Configuring Admin Data
To configure the Oracle Utilities Customer Cloud Service setup for the integration:
1. Login to Oracle Utilities Customer Cloud Service.
2. Create message senders. Refer to the
Message Senders section for details.
4. Create an external system. Refer to the
External System section for details.
7. Create activity types. Refer to the
Activity Types section for details.
Note: To create the external system and outbound message types follow the naming conventions specified to ensure compatibility with the refresh endpoint and related customizations.
Message Senders
This section provides the message sender configuration details in Oracle Utilities Customer to Meter and Oracle Utilities Customer Cloud Service.
To create a message sender:
1. Navigate to the Message Sender page, either from the Admin menu or from the Search menu.
2. Enter a unique message sender and its description.
3. Populate the following values:
• Invocation Type: Real-time
• Message Class: SOAPSNDR
• Active: Select the checkbox.
• MSG Encoding: UTF-8 message encoding
4. Select the Context tab and set values for the following context types:
• HTTP Header: SOAPAction:”<operation name in OIC Activated Integration wsdl url>”
• HTTP Method (POST/GET): POST
• HTTP Timeout: 60
• HTTP Transport Method: SendReceive
• HTTP URL 1: Set the Activated Integration end point URL by removing the ?wsdl from the URL.
If the URL value does not fit, use the additional HTTP URL types to set the complete URL.
• Message Namespace URI: Provide the namespace of the schema in the respective integration process.
Important! Make sure the namespace does not include any extra spaces. Copy the namespaces into Notepad to check for any extra spaces.
In addition to the values listed above, from the following security types, add the corresponding security policy specific context types.
• For Basic Auth Security type:
• HTTP Login User: User ID to access the Oracle Integration Cloud flow.
• HTTP Password: Password to access the flow.
• Sender Security Type: BASIC
• If the security policy used is OAuth Client Credentials, additional configuration for the context types should be as follows:
• OAuth Access Token URL: Identity service token url to retrieve the OAuth token for Oracle Integration Cloud Instance.
• The Token URL is of format: https://<idcs-tenant>/oauth2/v1/token
• OAuth Client ID: OAuth Client ID for Client Credentials grant type of Oracle Integration Cloud Instance.
• OAuth Client Secret: OAuth Client Secret for Client Credentials grant type of Oracle Integration Cloud Instance.
• OAuth Grant Type: client_credentials
• OAuth REST API Scope: OAuth Scope for Client Credentials grant type of Oracle Integration Cloud Instance.
• Sender Security Type: OAUTH
Message sender configuration for integration services in Oracle Utilities Customer to Meter
Message sender configuration for integration services in Oracle Utilities Customer Cloud Service
Outbound Message Types
To create a new outbound message type for each integration process:
1. Navigate to the Outbound Message Type page from the Admin menu or from the Search menu.
2. Enter an outbound message type, description, and detailed description.
3. Select the outbound message business object created for a specific service.
Outbound message types for integration services
External System
To create a new external system to support the integration:
1. Navigate to the External System page from the Admin menu or from the Search menu.
2. Enter a unique external system and description.
For example: Name = INT_OFSC_ES, Description = OFSC External System
3. Set the Our Name in Their System field to C2M.
4. Associate the outbound message types and message senders created to the external system.
For each outbound message type, set the following:
• Outbound Message Type: Outbound message type created for the respective integration service.
• Processing Method: Real-time
• Message Sender: Set the message sender created for the integration service
• Date/Time Format: XSD
• Namespace Option: Configured on sender.
For more information about message senders and outbound message type for each integration service, refer to the
Message Senders and
Outbound Message Types sections respectively.
External system configuration for integration services
Example External System - INT_OFSC_ES
External Application
Create an external application with the respective external system reference and add processing roles to invoke each integration service.
To create a new external application to support the integration:
1. Navigate to the External Application page from the Admin menu or from the Search menu.
2. Enter a unique external application and description.
Example: Name = INT_OFSC_EA, Description = INT_OFSC External Application - Field Work System
Note: The same value should be configured in the source.system property in the SOMOFSC_ConfigProps lookup in Oracle Integration Cloud.
4. Select the External System as <external system> created for this integration. For details about external system, refer to the
External System section.
Example: INT_OFSC_ES
5. Select Utility Device ID Type as Badge Number.
6. Click Save.
7. Under Processing Method List, add Processing Method for each integration service.
8. Associate the outbound message types and message senders to the external system. For each outbound message type, set the following:
• Processing Role: Select the relevant processing role.
• Business Object: Select the business object to generate the outbound message.
• Description: Describe the processing method.
• Status: Active
• Default Business Object: Select the business object for the respective outbound message type.
• Default Outbound Message Type: Outbound message type for the respective integration service.
Master Configuration
The master configuration has the necessary information to support this integration.
1. Navigate to the Master Configuration page from the Admin menu or from the Search menu.
2. Select Service Order Management Master Configuration.
3. Click + next to Service Order Management Master Configuration.
4. In the Master Configuration Details zone, configure the following values.
a. In the Main section:
a. Field Work System = Refer to the external application created in the
External Application section. <External Application name>
Example: INT_OFSC_EA
b. Near Schedule Meter Read Search (Days) = 5
b. In the Completion Event Exception Handling section:
a. To Do Type = Activity To Do Type
b. To Do Role = System Default Role
c. Maximum Retries = 2
d. Retry Frequency = 00:05:00
c. In the Management Dashboard Configuration section:
a. Number of Days to Consider for Snapshot = 7
b. Weekends/Holidays Inclusion in Activity Duration = Exclude from Activity Duration
c. Work Calendar = US Bank Work Calendar
d. Default Expected Activity Completion Time (Hours) = 3
d. In the Appointment Handling section:
a. Appointment Slot Request (Hours) = 360
b. Default Appointment Handling System = <External Application name>
e. In the Cut for Non-Payment Service Restrictions section:
a. Life Support/Sensitive Load Option = Allow Cut Service
f. In the Override Expected Completion Time Configuration section:
a. Activity Type = SOM_FIELD_ACTIVITY_TYPE
b. Task Type = Read Meter
c. Expected Completion Time (Hours) = 60
g. In the Hours Beyond Expected Activity Completion Time section:
a. On Time Completion Tolerance = 8
b. Late Completion Tolerance = 16
c. Very Late Completion Tolerance = 24
d. Normal In Progress Time = 8
e. Long In Progress Time = 16
f. Very Long In Progress Time = 24
h. In the Update Statistics section:
a. Batch Control = D1-ACTAG
i. In the Chart Options section:
a. Number of Historical Days to Include in Summary Charts = 12
j. In the Summary To Do Types section:
k. In the FA Cancelability Criteria section:
a. FA Cancellable Script = Determine FA Cancellability
Note: The values configured in the above master configuration section are the sample values for reference.
Activity Types
An activity type defines the properties common to a specific type of activity.
One or more activity types must be defined for the service order field activities.
Refer to the Oracle Utilities Customer Cloud Service Administrative User Guide for details on service order activity types and how to set up a service order field activity type.
Field Task Types
A service order field activity's field task type defines the task to be performed. The field task types in CCS correspond to the activity types in Oracle Fusion Field Service.
Refer to the Oracle Utilities Customer Cloud Service Administrative User Guide for details on field task types.
