External System
Configure an external system record for the GIS system. In this integration, there is no need to configure any Outbound Message Types or Message Senders for Asset synchronization. For Work Location Outbound synchronization, the Work Location Outbound Message Type (W1-WLOUTMSGT) is added to the external system. This is required in the Master Configuration Setup to process the synchronization requests that are created as part of the process.
Message Sender
Create a new Message Sender with the details used with the Work Location Outbound Message Type in the External System.
• Main tab
• Invocation Type: Real-time
• Message Class: RTJSONSNDR
• Active: <Check box checked>
• Message Encoding: UTF-8 message encoding
• Context tab
• HTTP Login User: <OIC login user>
• HTTP Login Password: <OIC login password>
• HTTP Method: POST
• HTTP Timeout: 60
• HTTP URL 1: <OIC end point URL>
Configure the following outbound message type in the external system:
Processing Method
Message Sender
Date/Time Format
W1-WLOUTMSGT
Real-time
<Message Sender defined in the above section>
XSD
