Meter - Losses
The following subject areas enable a multidimensional analysis of your organization's meter losses. This helps you to identify possible losses, identify meters assigned to the wrong district meter or transformer, and identify where losses are happening (such as water leaks and electric revenue protection issues). It also helps work crews by providing the possible loss amounts and loss areas.
Meter – Facilities
This subject area can be used to review and analyze individual service points mapped with facility.
Answer questions like these:
  • Is a facility (transformer) installed in an optimal geographical location with respect to connected downstream service points, or is there another facility that is better located?
  • Are there facilities with incorrect geo coordinates?
Meter – Facility Usage
This subject area can be used to review and analyze the relationship of usage between a facility and downstream service points.
  • What is the usage by facility?
  • (When combined with Meter - Downstream Usage ) What is the difference between the usage of the facility and the sum of the usage of the connected service points?
Meter – Downstream Usage
This subject area can be used to review and analyze the total downstream usage along with the percentage downstream usage by date.
  • What is the downstream usage by day and location?
  • What is the average downstream usage?
  • (When combined with Meter - Facility Usage) What is the difference between the usage of the facility and the sum of the usage of the connected service points?
Meter – Downstream Service Points
This subject area can be used to review and analyze a downstream service point’s physical location in a map, along with other details such as geographic latitude, longitude, address, and so on.
  • What is the physical location (such as address and postal code) of a service point on a map?
  • How many downstream service points are connected to a facility in a particular area or location?
