Using the Usage Tab
When you access Account 360, the Overview tab is selected by default. To view usage information, select the Usage tab, and then select the service type for which you want to view usage data. The data and layout of the Usage tab can differ, as follows:
- Billing Account Comparison Chart: If you are viewing an Oracle Fusion account that has 20 or fewer associated billing accounts, the system displays the Billing Account Comparison chart automatically.
- Billing account selection area: If you are viewing an Oracle Fusion account that has more than 20 billing accounts, the system displays a message instructing you to select up to 20 accounts to view the chart. You can select one or more account and then click the Update Chart button to render the chart.
- Service Contract Usage Map: If you have navigated to a specific billing account, the Usage tab displays a map and lists the service contracts associated with the selected billing account.
- Flat-fee services with no usage data: If you are viewing billing accounts that have a flat-fee service that has no measurable usage, the usage tab will not display any data when viewing that service type. Additionally, your utility can configure the links on the Service Contract Usage Map for service contracts with no usage data to be disabled.
When viewing an Oracle Fusion account, the lower section of the screen displays detailed records for each billing account that includes data for the selected service type such as:
- Billing account name and number
- Premise Addresses: If there are multiple premises associated with a billing account, a badge appears next to the displayed address to note how many additional premises there are.
- Usage for the selected service type over the last 12 months
- Icons for each service type associated with the billing account
Icons with a slash through them represent a service type that is not currently active, but was active within the configured range for historical data display. The date range available for viewing is determined by the Historical Data Range Profile Option set by your utility. By default, the Historical Data Range is set to allow you to view 3 years of data.
This image shows an example of the Usage tab when on the Account 360 view for a key account with more than 20 billing accounts:
Figure 5-14 Usage Tab
If you have already selected a single billing account using the Select Billing Account smart action in the header, the system displays only the Service Contract Usage Map, and does not include any additional detail below the map.
Topics in this section include:
