Supported Applications and Versions
The following table lists each application or integration supported in this solution, together with the applicable product versions.
Table 3-1 Supported Applications and Versions
Supported Application Version
Oracle Utilities Work and Asset Cloud Service Integration to Oracle Field Service 25.10, 25.4, 24C
Oracle Utilities Customer Cloud Service Integration to Oracle Field Service 26.4, 25.4, 24B
Oracle Utilities Network Management System Integration to Oracle Field Service 24C, 24A, 23C
Oracle Utilities Operational Device Management Integration to Oracle Utilities Meter Data Management 23A
Oracle Utilities Customer Cloud Service Integration to Oracle Utilities Network Management System 24C
Oracle Utilities Customer Cloud Service Integration to Oracle Utilities Work and Asset Cloud Service 24B, 22B
Oracle Utilities Notifications Hub 25.10, 24A, 23A
Oracle Utilities Work and Asset Cloud Service 26.4, 25.10, 25.4
Oracle Utilities Customer Cloud Service 26.4, 25.10, 25.4
Oracle Utilities Meter Solution Cloud Service 26.4, 25.10, 25.4
Oracle Utilities Testing Accelerator 26.4, 25.10, 25.4
Oracle Utilities Network Management System 25.12.0.0, 2.6.0.2, 2.6.0.1
Oracle Integration Cloud Latest
Oracle Field Service Latest
The product documentation for the applications and integrations listed in this table is available on Oracle Help Center.
