Initial Identity Management Setup
Initial set up related to Identity Management includes the following:
  • Create a password for the cloud administrator and log in into each of the provisioned environments.
  • Create a dedicated user and group in the OCI IAM Identity Domain for the Process Automation Tool and assign it to all your cloud service environments. Complete a setup by logging into each environment and verify that the user is created. Adjust user security access, if needed, using the K1PAUSER template user as an example.
  • Define the initial set of user groups and assign appropriate access rights to each.
  • Create Oracle Cloud Infrastructure Identity and Access Management (IAM) with Identity Domains user mapping configuration in each of the cloud service environments (optional).
Refer to Identity and Access Management with Identity Domains in the Oracle Utilities Cloud Services Administration Guide for more information.
