Creating and Provisioning Users
This section describes steps involved in creating users and providing access to the cloud service’s various components.
Setting Up an OUAF Security and Access Administrator
Perform the following steps:
- Create a new user or search for and select an existing user.
- Assign this user to the User Administrator role. See Setting Up a New Security Administrator for more details.
- After first login to OUAF this user will be provisioned with Template User K1SCRADM (security administrator).
Setting Up an Online Application User
- Assign the user to the group that represents the appropriate level of authorization for the environment.
- Locate the application that is corresponding to the environment. Assign the user to the Online Application User role in the environment.
Setting Up an Integration User for REST/SOAP Web Services
REST/SOAP API doesn't perform Just-In-Time provisioning. Users for web services must be created manually in both and OUAF applications.
An email address must be provided as part of user creation:
- It is recommended that this email address is used for non-human user setup only
- All email notifications concerning user account are sent to this email address
- Security administrator must have an access to this email account
- Create a new user or search for and select existing user
- Specify the email address allocated for the integration/non-human users.
- When the activation email is received, reset the user’s password and communicate the email address and password to the integration team.
- Assign the User to the REST/SOAP Web Services role in the Application that represents the environment.
- Login to OUAF and create a new User with Login ID = User Name. Assign the user to user groups that provide access to all or selected application services, according to the business requirements.
Notes on integration user accounts management:
- Expiring passwords may cause integration flows to stop working. Reset passwords regularly to avoid eventual outages.
- You may choose to maintain two user accounts for each integration - a "main" account and an "alternate" account - to allow a graceful switch to a new password. When required, first reset password for the "alternate" user while the "main" user is still valid and working; then reconfigure the integration to use "alternate" user credentials and only then reset the "main" account password.
- Oracle recommends that you setup a dedicated integration user account for each production and non-production environment.
Setting Up an Integration OAuth Client for REST/SOAP Web Services
External systems can securely interact with Oracle Utilities Cloud Service REST APIs using OAuth client. To set this up, follow the steps below to register and configure a new OAuth client in your Identity Domain.
Use the following procedure to create a new OAuth Client:
- Access the Identity Domain Console
- Navigate to your Identity Domain and open Integrated Applications.
- Click Add Application.
- Register a Confidential Application
- Select Confidential Application when prompted.
- Provide a meaningful Name and Description for easy identification.
- Click Next.
- Configure OAuth Settings
- On the Configure OAuth screen, enable Configure this application as a client now.
- Choose the OAuth flow required for your integration and select the supported grant types:
- client_credentials
- JWT assertion
- authorization_code (you may specify a custom redirect URI)
- Client Type and Certificate
- Choose the appropriate Client Type: trusted or confidential
- Upload the client certificate, if required by your integration setup
- Configure Token Issuance Policy
- Specify how tokens are issued and managed
- Click Add Scopes and select applicable scopes from the resource server application
- Scopes may allow access to: REST APIs SOAP APIs and ORDS REST APIs
- Finalize and Activate
- Review the configuration
- Click Activate to complete setup.
Once the client has been created, locate the newly created OAuth Client in the Identity Domain, under Integrated Application.
- The client ID and secret can be found in the General Information section of the OAuth Configuration section.
- The allowed scope can be found in the OAuth Client section on the Configuration section, under Token Issuance Policy.
If your integration implements Client Credentials OAuth flows, the next step is to create an application user in the appropriate Oracle Utilities Cloud Service (such as Oracle Utilities Meter Solution Cloud Service). Access the appropriate Oracle Utilities Cloud Service application, and navigate to the User portal.
Create a new user corresponding to the OAuth Client created above:
- Enter the OAuth client ID as the user’s Login ID.
- Assign User Group(s) that will provide the integration with access to the appropriate functionality.
The OAuth Client credentials are now ready to use. When issuing a webservice call, specify the client id, secret and allowed scope that you've determined from the Identity Domain.
Maintaining OAuth Clients Created for Integration
If you created the OAuth client online, you may delete, deactivate, or regenerate the client secret as needed.
If the OAuth client was created via service request and it appears under Oracle Cloud Services, it was likely created by Oracle Utilities Cloud Operations. In that case:
- You must open a Service Request to delete, deactivate, or rotate the secret
- Provide the OAuth Client ID and Identity Domain URL
Refer to the Oracle Utilities Cloud Services Cloud Operations Guide for instructions.
Setting Up a User with Access to Analytics Publisher and Analytics Visualization
- Locate the application that is corresponding to the environment. Assign the user to one of the Application Roles available in the environment:
- Analytics Publisher: Choose one (or both) of the following application roles:
- BI Consumer
- BI Content Author
- Analytics Visualization: Choose one or more product-specific application roles related to Oracle Utilities Analytics Visualization features, such as CustomerContentCreator or CustomerContentConsumer. The xxContentCreator role includes access to the BI Consumer and BI Content Author roles in Analytics Publisher listed above. Similarly, the xxContentConsumer role includes access to the BI Consumer role. See Set Up a User in the Oracle Utilities Analytics Visualization User Guide for more information about application roles used with Oracle Utilities Analytics Visualization.
Setting Up a User with Access to Utilities Testing Accelerator
- Locate the application that is corresponding to the environment. Assign the user to one of the Utilities Testing Accelerator roles available in the environment:
- Test Administrator
- Test Approver
- Test Developer
The Utilities Testing Accelerator user must be authorized to access the Utilities Cloud Service to perform the API and online application testing.
- Assign the user to the Online Application User and Web Services Access roles.
- Request the user to login to the online application to trigger the Just -In-Time provision. This action will create user record in the Utilities Cloud Service.
Setting Up a User Authorized to Execute Ad-hoc SQL Queries
- Locate the application that is corresponding to the environment. Assign the user to one of the following roles:
- SQL Developer Web Online User: Provides access to the online web-based interface that enables user to execute queries
- Rest Enabled SQL: Provides the ability to execute REST calls using cURL command
Setting Up an Integration OAuth Client for Ad-hoc SQL Queries
External systems may perform Ad-hoc SQL Queries via REST API using OAuth client credentials.
Create the OAuth clients following the steps outlined in the Setting Up an Integration OAuth Client for REST/SOAP Web Services section above, this time selecting /sql/* as a scope.
The OAuth Client is now ready to use. When issuing a RETS call, specify the client id, secret and allowed scope that you've determined from the Oracle Identity Cloud Service Admin Console.
If you are planning to utilize JWT Assertion OAuth flow and authorize on behalf of a user, make sure that the user that will be performing the call is assigned to both SQL Developer Web Online User and Rest Enabled SQL application roles.Maintaining OAuth Clients Created for Integration
You can delete the OAuth client or regenerate the OAuth client secret by creating a service request with the Oracle Utilities Cloud Operations team. Provide the OAuth Client ID and the Oracle Identity Cloud Service tenancy URL. The Oracle Utilities Cloud Operations team will perform the requested action on your behalf. Refer to the Oracle Utilities Cloud Services Cloud Operations Guide for more information about working with the Oracle Utilities Cloud Operations team.
Setting Up a User with Access to the Smart Grid Gateway Test Harness
- Locate the application that is corresponding to the environment. Assign the user to following role available in the environment:
- SGG Test Harness User (SGGHarnessUser)
