Troubleshooting Tools
DNS errors (OGG-10400 Host not found)
Cause: Receiver Server not resolving the FQDN
Fix:
- Confirm private zone/record exists and is Active
- Ensure DNS View is associated to the Receiver VCN
- Ensure subnet uses VCN resolver; renew DHCP/reboot
- Validate with dig/getent on the host
Temporary test only: add /etc/hosts entry mapping <FQDN> to the Private Endpoint IP; remove after DNS is fixed per security policy
Connection timeouts (OGG-10388 / OGG-30497)
Cause: TCP 443 blocked, target listener down, or LB path not reachable
Fix:
- Open egress/ingress on Security Lists/NSGs for TCP 443
- Verify listener on the Private Endpoint/LB is active; backends healthy
- Run nc -vz and packet capture (tcpdump) to confirm SYN/SYN-ACK and TLS
WebSocket upgrade fails with redirect (OGG-10400 “Moved Temporarily”)
Cause: Reverse proxy or LB returning 302 on base URL
Fix:
- Disable reverse proxy in Receiver Server (preferred), or
- Target the service path directly: /services/v2/sources (or /services/recvsrvr)
- Ensure LB forwards WebSocket Upgrade and does not redirect /services/*
TLS trust/name mismatch
Cause: Using IP or mismatched hostname
Fix:
- Always use the deployment FQDN that matches the wildcard cert
- Ensure client truststore includes the issuing CA if needed
- Validate with openssl s_client
Still Stuck?
Collect from both ends:
- Receiver/Distribution/Admin logs around the failure time
- Outputs of: dig, getent, nc, curl -I, openssl s_client
- Packet capture during connect attempt: tcpdump -nn host <PE IP> and port 443
- LB/WAF logs and policies (redirects, WebSocket support)
