Operational Tips
  • Monitor path lag and errors; enable Auto Restart for resilience.
  • Consider enabling compression for high-latency links after baseline testing.
  • Keep NSG/SecList and DNS View associations documented for future changes.
  • When rotating certificates or enabling mTLS, update truststores/keystores on both ends and re-validate TLS.
Template Values to Reuse
FQDN: <deployment-id>.deployment.goldengate.<region>.oci.oraclecloud.com
Source URL: wss://<FQDN>:443/services/v2/sources?trail=<TRAIL>
Target URL: trail://localhost/services/v2/targets?trail=<TRAIL>
Validation commands:
  • dig +short <FQDN>
  • getent hosts <FQDN>
  • nc -vz <FQDN> 443
  • openssl s_client -connect <FQDN>:443 -servername <FQDN> -brief
  • curl -vkI https://<FQDN>/services/recvsrvr
