Master Configuration Setup
This section describes the following master configurations that set up to process the synchronization requests:
ESRI WAM Integration Master Configuration
ESRI WAM Integration master configuration objects dictate the Map Viewer integration with the Oracle Utilities Work and Asset Management/Oracle Utilities Work and Asset Cloud Service application.
• ESRI Integration On/Off: Determines whether or not the integration is in use within your system. This required value provides a quick way to disable key features of the integration.
• External System: Identifies the external system for ESRI ArcGIS Server.
• Timeout Threshold Hours: Sets the number of hours after which the outbound synchronization messages should timeout.
• Default Number of Records in Results Grid: The maximum number of results records displayed in the Asset and Work tabs in the Map Viewer when the features are selected.
• Default Asset Effective Date/Time: The default value to use during creation of assets in the GIS data synchronization for the asset disposition.
• Map Notes: The name of the map layer considered when the share widget is opened (example: redlining) are performed in the Map Viewer.
• GIS Projected Coordinate Systems: Used to hold the value of projected coordinate system. This is important to make sure the proper coordinate model is used in your map.
• Default Out of Service Location: When the GIS features that were previously synchronized to Oracle Utilities Work and Asset Management/Oracle Utilities Work and Asset Cloud Service are deleted in the GIS system, the corresponding assets are retired and moved to this location on the next synchronization of these changes to Oracle Utilities Work and Asset Management/Oracle Utilities Work and Asset Cloud Service. The original location of these retired assets is deactivated.
Similarly, when the GIS features that were previously synchronized to Oracle Utilities Work and Asset Management/Oracle Utilities Work and Asset Cloud Service are marked as ‘abandoned’ in the GIS system, the corresponding assets are retired and moved to this location when the asset type configuration does not allow such assets to be retired in place.
• Abandoned Asset GIS Field/Value: A GIS feature is considered ‘abandoned’ if it has the Abandoned GIS field/value combination specified in the GIS system. The system assumes the life cycle status or related field/value is already configured in GIS to identify abandoned features. The GIS field and value are the one that marks a GIS feature as abandoned in the GIS system.
Note: The system assumes an abandoned GIS feature retains its GIS unique identifier as it remains key to the synchronization process between the systems.
• Outbound Process Option: The Sync Request option sends updated asset data immediately using the Outbound Message Type defined in the External System. The File Based option tracks updated assets in the General Process table and generates file when the W1GISEXT batch process is executed.
• Work Location Business Object: Defines the Work Location Business Object that will be used when a pin drop is used on the GIS Map Viewer to specify the work location.
• Related ESRI Layer: The name of the map layer considered for turning the Work Locations layer on/off in the GIS Map Viewer.
• Outbound Message Type: Defines the outbound message type that will be used to send supplemental work locations to ESRI ArcGIS. This should match the Outbound Message Type defined in the External System.
• Selected Asset: The color configured here is used to select the Oracle Utilities Work and Asset Management/Oracle Utilities Work and Asset Cloud Service mapped assets in the ESRI ArcGIS Map Viewer when drawing a graphic using select options within the Asset and Work tabs.
• Highlighted Asset: The color configured here is used to highlight a particular asset feature on the GIS viewer when hovering over the record item in the results on the Asset and Work tabs.
• Assets with no Work: The color configured here is used to represent the Oracle Utilities Work and Asset Management/Oracle Utilities Work and Asset Cloud Service mapped assets that do not have any linked work.
• Highlight Related Assets: The color configured here is used to highlight the assets that are associated with an activity record in the Work tab. The related assets for an activity can be highlighted using the Highlight icon that appears for each of the activity records in the Work tab results.
• Specific Webmaps for Asset Types: Allows for more specific definition of Web Maps based on Asset Type when you are using multiple web maps. This is useful when a specific Asset Type can only be displayed on a particular web map.
Master Data Synchronization Configuration
FK Reference
Initial Sync Key Reference View
Ongoing Sync Key Reference View
External System
Identifier Type
W1-ASLO
W1_INI_NODE_VW
W1_ON_NODE_VW
<GIS External System>
W1GI
W1-ASSET
W1_INI_ASSET_VW
W1_ON_ASSET_VW
W1GI
W1-NODE
W1_INI_NODE_VW
W1_ON_NODE_VW
W1GI
Seeder Sync Request Master Configuration
External System
Maintenance Object
Initial Sync Request BO
Ongoing Sync Request BO
Identifier Type
W1-ASSET
W1-InitialSyncRequestAsset
W1-OngoingSyncRequestAsset
W1_ON_ASSET_VW
W1GI
W1-NODE
W1-InitialSyncRequestLocation
W1-OngoingSyncRequestLocation
W1_ON_NODE_VW
W1GI
