9 Configure Your Oracle Utilities System
Before you can use CX for Utilities applications, you must ensure that the related features are set up appropriately in your Oracle Utilities system. The following information identifies each item that needs to be set up, provides implementation details, and refers you to related documentation that can assist you.
All of the documentation listed in this topic (unless otherwise noted) can be found in these libraries in the Oracle Help Center, along with additional information about using and configuring your Oracle Utilities system:
| Task | Details | Documentation |
| Configure Insights | Contextual Insights provide a powerful way to surface focused intelligence and alerts to users in the context of their customers. Customer insights are configured in your Oracle Utilities system, and can be displayed as noted below. | See: |
| Configure Person Data Options |
You can store customer data that is important for your business process, such as, but not limited to:
You must configure the administration data so that the appropriate types of customer information can be stored with person and business records within your Oracle Utilities system. |
See these topics in the Administration Guide:
| Configure Notification Preferences |
You can configure notification types for sending messages out of your Oracle Utilities system and maintaining customers’ communication preferences for receiving these messages. Once these communications are configured, you can set notifications preferences for each of the customer’s billing accounts. |
See:
| Configure To Do Types |
Customer service agents need access to service requests and to do entries from their Work Queue. To get the to do entries to display, you must complete the following tasks so that agents have access to the appropriate to do entries:
Once this configuration is complete, agents can view and manage accessible to do entries from the Work Queue or from within your Oracle Utilities system. |
See:
| Configure Start, Stop, and Transfer Processes |
Processes to start, stop, or transfer service can be launched after creating or identifying a customer record in the Customer List. To enable these processes, you must configure customer service request types that are used to orchestrate customer service processes related to service agreements and contracts at customer service locations. |
See:
| Inbound Web Services (APIs) |
The following information is integrated into CX for Utilities using inbound web services:
Inbound web services in the web service category of Customer Experience should be set to active for the message options so that they can be used in CX for Utilities. This web service category includes values of C1-CX, D1-CX, and X1-CX. |
See:
| Schema Constants |
Some optional Fusion features rely on schema constants to reference specific administrative entities configured by the customer. Schema constants are defined on a Feature Configuration record of type Schema Constants.
See:
| Extendable Lookups |
This task should have been completed during initial setup. Extendable lookups are used to control some items within CX for Utilities, such as:
Use the extendable lookup with a business object of F1-KnowledgeManagement to identify available locations to attach articles. The person synchronization is controlled by an F1-DataSyncControl extendable lookup business object of C1-CX4U-PERSON. The status of this lookup record must be active to enable the synchronization and the external system and message sender must be configured. |
See:
| Data Synchronization |
This task should have been completed during initial setup. Person data synchronization is used to trigger updates to CX for Utilities and other Oracle systems when person record changes are made. To set up the synchronization, be aware that:
See:
| Populating Old Account ID |
If your utility converts from one CIS to an Oracle Utilities CIS, you can store account ID numbers from your legacy system in the ‘Old Account Id’ field (table field name OLD_ACCT_ID). This field is used in the Utilities CIS system to ensure that payments made after a conversion are attributed to the correct accounts. In CX for Utilities Agent Service, the Prior Billing Account ID search parameter in the Person and Premise Search will return valid results only if this field is populated in your CIS. |
See:
| Configure Activity Types | Use the Master Configurations in your Oracle Utilities Customer Information System to define the activity categories and types that you want to display in the activity history in CX for Utilities. |
See:
| Configure Online Bill Display | If you want your agents to be able to view a PDF version of the customer's bill from the Bill Drawer, you need to set up online bill viewing in your Oracle Utilities Customer Information System. If the view is available in your CIS, it will be passed to the Customer Dashboard. | See:
| Set Up Outage Integration | If you want to display outage information in Account 360 or the Customer Dashboard, outage data must be available in your Oracle Utilities Customer Information System (CIS). To accomplish this, you must set up an integration between your CIS and Oracle Utilities Network Management System. Oracle provides information on integrating these systems, and the methods available to you are determined by the release of your Oracle Utilities CIS.
Oracle provides information on integrating these systems, and the methods available to you are determined by the release of your Oracle Utilities CIS. |
For utilities on release 25.4, see: For utilities on release 25.10 or later, see:
| Define the Unit of Measure (UOM) for Each Rate in the Master Configuration to Enable Usage Graphs | The Usage History graphs that display usage for a service contract contain a drop down menu that enables users to select the UOM to display in the graph. The values that are available in that menu are returned by an Oracle Utilities API that relies on the Billing and Usage Display Master Configuration. If the master configuration is not defined for a rate, you might receive a "Rate Schedule Not Found" error message when attempting to view the Usage History chart. | See:
| Configure County Display in Premises Address | To ensure that County information is displayed with other premises information, define a value for the Position of County parameter on the Premise Information (C1-PREM-INFO) algorithm. Refer to the algorithm's detailed description for more details about setting parameters. Refer to Defining Algorithms for general information about viewing and maintaining algorithms. | See:
In this section:
