2 Post-Provisioning Setup
When a customer of one of the Oracle Utilities Cloud Services receives notification that their cloud service was provisioned, there are a number of tasks that have to be performed before they can start with normal implementation activities.
This chapter provides implementation guidelines related to post-provisioning setup, including:
- Initial Identity Management Setup
- Initial Object Storage Setup
- Initial Cloud Service Setup
- Initial Cloud Service Setup - Adding a New Environment to an Existing Cloud Service
- Configure Product Use Metrics - Required
- Language Pack Setup (Optional)
- Oracle Guided Learning Integration (Optional)
Before You Begin
This chapter describes how Oracle Cloud Infrastructure Identity and Access Management (OCI IAM) is used with Oracle Utilities cloud services.
Before you begin configuring Oracle Cloud Infrastructure Identity and Access Management for your implementation, you should review the following Oracle Cloud Infrastructure documentation:
We also recommend you review the following technical papers and blog articles related to IAM security:
