Energy Use Benchmark
The Energy Use Benchmark module provides a personalized, at-a-glance visualization of the customer’s energy use. It consists of three sections of a gauge to indicate the customer's overall status as it relates to their energy use: Fair, Good, and Great.
Appears in: Progress Report, Welcome Report, Limited Income Report, Annual Report, Time of Use Report, Solar Report, Usage Lookback Report
Energy Use Benchmark Example
This image shows an example of the Energy Use Benchmark module for a gas customer.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
| Configuration Option | Input Value |
Benchmark Header The heading notifies the customer that the benchmark gives them an at-a-glance view of their energy use. It also includes the customer's fuel type. Default: "Your <fuel type variation> use at a glance." |
Optional Contact Your Delivery Team about configuring the benchmark header. |
Color Labels The benchmark has three potential states, and each corresponds to a color. The labels (Fair, Good, and Great) are configurable. However, the default labels and colors are strongly recommended. Default:
Optional Choose one of the following:
Benchmark Copy The copy below the gauge tells the customer how they can leverage the report or recognizes a change in state. Default: The copy defaults vary by fuel type and the customer’s energy use. Discuss the default language with your Service Delivery Manager. |
