Disaggregation Main Insight
The Disaggregation Main Insight module uses personalized information about an end use in the customer's home to motivate the customer to take advantage of a utility promotion. The goal is to help customers understand their use in a specific category where they are using more than the regional average so that they may feel motivated to uptake the promotion and subsequently reduce their energy use. The module can be used to promote the customer's largest end use category, or the utility may select a preferred end use category to reinforce the report promotion. Oracle Utilities Opower works closely with the utility to create marketing modules that enhance the report experience.
Appears in: Promotion Report
Disaggregation Main Insight Example
This image shows an example of the Disaggregation Main Insight module.
Image of the Disaggregation Main Insight module
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Disclaimer
The disclaimer explains to the customer why the customer is receiving the report.
Default:
"You were selected to receive this report because you may be using more than the regional average for this energy use category. Numbers are approximate."
Optional
Choose one of the following:
