Announcement Quadrant
The Quadrant module in the announcement version of the Welcome and Announcement Report includes four customized sections that echo the theme of the Announcement module, and provides the customer with context and rationale for the personalized insights included in the report.
Appears in: Welcome and Announcement Report
Announcement Quadrant Example
This image is an example of a Quadrant module customized for the Announcement Report.
Image of Quadrant module customized for the Announcement Report
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Feature Heading
The feature heading must support the announcement theme.
Default: Not applicable.
Required
Contact Your Delivery Team about creating custom content for the Quadrant module.
Quadrant Headings and Text
The quadrant headings and text must support the announcement theme.
Required
Images
The module images must support the announcement theme and quadrant text.
Required
Contact Your Delivery Team about selecting alternate images.
Module Placement
Default: The Quadrant module appears on the front of the report by default. It can be swapped with the Efficiency Zone or Neighbor Comparison to appear on the back of the report.
Optional
Choose one of the following:
Blank Slot
Utilities have the option of replacing the Quadrant module with a custom module created by the Client Design team. The custom module must fit the primary feature specifications. See the Client Design Menu of Services for more information.
Optional
Contact Your Delivery Team about replacing the module.
User Experience Variations
The user experience of the feature may vary for customers and utilities depending on their service types (gas, electricity, dual fuel, and so on), available data, costs, locale, and other factors. For more information, see the Announcement Quadrant description in the Energy Efficiency Cloud Services Overview Guide and go to the User Experience Variations section.
