Configuring Admin Data
To configure the Oracle Utilities Customer Cloud Service setup for the integration:
1. Login to Oracle Utilities Customer Cloud Service.
2. Create message senders. Refer to the Message Senders section for details.
3. Create outbound message types. Refer to the Outbound Message Types section for details.
4. Create an external system. Refer to the External System section for details.
5. Create an external application. Refer to the External Application section for details.
6. Complete the master configuration. Refer to the Master Configuration section for details.
7. Create activity types. Refer to the Activity Types section for details.
8. Generate certificates. Refer to the Adding Oracle Integration Cloud Certificates section for more details.
Note: To create the external system and outbound message types follow the naming conventions specified to ensure compatibility with the refresh endpoint and related customizations.
Message Senders
This section provides the message sender configuration details in Oracle Utilities Customer to Meter and Oracle Utilities Customer Cloud Service.
To create a message sender:
1. Navigate to the Message Sender page, either from the Admin menu or from the Search menu.
2. Enter a unique message sender and its description.
3. Populate the following values:
• Invocation Type: Real-time
• Message Class: SOAPSNDR
• Active: Select the checkbox.
• MSG Encoding: UTF-8 message encoding
4. Select the Context tab and set values for the following context types:
• HTTP Header: SOAPAction:”<operation name in OIC Activated Integration wsdl url>”
• HTTP Method (POST/GET): POST
• HTTP Timeout: 60
• HTTP Transport Method: SendReceive
• HTTP URL 1: Set the Activated Integration end point URL by removing the ?wsdl from the URL.
If the URL value does not fit, use the additional HTTP URL types to set the complete URL.
• Message Namespace URI: Provide the namespace of the schema in the respective integration process.
Important! Make sure the namespace does not include any extra spaces. Copy the namespaces into Notepad to check for any extra spaces.
In addition to the values listed above, from the following security types, add the corresponding security policy specific context types.
• For Basic Auth Security type:
• HTTP Login User: User ID to access the Oracle Integration Cloud flow.
• HTTP Password: Password to access the flow.
• Sender Security Type: BASIC
• If the security policy used is OAuth Client Credentials, additional configuration for the context types should be as follows:
• OAuth Access Token URL: Identity service token url to retrieve the OAuth token for Oracle Integration Cloud Instance.
• The Token URL is of format: https://<idcs-tenant>/oauth2/v1/token
• OAuth Client ID: OAuth Client ID for Client Credentials grant type of Oracle Integration Cloud Instance.
• OAuth Client Secret: OAuth Client Secret for Client Credentials grant type of Oracle Integration Cloud Instance.
• OAuth Grant Type: client_credentials
• OAuth REST API Scope: OAuth Scope for Client Credentials grant type of Oracle Integration Cloud Instance.
• Sender Security Type: OAUTH
Message sender configuration for integration services in Oracle Utilities Customer to Meter
Message Sender
Description
HTTP Header
HTTP URL
Process Activity (create/update/cancel)
INT_OFSC_PA
INT Process Activity-Message Sender-OFSC
http://xmlns.oracle.com/SRHUB/Message
SOAPAction:"ICS_OFSC_ProcessActivity
https://OIC_Host:OIC_Port/ic/ws/integration/v2/flows/oracleutilities/project/OUTL-BA-CCS_OFSC/OUTL-BA-CCS_OFSC_ACTIVITY_PROCES/1.0/
Get Appointment
INT_OFSC_GAP
INT Get appointment-Message Sender-OFSC
http://ouaf.oracle.com/outbound/D1-ApptOBMessage
SOAPAction: "OIC_OFSC_OIC_OFSC_GA
https://OIC_Host:OIC_Port/ic/ws/integration/v2/flows/oracleutilities/project/OUTL-BA-CCS_OFSC/OUTL-BA-CCS_OFSC_APPMT_GET/1.0/
Interim Status
INT_OFSC_STA
INT Interim Status-Message Sender-OFSC
SOAPAction:"ICS_OFSC_GetStatus
https://OIC_Host:OIC_Port/ic/ws/integration/v2/flows/oracleutilities/project/OUTL-BA-CCS_OFSC/OUTL-BA-CCS_OFSC_ACTIVITY_STATUS/1.0/
Message sender configuration for integration services in Oracle Utilities Customer Cloud Service
Message Sender
Description
HTTP Header
HTTP URL
INT_OFSC_PA
@EXT_PUB@OIC_Host:OIC_Port/ic/ws/integration/v2/flows/oracleutilities/project/OUTL-BA-CCS_OFSC/OUTL-BA-CCS_OFSC_ACTIVITY_PROCES/1.0/
Get Appointment
INT_OFSC_GAP
SOAPAction:"OIC_OFSC_OIC_OFSC_GA
@EXT_PUB@OIC_Host:OIC_Port/ic/ws/integration/v2/flows/oracleutilities/project/OUTL-BA-CCS_OFSC/OUTL-BA-CCS_OFSC_APPMT_GET/1.0/
Interim Status
INT_OFSC_STA
@EXT_PUB@OIC_Host:OIC_Port/ic/ws/integration/v2/flows/oracleutilities/project/OUTL-BA-CCS_OFSC/OUTL-BA-CCS_OFSC_ACTIVITY_STATUS/1.0/
To create a new outbound message type for each integration process:
1. Navigate to the Outbound Message Type page from the Admin menu or from the Search menu.
2. Enter an outbound message type, description, and detailed description.
3. Select the outbound message business object created for a specific service.
Outbound message types for integration services
Integration Service
Description
Business Object
Process Activity(create)
INT_OFSC_PA
INT Process Activity request to OFSC
D1-FAAddOBMsg
Get Appointment
INT_OFSC_GAP
INT Get appointment from OFSC
D1-ApptOBMessage
Interim Status
INT_OFSC_STA
INT Interim Status in OFSC
D1-InterimStatusRequest
Process Activity(update/ cancel)
INT_OFSC_UA
INT Update Activity request to OFSC
D1-FAModifyOBMsg
External System
To create a new external system to support the integration:
1. Navigate to the External System page from the Admin menu or from the Search menu.
2. Enter a unique external system and description.
For example: Name = INT_OFSC_ES, Description = OFSC External System
3. Set the Our Name in Their System field to C2M.
4. Associate the outbound message types and message senders created to the external system.
For each outbound message type, set the following:
• Outbound Message Type: Outbound message type created for the respective integration service.
• Processing Method: Real-time
• Message Sender: Set the message sender created for the integration service
• Date/Time Format: XSD
• Namespace Option: Configured on sender.
For more information about message senders and outbound message type for each integration service, refer to the Message Senders and Outbound Message Types sections respectively.
External system configuration for integration services
Example External System - INT_OFSC_ES
Integration Service
Message Sender
INT_OFSC_PA
INT_OFSC_PA
Process Activity(update/cancel)
INT_OFSC_UA
INT_OFSC_PA
Get Appointment
INT_OFSC_GAP
INT_OFSC_GAP
Interim Status
INT_OFSC_STA
INT_OFSC_STA
Create an external application with the respective external system reference and add processing roles to invoke each integration service.
To create a new external application to support the integration:
1. Navigate to the External Application page from the Admin menu or from the Search menu.
2. Enter a unique external application and description.
Example: Name = INT_OFSC_EA, Description = INT_OFSC External Application - Field Work System
Note: The same value should be configured in the source.system property in the SOMOFSC_ConfigProps lookup in Oracle Integration Cloud.
4. Select the External System as <external system> created for this integration. For details about external system, refer to the External System section.
Example: INT_OFSC_ES
5. Select Utility Device ID Type as Badge Number.
6. Click Save.
7. Under Processing Method List, add Processing Method for each integration service.
8. Associate the outbound message types and message senders to the external system. For each outbound message type, set the following:
• Processing Role: Select the relevant processing role.
• Business Object: Select the business object to generate the outbound message.
• Description: Describe the processing method.
• Status: Active
• Default Business Object: Select the business object for the respective outbound message type.
• Default Outbound Message Type: Outbound message type for the respective integration service.
Integration Service
Processing Role
Description
Default Business object
Field Activity
INT OFSC Process activity Processing Role
D1-FieldActivityOBComm
INT_OFSC_PA
Appointment Request
Appointment Request
INT OFSC Appointment Processing Role
n/a
INT_OFSC_GAP
Interim Status
Interim Status Update
INT OFSC Interim Status Processing Role
n/a
INT_OFSC_STA
Process Activity(Update)
Update Activity
INT OFSC Update activity Processing Role
D1-ActivityModifyOBComm
INT_OFSC_UA
Process Activity(Cancel)
Cancelation Activity
INT OFSC Cancel activity Processing Role
INT_OFSC _PA
The master configuration has the necessary information to support this integration.
1. Navigate to the Master Configuration page from the Admin menu or from the Search menu.
2. Select Service Order Management Master Configuration.
3. Click + next to Service Order Management Master Configuration.
4. In the Master Configuration Details zone, configure the following values.
a. In the Main section:
a. Field Work System = Refer to the external application created in the External Application section. <External Application name>
Example: INT_OFSC_EA
b. Near Schedule Meter Read Search (Days) = 5
b. In the Completion Event Exception Handling section:
a. To Do Type = Activity To Do Type
b. To Do Role = System Default Role
c. Maximum Retries = 2
d. Retry Frequency = 00:05:00
c. In the Management Dashboard Configuration section:
a. Number of Days to Consider for Snapshot = 7
b. Weekends/Holidays Inclusion in Activity Duration = Exclude from Activity Duration
c. Work Calendar = US Bank Work Calendar
d. Default Expected Activity Completion Time (Hours) = 3
d. In the Appointment Handling section:
a. Appointment Slot Request (Hours) = 360
b. Default Appointment Handling System = <External Application name>
e. In the Cut for Non-Payment Service Restrictions section:
a. Life Support/Sensitive Load Option = Allow Cut Service
f. In Override Expected Completion Time Configuration section:
a. Activity Type = SOM_FIELD_ACTIVITY_TYPE
b. Task Type = Read Meter
c. Expected Completion Time (Hours) = 60
g. In the Hours Beyond Expected Activity Completion Time section:
a. On Time Completion Tolerance = 8
b. Late Completion Tolerance = 16
c. Very Late Completion Tolerance = 24
d. Normal In Progress Time = 8
e. Long In Progress Time = 16
f. Very Long In Progress Time = 24
h. In the Update Statistics section:
a. Batch Control = D1-ACTAG
i. In the Chart Options section:
a. Number of Historical Days to Include in Summary Charts = 12
j. In the Summary To Do Types section:
To Do Type
To Do Role
Activity To Do Type
System Default Role
Inbound Communication To Do Type
System Default Role
Outbound Communication To Do Type
System Default Role
k. In the FA Cancelability Criteria section:
a. FA Cancellable Script = Determine FA Cancellability
Interim Status
FA Cancellability
Canceled
Not Cancellable
Completed
Not Cancellable
Declined
Cancellable
Dispatched
Cancellable
Enroute
Not Cancellable
Error
Cancellable
On Hold
Cancellable
Started
Not Cancellable
Queued for Dispatch
Cancellable
Scheduled
Cancellable
Suspended
Cancellable
Note: The values configured in the above master configuration section are the sample values for reference.
Activity Types
An activity type defines the properties common to a specific type of activity.
To create an activity type:
1. Navigate to the Activity Type page from the Admin menu or from the Search menu.
2. Enter the activity type and its description as appropriate.
The activity type includes the following:
Activity Type
Description
Field Activity
Record Information:
• Business Object = Field Activity Type
• Related Transaction BO = Field Activity
• Activity Type Category = Field Activity
To Do Information:
• Crew Request To Do Type = Activity To Do Type
• Crew Request To Do Role = System Default Role
• Appointment To Do Type = Appointment Notification
• Appointment To Do Role = System Default Role
• Field Cancellation To Do Type = Activity To Do Type
• Field Cancellation To Do Role = System Default Role
Exception Handling:
• To Do Type = Activity To Do Type
• To Do Role =System Default Role
• Retry Frequency = 00:10:00
• Maximum Retries = 2
The Field Task types are available as part of the following extendable lookup.
Business Object: D1-FieldTaskTypeLookup
Description: Field Task Type
The following activity types are supported in this integration:
• Turn on Pilot Light
• Service Investigation
• Trim Tree
• Disconnect SP at Device and Remove Device (Item)
• Item Exchange
• Connect SP at Item
• Meter Exchange
• Meter Read
• Disconnect SP at Meter and Remove Meter
• Connect SP
• Meter Install
• Disconnect Warning
• Maintain SP and Meter at Equipment
• Meter Inspect
• Meter Test
For Oracle Utilities Operational Device Management activity support ensure the following setup is present:
1. In the Oracle Utilities Customer to Meter Field Task Type section:
a. Navigate to Admin menu > E > Extendable Lookup > search for the “D1-FieldTaskTypeLookup” business object.
b. Select the respective Field Task Type.
c. Edit the Field Task Type.
d. Enable the Maintain As Asset Activity Type option as Yes.
e. Add the Asset System Data Retriever processing script.
f. Verify if the Asset Activity Type is mentioned.
2. In the Oracle Utilities Operational Device Management Asset Activity Type section:
a. Navigate to Admin menu > A > Asset Activity Type.
b. Select and edit the Activity Type.
c. Enter “Create Any Service History” in the Completion Event Type field.
3. In the Oracle Utilities Customer to Meter Device Type section:
a. Enter “Tracked by ODM” in the Track Location field.
4. In the Oracle Utilities Operational Device Management Asset Type section:
a. Add Service History Type under the Valid Service History Types section.
