Migrating from OFFS Test to Production Environment
Migrate the following Oracle Fusion Field Service components from test to production environment:
Properties
To migrate properties from the Oracle Fusion Field Service test environment to production:
1. Export the properties that have names starting with “c2m_” from the test environment and import them into the production environment.
2. Export the common_utilities_product_code property from the test environment and import it into the production environment.
Note: Make sure that the properties added manually in the test environment have been successfully imported in production environment.
Example: c2m_deviceType, c2m_Service_type, c2m_ert_custom_move_act_types
Plugins
To migrate plugins from the Oracle Fusion Field Service test environment to production:
1. Export the Device Verification plugin from test environment and import it into production environment. Configure the plugin secure parameters with production Oracle Integration Cloud details.
2. Export the Unrelated Customer Pickup plugin from test environment and import it into the production environment. Configure the plugin secure parameters with Oracle Integration Cloud production environment details.
User Types
To migrate user types from the Oracle Fusion Field Service test environment to production, export the customized user types from the test environment and import them into the production environment.
Screens
To migrate screens from the Oracle Fusion Field Service test environment to production, export the customized screens from the test environment and import them into the production environment.
Glossary
To migrate glossaries from the Oracle Fusion Field Service test environment to production, export them from the test environment and import them into production environment.
