response Code: 400
Bad request
Reject Delivery
This section describes the Reject Delivery API. This API cancels the vendor delivery without receiving goods and places it in rejected status.
Method
POST
URL
/dsds/{deliveryId}/reject
Request Parameters
Table 4-472 Reject Delivery — Request Parameters
deliveryId
Yes
Responses
This section describes the responses of the Reject Delivery API.
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Delivery
This section describes the Cancel Delivery API. This API cancels the vendor delivery without receiving goods and places it in canceled status.
Method
POST
URL
/dsds/{deliveryId}/cancel
Request Parameters
Table 4-473 Cancel Delivery — Request Parameters
deliveryId
Yes
Responses
This section describes the responses of the Cancel Delivery API.
Response Code: 204
No content
Response Code: 400
Bad request
Create Carton
This section describes the Crate Carton API. This API adds a new container to a new or in progress shipment.
Method
POST
URL
/dsds/{deliveryId}/cartons
Request Parameters
Table 4-474 Create Carton — Request Parameters
deliveryId
Yes
Details about the carton to create.
Example Value
  "lineItems": [
      "caseSize": 10,
      "uins": [
          "uin": "14532B12",
          "received": true,
          "damaged": false
Schema — VendorDeliveryCartonCreateIdo
Table 4-475 VendorDeliveryCartonCreateIdo — Object
Element Name Required Data Type/Example Description
externalCartonId
NA
referenceId
NA
damageReason
NA
serialCode
NA
trackingNumber
NA
damageRemaining
NA
receiveAtShopFloor
NA
True if will receive inventory to the shop floor, false otherwise.
qualityControl
NA
lineItems
Yes
object
The items to create within the carton.
Table 4-476 VendorDeliveryCartonCreateItemIdo — Object
itemId
Yes
caseSize
NA
The case size of the item in this carton.
quantityReceived
NA
The amount of the item received on the delivery.
quantityDamaged
NA
The amount of the item received as damaged on the delivery.
NA
purchaseOrderId
NA
The unique identifier of the purchase order for this item delivery.
uins
NA
object
Table 4-477 VendorDeliveryUinIdo — Object
uin
NA
received
NA
boolean example: true
damaged
NA
Responses
Response Code: 200
The media type is application/json.
Example Value
    "status": 1
Schema — VendorDeliveryCartonStatusIdo
Table 4-478 VendorDeliveryCartonStatusIdo— Object
eliveryId
NA
The unique identifier of the delivery record.
cartonId
NA
externalCartonId
NA
status
NA
1 - New
2 - In Progress
3 - Submitted
4 - Received
5 - Damaged
6 - Missing
7 - Canceled
Response Code: 400
Bad request
See the JSON Error Element and Error Codes section.
Update Carton
This section describes the Update Carton API. This API updates a previously existing carton that is in a new or in progress state, on a delivery that is also new or in progress.
Method
POST
URL
Request Parameters
Table 4-479 Update Carton — Request Parameters
cartonId
Yes
Details about the carton to update.
Example Value
  "lineItems": [
      "caseSize": 10,
      "uins": [
          "uin": "14532B12",
          "received": true,
          "damaged": false
Schema — VendorDeliveryCartonUpdateIdo
Table 4-480 VendorDeliveryCartonUpdateIdo — Object
externalCartonId
NA
referenceId
NA
damageReason
NA
serialCode
NA
trackingNumber
NA
damageRemaining
NA
receiveAtShopFloor
NA
True if the item should receive inventory to the shop floor, false otherwise.
qualityControl
NA
lineItems
NA
object
The items to update within the carton.
Table 4-481 VendorDeliveryCartonUpdateItemIdo — Object
itemId
Yes
caseSize
NA
A case size of the item within this carton.
quantityReceived
NA
The amount received for this item.
quantityDamaged
NA
The amounted received as damaged for this item.
NA
The override unit cost value of this item.
purchaseOrderId
Na
The unique identifer of the purchase order for this item.
uins
NA
object
Table 4-482 VendorDeliveryUinIdo — Object
uin
NA
received
NA
damaged
NA
Responses
Response Code: 204
No content
Response Code: 400
Bad request
Submit Carton
This section describes the Submit Carton API. This API moves the status of the carton to submitted and prevents further updates. The carton may still be confirmed. No inventory positions are updated via this operation.
Method
POST
URL
/dsds/cartons/{cartonId}/submit
Request Parameters
Table 4-483 Submit Carton — Request Parameters
cartonId
Yes
Responses
This section describes the responses of the Submit Carton API.
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Submitted Carton
This section describes the Cancel Submitted Carton API. This API opens a submitted carton for further updates, moving the status to in progress.
Method
POST
URL
/dsds/cartons/{cartonId}/cancelsubmit
Request Parameters
Table 4-484 Cancel Submitted Carton — Request Parameters
cartonId
Yes
Responses
This section describes the responses of the Cancel Submitted Carton API.
Response Code: 204
No content
Response Code: 400
Bad request
Confirm Carton
This section describes the Confirm Carton API. This API confirms the final receipt of a vendor delivery carton.
Method
POST
URL
Request Parameters
Table 4-485 Confirm Carton — Request Parameters
cartonId
Yes
Responses
Response Code: 204
No content
Response Code: 400
Bad request
Cancel Carton
This section describes the Cancel Carton API. This API cancels a vendor delivery carton.
Method
POST
URL
Request Parameters
Table 4-486 Cancel Carton — Request Parameters
cartonId
Yes
Responses
Response Code: 204
No content
Response Code: 400
Bad request
Open Carton
This section describes the Open Carton API. This API re--opens a completed carton after reciept allowing it to be received again.
Method
POST
URL
/dsds/cartons/{cartonId}/open
Request Parameters
Table 4-487 Open Carton — Request Parameters
cartonId
Yes
Responses
Response Code: 204
No content
Response Code: 400
Bad request
Import ASN Delivery
This section describes the Import ASN Delivery API. This API imports an ASN vendor delivery that is managed by an external system. When importing, the contents must contain the entire delivery. This asynchronous call places a record in the MPS message table for later processing, controlled by the DcsAsn work type.
Method
POST
URL
/dsds/imports
Request Parameters
There are no request parameters.
Example Value
  "asn": "789012",
  "storeId": 5000,
  "supplierId": 5101,
  "invoiceDate": "2025-02-06T11:48:31.239Z",
  "fiscalDocumentNumber": "USD",
  "expectedDate": "USD",
  "carrierType": 1,
  "cartons": [
      "cartonNumber": "444200301",
      "lineItems": [
          "quantity": 3,
          "purchaseOrderNumber": "500678",
          "uins": [
            333000341341,
            444001343243
  "looseItems": [
      "quantity": 3,
      "uins": [
        333000341341,
        444001343243
  "notes": [
    "This is note number one.",
    "This is note number two."
Schema — VendorDeliveryImportIdo
Table 4-488 VendorDeliveryImportIdo — Object
asn
Yes
string($text128) example: 789012
The the asn.
storeId
NA
number($int10) example: 5000
The identifier of the store receiving the inventory.
supplierId
Yes
number($int10) example: 5101
invoiceNumber
NA
invoiceDate
NA
string($date-time)
invoiceAmount
NA
currencyCode
NA
NA
The fiscal document number. This is an imported external fiscal document number and is simply stored. The document may not exist in the system as a fiscal document.
expectedDate
NA
string($date-time) example: USD
The date the delivery is expected to arrive.
displayCartonInfo
NA
If true, carton information will be displayed on the UI, otherwise only item information will be displayed.
billOfLadingId
NA
carrierName
NA
carrierType
NA
integer($int4) example: 1
1 - Corporate
2 - Third Party
Enum: Array [ 2
carrierCode
NA
A unique code that identifies the carrier.
sourceAddress
NA
licensePlate
NA
freightId
NA
A freight identifier associated to the delivery.
countryCode
NA
cartons*
Yes
object
looseItems
NA
object
A collection of loose items not on the delivery. These will be gathered and placed in a generated carton.
notes
NA
string($text2000)] example: List [ "This is note number one.", "This is note number two." ]
A collection of notes on the delivery.
Table 4-489 VendorDeliveryImportCartonIdo — Object
cartonNumber
NA
The external identifier of the carton. A carton will be added or updated based on whether or not it already exists on the delivery.
trackingNumber
NA
qualityControl
NA
lineItems
Yes
object
A collection of items in the container. If all items within the container are set to a zero quantity, the carton will be cancelled.
Table 4-490 VendorDeliveryImportItemdo — Object
itemId
Yes
quantity
Yes
The total amount of the item expected on the delivery.
purchaseOrderNumber
Yes
string($text128) example: 500678
The external system purchase order number.
uins
NA
string($text128)] example: List [ 333000341341, 444001343243 ]
A list of UINs that shipped as part of the delivery.
Responses
Response Code: 202
Accepted
Response Code: 400
Bad request
Import ASN Cancel Delivery
This section describes the Import ASN Cancel Delivery API. This API imports a cancellation of the vendor delivery. The vendor delivery must be in new status in order to be canceled. It cannot be cancelled if receiving has begun against it as well. This asynchronous call places a record in the MPS message table for later processing, controlled by the DcsAsn work type.
Method
POST
URL
/dsds/imports/cancel
Request Parameters
Example Value
  "asn": "5101",
  "storeId": 5000
Schema — VendorDeliveryImportCancelIdo
Table 4-491 VendorDeliveryImportCanelIdo — Object
asn
NA
string($text128) example: 5101
The advanced shipping notification of the delivery.
storeId
NA
Responses
Response Code: 202
Accepted
Response Code: 400
Bad request
Import ASN Adjustments
This section describes the Import ASN Adjustments API. This API is used to import external adjustments made to a vendor delivery. It does not adjust the delivery itself but does track adjustments made after the delivery is closed. It updates the inventory stock positions and the received amount of the purchase order. This asynchronous call places a record in the MPS message table for later processing, controlled by the DcsAsn work type.
Method
POST
URL
/dsds/adjustments
Request Parameters
Example Value
  "asn": "93471341",
  "storeId": 5000,
  "items": [
      "cartonNumber": "9834834",
      "purchaseOrderNumber": "34AA04134",
      "quantity": 55.23
Schema — VendorDeliveryAdjustmentImportIdo
Table 4-492 VendorDeliveryAdjustmentImportIdo — Object
asn
Yes
string($text128) example: 93471341
storeId
Yes
The unique identifier of the store receiving the inventory.
items
Yes
object
itmes
Table 4-493 VendorDeliveryAdjustmentImportItemIdo — Object
itemId
Yes
string($text25) example: 100637121
The item that is being adjusted.
cartonNumber
Yes
string($text128) example: 9834834
The carton number of the carton containing the item.
purchaseOrderNumber
Yes
string($text128) example: 34AA04134
The purchase order number associated to the adjustment.
quantity
Yes
number($decimal(20,4)) example: 55.23
The new amount of the item received to be adjusted to.
Responses
This section describes the responses of the Import ASN Adjustments API.
Response Code: 400
Bad request
Find ASN Adjustments
This section describes the Find ASN Adjustments API. This API retrieves the adjustments made for a delivery after the delivery was received.
Method
GET
URL
/dsds/adjustments
Request Parameters
Table 4-494 Find ASN Adjustments — Request Parameters
deliveryId
NA
number($int10) (query)
Include only records for this delivery.
asn
NA
string($text128) (query)
Responses
This section describes the responses of the Find ASN Adjustments API.
Response Code: 200
The request has been successful.
Example Value
    "adjustmentId": 55601,
    "deliveryId": 513434,
    "storeId": 5000,
    "adjustmentDate": "2025-02-06T13:25:54.461Z",
    "quantity": 55.23
Schema — VendorDeliveryAdjustmentIdo
Table 4-495 VendorDeliveryAdjustmentIdo— Object
adjustmentId
NA
number($int15) example: 55601
The identifier of the delivery adjustment record.
deliveryId
NA
number($int12) example: 513434
The identifier of the delivery.
storeId
NA
purchaseOrderNumber
NA
itemId
NA
The item that was adjusted.
adjustmentDate
NA
string($date-time)
The date of the adjustment.
quantity
NA
The new amount of the item to be adjusted to.
Response Code: 400
Bad request
REST Service: Vendor Return
A return request is a return to vendor that comes into the store from an external system. A return request is a made for items to be returned to the supplier from the store. The items and quantities requested to be returned and reasons (for RTV) will be listed. Updating the return allows the approved quantity to be assigned. Once the request has been approved, the items are shipped to the supplier. This service allows for the integration of return requests with an external system.
Service Base URL
Find Return
This section describes the Find Return API. This API Finds up to 10,000 return headers for the input criteria.
Method
GET
URL
/vendorreturns
Request Parameters
Table 4-496 Find Return — Request Parameters
storeId
NA
Include only returns from this store.
supplierId
NA
Include only returns to this supplier.
externalReturnId
NA
Include only returns for this vendor return external identifier.
status
NA
integer($int4) (query)
Include only returns with this status. Valid values are:
1 - Requested
2 - Request In Progress
3 - RTV In Progress
4 - Approved
5 - In Shipping
6 - Completed
7 - Rejected
8 - Canceled Request
9 - Canceled RTV
99 - Active
Available values : 1, 2, 3, 4, 5, 6, 7, 8, 9, 99
itemId
NA
string($text25) (query)
Include only returns that contain this item.
shipmentReasonId
NA
number($int15) (query)
Include only returns that contain this shipment reason.
updateDateFrom
NA
string($date-time) (query)
Include only returns with an update date on or after this date.
updateDateTo
NA
Include only returns with an update date on or before this date.
Responses
This section describes the responses of the Find Return API.
Response Code: 200
Example Value
    "returnId": 11111,
    "storeId": 5000,
    "supplierId": 5101,
    "externalReturnId": "90000",
    "status": 1,
    "notAfterDate": "2025-01-17T16:44:28.715Z",
    "approvedDate": "2025-01-17T16:44:28.715Z",
    "closedDate": "2025-01-17T16:44:28.715Z",
    "createDate": "2025-01-17T16:44:28.715Z",
    "updateDate": "2025-01-17T16:44:28.715Z"
Schema — VendorReturnHeaderIdo
Table 4-497 VendorReturnHeaderIdo— Object
returnId
NA
The unique identifier of the vendor return.
storeId
NA
The identifier of the store returning the inventory.
supplierId
NA
The identifier of the supplier the goods are being shipped to.
externalReturnId
NA
string($text128) example: 90000
A unique identifier of the vendor return from an external system.
status
NA
1 - Requested
3 - RTV In Progress
4 - Approved
5 - In Shipping
6 - Completed
7 - Rejected
9 - Canceled RTV
Enum: [ 1, 2, 3, 4, 5, 6, 7, 8, 9 ]
notAfterDate
NA
string($date-time)
A date after which the return should not be shipped.
approvedDate
NA
string($date-time)
The date the return was approved.
closedDate
NA
string($date-time)
The date the return was closed.
createDate
NA
string($date-time)
The date the return was created in SIOCS.
updateDate
NA
string($date-time)
The date the return was last updated in SIOCS.
Response Code: 400
Bad request
Create Return
This section describes the Create Return API. This service creates a new vendor return document.
Method
POST
URL
/vendorreturns
Request Parameters
The are no request parameters.
The request body is application/json.
Example Value
  "storeId": 5000,
  "supplierId": 5101,
  "notAfterDate": "2025-01-20T14:04:51.208Z",
  "authorizationCode": "JID112",
  "addressLine1": "460 Summer Street",
  "addressLine2": "Apartment 2",
  "addressLine3": "c/o John Smith",
  "aAddressCity": "Coolsville",
  "addressState": "NY",
  "addressCountry": "US",
  "addressPostalCode": "55555-1111",
  "lineItems": [
      "reasonId": "82236",
      "quantity": 100,
      "caseSize": 1
Schema — VendorReturnCreateIdo
Table 4-498 VendorReturnCreateIdo— Object
storeId
Yes
The identifier of the store returning the inventory. This value is ignored if the return already exists.
supplierId
Yes
The identifier of the supplier the goods are being shipped to. This value is ignored if the return already exists.
notAfterDate
NA
string($date-time)
A date after which the return should not be shipped. If not included, this value will be defaulted through system configuration.
authorizationCode
NA
string($text12) example: JID112
An authorization number that may be required for the return.
addressLine1
NA
string($text240) example: 460 Summer Street
The first line of the destination address.
addressLine2
NA
string($text240) example: Apartment 2
The second line of the destination address.
addressLine3
NA
string($text240) example: c/o John Smith
The third line of the destination address.
aAddressCity
NA
string($text120) example: Coolsville
The city of the destination address.
addressState
Na
string($text3) example: NY
The state of the destination address.
addressCountry
NA
The country code of the destination address.
addressPostalCode
NA
string($text30) example: 55555-1111
The postal code of the destination address.
lineItems*
Yes
object
The items to be returned.
Table 4-499 VendorReturnCreateLineItemIdo— Object
itemId
Yes
reasonId
NA
string($text6) example: 82236
The unique identifier of a return reason code for this item return.
quantity
Yes
number($decimal(20,4)) example: 100
The quantity to return.
caseSize
The case size of this item return.
Responses
This section describes the responses of the Create Return API.
Response Code: 200
Example Value
    "returnId": 11111,
    "storeId": 5000,
    "supplierId": 5101,
    "status": 1
Schema — VendorReturnStatusIdo
Table 4-500 VendorReturnStatusIdo— Object
returnId
NA
storeId
NA
supplierId
Na
status
NA
1 - Requested
3 - RTV In Progress
4 - Approved
5 - In Shipping
6 - Completed
7 - Rejected
9 - Canceled RTV
Response Code: 400
Bad request
Read Return
This section describes the Read Return API. This service retrieves all the details about a vendor return.
Method
GET
URL
/vendorreturns/{returnId}
Request Parameters
Table 4-501 Read Return — Request Parameters
returnId
Yes
Responses
This section describes the responses of the Read Return API.
Response Code: 200
Example Value
    "returnId": 11111,
    "storeId": 5000,
    "supplierId": 5101,
    "externalLocked": true,
    "originType": 1,
    "status": 1,
    "notAfterDate": "2025-01-17T16:59:15.721Z",
    "approvedUser": "smith123",
    "approvedDate": "2025-01-17T16:59:15.721Z",
    "closedUser": "smith123",
    "closedDate": "2025-01-17T16:59:15.721Z",
    "createDate": "2025-01-17T16:59:15.721Z",
    "updateDate": "2025-01-17T16:59:15.721Z",
    "lineItems": [
        "lineId": 2222222,
        "externalLineId": 456,
        "shipmentReasonId": 82236,
        "caseSize": 3,
        "quantityRequested": 100,
        "quantityApproved": 100,
        "quantityShipping": 100,
        "quantityShipped": 100
Schema — VendorReturnIdo
Table 4-502 VendorReturnIdo— Object
returnId
NA
storeId
NA
supplierId
NA
externalReturnId
NA
A unique identifer of the vendor return from an external system.
externalLocked
NA
True if the system no longer accepts changes to the vendor return from an external source.
originType
NA
The origin type of the return. Valid values are:
1 - External
2 - Internal <br/ 3 - Shipment
Enum: [ 1, 2, 3 ]
status
NA
1 - Requested
3 - RTV In Progress
4 - Approved
5 - In Shipping
6 - Completed
7 - Rejected
9 - Canceled RTV
notAfterDate
NA
string($date-time)
authorizationCode
NA
addressLine1
NA
addressLine2
NA
addressLine3
NA
aAddressCity
NA
addressState
NA
addressCountry
NA
addressPostalCode
NA
approvedUser
NA
The user that approved the return.
approvedDate
NA
string($date-time)
closedUser
NA
The user that closed the return.
closedDate
NA
string($date-time)
createUser
NA
The user that created the return.
createDate
NA
string($date-time)
The date the return was created.
updateUser
NA
The user that last updated the return.
updateDate
NA
string($date-time)
The date the return was last updated.
lineItems
NA
object
A collection of items to be returned.
Table 4-503 VendorReturnLineItemIdo— Object
lineId
NA
integer($int15) example: 2222222
The unique identifier of the line record.
externalLineId
NA
integer($int15) example: 456
An external identifier to this particular line item on the return.
itemId
NA
shipmentReasonId
NA
integer($int15) example: 82236
The unique identifier of the shipment reason.
caseSize
NA
number($decimal(10,2)) example: 3
The case size of this record.
quantityRequested
NA
The quantity requested to return.
quantityApproved
NA
The quantity approved to return.
quantityShipping
NA
The quantity prepared to ship on the return.
quantityShipped
NA
The quantity that has shipped on the return.
Response Code: 400
Bad request
Update Return
This section describes the Update Return API. This service updates vendor return approved quantities prior to approving the vendor return.
Method
POST
URL
Request Parameters
Table 4-504 Update Return — Request Parameters
returnId
Yes
Vendor return details to update.
Example Value
  "lineItems": [
      "quantity": 100
Schema — VendorReturnUpdateIdo
Table 4-505 VendorReturnUpdateIdo— Object
authorizationCode
NA
lineItems
NA
object
A list of up to 1,000 items with approved quantities to be included on the return. The collection can remain empty if only updating the authorization code.
Table 4-506 VendorReturnUpdateLineItemIdo— Object
itemId
Yes
shipmentReasonId
Yes
The unique identier of the shipment reason. If the shipment reason is unavailable, the quantity must not exceed the item's unavailable stock. Unavailable sub-buckets are not considered in vendor return and are only used when creating the vendor shipment.
quantity
Yes
Responses
This section describes the responses of the Update Return API.
Response Code: 204
No content.
Response Code: 400
Bad request
Approve Return
This section describes the Approve Return API. This service approves a vendor return for shipment. Use the Update Return operation to assign and persist desired quantities before approval.
Method
POST
URL
/vendorreturns/{returnId}/approve
Request Parameters
Table 4-507 Approve Return — Request Parameters
returnId
Yes
Responses
This section describes the responses of the Approve Return API.
Response Code: 204
No content.
Response Code: 400
Bad request
Close Return
This section describes the Close Return API. This service closes out the vendor return.
Method
POST
URL
/vendorreturns/{returnId}/close
Request Parameters
Table 4-508 Close Return — Request Parameters
returnId
Yes
Responses
This section describes the responses of the Close Return API.
Response Code: 204
No content.
Response Code: 400
Bad request
Import Return
This section describes the Import Return API. This service imports a vendor return request managed by an external system. Processing assumes that any notification to other systems about the creation of this information will be managed by the external system. The imported return is processed asynchronous through our MPS sub-system and is controlled by the DcsRtv work type. If more than 1,000 items are included in the return, a "input too large" error will be returned. This operation will return a forbidden error code if the system is integrated with Oracle merchandising.
Method
POST
URL
/vendorreturns/imports
Request Parameters
Vendor return details to import.
Example Value
  "storeId": 5000,
  "supplierId": 5101,
  "notAfterDate": "2025-01-20T15:17:16.265Z",
  "comment": "Originally overshipped goods.",
  "createDate": "2025-01-20T15:17:16.265Z",
  "lineItems": [
      "reasonCode": "82236",
      "quantity": 100,
      "sequence": 1
Schema — VendorReturnImportIdo
Table 4-509 VendorReturnImportIdo— Object
externalReturnId
Yes
A unique identifer of the vendor return from an external system. This identifier is used to determine if the import will be created or updated.
storeId
Yes
supplierId
Yes
notAfterDate
NA
string($date-time)
authorizationCode
NA
addressLine1
NA
addressLine2
NA
addressLine3
NA
aAddressCity
NA
addressState
NA
addressCountry
NA
addressPostalCode
NA
comment
NA
string($text2000) example: Originally overshipped goods.
A comment to associate to the vendor return request.
createDate
Yes
string($date-time)
lineItems
Yes
object
Table 4-510 VendorReturnImportLineItemIdo— Object
itemId
Yes
reasonCode
Yes
A reason code associate to the item return.
quantity
Yes
sequence
NA
number($int15) example: 1
An external sequence number for the item on the return.
Responses
This section describes the responses of the Import Return API.
Response Code: 204
No content.
Response Code: 400
Bad request
Import Return Delete
This section describes the Import Return Delete API. This service will place a delete notification in the system (in the MPS work queue with DcsRtv work type) for asynchronous processing. When processed, it will cancel the vendor return if it qualifies for cancellation (it is not already in progress). This operation will return a forbidden error code if the system is integrated with Oracle merchandising.
Method
DELETE
URL
/vendorreturns/imports/{externalReturnId}
Request Parameters
Table 4-511 Import Return Delete — Request Parameters
externalReturnId
Yes
string($text128) (path)
The unique identifier of the vendor return from the external system.
Responses
This section describes the responses of the Import Return Delete API.
Response Code: 202
Accepted.
Response Code: 400
Bad request
REST Service: Vendor Shipment
Vendor shipment is the process of shipping inventory out of the store back to a supplier for redistribution or disposal. If the store plans to return items to the vendor, it can be done by creating a vendor shipment (RTV shipment). The items, quantities to be returned, and reasons for the return, can be added to the shipment. When the shipment is dispatched, the goods are removed from inventory.
To create a shipment, a supplier must be identified for this return. The supplier must allow for returns and must be a DSD supplier, and if the system is configured to use multiple sets of books, then the supplier is limited to the same operating unit as that of the store.
Items along with reasons can be added to the return. For Return to Vendors, the system allows a mix of available and unavailable inventory status items on the return; therefore, all reasons for the Return to Vendor type will be listed. All items on the return must be sourced by the supplier designated on the RTV. Authorization Number, which is required for certain suppliers, would need to be entered before dispatching.
The service defines operations to manage vendor shipment information by integration with an external system.
Service Base URL
The Cloud service base URL follows the format:
Find Shipments
This section describes the Find Shipments API. This API finds up to 10,000 shipments headers for the input criteria.
Method
GET
URL
/rtvshipments
Request
This section describes the request parameters.
Table 4-512 Find Shipments— Request Parameters
storeId
NA
number ($int10) (query)
Include only records where the shipment is from this store.
supplierId
NA
Include only shipments where the shipment is to this supplier.
vendorReturnId
NA
number ($int15) (query)
Include only shipments for this vendor return (by internal identifier).
vendorReturnExternalId
NA
string ($text128) (query)
Include only shipments for this vendor return (by external identifier).
status
NA
integer ($int4) (query)
Include only shipments with this delivery status. Valid values are
1 – New
2 - In Progress
3 – Submitted
4 – Shipped
5 – Canceled
99 – Active
itemId
NA
Include only shipments that contain this item.
updateDateFrom
NA
string ($date-time)(query)
Include only shipments with an update date on or after this date.
updateDateTo
NA
string ($date-time) (query)
Include only shipments with an update date on or before this date.
Responses
This section describes the responses of the Find Shipments API.
Response Code: 200
Example Value
    "shipmentId": 11111,
    "storeId": 5000,
    "supplierId": 5101,
    "vendorReturnId": 789012,
    "vendorReturnExternalId": "90000",
    "status": 1,
    "notAfterDate": "2024-08-30T07:40:22.421Z",
    "submitDate": "2024-08-30T07:40:22.421Z",
    "dispatchDate": "2024-08-30T07:40:22.422Z",
    "updateDate": "2024-08-30T07:40:22.422Z"
Schema — VendorShipmentHeaderIdo
This section describes the VendorShipmentHeaderIdo schema.
Table 4-513 VendorShipmentHeaderIdo — Object
Element Name Required Data Type Description
shipmentId
NA
The unique identifier of the vendor shipment.
storeId
NA
The identifier of the store shipping the inventory.
supplierId
NA
vendorReturnId
NA
number($int15) example: 789012
The unique identifier of the vendor return this shipment is for.
NA
status
NA
The current status of the vendor shipment. Valid values are:
1 – New
2 - In Progress
3 – Submitted
4 – Shipped
5 – Canceled
Enum: [ 1, 2, 3, 4, 5 ]
notAfterDate
NA
string($date-time)
A date after which the shipment should not be shipped.
submitDate
NA
string($date-time)
The date the shipment was submitted.
dispatchDate
NA
string($date-time)
The date the shipment was dispatched.
updateDate
NA
string($date-time)
The date the delivery was last updated.
Response Code: 400
Bad Request
Create Shipment
This section describes the Create Shipment API. It creates a new vendor shipment whose status is in progress. When creating the vendor shipment, it only allows up to 1,000 items in the overall shipment.
Method
POST
URL
/rtvshipments
Request
The shipment details of the new shipment.
Example Value
  "storeId": 5000,
  "supplierId": 5101,
  "supplierCountryCode": "USA",
  "authorizationCode": "H112",
  "notAfterDate": "2024-08-30T07:55:27.191Z",
  "contextId": 90000,
  "contextValue": "Spring Return",
  "addressType": 1,
  "carrierRole": 1,
  "carrierId": 123,
  "carrierServiceId": 456,
  "alternateAddress": "Another Street, Different City, NY, 44444",
  "alternateCarrierName": "Speedy Delivery",
  "alternateCarrierAddress": "Carrier Street, Carrier City, NY, 44444",
  "motiveId": 123,
  "taxId": "11-33500",
  "trackingNumber": "44000567002",
  "dimensionId": 100,
  "weight": 12.8,
  "weightUom": "KG",
  "requestedPickupDate": "2024-08-30T07:55:27.191Z",
  "cartons": [
      "externalCartonId": "4500300",
      "trackingNumber": "876300456",
      "restrictionLevel": 1,
      "cartonSizeId": 1000,
      "weight": 4.5,
      "weightUom": "LBS",
      "lineItems": [
          "reasonId": 2222222,
          "caseSize": 3,
          "quantity": 100,
          "uins": [
            111345000,
            222220000
  "notes": [
    "The first note",
    "The second note"
Schema — VendorShipmentCreateIdo
This section describes the VendorShipmentCreateIdo schema.
Table 4-514 VendorShipmentCreateIdo — Object
storeId
Yes
supplierId
Yes
supplierCountryCode
NA
string($text3) example: USA
The country code of the supplier for this shipment. All items must be available with this country code. If left blank, a country code will be selected from the available supplier items giving preference to a country code that matches the store.
vendorReturnId
NA
authorizationCode
NA
string($text12) example: H112
notAfterDate
NA
string($date-time)
contextId
NA
number($int18) example: 90000
A unique identifier of a context for the shipment (see shipping service).
contextValue
NA
string($text25) example: Spring Return
An additional value associated to the context for the shipment.
addressType
NA
The hierarchy restriction level for items in the container. Valid values are:
1 - Department
2 - Class
3 - Subclass
4 - None
Enum: [ 1, 2, 3, 4
carrierRole
Yes
integer($int2) example: 1
The type of carrier for the shipment. Valid values are:
1 - Sender
2 - Receiver
3 - Third Party
Enum: [ 1, 2, 3 ]
carrierId
NA
integer($int10) example: 123
A unique identifier of a carrier for the shipment.
carrierServiceId
NA
integer($int10) example: 456
A unique identifier of a carrier service for the shipment.
alternateAddress
NA
string($text2000) example: Another Street, Different City, NY, 44444
An alternate destination address.
NA
string($text240) example: Speedy Delivery
The name of a third-party shipping company.
NA
string($text240) example: Carrier Street, Carrier City, NY, 44444
The address of a third-party shipping company.
motiveId
NA
number($int18) example: 123
The identifier ofa motive for the bill of lading.
taxId
NA
string($text18) example: 11-33500
The tax identifier of the supplier it is being shipped to.
trackingNumber
NA
string($text128) example: 44000567002
A tracking number associated to the shipment.
dimensionId
NA
The identifier of a dimension object associated to the shipment.
weight
NA
number($decimal(12,4)) example: 12.8
The weight of the shipment.
weightUom
NA
string($text4) example: KG
The unit of measure of the weight of the shipment.
requestedPickupDate
NA
string($date-time)
The requested pickup date.
cartons Yes object cartons
notes NA string ($text2000) example: List [ "The first note", "The second note" ] A collection of up to 100 notes to be created.
Table 4-515 VendorShipmentCreateCartonIdo — Object
externalCartonId
NA
string($text128) example: 4500300
A container identifier from an external system.
trackingNumber
NA
string($text128) example: 876300456
restrictionLevel
NA
integer($int4)
example: 1 The hierarchy restriction level for items in the container. Valid values are:
1 - Department
2 - Class
3 - Subclass
4 - None
cartonSizeId
NA
integer($int10) example: 1000
The unique identifier of the container dimension object.
weight
NA
number($decimal(12,4)) example: 4.5
The weight of the container.
weightUom
NA
string($text4) example: LBS
The unit of measure of the weight of the container.
lineItems
Yes
object
line items
Table 4-516 VendorShipmentCreateLineItemIdo — Object
itemId
Yes
reasonId
Yes
caseSize
NA
quantity
Yes
The quantity that was shipped.
uins
NA
string($text128)] example: List [ 111345000, 222220000 ]
The UINs that were shipped. They total number must match the quantity shipped.
Responses
This section describes the responses of the Create Shipment API.
Response Code: 200
Successful response.
Example Value
    "shipmentId": <shipmentId>,
    "returnId": <returnId>,
    "status": 1
Schema — VendorShipmentStatusIdo
This section describes the VendorShipmentStatusIdo schema.
Table 4-517 VenderoShipmentStatusIdo
shipmentId
NA
number($int15) example: 11111
returnId
NA
number($int15) example: 5000
The identifier of the associated vendor return.
status
NA
The current status of the vendor shipment. Valid values:
1 - New
2 - In Progress
3 - Submitted
4 - Shipped
5 - Canceled
Response Code: 400
Bad request
Read Shipment
This section describes the Read Shipment API. This API retrieves all the details about an vendor shipment.
Method
GET
URL
/rtvshipments/{shipmentId}
Request
Table 4-518 Read Shipment — Request Parameters
Parameters Required Data Type Description
shipmentId
Yes
Responses
This section describes the responses of the Read Shipment API.
Response Code: 200
Successful response
This media type is application/json.
Example Value
    "storeId": 5000,
    "supplierId": 5101,
    "status": 1,
    "notAfterDate": "2024-08-28T09:29:33.327Z",
    "contextId": 90000,
    "destinationAddress1": "460 Summer Street",
    "destinationAddress2": "Apartment 2",
    "destinationAddress3": "c/o John Smith",
    "destinationAddressCity": "Coolsville",
    "destinationAddressState": "NY",
    "destinationAddressCountry": "US",
    "destinationAddressPostalCode": "55555-1111",
    "billOfLadingId": 55601,
    "carrierRole": 1,
    "carrierId": 123,
    "motive": "Overstock",
    "dimensionId": 100,
    "weight": 12.8,
    "weightUom": "KG",
    "requestedPickupDate": "2024-08-28T09:29:33.327Z",
    "fiscalDocumentStatus": 1,
    "fiscalDocumentRejectReason": "Missing Requirements",
    "fiscalDocumentUrl": "http://fiscaldoc/doc123",
    "createDate": "2024-08-28T09:29:33.327Z",
    "submitUser": "smith123",
    "submitDate": "2024-08-28T09:29:33.327Z",
    "dispatchUser": "smith123",
    "dispatchDate": "2024-08-28T09:29:33.327Z",
    "updateDate": "2024-08-28T09:29:33.327Z",
    "cartons": [
        "status": 1,
        "cartonDimensionId": 1000,
        "weight": 4.5,
        "weightUom": "LBS",
        "createDate": "2024-08-28T09:29:33.328Z",
        "updateDate": "2024-08-28T09:29:33.328Z",
        "approvalDate": "2024-08-28T09:29:33.328Z",
        "approvalUser": "smith123",
        "lineItems": [
            "lineId": 2222222,
            "shipmentReasonId": 2222222,
            "caseSize": 3,
            "quantity": 100,
            "uins": [
              111345000,
              222220000
Schema — VendorShipmentIdo
This section describes the VendorShipmentIdo schema.
Table 4-519 VendorShipmentIdo — Object
shipmentId
NA
storeId
NA
supplierId
NA
vendorReturnId
NA
NA
status
NA
1 - New
2 - In Progress
3 - Submitted
4 - Shipped
5 - Canceled
notAfterDate
NA
string($date-time)
authorizationCode
NA
A vendor authorization code
contextId
NA
A unique identifer of a context for the shipment (see shipping service).
contextValue
NA
destinationAddress1
NA
destinationAddress2
NA
destinationAddress3
NA
NA
NA
NA
NA
billOfLadingId
NA
A bill of lading identifier.
alternateAddress
NA
carrierRole
NA
1 - Sender
2 - Receiver
3 - Third Party
Enum: [ 1, 2, 3 ]
carrierId
NA
carrierServiceId
NA
NA
NA
motive
NA
string($text120) example: Overstock
A motive for the shipment.
taxId
NA
trackingNumber
NA
dimensionId
NA
weight
NA
weightUom
NA
requestedPickupDate
NA
string($date-time)
NA
The identifier of the request for a fiscal document.
NA
The unique identifier of the fiscal document
NA
NA
The status of the fiscal document. Valid values are
1 - Approved
2 - Submitted
3 - Rejected
4 - Canceled
NA
string($text255) example: Missing Requirements
A reason the fiscal document was rejected.
fiscalDocumentUrl
NA
A URL to the fiscal document.
createUser
NA
The user that created the shipment.
createDate
NA
string($date-time)
The date the shipment was created.
submitUser
NA
The user that submitted the shipment.
submitDate
NA
string($date-time)
dispatchUser
NA
The user that dispatched the shipment.
dispatchDate
NA
string($date-time)
updateUser
NA
The user that last updated the shipment.
updateDate
NA
string($date-time)
cartons NA object cartons
Table 4-520 VendorShipmentCartonIdo — Object
cartonId
NA
integer($int15) example: 100200300
externalCartonId
NA
status
NA
1 - New
2 - In Progress
3 - Completed
4 - Shipped
5 - Canceled
cartonDimensionId
NA
weight
NA
weightUom
NA
trackingNumber
NA
The tracking number of the container.
restrictionLevel
NA
The hierarchy restriction level for items in the container. Valid values are1 - Department
2 - Class
3 - Subclass
4 - None
createDate
NA
string($date-time)
createUser
NA
The user that created the carton.
updateDate
NA
string($date-time)
updateUser
NA
The user that last updated the carton.
approvalDate
NA
string($date-time)
The date the carton was approved.
approvalUser
NA
The user that approved the carton.
lineItems NA object line items
Table 4-521 VendorShipmentLineItemIdo — Object
lineId
NA
The unique identier of the line record.
itemId
NA
shipmentReasonId
NA
caseSize
NA
quantity
NA
uins
Na
string($text128) example: List [ 111345000, 222220000 ]
Response Code: 400
Bad request
Update Shipment
This section describes the Update Shipment API. This API updates the header portion of a shipment as well as its bill of lading information. See carton related operations for creating or updating cartons on the shipment.
Method
POST
URL
Request
Table 4-522 Update Shipment — Request Parameters
shipmentId
Yes
Shipment header details to update
Example Value
  "notAfterDate": "2024-08-28T12:54:48.823Z",
  "contextId": 90000,
  "addressType": 1,
  "carrierRole": 1,
  "carrierId": 123,
  "motiveId": 123,
  "dimensionId": 100,
  "weight": 20.4,
  "weightUom": "KG",
  "requestedPickupDate": "2024-08-28T12:54:48.823Z",
  "notes": [
    "The first note",
    "The second note"
Schema — VendorShipmentUpdateIdo
This section describes the VendorShipmentUpdateIdo schema.
Table 4-523 VendorShipmentUpdateIdo — Object
notAfterDate
NA
string($date-time)
authorizationCode
NA
contextId
NA
contextValue
NA
addressType
NA
1 - Department
2 - Class
3 - Subclass
4 - None
carrierRole
Yes
1 - Sender
2 - Receiver
3 - Third Party
Enum: [ 1, 2, 3 ]
carrierId
NA
carrierServiceId
NA
alternateAddress
NA
NA
NA
motiveId
NA
The unique identifier of a mtoive for the bill of lading.
taxId
NA
trackingNumber
NA
dimensionId
NA
The idnetifier of a dimension object associated to the shipment.
weight
NA
number($decimal(12,4)) example: 20.4
weightUom
NA
requestedPickupDate
NA
string($date-time)
notes
NA
string($text2000) example: List [ "The first note", "The second note" ]
A collection of up to 100 notes to be added to the list of notes.
Responses
This section describes the responses of the Update Shipment API.
Response Code: 204
No Content
Response Code: 400
Bad request
Submit Shipment
This section describes the Submit Shipment API. This API submits a vendor shipment placing it into submitted status awaiting review and eventual dispatch. Fiscal document data capture can occur as part of this process.
Method
POST
URL
/rtvshipments/{shipmentId}/submit
Request
This section describes the request paramters.
Table 4-524 Submit Shipment — Request Parameters
shipmentId
Yes
Fiscal document information to include as part of the submission.
Example Value
  "vehicleNumber": "ABC-222",
  "vehicleStateOrCountry": "New York",
  "driverName": "John Smith",
  "driverLicenseNumber": "HBAC-123456"
Schema — VendorShipmentFiscalSubmitIdo
This section describes the VendorShipmentFiscalSubmitIdo schema.
Table 4-525 VendorShipmentFiscalSubmitIdo — Object
vehicleNumber
NA
string($text25) example: ABC-222
The vehicle license plate or identifying number.
NA
string($text25) example: New York
The vehicle's state or country.
driverName
NA
string($text30) example: John Smith
The name of the driver.
driverLicenseNumber
NA
string($text30) example: HBAC-123456
The driver's liscence number.
Responses
This section describes the responses of the Submit Shipment API.
Response Code: 204
No Content
Response Code: 400
Bad request
Cancel Submit Shipment
This section describes the Cancel Submit Shipment API. Cancels the submission of a shipment moving it back to in progress state.
Method
POST
URL
/rtvshipments/{shipmentId}/cancelSubmit
Request
Table 4-526 Cancel Submit Shipment — Request Parameters
shipmentId
Yes
Responses
This section describes the responses of the Cancel Submit Shipment API.
Response Code: 204
No Content
Response Code: 400
Bad request
Dispatch Shipment
This section describes the Dispatch Shipment API. This API dispatches the shipment to the destination, closing the shipment, and updating inventory.
Method
POST
URL
/rtvshipments/{shipmentId}/dispatch
Request
Table 4-527 Dispatch Shipment — Request Parameters
shipmentId
Yes
Responses
This section describes the responses of the Dispatch Shipment API.
Response Code: 204
No Content
Response Code: 400
Bad request
Cancel Shipment
This section describes the Cancel Shipment API. This API cancels the shipment. This will close the associated vendor return.
Method
POST
URL
Request
Table 4-528 Cancel Shipment — Request Parameters
shipmentId
Yes
Responses
This section describes the responses of the Cancel Shipment API.
Response Code: 204
No Content
Response Code: 400
Bad request
Create Carton
This section describes the Create Carton API. This API adds a new container to a new or in progress shipment.
Method
POST
URL
/rtvshipments/{shipmentId}/cartons
Request
Table 4-529 Create Carton — Request Parameters
shipmentId
Yes
The unique identifier of the shipment.
The request body is applicaton/json.
Details for the carton to create.
Example Value
  "weight": 4.5,
  "weightUom": "LBS",
  "lineItems": [
      "caseSize": 3,
      "quantity": 100,
      "uins": [
        111345000,
        222220000
Schema — VendorShipmentCartonCreateIdo
This section describes the VendorShipmentCartonCreateIdo schema.
Table 4-530 VendorShipmentCartonCreateIdo — Object
externalCartonId
NA
trackingNumber
NA
restrictionLevel
NA
1 - Department
2 - Class
3 - Subclass
4 - None
cartonSizeId
NA
weight
NA
weightUom
NA
lineItems
Yes
object
line items
Table 4-531 VendorShipmentCartonCreateLineItemIdo — Object
itemId
Yes
reasonId
Yes
caseSize
NA
quantity
Yes
uins
NA
string($text128 example: List [ 111345000, 222220000 ]
The UINs that were shipped. The total number must match the quantity shipped.
Responses
This section describes the responses of the Create Carton API.
Reason Code: 200
Successful response
Example Value
    "cartonId": 5000,
    "status": 1
Schema — VendorShipmentCartonStatusIdo
This section describes the VendorShipmentCartonStatusIdo schema.
Table 4-532 VendorShipmentCartonStatusIdo — Object
shipmentId
NA
cartonId
NA
The identifier of the new carton.
status
NA
1 - New
2 - In Progress
3 - Completed
4 - Shipped
5 - Canceled
Response Code: 400
Bad request
Update Carton
This section describes the Update Carton API. Updates a previously existing carton that is in a new or in progress state, on a shipment that is also new or in progress.
Method
POST
URL
/rtvshipments/cartons/{cartonId}
Request
Table 4-533 Update Create — Request Parameters
Parameters Required Data Type/Example Description
cartonId
Yes
The unique identifier of the shipment carton.
Details for the carton to update.
Example Value
  "weight": 4.5,
  "weightUom": "LBS",
  "lineItems": [
      "caseSize": 3,
      "quantity": 100,
      "uins": [
        111345000,
        222220000
Schema — VendorShipmentCartonUpdateIdo
This section describes the VendorShipmentCartonUpdateIdo schema.
Table 4-534 VendorShipmentCartonUpdateIdo — Object
externalCartonId
NA
trackingNumber
NA
restrictionLevel
NA
1 - Department
2 - Class
3 - Subclass
4 - None
cartonSizeId
NA
weight
NA
weightUom
NA
lineItems
Yes
object
Line items
Table 4-535 VendorShipmentCreateLineItemIdo — Object
itemId
Yes
reasonId
Yes
caseSize
NA
quantity*
Yes
uins
NA
Responses
This section describes the responses of the Update Carton API.
Response Code: 204
No Content
Response Code: 400
Bad request
Confirm Carton
This section describes the Confirm Carton API. This API confirms a carton indicating the carton is ready for dispatch. This sets the carton so it can no longer be modified.
Method
POST
URL
/rtvshipments/cartons/{cartonId}/confirm
Request
Table 4-536 Confirm Carton — Request Parameters
cartonId
Yes
Responses
This section describes the responses of the Confirm Carton API.
Response Code: 204
No Content
Response Code: 400
Bad request
Cancel Carton
This section describes the Cancel Carton API. This API cancels a carton effectively removing its contents from the shipment.
Method
POST
URL
/rtvshipments/cartons/{cartonId}/cancel
Request
Table 4-537 Cancel Carton — Request Parameters
cartonId
Yes
Responses
This section describes the responses of the Cancel Carton API.
Response Code: 204
No Content
Response Code: 400
Bad request
Open Carton
This section describes the Open Carton API. This API opens a previously confirmed carton so that it can be modified again.
Method
POST
URL
/rtvshipments/cartons/{cartonId}/open
Request
Table 4-538 Open Carton — Request Parameters
cartonId
Yes
Responses
This section describes the responses of the Open Carton API.
Response Code: 204
No Content
Response Code: 400
Bad request
REST Service: Warehouse
This service integrates warehouse and warehouse item foundation data as well as warehouse item inventory adjustments.
Asynchronous warehouse integration is processed through staged messages and is controlled by the MPS Work Type: DcsWarehouse.
Service Base URL
https://<external_load_balancer>/<cust_env>/siocs-int-services/api/warehouses
API Definitions
API
Description
Import Warehouses
Imports a collection of warehouses into the system.
Delete Warehouse
Deletes a warehouse from the system.
Import Items
Imports a collection of warehouse items.
Delete Items
Deletes warehouse items from the system.
Import Adjustments
Imports a collection of warehouse items adjustments that took place.
Import Inventory
Imports a collection of warehouse item inventory to update the inventory positions.
API: Import Warehouses
This will import warehouses through foundation warehouse processing.
If more than 500 warehouses are sent in a single call, an input too large error will be returned.
API Basics
Endpoint URL
{base URL}/import
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of warehouses to import
Output
None
Max Response Limit
500
Input Data Definition
Attribute
Data Type
Required
Description
warehouses
List of details
Yes
A list of warehouses to import.
Detail Data Definition
Attribute
Data Type
Required
Size
Description
warehouseId
Long (10)
Yes
The warehouse identifier.
name
String (150)
Yes
150
The name of the warehouse.
organizationUnit
String (15)
15
The organization the warehouse belongs to.
countryCode
String (3)
3
The ISO country code of the warehouse.
currencyCode
String (40)
3
The ISO currency code of the warehouse.
Example Output
"warehouses": [
"warehouseId": 64,
"name": "DownTownWarehouse-1",
"organizationUnit": "70001",
"countryCode": "IN",
"currencyCode": "INR"
"warehouseId": 65,
"name": "CitynWarehouse-1",
API: Delete Warehouse
Deletes a warehouse. The warehouse will not be deleted if any items remain ranged to the warehouse.
API Basics
Endpoint URL
{base URL}{warehouseId}/delete
Method
POST
Successful Response
202 Accepted
Processing Type
Synchronous
Input
None
Output
None
Max Response Limit
N/A
Path Parameter Definitions
Attribute
Definition
warehouseId
The internal identifier of the warehouse.
API: Import Items
API Basics
If more than 5000 items are sent in a single call, an input too large error will be returned.
Endpoint URL
{base URL}/{warehouseId}/items/import
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous (High Volume)
Input
A list of warehouse items to import
Output
None
Max Response Limit
5000
Attribute
Definition
warehouseId
Attribute
Data Type
Required
Description
items
List of details
Yes
A list of warehouse items to import.
Detail Import Data Definition
Attribute
Data Type
Required
Description
itemId
String (25)
Yes
The item identifier.
standardUom
String (4)
Yes
The standard unit of measure of the item.
status
Integer
Yes
The status (See Index: Warehouse Item Import Status)
clearInventory
Boolean
Yes
True indicates that the inventory positions should all be set to zero.
Example Input
"items": [
"itemId": "100000147",
"standardUom": "EA",
"status": 1,
"clearInventory": true
"itemId": "100000148",
"standardUom": "KG",
"status": 2,
"clearInventory": false
Additional Data Definitions
Warehouse Import Item Status
Value
Definition
1
ACTIVE
2
DISCONTINUED
3
INACTIVE
API: Delete Items
Marks warehouse items for later deletion.
API Basics
Endpoint URL
Method
POST
Successful Response
202 Accepted
Processing Type
Asynchronous
Input
List of item ids to delete
Output
None
Max Response Limit
5000
Attribute
Definition
warehouseId
Attribute
Data Type
Required
Description
items
List<String(25)>
Yes
A collection of up to 5000 items to remove.
Example Input
"itemIds": [ "100000301", "100000147" ]
API: Import Adjustments
A list of warehouse adjustments is processed, inventory is updated for the warehouse items, and then the adjustments are discarded.
They are not persisted anywhere and this process does not produce a transaction history record.
API Basics
Endpoint URL
{base URL} {warehouseId}/adjustments/import
Method
POST
Successful Response
202 Accepted
Processing Type
Input
A list of warehouse adjustments to import
Output
None
Max Response Limit
5000
Attribute
Definition
warehouseId
Attribute
Data Type
Required
Description
adjustments
List of details
Yes
A list of adjustments that occurred for that warehouse.
Attribute
Data Type
Required
Description
itemId
String (25)
Yes
The unique item identifier.
quantity
BigDecimal
Yes
The quantity to be adjusted.
reasonCode
Integer
Yes
The unique reason code of an inventory adjustment reason code.
Example Input
"adjustments": [
"quantity": 100,
"reasonCode": 182
"itemId": "100000024",
"quantity": 50,
"reasonCode": 183
API: Import Inventory
This operation updates the inventory positions of a warehouse.
API Basics
Endpoint URL
{base URL}/{warehouseId}/inventory/import
Method
POST
Successful Response
200 Accepted
Processing Type
Asynchronous
Input
List of items with their inventory
Max Input
10,000 items
Output
N/A
Max Response Limit
N/A
Attribute
Type
Definition
Items
List of Warehouse Inventory
A list of items to overwrite inventory for at the warehouse.
Warehouse Inventory Ido
Attribute
Type
Definition
itemId
String(25)
quantityTotal
BigDecimal(12,4)
The total quantity of the item in inventory.
quantityReserved
BigDecimal(12,4)
he quantity reserved for outgoing shipping.
quantityUnavailable
BigDecimal(12,4)
The quantity unavailable for usage.
quantityInTransit
BigDecimal(12,4)
The quantity in transit to the warehouse.
Example Input
"items
"quantityTotal”: 100,
"quantityReserved”: 8
"quantityTotal”: 50,
"quantityInTransit”: 183
