Landing Page Role Priority
If a user has multiple roles, the system uses the priorities assigned to each role to decide which landing page the user sees based on the priority assigned for each of the user's roles. You can use the default role priorities, or you can change the priorities using the information in this section.
This table provides additional details on the tasks you can complete.
| Task | Configuration | Comments |
| Get Page Priorities |
GET /utilitiesAdmin/v1/landingPageRolePriority Example: GET https://<hostname>/api/utilitiesAdmin/v1/landingPageRolePriority?orderBy=pagePriority:asc A specific role priority can be fetched using: GET /utilitiesAdmin/v1/landingPageRolePriority/{id} Example: GET https://<hostname>/api/utilitiesAdmin/v1/landingPageRolePriority/ORA_UER_UTILITIES_CUSTOMER_SERVICE_REPRESENTATIVE |
| Modify priority |
POST /CXIPlatformService/v1/CXIReferenceEntity/landingPageRolePriority Example: POST https://<hostname>/api/CXIPlatformService/v1/CXIReferenceEntity/landingPageRolePriority |
Multiple roles can be added at the same time by adding them to the "items" list in the request. |
Parent topic: View, Edit and Add Reference Types
