Numbered Steps
The Numbered Steps module for quarterly alerts shows three easy steps for the process of finding financial assistance through the Savings Hub survey.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Savings Hub Name Appears in the title of the module. Default: Savings Hub |
Required Choose from the following:
Numbered Steps Variations
The Numbered Steps module in quarterly alerts varies depending on the season, and on the status of the customer's Savings Hub survey.
General (Not Summer or Winter)
| Survey Status | Variation Text |
| Unstarted Survey | Step 1: Take a 2-minute survey about your household. |
| Started Survey |
Winter
| Unstarted Survey |
| Started Survey |
Summer
| Default and Fallback Unstarted Survey |
| Started Survey |
