Phone Type Purpose
The admin entity holds the mapping between the PhoneType and PhonePurpose lookup code values. These mappings provide upgrade safety of existing data. The following phone type purpose mappings are delivered with the solution. Review the values you need for your implementation, which should be based on the phone type values configured in the Utility configuration PHONE_purpose section.
Customers can modify these values or can add new values as needed using the APIs noted below.
| PhoneType | PhonePurpose | ID |
| WORK | BUSINESS | WORK |
| HOME | HOME_BUSINESS | HOME |
| MOBILE | PERSONAL | MOBILE |
To view, edit, and add reference types, use the information in this table.
| Person Data | Configuration | Comment |
| Add a phone type - phone purpose mapping. | You can add multiple phone type -phone purpose mapping to the payload, as needed.
POST /CXIPlatformService/v1/CXIReferenceEntity/phoneTypePurposeMapping Example: |
Multiple records can be added together by adding them to the "items" list in the request. |
| Edit phone type - phone purpose mapping. | POST /CXIPlatformService/v1/CXIReferenceEntity/phoneTypePurposeMapping
Example: |
Multiple records can be edited at the same time by adding them to the "items" list in the request. |
| Fetch phone type - phone purpose mapping. | GET /utilitiesAdmin/v1/phoneTypePurposeMapping
Example: |
| Fetch phone type - phone purpose mapping by id. | A specific identifier type can be fetched as well.
GET /utilitiesAdmin/v1/phoneTypePurposeMapping/WORK Example: |
Parent topic: View, Edit and Add Reference Types
