Facts
Important! As of the v2.7.0.1 release, all materialized views are removed from Oracle Utilities Analytics Warehouse.
This section lists all the Oracle Utilities Network Management System star schemas.
Abnormal Device Log
Captures details of devices that go into an abnormal state and end up with an alarm log in the source system.
Note: This fact is designed to cater to various KPI requirements about abnormal devices in the Switching dashboard in Oracle Utilities Analytics Warehouse.
Entity Relationship Diagram
Entity relationship diagram for the Abnormal Device Log fact
Properties
Property
Value
Target Table Name
CF_ABNORMAL_DEVICE_LOG
Table Type
Fact
Fact Type
Accumulation
Driver Table
DDS_ALARM_LOG
ODI Package Name
B1_PKG_CF_ABNORMAL_DEVICE_LOG
ETL View Name
B1_F_ABNORMAL_DEVICE_LOG_VW
Fields
Target Field
OAS Field
Source Field
Transformation Logic
Surrogate Key
ABNORMAL_DEVICE_
LOG_KEY
Abnormal Device Log Surrogate Key
Populated with the sequence from B1_ABNORMAL_DEVICE_LOG_SEQ.NEXTVAL.
Natural Keys
SRC_ALARM_CLS
Alarm Message Class
DDS_ALARM_LOG.ALARM_CLS
SRC_ALARM_IDX
Alarm Message Index
DDS_ALARM_LOG.ALARM_IDX
Measures
FACT_CNT
Count
Populated with the standard value of ‘1’.
Degenerate Dimensions
ABNORMAL_DTTM
Abnormal Date/Time
DDS_ALARM_LOG.
USER_TIME
ACK_DTTM
Acknowledgment Date/Time
DDS_ALARM_LOG.
TIME_ACK
DEACT_DTTM
Deactivation Date/Time
DDS_ALARM_LOG.
WHEN_DEACTIVATED
SYSTEM_TIME
System Date/Time
DDS_ALARM_LOG.SYSTEM_TIME
Foreign Keys
ABNORMAL_DATE_KEY
Abnormal Date Key
DDS_ALARM_LOG.USER_TIME
Populated based on the Date part of ABNORMAL_DTTM.
ABNORMAL_TIME_KEY
Abnormal Time Key
Populated based on the Time of ABNORMAL_DTTM.
ACK_DATE_KEY
Acknowledgment Date Key
DDS_ALARM_LOG.TIME_ACK
Populated based on the Date part of ACK_DTTM.
ACK_TIME_KEY
Acknowledgment Time Key
Populated based on the Time part of ACK_DTTM.
DEACT _DATE_KEY
Deactivation Date Key
DDS_ALARM_LOG. WHEN_DEACTIVATED
Populated based on the Date part of DEACT_DTTM.
DEACT _TIME_KEY
Deactivation Time Key
Populated based on the Time part of DEACT_DTTM.
ALARM_LOG_KEY
Alarm Log Key
Populated based on ALARM_CLS and ALARM_IDX from DDS_ALARM_LOG table.
If any (either alarm class or index) of the values is 0, then map to the zeroth key.
DEVICE_KEY
Device Dimension Surrogate Key
DDS_ALARM_LOG.DEVICE_CLS
DDS_ALARM_LOG.DEVICE_IDX
Populated based on DEVICE_CLS and DEVICE_IDX from DDS_ALARM_LOG table.
If any (either device class or index) of the values is 0, then map to the zeroth key.
In case of non-electrical devices, devices will not be available in the Device dimension. Facts referring to these devices will be populated with 0 instead of -99.
CTRL_ZONE_KEY
Control Zone Dimension Surrogate Key
DDS_ALARM_LOG.NCG
Populated based on the primary control zone hierarchy of NCG from the DDS_ALARM_LOG table.
CTRL_ZONE_SEC_KEY
Control Zone Sec Dimension Surrogate Key
DDS_ALARM_LOG.NCG
Populated based on the secondary control zone hierarchy of NCG from DDS_ALARM_LOG table.
ABNORMAL_DEVICE_LOG_UDD1_KEY
Abnormal Device Log User Defined Dimension 1 Surrogate Key
ABNORMAL_DEVICE_LOG_UDD2_KEY
Abnormal Device Log User Defined Dimension 2 Surrogate Key
SYSTEM_DATE_KEY
System Date Key
Populated based on the SYSTEM_DTTM part from the CD_DATE table.
SYSTEM_TIME_KEY
System Time Key
Populated based on the SYSTEM_DTTM part from the CD_TIME table.
User Defined Attributes
UDM1
User Defined Measure 1
UDM2
User Defined Measure 2
UDM3
User Defined Measure 3
UDM4
User Defined Measure 4
UDM5
User Defined Measure 5
UDM6
User Defined Measure 6
UDM7
User Defined Measure 7
UDM8
User Defined Measure 8
UDM9
User Defined Measure 9
UDM10
User Defined Measure 10
UDM11
User Defined Measure 11
UDM12
User Defined Measure 12
UDM13
User Defined Measure 13
UDM14
User Defined Measure 14
UDM15
User Defined Measure 15
UDM16
User Defined Measure 16
UDM17
User Defined Measure 17
UDM18
User Defined Measure 18
UDM19
User Defined Measure 19
UDM20
User Defined Measure 20
UDDGEN1
User Defined Degenerate Dimension 1
UDDGEN2
User Defined Degenerate Dimension 2
UDDGEN3
User Defined Degenerate Dimension 3
UDDGEN4
User Defined Degenerate Dimension 4
UDDGEN5
User Defined Degenerate Dimension 5
UDDGENL1
User Defined Long Degenerate Dimension 1
UDDGENL2
User Defined Long Degenerate Dimension 2
UDDGENL3
User Defined Long Degenerate Dimension 3
UDDGENL4
User Defined Long Degenerate Dimension 4
UDDGENL5
User Defined Long Degenerate Dimension 5
UDDFK1_KEY
User Defined Dimension Foreign Key 1
UDDFK2_KEY
User Defined Dimension Foreign Key 2
UDDFK3_KEY
User Defined Dimension Foreign Key 3
UDDFK4_KEY
User Defined Dimension Foreign Key 4
UDDFK5_KEY
User Defined Dimension Foreign Key 5
Data Load Attributes
DATA_SOURCE_IND
Data Source Indicator
CES_PARAMETER.
VALUE
Populated with the DSI value on the source product instance configuration.
The table is populated as part of the initial setup and the DSI value is extracted from the source system.
JOB_NBR
Job Number
Populated with the ODI job execution session number.
Call
Stores details about the incidents created in the source system and also captures details about the associated jobs. The data is stored for all restored and un-restored jobs.
Entity relationship diagram for the Call fact
Properties
Property
Value
Target Table Name
CF_RST_CALL
Table Type
Fact
Fact Type
Accumulation
Driver Table Name
INCIDENTS
ODI Package Name
B1_PKG_CF_RST_CALL
ETL View Name
B1_F_RECENT_CALL_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
RST_CALL_KEY
Restored Call Fact Surrogate Key
Populated with the sequence from SPL_RST_CALL_SEQ.
Natural Keys
SRC_INCIDENT_ID
Source Incident ID
INCIDENTS.DECODE(NVL(ASSOCIATE_IDX, 0), 0,NU=MB,ASSOCIATE_IDX)
Populated with NUMB if the Associate Index value is 0. Else, Associated Index value is populated.
Measures
FACT_CNT
Count
PRIORITY_IND
Priority Indicator
INCIDENTS.DECODE(SUBSTR(INCIDENTS.COMPLAINT, 7, 1 ), '1', '1', '2', '1'= ,'0')
Populate from the extracted nth character of the COMPLAINT column of INCIDENTS table, where ‘n’ is defined by the configuration parameter B1_PRTY_BIT.
If the extracted value is 1 or 2, populate as 1, else populate as 0.
RST_IND
Restored Indicator
JOBS.RESTORE_TIME
If RESTORE_TIME is populated in the JOBS table, then this field is populated as 1; else as 0.
Foreign Keys
EVENT_KEY
Event Key
JOBS.NUMB
Populated from CD_EVENT's surrogate key using NUMB column JOBS table.
ACCT_KEY
Account Key
CES_CUSTOMERS_HISTORY.ACCOUNT_
NUMBER
Populated based on the account in the CD_ACCOUNT dimension.
CALL_DATE_KEY
Call Date Key
INCIDENTS.INPUT_
TIME
Populated based on the date part in the CD_DATE dimension.
CALL_TIME_KEY
Call Time Key
INCIDENTS.INPUT_
TIME
Populated based on the Time part in the CD_TIME dimension.
CTRL_ZONE_KEY
Control Zone Key
INCIDENTS.NCG
USER_KEY
User Key
CES_USER.USER_NAME
Populated with user name in the CD_USER table.
CALL_INFO_KEY
Call Info Key
INCIDENTS.DECODE(NVL(ASSOCIATE_IDX, 0),0,NUMB,ASSOCIATE_IDX)
If the Associate Index value is 0, this field is populated with NUMB. Else, it is populated with Associated Index value.
PREM_KEY
Premise Key
CES_CUSTOMERS_HISTORY.SERV_LOC_ID
Populated with the service location ID in the CD_PREM table.
ADDR_KEY
Address Key
DEVICE_KEY
Device Key
INCIDENTS.H_IDX
INCIDENTS.H_CLS
Populated based on H_IDX and H_CLS in the CD_DEVICE table.
ACCT_TYPE_KEY
Account Type Key
CES_CUSTOMERS_HISTORY.ACCOUNT_TYPE
Populated with the account type.
METER_KEY
Meter Key
CES_CUSTOMERS_HISTORY.METER_ID
Populated with the meter ID in the CD_METER table.
NETWORK_PREMISE_
KEY
Network Premise Key
Populated with the service location ID in the CD_NETWORK_PREM table.
CTRL_ZONE_SEC_KEY
Control Zone Secondary Key
INCIDENTS.NCG
Populate from CD_CTRL_ZONE_SEC dimension's surrogate key based on NCG ID and records effective date/time is between effective start and end date/time of dimension.
STORM_KEY
Storm Key
STORMMAN_STORMS.STORM_NAME
STORMMAN_STORMS.STORM_DATE
STORMMAN_STORMS.ZONE_IDX
Populated based on the storm name, date and control zone.
CALL_UDD1_KEY
User Defined Dimension 1 Key
CALL_UDD2_KEY
User Defined Dimension 2 Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
User Defined Dimension Surrogate Key 1
UDDFK2_KEY
User Defined Dimension Surrogate Key 2
UDDFK3_KEY
User Defined Dimension Surrogate Key 3
UDDFK4_KEY
User Defined Dimension Surrogate Key 4
UDDFK5_KEY
User Defined Dimension Surrogate Key 5
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
City Outage
A monthly snapshot fact that stores various measures (such as CMI, SAIDI, SAIFI, number of customers, number of interruptions, etc) at the city and major event type level.
This fact is unusual in the sense that its data is not populated directly from the source tables in the replication schema. It is a calculated fact whose data is derived from the data in the Customer restored facts.
Entity relationship diagram for the City Outage fact
Properties
Property
Value
Target Table Name
CF_CITY_OUTG
Table Type
Fact
Fact Type
Snapshot
Driver Table
CD_CITY
ODI Package Name
B1_PKG_CF_CITY_OUTG
ETL View Name
n/a
Fields
Target Field
OAS Field
Source Field
Surrogate Key
CITY_OUTG_KEY
City Outage Snapshot Fact Key
Populated with the sequence from SPL_CITY_OUTG_SEQ.
Natural Keys
SRC_CITY
City
CD_CITY.SRC_CITY
Loaded with city information from the City dimension that is active during the slice period.
SRC_STATE
State
CD_CITY.SRC_STATE
Loaded with state information from the City dimension that is active during the slice period.
SRC_COUNTRY
Country
CD_CITY.SRC_COUNTRY
Loaded with country information from the City dimension that is active during the slice period.
SNAP_TYPE_CD
Snapshot Type Code
B1_DSI_CONFIG_VW.SNAP_TYPE_CD
Populated with snapshot type from DSI config view based on the configuration of the snapshot defined in the target entity table.
MAJ_EVT_SNAP_TYPE_
CD
Major Event Snapshot Type Code
CD_MJR_EVT_SNAP_TYPE.SNAP_TYPE_CD
Populated with all combinations of control zone.
Measures
NUM_CUST_SERVED
Number of Customers Served
CES_CUSTOMERS_HISTORY.NUM_CUST_SERVED
Populated with the number of active customers served within the City during the snapshot period.
NUM_SUST_INTRPT
Number of Sustained Interruptions
CF_CUST_RST_OUTG.NUM_SUST_INTRPT
Populated with the count of sustained outages during the snapshot period.
An outage is considered sustained if the difference between the beginning and ending time of the outage (in minutes) is greater than the configured momentary threshold in minutes.
NUM_MOM_INTRPT
Numb. Mom. Interruptions
CF_CUST_RST_OUTG.NUM_MOM_INTRPT
Populated with the count of momentary outages during the snapshot period.
An outage is considered momentary if the difference between the beginning and ending time of the outage (in minutes) is less than or equal to the configured momentary threshold in minutes.
CMI
CMI
CF_CUST_RST_OUTG.
CMI
Populated with the sum of customer minutes interrupted (in minutes) for sustained outages.
NUM_MULT_SUST_
INTRPT
Number of Multiple Sustained Interruptions
CF_CUST_RST_OUTG.
NUM_MULT_SUST_
INTRPT
Populated with the count of sustained outages greater than the configured CEMI count.
NUM_MULT_CUST_
INTRPT
Number of Multiple Customer Interruptions
CF_CUST_RST_OUTG.
NUM_MULT_CUST_
INTRPT
Populated with the count of sustained and momentary outages greater than the configured CEMI count.
SAIDI
SAIDI
CF_CUST_RST_OUTG.
BEGIN_DTTM
CF_CUST_RST_OUTG.
RST_DTTM
Populated with the customer minutes interrupted by number of customers served.
CAIDI
CAIDI
CF_CUST_RST_OUTG.
CAIDI
Populated with the customer minutes interrupted divided by the number of customers interrupted.
SAIFI
SAIFI
CF_CUST_RST_OUTG.
SAIFI
Populated with the number of customer interruptions divided by the number of customers served.
MAIFIE
MAIFIE
CF_CUST_RST_OUTG.
MAIFIE
Populated with the momentary customer interruptions divided by the number of customers served.
Note
: This metric is for momentary events - if there were multiple reclose attempts to clear a fault, it only counts as a single event.
NUM_CUST_INTRPT
Customers Interrupted
CF_CUST_RST_OUTG.
NUM_CUST_INTRPT
Populated with the number of sustained customer interruptions.
Note: If a customer has had multiple sustained interruptions, each one is counted.
NUM_MOM_E_INTRPT
Number of Momentary Events Preceding a Sustained Interruption
CF_CUST_RST_OUTG.
NUM_MOM_E_INTRPT
Populated with the number of momentary events during the period, excluding the events that immediately precede a sustained interruption.
NUM_EVENT
Number of Events
CF_CUST_RST_OUTG.
NUM_EVENT
Populated with the number of events during the period.
It is the sum of number of sustained interruptions and number of momentary interruptions.
NUM_CUST_SUST_
INTRPT
Number of Customers who experienced a Sustained Interruption
CF_CUST_RST_OUTG.
NUM_CUST_SUST_
INTRPT
Populated with the number of customers who experienced a sustained interruption during the period.
FACT_CNT
Count
SNAPSHOT_DT
Snapshot Date
B1_JOB_EXEC.SLICE_END_DTTM
Consider one second less than the slice end date (<date>23:59:59).
Foreign Keys
SNAPSHOT_DATE_KEY
Snapshot Date Surrogate Key
Populated with the last date of current snapshot period (populates only the date part).
CITY_KEY
City Surrogate Key
CD_CITY.CITY_KEY
Populated based on the customers active during the snapshot period.
BEGIN_DATE_KEY
Snapshot Begin Date Surrogate Key
B1_JOB_EXEC.SLICE_START_DTTM
Populated based on the slice start date from the B1_JOB_EXEC table.
END_DATE_KEY
Snapshot End Date Surrogate Key
Populated based on the difference between slice end date and one second from the B1_JOB_EXEC table.
CITY_OUTG_UDD1_KEY
City outage User Defined Dimension 1 Surrogate Key
CITY_OUTG_UDD2_KEY
City outage User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Control Zone Outage
An accumulation fact that captures all reliability metrics for leaf level NCG daily.
Entity relationship diagram for the Control Zone Outage fact
Properties
Property
Value
Target Table Name
CF_CTRL_ZONE_OUTG
Table Type
Fact
Fact Type
Accumulation
Driver Table
CD_CTRL_ZONE
ODI Package Name
B1_PKG_CF_CTRL_ZONE_OUTG
ETL View Name
n/a
Fields
Target Field
OAS Field
Source Field
Surrogate Key
CTRL_ZONE_OUTG_
KEY
Control Zone Outage Fact Key
Populated with the sequence from SPL_CTRL_ZONE_OUTG_SEQ.
Natural Keys
SRC_NCG_ID
NCG ID
CD_CTRL_ZONE.NCG_
ID
Loaded with control zone details from Control Zone dimension that are active during the slice period.
Measures
NUM_CUST_SERVED
Populated with the number of active customers served in the control zone during the snapshot period.
1. Joins with CES_CUSTOMERS_HISTORY on NCG and the BIRTH and DEATH effective for that snapshot period.
2. Counts the number of records.
NUM_SUST_EVENT
Number of Sustained Events
Populated with the count of events that are momentary within the statistics period.
A sustained event can be identified when the difference between begin and end time of the outage (outage duration in minutes) is greater than the configured number of momentary minutes.
NUM_SUST_INTRPT
CF_CUST_RST_OUTG.BEGIN_DTTM
CF_CUST_RST_OUTG.RST_DTTM
Populated with the count of sustained outages during the period.
An outage is considered sustained if the difference between the beginning and ending time of the outage (in minutes) is greater than the configured number of momentary minutes.
NUM_MOM_EVENT
Populated with the count of momentary events during the period.
A momentary event can be identified when the difference between begin and end time of the outage (the outage duration in minutes) is less than the configured number of momentary minutes.
NUM_MOM_INTRPT
An outage is considered momentary if the difference between the beginning and ending time of the outage (in minutes) is less than or equal to the configured number of momentary minutes.
CMI
CMI
NUM_MULT_SUST_
INTRPT
CF_CUST_RST_OUTG.PER.SRC_PER_ID
CF_CUST_RST_OUTG.PREM.SRC_PREM_ID
CF_CUST_RST_OUTG.METER.SRC_METER_ID
Populated with the count of sustained outages that are greater than the configured CEMI count.
NUM_MULT_CUST_
INTRPT
Populated with the count of sustained and momentary outages that are greater than the configured CEMI count.
SAIDI
SAIDI
CAIDI
CAIDI
Populated with the number of customer minutes interrupted divided by the number of customers interrupted.
SAIFI
SAIFI
Populated with the number of customers interrupted divided by the number of customers served.
MAIFIE
MAIFIE
Populated with the number of momentary customer interruption events divided by the number of customers served.
NUM_CUST_INTRPT
Populated with the sum of customer interruptions during the period.
If a customer experiences multiple interruptions, each should be counted.
NUM_MOM_E_INTRPT
NUM_EVENT
Number of Events
NUM_CUST_SUST_
INTRPT
Populated with the count of customers who experienced more than P_CEMI_COUNT sustained interruptions during the period.
FACT_CNT
Count
STATISTICS_DTTM
Statistics Date/Time
Populated with job processing date end time in the DD-MON-YYYY HH24:MI:SS format.
Foreign Keys
CTRL_ZONE_KEY
Control Zone Surrogate Key
CD_CTRL_ZONE.CTRL_ZONE_KEY
CTRL_ZONE_SEC_KEY
Control Zone Secondary Surrogate Key
CD_CTRL_ZONE_SEC.CTRL_ZONE_SEC_KEY
BEGIN_DATE_KEY
END_DATE_KEY
CTRL_ZONE_OUTG_
UDD1_KEY
Control Zone outage User Defined Dimension 1 Surrogate Key
CITY_OUTG_UDD2_KEY
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Crew
For all jobs created in the source system, several activities (such as assignment, un-assignment, dispatch, arrival and completion) are performed to complete them. Each of these activities are carried out by the corresponding crew.
This fact stores all such crew activity information for every job created in the source system. The data is stored for all restored and un-restored jobs.
Entity relationship diagram for the Crew fact
Properties
Property
Value
Target Table Name
CF_RST_CREW
Table Type
Fact
Fact Type
Accumulation
Driver Table Name
CREW_ASSIGNMENTS
CREW_DISPATCHES
STORMMAN_STORMS
ODI Package Name
B1_PKG_CF_RST_CREW
ETL View Name
B1_F_RST_CREW_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
RST_CREW_KEY
Recent Crew Key
Populated with the sequence from SPL_RECENT_CREW_SEQ.
Natural Keys
SRC_CREW_ID
Source Crew ID
CREW_ASSIGNMENTS.CREW_KEY
CREW_DISPATCHES.CREW_KEY
Measures
FACT_CNT
Count
INROUTE_DURATION
Inroute Duration
CREW_DISPATCHES.WHEN_HAPPENED
Populated with the total time spent by the crew in ‘Dispatch’ state for a particular event.
WORK_DURATION
Work Duration
Populated with the total time spent by the crew in ‘Arrive’ state for a particular event.
ASSIGN_DURATION
Assign Duration
CREW_ASSIGNMENT.WHEN_HAPPENED
Populated with the total time spent by the crew in ‘Assign’ state for a particular event.
DISPATCH_DURATION
Dispatch Duration
CREW_ASSIGNMENTS.WHEN_HAPPENED
Populated with the total time spent by the crew while assigned, en route and working on the event.
Dispatch Duration = En Route Duration + Work Duration + Assign Duration
SRC_EVENT_NBR
Source Event Number
INCIDENTS.DECODE(NVL(ASSOCIATE_IDX, 0), 0,NUMB,ASSOCIATE_IDX)
If the Associate Index value is 0, populate this field with NUMB. Else, populate Associated Index value.
EXCL_PERIOD_START_DTTM
Exclusion Period End Date/Time
STORMMAN_STORMS. EX_STORM_START
If a storm is present and it has an exclusion period defined within which the begin date/time of the job falls, then populate this field with the exclusion period start date/time.
EXCL_PERIOD_END_
DTTM
Exclusion Period Start Date/Time
STORMMAN_STORMS. EX_STORM_END
If a storm is present and it has an exclusion period defined within which the begin date/time of the job falls, then populate this field with the exclusion period end date/time.
Foreign Keys
EVENT_KEY
Event Key
JOBS.NUMB
Populated from CD_EVENT’s surrogate key using NUMB column in the JOBS table.
ASSIGN_DATE_KEY
Last Assign Date Key
Populate with the surrogate key of the CD_DATE dimension by looking up with the date part of the latest assignment date of the crew. In case of no assignments for the crew, populate as 0.
ASSIGN_TIME_KEY
Last Assign Time Key
Populate with the surrogate key of the CD_TIME dimension by looking up with the time part of the latest assignment date of the crew. In case of no assignments for the crew, populate as 0.
CTRL_ZONE_KEY
Control Zone Key
JOBS.NCG
ASSIGN_USER_KEY
Last Assign User Key
CREW_ASSIGNMENTS.
CES_USER
Populated with the last user who assigned the crew.
CREW_KEY
Crew Key
Populated with the crew details in the CREW_ASSIGNMENTS dimension.
DEVICE_KEY
Device Key
JOBS.H_IDX
JOBS.H_CLS
UNASSIGN_DATE_KEY
Unassign Date Key
Populate with the surrogate key of the CD_DATE dimension by looking up with the date part of the latest un-assignment date of the crew. In case of no un-assignments for the crew, populate as 0.
UNASSIGN_TIME_KEY
Unassign Time Key
Populate with the surrogate key of the CD_TIME dimension by looking up with the time part of the latest un-assignment date of the crew. In case of no un-assignments for the crew, populate as 0.
UNASSIGN_USER_KEY
Unassign User Key
CREW_ASSIGNMENTS.CES_USER
Look up the CD_USER dimension with the last user who unassigned the crew and populate with surrogate key.
ACCEPT_DATE_KEY
Unassign Date Key
Populated based on the date part of the latest dispatch date of the crew. In case of no dispatches for the crew, populate as 0.
ACCEPT_TIME_KEY
Accept Time Key
Populated based on the time part of the latest dispatch date of the crew and lookup the CD_TIME dimension. In case of no dispatches for the crew, populate as 0.
ACCEPT_USER_KEY
Accept User Key
CREW_DISPATCHES.CES_USER
Populate with the last user who dispatched the crew, by looking up the CD_USER dimension.
ARRIVE_DATE_KEY
Arrive Date Key
Populate with the surrogate key of the CD_DATE dimension by looking up with the date part of the latest arrival date of the crew. In case of no completions for the crew, populate as 0.
ARRIVE_TIME_KEY
Arrive Time Key
Populated based on the time part of the latest arrival date of the crew and lookup the CD_TIME dimension. In case of no completions for the crew, populate as 0.
ARRIVE_USER_KEY
Arrive User Key
Populate with the last user who marked the crew activity as arrived, by looking up the CD_USER dimension.
CMPL_DATE_KEY
Completed Date Key
Extract the date part of the latest completion date of the crew and lookup the CD_DATE dimension. In case of no completions for the crew, populate as 0.
CMPL_TIME_KEY
Completed Time Key
Extract the time part of the latest completion date of the crew and lookup the CD_TIME dimension. In case of no completions for the crew, populate as 0.
CMPL_USER_KEY
Completed User Key
Populate with the last user who marked the crew activity as completed, by looking up the CD_USER dimension.
STORM_KEY
Storm Key
STORM_OUTAGE_TYPE_KEY
Storm Outage Type Key
JOBS.STORMMAN_TYPE
Populated based on the storm outage type in the Jobs table.
CTRL_ZONE_SEC_KEY
Control Zone Key
JOBS.NCG
Populated from CD_CTRL_ZONE_SEC dimension's surrogate key based on NCG ID and records effective date/time is between effective start and end date/time of dimension.
EXCL_DETAIL_KEY
Excludable Detail Key
STORMMAN _STORMS. STORM_NAME
STORMMAN _STORMS. STORM_DATE
Populated based on the storm level NCG, storm name, and storm name suffix from the CD_EXCL_DETAIL table.
EXCL_START_DATE_
KEY
Exclusion Period Start Date Key
Populated based on the date part in the CD_DATE table.
EXCL _END_DATE_KEY
Exclusion Period End Date Key
Populated based on the date part from the CD_DATE dimension.
EXCL_START_TIME_
KEY
Exclusion Period Start Time Key
Populated based on the time part from the CD_TIME dimension.
EXCL _END_TIME_KEY
Exclusion Period End Time Key
CREW_UDD1_KEY
CREW_UDD2_KEY
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Crew Activity
Captures the complete history of all the crews that worked on an event, including multiple assignments of the same crew to the same event.
Note: The data for this fact is captured from both the driver tables (CREW_ASSIGNMENTS and CREW_DISPATCHES) in a mutually exclusive manner. All columns of the table are separately populated from each of these driver tables.
Entity relationship diagram for the Crew Activity fact
Properties
Property
Value
Target Table Name
CF_CREW_ACTIVITY
Table Type
Fact
Fact Type
Accumulation
Driver Table
CREW_ASSIGNMENTS
CREW_DISPATCHES
STORMMAN_STORMS
ODI Package Name
B1_PKG_CF_CREW_ACTIVITY
ETL View Name
B1_F_CREW_ACTIVITY_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
CREW_ACTIVITY_KEY
Crew Activity Fact Surrogate Key
Populated with the sequence from B1_CREW_ACTIVITY_SEQ.NEXTVAL.
Natural Keys
SRC_IND
Source Indicator
Populated based on the table the data is being loaded from.
• ‘A’ if the source table is CREW_ASSIGNMENTS
• ‘D’ if the source is CREW_DISPATCHES
SEQ_NUM
Sequence Number
CREW_ASSIGNMENTS.
SEQ_NUM
CREW_DISPATCHES.
SEQ_NUM
ACTIVE_FLG
Active Flag
CREW_ASSIGNMENTS.
ACTIVE
CREW_DISPATCHES.
ACTIVE
ACTION_CD
Action Code
CREW_ASSIGNMENTS.
ACTION
CREW_DISPATCHES.
ACTION
Measures
FACT_CNT
Count
ACTION_DTTM
Action Date/Time
CREW_DISPATCHES. WHEN_HAPPENED
Foreign Keys
ACTION_DATE_KEY
Action Date Key
Populated based on the date part of ACTION_DTTM.
ACTION _TIME_KEY
Action Time Key
Populated based on the time of ACTION_DTTM.
CREW_KEY
Crew Key
CREW_ASSIGNMENTS.CREW_ID
CREW_DISPATCHES.CREW_ID
Populated based on the CREW_ID from the CREW_ASSIGNMENTS/CREW_DISPATCHES.
EVENT_KEY
Event Key
JOBS.NUMB
Populated based on NUMB from the JOBS table.
CTRL_ZONE_ KEY
JOBS.NCG
CTRL_ZONE_SEC_KEY
JOBS.NCG
STORM_KEY
Storm Dimension Surrogate Key
Storm Outage Type Dimension Surrogate Key
JOBS.STORMMAN_TYPE
Populated based on jobs STORMMAN_TYP.
DEVICE_KEY
Device Key
JOBS.H_IDX
JOBS.H_CLS
Populated based on H_IDX and H_CLS from JOBS table.
If any (either device class or index) value is 0, then map to the zeroth key.
In case of non-electrical devices, devices are not available in Device dimension. Facts referring to these devices will be populated with 0 instead of -99.
ASSIGN_USER_KEY
Assigned User Key
Populated based on CES_USER from CREW_ASSIGNMENTS.
CREW_ACTIVITY_UDD1_KEY
Crew Activity User Defined Dimension 1 Surrogate Key
CREW_ACTIVITY_UDD2_KEY
Crew Activity User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Customer Outage
Stores the details of customers experiencing service interruptions based on the supply node log information from the source system. The supply node log data will be mapped to the Supply Node Lookup dimension to determine the actual list of customers experiencing the outage.
Few measures captured in this fact are outage duration, CMI, number of momentary outages, etc. The data is stored for all restored and un-restored jobs.
Entity relationship diagram for the Customer Outage fact
Properties
Property
Value
Target Table Name
CF_CUST_RST_OUTG
Table Type
Fact
Fact Type
Accumulation
Driver Table Name
SUPPLY_NODE_LOG
JOBS
STORMMAN_STORMS
ODI Package Name
B1_PKG_CF_CUST_RST_OUTG
ETL View Name
B1_F_CUST_RECENT_OUTG_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
CUST_RST_OUTG_KEY
Customer Restored Outage Fact Surrogate Key
Populated with the sequence from SPL_CUST_RST_OUTG_SEQ.
Natural Keys
SRC_ID
Source Outage ID
SUPPLY_NODE_LOG.ID
Measures
FACT_CNT
Count
OUTG_DURATION
Outage Duration
SUPPLY_NODE_LOG.OUTAGE_TIME
SUPPLY_NODE_LOG.RESTORE_TIME
Populated with the difference between restore time and outage time.
NUM_MOMENTARY
Number of Momentaries Covered
JOBS.MOMENTARIES
Populated with the number of momentaries covered.
CMI
Customer Minutes Interrupted
SUPPLY_NODE_LOG.
OUTAGE_TIME
SUPPLY_NODE_LOG.
RESTORE_TIME
Populated with difference between restored time and outage time, in minutes.
EST_RST_DUR
Estimated Restoration Duration
JOBS.BEGIN_TIME
JOBS.EST_REST_TIME
Populated with the difference between estimated restore time and begin time, in minutes.
DURATION_
DEVIATION
Duration Deviation
JOBS.RESTORE_TIME
JOBS.EST_REST_TIME
Populated with the difference between restore time and estimated restore time, in minutes.
BEGIN_DTTM
Begin Date Time
SUPPLY_NODE_LOG.
OUTAGE_TIME
RST_DTTM
Restored Date Time
SUPPLY_NODE_LOG.
RESTORE_TIME
RST_IND
Restored Indicator
Populated based on JOBS.RESTORE_TIME.
If the restored date/time exists, then this field is populated with 1. Else, with 0.
PLANNED_IND
Planned Indicator
SWMAN_SHEET.SHEET_CATEGORY_NAME
Populated based on SHEET_CATEGORY_NAME.
If the sheet category is planned, then this field is populated with 1. Else, 0.
EXCLUDE_IND
Exclude Indicator
JOBS J.STATE_VALUE
PICKLIST_INFO_UPD_TR P.NO_DTR_FLAG
SWMAN_SHEET_CATEGORYSSCA.SHEET_CATEGORY_NAME
Populated based on STATE_VALUE '1024, NO_DTR_FLAG 'Y' and SHEET_CATEGORY_NAME 'Planned.
OMS_EXCLUDE_IND
OMS Exclude Indicator
PICKLIST_INFO_UPD_
TR.NO_DTR_FLAG
Populated based on NO_DTR_FLAG.
If it is set to 'Y', then this field is populated with 1. Else, with 0.
CANCELLED_IND
Cancelled Indicator
JOBS.STATE_VALUE
Populated based on STATE_VALUE.
if set to 1024, then the indicator is populated with 1. Else, with 0.
SRC_PREMISE_ID
Premise ID
CD_PREM.SRC_PREM_
ID
SRC_PERSON_ID
Person ID
CD_PER.SRC_PER_ID
SRC_METER_ID
Meter ID
CD_METER.SRC_
METER_ID
DEVICE_ID
Device ID
CD_DEVICE.DEVICE_
ID
Foreign Keys
EVENT_KEY
Event Key
JOBS.NUMB
EVENT_STATUS_KEY
Event Status Key
JOBS.STATUS
Populated based on the jobs status.
ACCT_KEY
Account Key
CD_ACCT.SRC_ACCT_ID
INCIDENTS.ACCOUNT_NUM
CES_CUSTOMERS.ACCOUNT_NUMBER
Populated based on the account ID retrieved from the CES_CUSTOMER_
HISTORY table.
PREM_KEY
Premise Key
CD_PREM.SRC_PREM_
ID
Populated based on the service location retrieved from CES_CUSTOMER_
HISTORY.
PER_KEY
Person Key
CD_PER.SRC_PER_ID
Populated based on the CUST_ID retrieved from CES_CUSTOMER_
HISTORY.
METER_KEY
Meter Key
CD_METER.SRC_
METER_ID
Populated based on METER_ID retrieved from CES_CUSTOMER_
HISTORY.
ADDR_KEY
Address Key
CD_ADDR.SRC_ADDR_
ID
Populated based on service location retrieved from CES_CUSTOMER_
HISTORY.
BEGIN_DATE_KEY
Begin Date Key
SUPPLY_NODE_LOG.
OUTAGE_TIME
Populated based on the outage begin date.
BEGIN_TIME_KEY
Begin Time Key
SUPPLY_NODE_LOG.
OUTAGE_TIME
Populated based on the outage begin time.
RST_DATE_KEY
Restored Time Key
SUPPLY_NODE_LOG.
RESTORE_TIME
Populated based on the restored date.
RST_TIME_KEY
Restored Date Key
SUPPLY_NODE_LOG.
RESTORE_TIME
Populated based on the restored time.
EST_RST_TIME_KEY
Estimated Restored Time Key
JOBS.EST_REST_TIME
Populate based on the estimated restored date.
EST_RST_DATE_KEY
Estimated Restored Date Key
JOBS.EST_REST_TIME
Populate based on the estimated restored time.
CTRL_ZONE_KEY
Control Zone Key
SUPPLY_NODE_LOG.
NCG
CAUSE_CTRL_ZONE_
KEY
Cause Control Zone Key
JOBS.NCG
Populated based on jobs NCG.
AFF_DEVICE_KEY
AFF Device Key
SUPPLY_NODES.
DEVICE_IDX
SUPPLY_NODES.
DEVICE_CLS
If H_IDX and H_CLS are ‘0’, ‘0’ is populated.
CAUSE_DEVICE_KEY
Cause Device Key
JOBS.H_IDX
JOBS.H_CLS
FEEDER_KEY
Feeder Key
SUPPLY_NODES.FEEDER
If FEEDER_IDX and FEEDER_CLS are ‘0’, ‘0’ is populated.
SW_PLAN_KEY
Switch Plan Key
JOBS.SWSHEET_IDX
JOBS.SWSHEET_CLS
If SWSHEET_IDX and SWSHEET_CLS are ‘0’, ‘0’ is populated.
STORM_KEY
Storm Key
STORM_OUTG_TYPE_
KEY
JOBS.STORMMAN_TYPE
Populated based on jobs STORMMAN_TYPE.
PARENT_EVENT_KEY
Parent Event Key
PARENT_EVENT.NUMB
Populated based on PARENT_EVENT.NUMB.
OUTG_DUR_KEY
Outage Duration Key
EST_RST_DUR_KEY
Estimated Restore Duration Key
JOBS.BEGIN_TIME
JOBS.EST_REST_TIME
Populated with the difference between estimated restoration time and begin time.
DURATION_DEVIATION_KEY
Duration Deviation Key
JOBS.RESTORE_TIME
JOBS.EST_REST_TIME
Populated with the difference between restoration time and estimated restore time.
CREW_KEY
CREW_ASSIGNMENT.CREW_KEY
Lookup in CREW_DISPATCHES and populate the surrogate key.
CUST_OUTG_UDD1_
KEY
CUST_OUTG_UDD2_
KEY
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Damage Assessment
Captures information about the damage assessment (such as what parts are damaged).
Entity relationship diagram for the Damage Assessment fact
Properties
Property
Value
Target Table Name
CF_DAMAGE_ASMT
Table Type
Fact
Fact Type
Accumulation
Driver Table
DAMAGE_REPORT
STROMMAN_STORMS
ODI Package Name
B1_PKG_CF_DAMAGE_ASMT
ETL View Name
B1_F_DAMAGE_ASMT_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
DAMAGE_ASMT_F_KEY
Damage Assessment Fact Surrogate Key
Populated with the sequence from B1_DAMAGE_ASMT_F_
SEQ.
Natural Keys
SRC_DAMAGE_ASMT_ID
Damage Assessment ID
DAMAGE_REPORT.REPORT_ID
Populated with the primary key of the Damage Assessment Report.
Measures
EST_REPAIR_DUR
Estimated Repair Duration
DAMAGE_REPORT.REPAIR_MINUTES
Populated with the estimated repair duration.
FACT_CNT
Count
REPORT_DTTM
Reported Date/Time
DAMAGE_REPORT.REPORT_TIME
Populated with the reported date/time of the Damage Assessment Report.
Foreign Keys
REPORT_DATE_KEY
Reported Date Key
CD_DATE.DATE_KEY
Populated based on the date part of REPORT_DTTM.
REPORT_TIME_KEY
Reported Time Key
CD_TIME.TIME_KEY
Populated based on the time part of REPORT_DTTM.
DAMAGE_ASMT_KEY
Damage Assessment Dimension Surrogate Key
Populated based on the Damage Report ID.
DAMAGE_ASMT_
STATUS_KEY
Damage Assessment Status Dimension Surrogate Key
DAMAGE_REPORT.STATE_KEY
Populated based on the Damage Report State Key Value.
DEVICE_KEY
JOBS.H_CLS
JOBS.H_IDX
Populated based on Jobs Device Class and Index.
If the Damage Report is mapped to a non-electrical device, this field will be populated with 0.
EVENT_KEY
Event Dimension Surrogate Key
JOBS.NUMB
Populated based on the Jobs Number.
Jobs number is retrieved from event class and index from the incident based on the Damage Report incident number.
EVENT_STATUS_KEY
Event Status Dimension Surrogate Key
JOBS.STATUS
Populated based on the Jobs Status.
CTRL_ZONE_ KEY
INCIDENTS.NCG
CTRL_ZONE_SEC_KEY
INCIDENTS.NCG
STORM_KEY
STORMMAN_STORMS. STORM_NAME
Storm will affect zones at higher level. Damage Report mapped to NCG falls within the same zone and jobs begin time within the storm period will be populated with storm key.
DAMAGE_ASMT_
DETAIL_UDD1_KEY
Damage Assessment Detail User Defined Dimension 1 Surrogate Key
DAMAGE_ASMT_
DETAIL_UDD2_KEY
Damage Assessment Detail User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Populated with a combination of the various components involved in a damage report, namely outage parts, damage types, and crew types.
Note: For a single damage report, there will be a mutually exclusive fact record for reach of its outage parts, damage types, and crew types. The fact records are loaded into this fact with the combination below:
1. Damage Assessment and Damage Part
2. Damage Assessment and Damage Type
3. Damage Assessment and Crew Type
The record for the damage part only contains that damage part information, and does not include information for damage types and crew types. Similarly, a record for the damage type only contains that damage type information, and not information for damage parts and crew types. A record for the crew type only includes information for that crew type, and not for damage parts or damage types.
Measures are also populated according to the combination mentioned above. For example: Crew count is populated for those whose Crew Type ID is not null. Otherwise, it will be set to 0.
The three tables listed below are replaced with DAMAGE_ASSETS table in Oracle Utilities Network Management System v2.4.0.1.
• DAMAGE_OUTAGE_TYPES
• DAMAGE_TYPES
• DAMAGE_OUTAGE_PARTS
Entity relationship diagram for the Damage Assessment Detail fact
Properties
Property
Value
Target Table Name
CF_DAMAGE_ASMT_DETAIL
Table Type
Fact
Fact Type
Accumulation
Driver Table
For NMS versions below 2.4.0.1:
DAMAGE_REPORT
DAMAGE_OUTAGE_PARTS
DAMAGE_OUTAGE_TYPES
DAMAGE_CREW_TYPES
STORMMAN_STORMS
For NMS versions 2.4.0.1 or higher:
DAMAGE_REPORT
DAMAGE_ASSETS
DAMAGE_CREW_TYPES
STORMMAN_STORMS
ODI Package Name
B1_PKG_CF_DAMAGE_ASMT_DETAIL
ETL View Name
B1_F_DAMAGE_ASMT_DETAIL _VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
DAMAGE_ASMT_
DETAIL_KEY
Damage Assessment Detail Fact Surrogate Key
Populated with the sequence from B1_DAMAGE_ASMT_DETAIL_SEQ.NEXTVAL.
Natural Keys
These fields are applicable only for NMS v2.4.0.0 or lower.
SRC_DAMAGE_TYPE_ID
Damage Type ID
DAMAGE_OUTAGE_
TYPES.TYPE_ID
Populate this column by retrieving data from DAMAGE_OUTAGE_TYPES.TYPE_ID based on the REPORT_ID.
Populate this column with -1 if null.
SRC_DAMAGE_PART_ID
Damage Part ID
DAMAGE_OUTAGE_
PARTS.PART_ID
Populate this column by retrieving data from DAMAGE_OUTAGE_PARTS.PART_ID based on the REPORT_ID.
Populate this column with ‘***’ if null.
SRC_DAMAGE_ASMT_ID
Populated with the primary key of the Damage Report.
SRC_CREW_TYPE_ID
Crew Type
DAMAGE_CREW_TYPES.CREW_TYPE_ID
Populated with the primary key of the Crew Type, if the fact record is for crew types. Else, it is set to 0.
These fields are applicable only for NMS v2.4.0.1 or higher.
SRC_DAMAGE_TYPE_ID
DAMAGE_REPORT.
REPORT_ID
As part of NMS v2.4.0.1, Damage Type ID is deprecated. This column will be populated with -1.
SRC_DAMAGE_PART_ID
DAMAGE_ASSETS.PART_ID
Populate this column by retrieving data from DAMAGE_ASSETS.PART_
ID based on REPORT_ID identified above.
Populate this column with ‘***’ in case null.
SRC_DAMAGE_ASMT_ID
SRC_CREW_TYPE_ID
Crew Type
Measures
ACCESS_CNT
Accessible Count
DAMAGE_OUTAGE_
TYPES.NUM_ACC
Retrieves the number of damaged outage access count from DAMAGE_OUTAGE_
TYPES.NUM_ACC.
INACCESS_CNT
Inaccessible Count
DAMAGE_OUTAGE_
TYPES.NUM_INACC
Retrieves the number of damaged outage in access count from DAMAGE_OUTAGE_
TYPES.NUM_INACC.
PART_QUANTITY
Part Quantity
DAMAGE_OUTAGE_PARTS.QUANTITY
Retrieves the number of damaged outage parts from DAMAGE_OUTAGE_
PARTS.QUANTITY.
CREW_NEEDED
Crews Needed
DAMAGE_CREW_TYPES.NUM_CREWS
Populated only if the fact record is for Crew Types.
FACT_CNT
Count
ACCESS_CNT
Accessible Count
SUM(DAMAGE_ASSETS.QUANTITY)
Retrieve all records from DAMAGE_ASSETS table for current REPORT_ID, PART_ID with ACCESSIBLE ='Y'.
Populate this column with SUM(DAMAGE_ASSETS.QUANTITY), only if Part ID is not '***'. Else, ‘0’.
INACCESS_CNT
Inaccessible Count
Retrieve all records from DAMAGE_ASSETS table for current REPORT_ID, PART_ID with ACCESSIBLE ='N'.
Populate this column with SUM(DAMAGE_ASSETS.QUANTITY), only if Part ID is not '***'. Else ‘0’.
PART_QUANTITY
ACCESS_CNT+INACCESS_CNT
Sum of ACCESS_CNT and INACCESS_CNT.
Populate this column only if Part ID is not '***'. Else ‘0’.
CREW_NEEDED
Crews Needed
FACT_CNT
Count
REPORT_DTTM
Reported Date/Time
DAMAGE_REPORT.
REPORT_TIME
Foreign Keys
REPORT_DATE_KEY
Reported Date Key
Populated based on the Damage Report date.
REPORT_TIME_KEY
Reported Time Key
Populated based on the Damage Report time.
DAMAGE_ASMT_KEY
DAMAGE_ASMT_
STATUS_KEY
Populated based on the Damage Report State Key value.
DAMAGE_TYPE_KEY
Damage Type Dimension Surrogate Key
Populated from CD_DAMAGE_TYPE dimension surrogate key based on Damage Type identified for SRC_DAMAGE_TYPE_ID.
CREW_TYPE_KEY
Crew Type Dimension Surrogate Key
Populated based on the damage Crew Type's Crew Type ID.
DAMAGE_PART_KEY
Damage Part Dimension Surrogate Key
Populated from CD_DAMAGE_PART dimension surrogate key based on Damage Part ID identified for target column SRC_DAMAGE_PART_ID.
DEVICE_KEY
If the damage report is mapped to a non-electrical device, then this field will be populated with 0.
EVENT_KEY
Jobs number is retrieved from event class and index from incident based on damage report incident number.
EVENT_STATUS_KEY
CTRL_ZONE_ KEY
CTRL_ZONE_SEC_KEY
STORM_KEY
Storm will affect zones at higher level. Damage report mapped to NCG fall within the same zone and jobs begin time within the storm period will be populated with storm key.
DAMAGE_ASMT_
DETAIL_UDD1_KEY
DAMAGE_ASMT_
DETAIL_UDD2_KEY
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Feeder Delivered Load
Extracts the hourly feeder delivered load information from Network Management System on a weekly or monthly schedule.
Entity relationship diagram for the Feeder Delivered Load Snapshot fact
Properties
Property
Value
Target Table Name
CF_FEEDER_DLVRD_LOAD
Table Type
Fact
Fact Type
Snapshot
Driver Table
FLM_FDR_LOAD
ODI Package Name
B1_PKG_CF_FEEDER_DLVRD_LOAD
ETL View Name
B1_F_FEEDER_DLVRD_LOAD_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
FEEDER_DLVRD_LOAD_KEY
Feeder Delivered Load Snapshot Fact Surrogate Key
Populated with the sequence from SPL_FEEDER_DLVRD_LOAD_SEQ.
Natural Keys
SRC_FEEDER_CLS
Source Feeder Class
FLM_FDR_LOAD.FDR_
CLS
SRC_FEEDER_IDX
Source Feeder Index
FLM_FDR_LOAD.FDR_
IDX
SRC_PHASE_ID
Source Phase ID
FLM_FDR_LOAD.ANALYSIS_DATE
Measures
BRKR_AMP_LIMIT
Breaker Amp Limit
PF_SWITCHES.AMP_
LIMIT
AMP
Ampere
FLM_FDR_LOAD.AMP_A
KW
Kilo Watt
FLM_FDR_LOAD.KW_A
KVAR
KVAR
FLM_FDR_LOAD.KVAR_A
KVA
Kilo
FLM_FDR_LOAD.KW_A
FLM_FDR_LOAD.KVAR_A
VOLTAGE
Voltage
FLM_FDR_LOAD.KV_A
POWER_FACTOR
Power Factor
FACT_CNT
Count
SRC_DTTM
Source Date
Foreign Keys
FEEDER_KEY
Feeder Dimension Surrogate Key
FLM_FDR_LOAD.FDR_
CLS
FLM_FDR_LOAD.FDR_
IDX
CTRL_ZONE_KEY
NETWORK_COMPONENTS.NCG
BRKR_DEVICE_KEY
FLM_FDR_LOAD.CB_
CLS
FLM_FDR_LOAD.CB_
IDX
SUBSTN_DEVICE_KEY
FLM_FDR_LOAD.CB_
CLS
FLM_FDR_LOAD.CB_
IDX
SNAPSHOT_DATE_KEY
Snapshot Date Key
SNAPSHOT_TIME_KEY
Snapshot Time Key
PHASE_KEY
Source Phase Key
FEEDER_DLVRD_LOAD_UDD1_KEY
Feeder Delivered Load User Defined Dimension 1 Surrogate Key
FEEDER_DLVRD_LOAD_UDD2_KEY
Feeder Delivered Load User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Job
Stores job information from Network Management System. It populates key measures, such as outage duration, number of calls, and customers impacted. The data is stored for all restored and un-restored jobs.
Entity relationship diagram for the Job fact
Properties
Property
Value
Target Table Name
CF_RST_JOB
Table Type
Fact
Fact Type
Accumulation
Driver Table Name
JOBS
ODI Package Name
B1_PKG_CF_RST_JOB
ETL View Name
B1_F_RECENT_JOB_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
RST_JOB_KEY
Restored Job Fact Surrogate Key
Populated with the sequence from SPL_RST_JOB_SEQ.
Natural Keys
SRC_JOB_NBR
Source Job Number
JOBS.NUMB
Measures
FACT_CNT
Count
OUTG_DURATION
Outage Duration
JOBS.RESTORE_TIME
JOBS.BEGIN_TIME
Populated as the difference (in minutes) between begin date/time and the actual restoration date/time of the job.
EST_RST_DUR
JOBS.EST_REST_TIME
JOBS.BEGIN_TIME
Populated with the difference (in minutes) between the begin date/time and the estimated restoration date/time of the job.
CUST_OUT
Customers Out
JOBS. NUM_CUST_OUT
CALL_RECVD
Calls Received
INCIDENTS. NUMB
Populated with the number of calls received by counting the number of incidents associated with the job.
DURATION_DEVIATION
Duration Deviation
JOBS. RESTORE_TIME
JOBS. EST_REST_TIME
Populated with the difference (in minutes) between the actual restoration date/time and the estimated restoration date/time of the job.
CRIT_A
Critical Customer A Count
JOBS.CRIT_A
Populated with the total number of customers affected with type A criticality for the outage.
CRIT_B
Critical Customer B Count
JOBS.CRIT_B
Populated with the total number of customers affected with type B criticality for the outage.
CRIT_C
Critical Customer C Count
JOBS.CRIT_C
Populated with the total number of customers affected with type C criticality for the outage.
CRIT_D
Critical Customer D Count
JOBS.CRIT_D
Populated with the total number of customers affected with type D criticality for the outage.
CRIT_E
Critical Customer E Count
JOBS.CRIT_E
Populated with the total number of customers affected with type E criticality for the outage.
CRIT_F
Critical Customer F Count
JOBS.CRIT_F
Populated with the total number of customers affected with type F criticality for the outage.
CRIT_G
Critical Customer G Count
JOBS.CRIT_G
Populated with the total number of customers affected with type G criticality for the outage.
CRIT_H
Critical Customer H Count
JOBS.CRIT_H
Populated with the total number of customers affected with type H criticality for the outage.
CRIT_I
Critical Customer I Count
JOBS.CRIT_I
Populated with the total number of customers affected with type I criticality for the outage.
CRIT_J
Critical Customer J Count
JOBS.CRIT_J
Populated with the total number of customers affected with type J criticality for the outage.
CRIT_K
Critical Customer K Count
JOBS.CRIT_K
Populated with the total number of customers affected with type K criticality for the outage.
CRIT_L
Critical Customer L Count
JOBS.CRIT_L
Populated with the total number of customers affected with type L criticality for the outage.
CRIT_M
Critical Customer M Count
JOBS.CRIT_M
Populated with the total number of customers affected with type M criticality for the outage.
CRIT_N
Critical Customer N Count
JOBS.CRIT_N
Populated with the total number of customers affected with type N criticality for the outage.
CRIT_O
Critical Customer O Count
JOBS.CRIT_O
Populated with the total number of customers affected with type O criticality for the outage.
CRIT_P
Critical Customer P Count
JOBS.CRIT_P
Populated with the total number of customers affected with type P criticality for the outage.
CRIT_Q
Critical Customer Q Count
JOBS.CRIT_Q
Populated with the total number of customers affected with type Q criticality for the outage.
CRIT_R
Critical Customer R Count
JOBS.CRIT_R
Populated with the total number of customers affected with type R criticality for the outage.
CRIT_S
Critical Customer S Count
JOBS.CRIT_S
Populated with the total number of customers affected with type S criticality for the outage.
CRIT_T
Critical Customer T Count
JOBS.CRIT_T
Populated with the total number of customers affected with type T criticality for the outage.
CRIT_U
Critical Customer U Count
JOBS.CRIT_U
Populated with the total number of customers affected with type U criticality for the outage.
CRIT_V
Critical Customer V Count
JOBS.CRIT_V
Populated with the total number of customers affected with type V criticality for the outage.
CRIT_W
Critical Customer W Count
JOBS.CRIT_W
Populated with the total number of customers affected with type W criticality for the outage.
CRIT_X
Critical Customer X Count
JOBS.CRIT_X
Populated with the total number of customers affected with type X criticality for the outage.
CRIT_Y
Critical Customer Y Count
JOBS.CRIT_Y
Populated with the total number of customers affected with type Y criticality for the outage.
CRIT_Z
Critical Customer Z Count
JOBS.CRIT_Z
Populated with the total number of customers affected with type Z criticality for the outage.
RST_IND
Restored Indicator
JOBS.RESTORE_TIME
PLANNED_IND
Planned Indicator
SWMAN_SHEET_CATEGORY.SHEET_CATEGORY_NAME
If the sheet category is planned, then this field is populated with 1. Else, with 0.
EXCLUDE_IND
Exclude Indicator
JOBS.STATE_VALUE
PICKLIST_INFO_UPD_TR.NO_DTR_FLAG
Populated based on STATE_VALUE '1024, NO_DTR_FLAG 'Y' and SHEET_CATEGORY_NAME 'Planned'.
OMS_EXCLUDE_IND
If set to 'Y,' then this field is populated with 1. Else, with 0.
CANCELLED_IND
Cancelled Indicator
JOBS.STATE_VALUE
If set to 1024, then the indicator is populated with 1. Else, with 0.
BEGIN_DTTM
Begin Date Time
JOBS.BEGIN_TIME
RST_DTTM
Restored Date Time
JOBS.RESTORE_TIME
COMPLETION_DTTM
Completion Time
JOBS.JOB_COMPLETE_
TIME
EXCL _START_DTTM
STORMMAN_STORMS.
EX_STORM_START
Populated with begin time only when there's excludable storm based on NCG.
EXCL _END_DTTM
Populated with end time only when there's excludable storm based on NCG.
Foreign Keys
EVENT_KEY
Event Key
JOBS.NUMB
Populated based on the event.
EVENT_STATUS_KEY
Event Status Key
JOBS.STATUS
Populated based on the event status.
BEGIN_DATE_KEY
Begin Date Key
JOBS.BEGIN_TIME
Populated based on the data part of the CD_DATE dimension.
BEGIN_TIME_KEY
Begin Time Key
JOBS.BEGIN_TIME
Populated based on the time part of the CD_TIME dimension.
RST_TIME_KEY
Restored Time Key
JOBS.RESTORE_TIME
RST_DATE_KEY
Restored Date Key
JOBS.RESTORE_TIME
Populated based on the date part of the CD_DATE dimension.
EST_RST_TIME_KEY
JOBS.EST_REST_TIME
EST_RST_DATE_KEY
JOBS.EST_REST_TIME
CTRL_ZONE_KEY
Control Zone Key
JOBS.NCG
DEVICE_KEY
Device Key
JOBS.H_IDX
JOBS.H_CLS
If H_IDX and H_CLS is '0', then populate DEVICE_KEY as '0'.
CMPL_USER_KEY
Completed User Key
WHO_COMPLETED.USER_NAME
Populated based on the users who completed the tasks.
RESP_USER_KEY
Responsible User Key
WHO_RESPONSIBLE.USER_NAME
Populated based on the responsible user key in the CD_USER table.
CREW_KEY
Crew Key
CREW_ASSIGNMENT.
CREW_KEY
Populated based on the crew details in the CREW_DISPATCHES table.
FEEDER_KEY
Feeder Key
JOBS.FEEDER_CLS
JOBS.FEEDER_IDX
Populated with 0 if FEEDER_IDX and FEEDER_CLS are 0.
SW_PLAN_KEY
Switch Plan Key
JOBS.SWSHEET_IDX
JOBS.SWSHEET_CLS
Populated with 0 if SWSHEET_IDX and SWSHEET_CLS are 0.
STORM_KEY
Storm Key
JOBS.STORMMAN_TYPE
Populated based on the storm outage type from the CD_STORM_OUTAGE_TYPE table.
PARENT_EVENT_KEY
Parent Event Key
PARENT_EVENT.NUMB
JOBS.NUMB
Populated with parent event from the CD_EVENT table.
OUTG_DUR_KEY
Outage Duration
JOBS.RESTORE_TIME
JOBS.BEGIN_TIME
Populated with the outage duration (different between start range and end range).
EST_RST_DUR_KEY
Est Restoration Duration
JOBS.EST_REST_TIME
JOBS.BEGIN_TIME
Populated with the estimated restoration duration.
Duration Deviation
JOBS.RESTORE_TIME
JOBS.EST_REST_TIME
Populated with duration deviation (outage duration is between start range and end range).
CUST_OUT_KEY
Customers Out Key
JOBS. NUM_CUST_OUT
Populated with number of customers experiencing outage.
COMPLETION_DATE_
KEY
Completion Date Key
JOBS.JOB_COMPLETE_
TIME
Populated with the completion date.
COMPLETION_TIME_
KEY
Completion Time Key
JOBS.JOB_COMPLETE_
TIME
Populated with the completion time.
CTRL_ZONE_SEC_KEY
Control Zone Sec Key
JOBS.NCG
Populated from CD_CTRL_ZON_SEC dimension surrogate key based on NCG ID and modified date/time is between effective start and end date/times
EXCL_DETAIL_KEY
STORMMAN_STORMS.
ZONE_IDX
STORMMAN_STORMS.
STORM_NAME
Populated based on the storm level NCG, storm name, and storm name suffix.
EXCL_START_DATE_
KEY
EXCL _END_DATE_KEY
EXCL_START_TIME_
KEY
Populated based on the time part in the CD_TIME table.
EXCL _END_TIME_KEY
JOB_UDD1_KEY
JOB_UDD2_KEY
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
User Defined Measure 21
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Outage
A snapshot fact (that can be configured hourly, weekly, monthly etc) and stores various measures at the control zone level.
This fact is unusual in the sense that its data is not populated directly from the source tables in the replication schema. It is a calculated fact whose data is derived from the data in the restored facts (Storm, Storm, Switch Plan, and Storm) and the recent facts (Recent Call, Recent Crew, Recent Job, and Storm).
Entity relationship diagram for the Outage fact
Properties
Property
Value
Target Table Name
CF_OUTG
Table Type
Fact
Fact Type
Snapshot
Driver Table
CF_RECENT_CALL
CF_RECENT_CREW
CF_RECENT_JOB JOB
CF_CUST_RECENT_OUTG CUST
Stage Table Name
STG_CF_OUTG
ODI Package Name
B1_PKG_CF_OUTG
ETL View Name
B1_F_CF_OUTG_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
OUTG_KEY
Populated with the sequence from SPL_OUTG_SEQ.
Natural Keys
SNAP_TYPE_CD
Snapshot Type
Populated with ‘H’, ‘W’, or ‘M’ depending on whether the snapshot is configured as Hourly, Weekly, or Monthly.
The out-of-the-box solution is Hourly.
SRC_NCG_ID
Control Zone ID
CD_CTRL_ZONE.SRC_NCG_ID
Measures
NUM_CREW_ASSIGN
Number of Crew Assignments
CF_RECENT_CREW.
FACT_CNT
Populated with the count of crew assignments during the hour.
NUM_CREW_DISP
Number of Crew Dispatches
CF_RECENT_CREW.
FACT_CNT
Populated with the count of crew dispatches during the hour.
NUM_CUST_OUTG
Number of Customers Out
CF_CUST_RECENT_OUTG.FACT_CNT
Populated with the count of customers experiencing outage.
NUM_CUST_RST
Number of Customers Restored
Populated with the count of customers restored during the hour.
NUM_CUST_NEW
Number of New Customers
Populated with the count of new customers experiencing outages during the hour.
NUM_CUST_MOM
Number of Customer Momentaries
CF_RECENT_JOB.
FACT_CNT
Populated with the sum of fact count from the Recent Customer Job fact suffering momentary outages during that hour.
NUM_EVENT
Number of Events
CF_RECENT_JOB.
FACT_CNT
Populated with the number of events.
NUM_NEW_EVENT
Number of New Events
CF_RECENT_JOB.
FACT_CNT
Populated with the number of new events started during the hour.
NUM_CLOSED_
EVENT
Number of Closed Events
CF_RECENT_JOB.
FACT_CNT
Populated with the number of events closed during the hour.
NUM_CANCELLED_
EVENT
Number of Cancelled Events
CF_RECENT_JOB.
CANCELLED_IND
Populated with the number of events cancelled during the hour.
NUM_CALL
Number of Calls
CF_RECENT_CALL.
FACT_CNT
Populated with the number of calls received during the hour.
NUM_CUST_EST_RST
Number of Customers Estimated to be Restored
CF_CUST_RECENT_
OUTG. FACT_CNT
Populated with the number of customers estimated to be restored during the hour.
FACT_CNT
Count
SNAPSHOT_DTTM
Snapshot Date/Time
B1_JOB_CONFIG.SLICE_END_DTTM
Foreign Keys
CTRL_ZONE_KEY
Control Zone Key
CTRL_ZONE_SEC_KEY
JOBS.NCG
SNAPSHOT_DATE_
KEY
Snapshot Date Type
Populated based on the date part of the snapshot type key.
SNAPSHOT_TIME_
KEY
Snapshot Time Type
Populated based on the time part of the snapshot type key.
OUTG_UDD1_KEY
Outage User Defined Dimension 1 Surrogate Key
OUTG_UDD2_KEY
Outage User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Recent Call
Stores the details of the incidents, including associated job details, which are created in the Network Management System. The fact stores details about all un-restored jobs, as well as jobs restored within the last 'X' number of days. The value of 'X' days has to be configured using the Oracle Utilities Administration Tool.
See the Configuring Oracle Utilities Network Management System (NMS) section in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide for more details.
The ETL job for this fact is configured to load data in near real-time (NRT). The primary purpose to configure it as NRT is to support tracking current (active) and relatively recent restored outages. The NRT data store can also be used to help gauge the ability of the existing resources to deal with a current storm to help determine if external/foreign (crew) resources are or are not required.
The “recent fact” data store is not intended to be a long-term repository, and hence there is a purging mechanism based on a user configured number of days that is set in Oracle Utilities Administration Tool.
Entity relationship diagram for the Recent Call fact
Properties
Property
Value
Target Table Name
CF_RECENT_CALL
Table Type
Fact
Fact Type
Accumulation
Driver Table
INCIDENTS
ODI Package Name
B1_PKG_CF_RECENT_CALL
ETL View Name
B1_F_RECENT_CALL_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
RECENT_CALL_KEY
Recent Call Fact Surrogate Key
Populated with the sequence from SPL_RECENT_CALL_SEQ.
Natural Keys
SRC_INCIDENT_ID
Source Incident ID
Measures
FACT_CNT
Count
PRIORITY_IND
Priority Indicator
INCIDENTS.DECODE(SUBSTR(INCIDENTS.COMPLAINT, 7, 1), '1', '1', '2', '1', '0')
Use parameter B1_PRTY_BIT instead of 7.
RST_IND
Restored Indicator
JOBS.RESTORE_TIME
Populated with 1 if restoration date/time is populated. Else, it is populated with 0.
Foreign Keys
EVENT_KEY
Event Key
JOBS.NUMB
Populated with the event key.
ACCT_KEY
Account Key
Populated with the account key.
CALL_DATE_KEY
Call Date Key
INCIDENTS.INPUT_TIME
Populated with the date part.
CALL_TIME_KEY
Call Time Key
Populated with the time part.
CTRL_ZONE_KEY
Control Zone Key
INCIDENTS.NCG
Populated based on the incidents NCG.
USER_KEY
User Key
CES_USER.USER_NAME
Populated based on the user key value.
CALL_INFO_KEY
Call Info Key
INCIDENTS.DECODE( NVL( ASSOCIATE_IDX, 0 ), 0, NUMB, ASSOCIATE_IDX )
Populated based on the call information.
PREM_KEY
Premise Key
CES_CUSTOMERS.SERV_LOC_ID
Populated with the mailing premise ID.
ADDR_KEY
Address Key
Populated with the mailing address.
DEVICE_KEY
Device Key
INCIDENTS.H_IDX
INCIDENTS.H_CLS
Populated with the device key value.
ACCT_TYPE_KEY
Account Type Key
Populated with the account type value.
METER_KEY
Meter Key
Populated with the meter key value.
NETWORK_PREMISE_
KEY
Network Premise Key
Populated with the network premise key value.
CTRL_ZONE_SEC_KEY
INCIDENTS.NCG
STORM_KEY
Storm Key
STORMAN_STORMS.
STORM_NAME
STORMAN_STORMS.
STORM_DATE
STORMMAN_STORMS.
ZONE_IDX
CALL_UDD1_KEY
Call User Defined Dimension 1 Key
CALL_UDD2_KEY
Call User Defined Dimension 2 Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Recent Crew
For every job created in the source system, several activities (such as assignment, un-assignment, dispatch, arrival, and completion) are performed to complete the job. Each of these activities is carried out by the corresponding crew. This fact stores the summarized information of all such crew activities for every job created in the source system. The fact stores details about all un- restored jobs as well as jobs restored within the last 'X' number of days. The value of 'X' days has to be configured using the Oracle Utilities Administration Tool.
See Configuring Oracle Utilities Network Management System (NMS) in the Oracle Utilities Analytics Warehouse Installation and Configuration Guide for more details.
The “recent fact” data store is not intended to be a long-term repository and hence there is a purging mechanism based on a user configured number of days that is set in Oracle Utilities Administration Tool.
Entity relationship diagram for the Recent Crew fact
Properties
Property
Value
Target Table Name
CF_RECENT_CREW
Table Type
Fact
Fact Type
Accumulation
Driver Table
CREW_ASSIGNMENTS
CREW_DISPATCHES
STORMMAN_STORMS
ODI Package Name
B1_PKG_CF_RECENT_CREW
ETL View Name
n/a
Fields
Target Field
OAS Field
Source Field
Surrogate Key
RECENT_CREW_KEY
Recent Crew Fact Surrogate Key
Natural Keys
SRC_EVENT_NBR
Source Event Number
JOBS.NUMB
SRC_CREW_ID
Source Crew ID
Measures
FACT_CNT
Count
INROUTE_DURATION
En Route Duration
WORK_DURATION
Work Duration
ASSIGN_DURATION
Assign Duration
DISPATCH_DURATION
Dispatch Duration
EXCL_PERIOD_END_
DTTM
Foreign Keys
EVENT_KEY
Event Key
JOBS.NUMB
ASSIGN_DATE_KEY
CREW_ASSIGNMENTS ASSIGN.WHEN_HAPPENED
ASSIGN_TIME_KEY
CTRL_ZONE_KEY
Control Zone Key
JOBS.NCG
ASSIGN_USER_KEY
Assign User Key
CREW_ASSIGNMENTS ASSIGN.CES_USER
Look up the CD_USER dimension with the last user who assigned the crew.
CREW_KEY
Crew Key
Lookup in CD_CREW dimension to populate surrogate key.
DEVICE_KEY
Device Key
JOBS.H_IDX
JOBS.H_CLS
Populated based on H_IDX and H_CLS in the CD_DEVICE table. .
UNASSIGN_USER_KEY
Unassign User Key
CREW_ASSIGNMENTS UNASSIGN.CES_USER
UNASSIGN_DATE_KEY
Unassign Date Key
CREW_ASSIGNMENTS UNASSIGN.WHEN_HAPPENED
UNASSIGN_TIME_KEY
Unassign Time Key
ACCEPT_USER_KEY
Accept User Key
CREW_DISPATCHES DISPATCH.CES_USER
ACCEPT_DATE_KEY
Accept Date Key
CREW_DISPATCHES DISPATCH.WHEN_HAPPENED
ACCEPT_TIME_KEY
Accept Time Key
ARRIVE_TIME_KEY
Arrive Time Key
CREW_DISPATCHES ARRIVE.WHEN_HAPPENED
ARRIVE_DATE_KEY
Arrive Date Key
ARRIVE_USER_KEY
Arrive User Key
CREW_DISPATCHES ARRIVE.CES_USER
CMPL_TIME_KEY
Complete Time Key
CREW_DISPATCHES COMPLETE.WHEN_HAPPENED
Populated with the time part of the latest completion date of the crew.
CMPL_DATE_KEY
Completed Date Key
Populated with the date part of the latest completion date of the crew.
CMPL_USER_KEY
Completed User Key
CREW_DISPATCHES COMPLETE.CES_USER
STORM_KEY
Storm Key
JOBS.STORMMAN_TYPE
CTRL_ZONE_SEC_KEY
Control Zone Key
JOBS.NCG
EXCL_DETAIL_KEY
STORMAN_STORMS.ZONE_IDX
EXCL_START_DATE_
KEY
Populated based on the start date part of the exclusion period.
EXCL _END_DATE_KEY
Populated with the end date part of the exclusion period.
EXCL_START_TIME_
KEY
Populated with the start time part of the exclusion period.
EXCL _END_TIME_KEY
Populated with the end time part of the exclusion period.
CREW_UDD1_KEY
Crew User Defined Dimension 1 Key
CREW_UDD2_KEY
Crew User Defined Dimension 2 Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Recent Customer Outage
This fact stores the details of customers experiencing service interruptions based on the supply node log information from the source system. The actual list of customers experiencing the outage is retrieved from CES Customer History. Some of the measures captured in this fact are outage duration, CMI, number of momentary outages, etc.
The fact stores details about all un-restored jobs as well as jobs restored within the last 'X' number of days. The value of 'X' days has to be configured using the Oracle Utilities Administration Tool.
The “recent fact” data store is not intended to be a long-term repository and hence the purging mechanism based on a user configured 'X' number of days that is set in Oracle Utilities Administration Tool.
Entity Relationship Diagram
Entity relationship diagram for the Recent Customer Outage fact
Properties
Property
Value
Target Table Name
CF_CUST_RECENT_OUTG
Table Type
Fact
Fact Type
Accumulation
Driver Table Name
JOBS J
STORMMAN_STORMS
ODI Package Name
B1_PKG_CF_CUST_RECENT_OUTG
ETL View Name
Fields
Target Field
OAS Field
Source Field
Transformation Logic
Surrogate Key
CUST_RECENT_OUTG_KEY
Recent Customer Outage Fact Surrogate Key
Populated with the sequence from SPL_CUST_RECENT_
OUTG_SEQ.
Natural Keys
SRC_ID
Source Outage ID
SUPPLY_NODE_LOG.ID
Measures
FACT_CNT
Count
Populated with the standard value of ‘1’.
OUTG_DURATION
Outage Duration
Populated with the difference between restored time and outage time, in minutes.
NUM_MOMENTARY
JOBS.NUM_MOMENTARIES
CMI
CMI
EST_RST_DUR
Populated with the difference between jobs estimated restored time and begin time, in minutes.
DURATION_DEVIATION
Duration Deviation
Populated with the difference between jobs restored time and estimated restored time, in minutes.
Degenerate Dimensions
BEGIN_DTTM
Begin Date Time
RST_DTTM
Restored Date Time
EST_RST_DTTM
Estimated Restoration Date/Time
JOBS.EST_REST_TIME
EXCL_START_DTTM
Populated based on NCG only when there is an excludable storm.
EXCL_END_DTTM
RST_IND
Restored Indicator
Populated with 1 for all restored outages (supply node log restored time is not null). Else, populated with 0.
PLANNED_IND
Planned Indicator
Populated with 1 for all planned outages (SWMAN_SHEET_CATEGORY.SHEET_CATEGORY_NAME is not null). Else, it is populated with 0.
EXCLUDE_IND
Exclude Indicator
JOBS J.STATE_VALUE
OMS_EXCLUDE_IND
Populated with 1 when no_dtr_flag value is 'Y' in PICKLIST_INFO_UPD_TR table. Else, 0.
CANCELLED_IND
Cancelled Indicator
Populated with 1 based on the jobs state value. Else, it is populated with 0.
SRC_PREMISE_ID
Outage Premise ID
CES_CUSTOMER_HISTORY.SERV_LOC_ID
SRC_PERSON_ID
Outage Person ID
CES_CUSTOMER_HISTORY.CUST_ID
SRC_METER_ID
Outage Meter ID
CES_CUSTOMER_HISTORY.METER_ID
DEVICE_ID
Outage Device ID
CES_CUSTOMER_HISTORY.DEVICE_ID
MOM_OUTG_IND
Momentary Outage Indicator
Populated with 1 if outage duration is less than the momentary outage duration configured parameter value. Else, it is populated with 0.
Foreign Keys
EVENT_KEY
Event Key
EVENT_STATUS_KEY
Event Status Key
Populated with the event status.
ACCT_KEY
Account Key
Populated with the account ID.
PREM_KEY
Premise Key
Populated with the service location.
PER_KEY
Person Key
Populated with the customer ID.
METER_KEY
Meter Key
Populated with the meter ID.
ADDR_KEY
Address Key
Populated based on the service location.
BEGIN_DATE_KEY
Begin Date Key
BEGIN_TIME_KEY
Begin Time Key
RST_DATE_KEY
Restored Time Key
RST_TIME_KEY
Restored Date Key
EST_RST_TIME_KEY
Populated based on the estimated restored time.
EST_RST_DATE_KEY
Populated based on the estimated restored date.
CTRL_ZONE_KEY
Control Zone Key
Populated based on the primary control zone hierarchy of NCG from the DDS_ALARM_LOG table.
CAUSE_CTRL_ZONE_
KEY
Populated based on the jobs NCG.
CTRL_ZONE_SEC_KEY
Control Zone Sec Dimension Surrogate Key
Populated based on the secondary control zone hierarchy of NCG from DDS_ALARM_LOG table.
CAUSE_CTRL_ZONE_
SEC_KEY
AFF_DEVICE_KEY
Device Dimension Surrogate Key
Populated based on the supply node device class and index.
If the damage report is mapped to a non-electrical device, then this field is populated with 0.
CAUSE_DEVICE_KEY
Populated based on the jobs device class and index.
FEEDER_KEY
Feeder Key
Populated based on FEEDER_IDX and FEEDER_CLS.
SW_PLAN_KEY
Switch Plan Key
Populated based on jobs SWSHEET_IDX and SWSHEET_CLS.
STORM_KEY
Storm Key
Storm affects the zones at higher level. Outages fall within the same zone and jobs begin time within the storm period is populated with the storm key.
Populated based on the jobs’ STORMMAN_TYPE.
PARENT_EVENT_KEY
Populated based on the parent event number.
OUTG_DUR_KEY
Outage Duration Key
Populated with the outage duration based on the RANGE_START and RANGE_END period.
EST_RST_DUR_KEY
Est Restoration Duration Surrogate key
Populated with the estimated restoration duration based on the RANGE_START and RANGE_END.
Duration Deviation Surrogate Key
Populated with duration deviation based on the RANGE_START and RANGE_END.
NETWORK_PREM_KEY
Network Premise Dimension Surrogate Key
Populated with the service location ID based on the customer history.
CREW_KEY
Crew Dimension Surrogate Key
Populated based on the crew dispatched crew key.
ACCT_TYPE_KEY
Account Type Dimension Surrogate Key
Populated with account type based on the customer history.
EXCL_DETAIL_KEY
Excludable Detail Dimension Surrogate Key
Populated based on ZONE_IDX, NAME,DATE retrieved from STORMMAN_STORMS.
EXCL_START_DATE_
KEY
Populated based on the exclusion detail start date.
EXCL_END_DATE_KEY
Populated based on the exclusion detail end time.
EXCL_START_TIME_
KEY
Populated based on the exclusion detail start time.
EXCL_END_TIME_KEY
CUST_OUTG_UDD1_
KEY
CUST_OUTG_UDD2_
KEY
User Defined Attributes
UDM1
User Defined Measure 1
UDM2
UDM3
User Defined Measure 3
UDM4
User Defined Measure 4
UDM5
User Defined Measure 5
UDM6
User Defined Measure 6
UDM7
User Defined Measure 7
UDM8
User Defined Measure 8
UDM9
User Defined Measure 9
UDM10
User Defined Measure 10
UDM11
User Defined Measure 11
UDM12
User Defined Measure 12
UDM13
User Defined Measure 13
UDM14
User Defined Measure 14
UDM15
User Defined Measure 15
UDM16
User Defined Measure 16
UDM17
User Defined Measure 17
UDM18
User Defined Measure 18
UDM19
User Defined Measure 19
UDM20
User Defined Measure 20
UDDGEN1
User Defined Degenerate Dimension 1
UDDGEN2
User Defined Degenerate Dimension 2
UDDGEN3
User Defined Degenerate Dimension 3
UDDGEN4
User Defined Degenerate Dimension 4
UDDGEN5
User Defined Degenerate Dimension 5
UDDGENL1
User Defined Long Degenerate Dimension 1
UDDGENL2
User Defined Long Degenerate Dimension 2
UDDGENL3
User Defined Long Degenerate Dimension 3
UDDGENL4
User Defined Long Degenerate Dimension 4
UDDGENL5
User Defined Long Degenerate Dimension 5
UDDFK1_KEY
User Defined Dimension Surrogate Key 1
UDDFK2_KEY
User Defined Dimension Surrogate Key 2
UDDFK3_KEY
User Defined Dimension Surrogate Key 3
UDDFK4_KEY
User Defined Dimension Surrogate Key 4
UDDFK5_KEY
User Defined Dimension Surrogate Key 5
Data Load Attributes
DATA_SOURCE_IND
Data Source Indicator
CES_PARAMETER.
VALUE
Populated with the DSI value on the source product instance configuration.
The table is populated as part of the initial setup and the DSI value is extracted from the source system.
JOB_NBR
Job Number
Populated with the ODI job execution session number.
Recent Job
Stores job information from the source system. This fact stores KPIs, such as number of events, outage duration, restoration duration, resolved event count, etc. It also stores details about all un-restored jobs, as well as jobs restored within the last 'X' number of days. Value of 'X' days has to be configured using Oracle Utilities Administration Tool.
The “recent fact” data store is not intended to be a long-term repository and hence there is a purging mechanism based on a user configured 'X' number of days set in the Oracle Utilities Administration Tool.
Entity relationship diagram for the Recent Job fact
Properties
Property
Value
Target Table Name
CF_RECENT_JOB
Table Type
Fact
Fact Type
Accumulation
Driver Table Name
JOBS
ODI Package Name
B1_PKG_CF_RECENT_JOB
ETL View Name
B1_F_RECENT_JOB_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
RECENT_JOB_KEY
Recent Job Fact Surrogate Key
Populated with the sequence from SPL_RECENT_JOB_SEQ.
Natural Keys
SRC_JOB_NBR
Source Job Number
JOBS.NUMB
Measures
FACT_CNT
Count
OUTG_DURATION
Outage Duration
JOBS.RESTORE_TIME
JOBS.BEGIN_TIME
Populated with the difference (in minutes) between the begin date/time and the actual restoration date/time of the job.
EST_RST_DUR
Outage Duration
JOBS.EST_REST_TIME
JOBS.BEGIN_TIME
CUST_OUT
Customers Out
JOBS. NUM_CUST_OUT
Populated with the customer count experiencing outage.
CALL_RECVD
Calls Received
INCIDENTS. NUMB
DURATION_DEVIATION
Duration Deviation
JOBS. RESTORE_TIME
JOBS. EST_REST_TIME
CRIT_A
JOBS.CRIT_A
CRIT_B
JOBS.CRIT_B
CRIT_C
JOBS.CRIT_C
CRIT_D
JOBS.CRIT_D
CRIT_E
JOBS.CRIT_E
CRIT_F
JOBS.CRIT_F
CRIT_G
JOBS.CRIT_G
CRIT_H
JOBS.CRIT_H
CRIT_I
JOBS.CRIT_I
CRIT_J
JOBS.CRIT_J
CRIT_K
JOBS.CRIT_K
CRIT_L
JOBS.CRIT_L
CRIT_M
JOBS.CRIT_M
CRIT_N
JOBS.CRIT_N
CRIT_O
JOBS.CRIT_O
CRIT_P
JOBS.CRIT_P
CRIT_Q
JOBS.CRIT_Q
CRIT_R
JOBS.CRIT_R
CRIT_S
JOBS.CRIT_S
CRIT_T
JOBS.CRIT_T
CRIT_U
JOBS.CRIT_U
CRIT_V
JOBS.CRIT_V
CRIT_W
JOBS.CRIT_W
CRIT_X
JOBS.CRIT_X
CRIT_Y
JOBS.CRIT_Y
CRIT_Z
JOBS.CRIT_Z
RST_IND
Restored Indicator
JOBS.RESTORE_TIME
Populated with 1 for all restored outages (supply node log restored time is not null). Else, it is populated with 0.
PLANNED_IND
Planned Indicator
Populated with 1 for all planned outages. Else, it is populated with 0.
EXCLUDE_IND
Exclude Indicator
JOBS.STATE_VALUE
Populated with 1 for all excluded outages. Else, it is populated with 0.
OMS_EXCLUDE_IND
Populated based on the NO_DTR_FLAG. If this is 'Y', the field is populated with '1'. Else, '0'.
CANCELLED_IND
Cancelled Indicator
JOBS.STATE_VALUE
Populated based on the STATE_VALUE. If this is 1024, then the indicator is populated with '1'. Else, with '0.
BEGIN_DTTM
Begin Date Time
JOBS.BEGIN_TIME
RST_DTTM
Restored Date Time
JOBS.RESTORE_TIME
COMPLETION_DTTM
Completion Time
JOBS.JOB_COMPLETE_
TIME
EXCL _START_DTTM
EXCL _END_DTTM
Foreign Keys
EVENT_KEY
Event Key
JOBS.NUMB
EVENT_STATUS_KEY
Event Status Key
JOBS.STATUS
BEGIN_DATE_KEY
Begin Date Key
JOBS.BEGIN_TIME
BEGIN_TIME_KEY
Begin Time Key
JOBS.BEGIN_TIME
RST_TIME_KEY
Restored Time Key
JOBS.RESTORE_TIME
RST_DATE_KEY
Restored Date Key
JOBS.RESTORE_TIME
EST_RST_TIME_KEY
JOBS.EST_REST_TIME
EST_RST_DATE_KEY
JOBS.EST_REST_TIME
CTRL_ZONE_KEY
Control Zone Key
JOBS.NCG
DEVICE_KEY
Device Key
JOBS.H_IDX
JOBS.H_CLS
CMPL_USER_KEY
Completed User Key
RESP_USER_KEY
CREW_KEY
Crew Key
CREW_ASSIGNMENT.
CREW_KEY
FEEDER_KEY
Feeder Key
JOBS.FEEDER_CLS
JOBS.FEEDER_IDX
SW_PLAN_KEY
Switch Plan Key
JOBS.SWSHEET_IDX
JOBS.SWSHEET_CLS
STORM_KEY
Storm Key
STORMMAN_STORMS.STORM_NAME
STORMMAN_STORMS.STORM_DATE
STORMMAN_STORMS.ZONE_IDX
Populated based on the storm name, date and control zone.
JOBS.STORMMAN_TYPE
PARENT_EVENT_KEY
Parent Event Key
PARENT_EVENT.NUMB
JOBS.NUMB
OUTG_DUR_KEY
Outage Duration
JOBS.RESTORE_TIME
JOBS.BEGIN_TIME
EST_RST_DUR_KEY
JOBS.EST_REST_TIME
JOBS.BEGIN_TIME
Duration Deviation
JOBS.RESTORE_TIME
JOBS.EST_REST_TIME
CUST_OUT_KEY
Customers Out Key
JOBS. NUM_CUST_OUT
COMPLETION_DATE_
KEY
Completion Date Key
JOBS.JOB_COMPLETE_
TIME
COMPLETION_TIME_
KEY
Completion Time Key
JOBS.JOB_COMPLETE_
TIME
CTRL_ZONE_SEC_KEY
JOBS.NCG
EXCL_DETAIL_KEY
EXCL_START_DATE_
KEY
STORMMAN_STORMS.EX_STORM_START
EXCL _END_DATE_KEY
STORMMAN_STORMS.EX_STORM_END
EXCL_START_TIME_
KEY
EXCL _END_TIME_KEY
JOB_UDD1_KEY
JOB_UDD2_KEY
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Storm
Captures various metrics (such as CI, CMI, MCI, events, and damage assessments) for every hour a storm was active. This fact caters to the various KPI requirements in the Storm Analysis dashboard in the Oracle Utilities Analytics Warehouse application.
Note: Though this is an accumulation fact, all measures have to computed on an hourly basis till the end of the storm. This helps to update the computed measures for any changes in the source system. Measures are calculated for every storm at the beginning hour (based on the storm’s start date).
Entity relationship diagram for the Storm fact
Properties
Property
Value
Target Table Name
CF_STORM
Table Type
Fact
Fact Type
Accumulation
Driver Table Name
STORMMAN_STORMS
ODI Package Name
B1_PKG_CF_STORM
ETL View Name
B1_F_STORM_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
STORM_F_KEY
Storm Fact Surrogate Key
Populated with the sequence from B1_STORM_SEQ.
Natural Keys
SRC_STORM_NAME
Storm Name
CD_STORM.SRC_STORM_NAME
SRC_STORM_NAME_SFX
Storm Name Suffix
CD_STORM.SRC_STORM_NAME_SFX
SRC_NCG_ID
Source NCG ID
MAJ_EVT_SNAP_TYPE_
CD
Major Event Snapshot Type
CD_MJR_EVT_SNAP_TYPE.SNAP_TYPE_CD
Measures
FACT_CNT
Count
CI
Customers Interrupted
CF_CUST_RST_OUTG.SUM(FACT_CNT)
Populated with the count of customers interrupted.
CMI
CF_CUST_RST_OUTG.BEGIN_DTTM
CF_CUST_RST_OUTG.RST_DTTM
Populated with the customer minutes interrupted.
MCI
Momentary Customers Interrupted
Populated with the count of momentary customer interruptions.
SAIDI
SAIDI
Populated with customer minutes interrupted by number of customers served.
SAIFI
SAIFI
Populated with the sum of customer interruptions divided by number of customer served.
MAIFI
MAIFI
Populated with the sum of momentary customer interruptions divided by number of customer served.
CAIDI
CAIDI
Populated with the number of customer minutes interrupted divided by the number of customer interruptions.
NUM_NEW_CUST_OUT
New Customers Out
Populated with count of customers that went out only during that hour (begin date/time fall in that hour).
NUM_ CUST_RST
Customers Restored
Populated with count of customers restored during that hour (the RST_DTTM fall in that hour).
NUM_CUST_REMAIN_
OUT
Customers Remaining Out
Populated with the remaining customers out.
Total Number of Customer Out – Customers Restored in that hour.
NUM_NEW_EVENT
New Events
Populated with the count of jobs created during that hour.
NUM_CLOSED_EVENT
Closed Events
Populated with the count of jobs restored during that hour.
NUM_REMAIN_EVENT
Remaining Events
Populated with number of remaining events.
Total Events - Closed Events
STATISTICS_DTTM
Statistics Date/Time
LEAST OF STORM_START AND EX_STORM_START TILL
GREATEST OF STORM_END AND EX_STORM_END
Populate for every hour starting from least of (STORM_START and EX_STORM_START) till greatest of (STORM_END and EX_STORM_END) in the STORMMAN_STORMS table.
In case of an active storm, load till SYSDATE and populate the hour end time.
Example: For 9th hour, the statistics DTTM is populated as: 09:59:59.
EXCL _START_DTTM
EXCL _END_DTTM
Foreign Keys
CTRL_ZONE_KEY
Control Zone Key
JOBS.NCG
STORM_KEY
Storm Key
CTRL_ZONE_SEC_KEY
JOBS.NCG
EXCL_DETAIL_KEY
EXCL_START_DATE_
KEY
EXCL _END_DATE_KEY
EXCL_START_TIME_
KEY
EXCL _END_TIME_KEY
STORM_UDD1_KEY
Storm User Defined Dimension 1 Surrogate Key
STORM_UDD2_KEY
Storm User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Switch Plan
Supports KPIs, such as number of steps, number of aborted/failed steps, and number of safety documents.
Entity relationship diagram for the Switch Plan fact
Properties
Property
Value
Target Table Name
CF_SW_PLAN
Table Type
Fact
Fact Type
Accumulation
Driver Table Name
SWMAN_SHEET S
ODI Package Name
B1_PKG_CF_SW_PLAN
ETL View Name
B1_F_SW_PLAN_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
SW_PLAN_F_KEY
Switch Plan Fact Surrogate Key
Populated with the sequence from SPL_SW_PLAN_SEQ.
Natural Keys
SRC_SW_PLAN_CLS
Switch Plan Class
SWMAN_SHEET.SWITCH_SHEET_CLS
SRC_SW_PLAN_IDX
Switch Plan Index
SWMAN_SHEET.SWITCH_SHEET_IDX
Measures
FACT_CNT
Count
DURATION
Duration
Populated with the difference (in minutes) between Switch Plan Begin Date and End Date.
(Switch Plan End - Switch Plan Begin) * 1440
NBR_OF_STEPS
Number of Steps
Populated with the number of steps present in SWMAN_STEP (SWMAN_STEP.COUNT(*)) for a switch plan class and index.
NBR_OF_FAILED_STEPS
Number of Failed Steps
Populated with the number of failed switching plan steps.
NBR_OF_ABORTED_
STEPS
Number of Aborted Steps
Populated with the number of aborted switching plan steps.
NBR_OF_SAFETY_DOCS
Number of Safety Documents
SWMAN_SAFETY_DOCS.ID
BEGIN_DTTM
Begin Date/Time
Switch Plan Begin.WHEN_ISSUED
END_DTTM
End Date/Time
Switch Plan End.WHEN_EXECUTED
FINISH_DTTM
Finish Date/Time
SWMAN_SHEET.FINISH_DATE
Foreign Keys
BEGIN_DATE_KEY
Begin Date Key
Populated based on the date part of switch plan begin WHEN_ISSUED.
BEGIN_TIME_KEY
Begin Time Key
Populated based on the time part of switch plan begin WHEN_ISSUED.
END_DATE_KEY
End Date Key
Populated based on the date part of Switch Plan End.WHEN_EXECUTED.
END_TIME_KEY
End Time Key
Populated based on the time part of Switch Plan End.WHEN_EXECUTED.
FINISH_DATE_KEY
Finish Date Key
Populated based on the date part of SWMAN_SHEET.FINISH_DATE.
FINISH_TIME_KEY
Finish Time Key
Populated based on the time part of SWMAN_SHEET.FINISH_DATE.
SW_PLAN_KEY
Switch Plan Key
Populated based on:
SW_PLAN_STATE_KEY
Switch Plan State Key
Populated based on SWMAN_SHEET.STATE_KEY.
USER_KEY1
User1
Populated with ‘0’.
USER_KEY2
User2
Populated with ‘0’.
USER_KEY3
User3
Populated with ‘0’.
USER_KEY4
User4
Populated with ‘0’.
USER_KEY5
User5
Populated with ‘0’.
USER_KEY6
User6
Populated with ‘0’.
USER_KEY7
User7
Populated with ‘0’.
USER_KEY8
User8
Populated with ‘0’.
CTRL_ZONE_ KEY
Control Zone Dimension Surrogate Key
CTRL_ZONE_SEC_KEY
Populate from CD_CTRL_ZONE_SEC dimension's surrogate key based on NCG ID and records effective date/time is between effective start and end date/time of dimension.
SW_PLAN_UDD1_KEY
Switch Plan User Defined Dimension 1 Surrogate Key
SW_PLAN_UDD2_KEY
Switch Plan User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Switch Plan Segmentation
Captures the customer related outage information at a switch plan and feeder level for switch plan segments.
A switch plan is associated to multiple events (outage associated to the switch plan). It is a time period created using the earliest starting time of the outages associated with the switch plan and updated when the number of customers out due to an outage changes due to the outage restoration or due to a new outage associated to the switch plan.
This fact stores the outage metrics for switch plan computed for every such segment. It is dependent on the Customer Outage fact (CF_CUST_RST_OUTG). It should be processed when the Outage fact is processed. Since this fact stores information at a switch plan level and at a feeder level, all the measures need to be computed at the switch plan and feeder level.
Properties
Property
Value
Target Table Name
CF_SW_PLAN_SEG
Table Type
Fact
Fact Type
Accumulation
Driver Table Name
SWMAN_SHEET
B1_BR_SW_PLAN_JOBS
CF_CUST_RST_OUTG
ODI Package Name
B1_PKG_CF_SW_PLAN_SEG
ETL View Name
B1_F_SW_PLAN_SEG_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
SW_PLAN_SEG_KEY
Switch Plan Segmentation Key
Populated with the sequence from B1_SW_PLAN_SEG_SEQ.
Natural Keys
SRC_SW_PLAN_CLS
Switch Plan Class
SRC_SW_PLAN_IDX
Switch Plan Index
SRC_NCG_ID
Control Zone ID
CD_CTRL_ZONE.SRC_
NCG_ID
Populated based on the FEEDER_KEY from Customer Outage fact.
Measures
FACT_CNT
Count
SEG_SEQ
Segmentation Sequence
Populated as a sequence value (beginning with 1) for all segments of the switch plan.
NUM_NEW_CUST_OUT
Number of New Customers Out
Retrieves the customer count impacted due to outage associated with the switch plan from the Customer Outage table.
NUM_CUST_RST
Retrieves the total count of customers restored for the outage associated with the switch plan.
NUM_CUST_REMAIN_
OUT
Number of Customers Remaining Out
Populated with the difference in the running sum of Customer Out (NUM_NEW_CUST_OUT) and the running sum of Customer Restored (NUM_CUST_RST).
SEG_START_DTTM
Segmentation Start Date Time
Populated with the start date and time of the new outage.
SEG_END_DTTM
Segmentation End Date Time
Populated with the end date and time of the new outage.
SW_PLAN_BEGIN_
DTTM
Switch Plan Begin Date Time
SWMAN_SHEET.START_DATE
Populated with SWMAN_SHEET. START_DATE.
SW_PLAN_END_DTTM
Switch Plan End Date Time
SWMAN_SHEET.COMPLETED_DATE
Populated with SWMAN_SHEET.COMPLETED_DATE.
Foreign Keys
SW_PLAN_KEY
Switch Plan Key
SWMAN_SHEET.SRC_
SWITCH_SHEET_CLS
SWMAN_SHEET.SRC_
SWITCH_SHEET_IDX
Populated based on:
SWMAN_SHEET.SRC_SWITCH_SHEET_CLS
SWMAN_SHEET.SRC_SWITCH_SHEET_IDX
FEEDER_KEY
Feeder Key
CF_CUST_RST_OUTG.
FEEDER_KEY
Populated with FEEDER_KEY from the Customer Outage fact.
CTRL_ZONE_KEY
Control Zone Key
CF_CUST_RST_OUTG.CTRL_ZONE_KEY
Populated with CTRL_ZONE_KEY from the Customer Outage fact.
SW_PLAN_STATE_KEY
SW_PLAN_BEGIN_DATE_KEY
Switch Plan Begin Date Key
Populated based on the date part of the start of the switch plan.
SW_PLAN_BEGIN_TIME_KEY
Switch Plan Begin Time Key
Populated based on the time part of the start of the switch plan.
SW_PLAN_END_DATE_KEY
Switch Plan End Date Key
Populated based on the date part of the end of the switch plan.
SW_PLAN_END_TIME_
KEY
Switch Plan End Time Key
SEG_START_DATE_KEY
Segmentation Start Date Key
Populated based on the date part of segment start.
SEG_START_TIME_KEY
Segmentation Start Time Key
Populated based on the time part of segment start.
SEG_END_DATE_KEY
Segmentation End Date Key
Populated based on the date part of segment end.
SEG_END_TIME_KEY
Segmentation End Time Key
Populated based on the time part of segment end.
CTRL_ZONE_SEC_KEY
CF_CUST_RST_OUTG.CTRL_ZONE_SEC_KEY
SW_PLAN_SEG_UDD1_
KEY
Switch Plan Segmentation User Defined Dimension 1 Surrogate Key
SW_PLAN_SEG_UDD2_
KEY
Switch Plan Segmentation User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
Switch Plan State
Captures details about the crews working on jobs with measures, such as in-route duration, work duration, and dispatch duration.
Entity relationship diagram for the Switch Plan State fact
Properties
Property
Value
Target Table Name
CF_SW_PLAN_STATE
Table Type
Fact
Fact Type
Accumulation
Driver Table Name
SWMAN_AUDIT_LOG SAL1
ODI Package Name
B1_PKG_CF_SW_PLAN_STATE
ETL View Name
B1_F_SW_PLAN_STATE_VW
Fields
Target Field
OAS Field
Source Field
Surrogate Key
SW_PLAN_STATE_F_
KEY
Switch Plan State Fact Surrogate Key
Populated with the sequence from SPL_SW_PLAN_STATE_
SEQ.
Natural Keys
SRC_LOG_ENTRY
Switch Plan Log Entry ID
SWMAN_AUDIT_LOG.
SEQ_LOG_ID
Measures
FACT_CNT
Count
STATE_DURATION
Duration of the Switch Plan State
BEGIN_DTTM
Begin Date/Time
SWMAN_AUDIT_LOG.
INSERT_TIME
END_DTTM
End Date/Time
SWMAN_AUDIT_LOG.
INSERT_TIME
Populated with the difference between SWMAN_AUDIT_LOG.INSERT_TIME when state change happens * 1440.
Foreign Keys
BEGIN_DATE_KEY
Begin Date Key
Populated based on the switch plan begin date.
BEGIN_TIME_KEY
Begin Time Key
Populated based on the switch plan begin time.
END_DATE_KEY
End Date Key
Populated based on the switch plan end date.
END_TIME_KEY
End Time Key
Populated based on the switch plan end time.
SW_PLAN_KEY
Switch Plan Key
SW_PLAN_STATE_KEY
Populated based on the switch plan state key.
USER_KEY
User Key
Populated based on the CES user name.
CTRL_ZONE_ KEY
CTRL_ZONE_SEC_KEY
Populated from CD_CTRL_ZONE_SEC dimension's surrogate key based on NCG ID and records effective date/time is between effective start and end date/time of dimension.
SW_PLAN_STATE_UDD1_KEY
Switch Plan State User Defined Dimension 1 Surrogate Key
SW_PLAN_STATE_UDD2_KEY
Switch Plan State User Defined Dimension 2 Surrogate Key
UDM1
UDM2
UDM3
UDM4
UDM5
UDM6
UDM7
UDM8
UDM9
UDM10
UDM11
UDM12
UDM13
UDM14
UDM15
UDM16
UDM17
UDM18
UDM19
UDM20
UDDGEN1
UDDGEN2
UDDGEN3
UDDGEN4
UDDGEN5
UDDGENL1
UDDGENL2
UDDGENL3
UDDGENL4
UDDGENL5
UDDFK1_KEY
UDDFK2_KEY
UDDFK3_KEY
UDDFK4_KEY
UDDFK5_KEY
DATA_SOURCE_IND
CES_PARAMETER.
VALUE
JOB_NBR
Job Number
