Pre-Event Email
The pre-event email is a short message that tells customers when a peak event is going to occur. It displays user-friendly graphics and insights to motivate participation and behavior change. The email has a different appearance depending on which user experience variation the customer receives. See Customer Experience Variations for more information.
If multiple consecutive peak days are called, pre-event emails and voice messages will reflect that a customer is in a multi-day event period.Neighbor Comparison Experience
The Neighbor Comparison pre-event email shows the customer their energy usage during peak hours compared with other homes that have similar characteristics. The goal is to persuade customers to improve their status by using less energy on subsequent peak days.
The user experience for the neighbor comparison includes a bar chart that represents the customer's energy usage in relation to similar homes, followed by a list of actionable tips to be more energy-efficient.
The following image is an example of the hot-weather experience. You can also use it for cold-weather seasons, and include the peak day definition, and actionable tips related to cold weather.
The first pre-event email of the season does not include any actual customer data. Instead, it includes a generic bar chart containing mock data and poses a question to customers to entice them to participate in the upcoming peak event. In most cases, subsequent pre-event emails use actual data from the last peak event to show customers how well they performed and motivate them to do better next time.
Allowable Modules
The following modules may be used in a Neighbor Comparison pre-event email:
- Header and Footer Modules
- Upcoming Event Module
- Neighbor Comparison
- Introduction (Peak Day Definition) Module
- Tips Module
The neighbor comparison user experience will vary for customers depending upon their energy use, the data available, and whether they are receiving a pre-event or post-event email. The following table indicates the most common user experience variations.
| Variation | Description |
| The customer used less or the same amount of energy as all neighbors. | The “You used less than average but more that the most efficient homes on the last peak day.” message followed by the three bar graph comparing YOU, Efficient Neighbors, and All Neighbors energy use is displayed. |
| The customer used less or the same amount of energy as efficient neighbors. | The “You used LESS than the most efficient homes on the last peak day.” message followed by the three bar graph comparing YOU, Efficient Neighbors, and All Neighbors energy use is displayed. |
| The customer used less energy or the same as their efficient neighbors. | The “Great work on X date!” message followed by the three bar graph comparing YOU, Efficient Neighbors, and All Neighbors energy use is displayed. |
| The customer used less energy than neighbors, but more energy than efficient neighbors. | The “You used less than average but more than the most efficient homes on the last peak day.” message followed by the three bar graph comparing Efficient Neighbors, YOU, and All Neighbors energy use is displayed. |
| The customer used more energy than their neighbors. | The “You used MORE than similar homes on the last peak day” message followed by the three bar graph comparing Efficient Neighbors, All Neighbors, and YOU energy use is displayed. |
One of the following scenarios occurs:
The “Can you use less energy than your neighbors on the next peak day?” message followed by a two bar graph comparing a hypothetical YOU and All Neighbors energy use is displayed. The YOU bar energy use is lower than the All Neighbors energy use. |
Neighbor Rank Experience
The Neighbor Rank pre-event email ranks the customer based on how their usage during peak hours compares to the usage of approximately 100 similar homes. The goal is to persuade customers to improve their ranking by using less energy during subsequent peak days. Below the rank graphic are a definition of what a peak event is, and a list of actionable tips that customers can follow to save energy. The following image is an example of the hot-weather experience. You can also use it for cold-weather events, and include the peak day definition and actionable tips related to cold-weather.
The Neighbor Rank email is only available for customers who receive electricity from their utility.The following image is an example of the neighbor rank graph within the pre-event email sent to customers who receive the neighbor rank experience for hot-weather events. You can also use this email for cold-weather events, and include a peak day definition and actionable tips related to cold weather.
The first pre-event email of the season does not include any customer data. Instead, it includes a generic bar chart containing mock data and poses a question to customers to entice them to participate in the upcoming peak event. In most cases, subsequent pre-event emails use data from the last peak event to determine the customer's rank and show them whether or not they moved up, dropped down, or remained at the same position. See Neighbor Rank for more information.
Allowable Modules
The following modules may be used in a Neighbor Rank pre-event email:
Non-AMI Gas Experience
The non-AMI pre-event gas email uses static content to invite customers to participate in a peak event. However, due to the absence of AMI data, the email does not include a neighbor rank or neighbor comparison module.
The non-AMI email is only available for customers who receive gas from their utility.
Allowable Modules
The modules below may be used in a non-AMI pre-event email. Note that there is no neighbor comparison, or neighbor rank modules.
User Experience Variations
The user experience varies for customers depending upon their service types, available data, costs, and locale. Note that this section indicates the primary user experience variations, not all possible variations.
The pre-event email can use a neighbor comparison variation to motivate energy efficient behavior during the peak event. The neighbor comparison variation shows the customer their energy usage during peak hours compared with the same usage for average and efficient homes with similar characteristics.
The following image is an example of the neighbor comparison module.
Multi-Day Variation
If a peak event spans across multiple days, the following message is an example of what will appear at the top of the Behavioral Demand Response pre-event email during hot-weather months. It can also be used to show multi-day variation during cold-weather seasons:
The pre-event email can vary if customers receive the non-AMI gas experience. In this case, both the pre-event and post-event emails use static content to invite customers to participate in a peak event. However, due to the absence of AMI data, the non-AMI experience does not include a neighbor comparison or neighbor rank module.
