Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Configuration Option Input Value
Promotion Introduction - Utility Selected End Use
The utility may select end uses that support the report promotion.
Default: By default, the categories are drawn from the customer's top three energy use categories.
Optional
  • Use the customer's top three energy use categories.
  • Contact Your Delivery Team about selecting end uses to support the report promotion.
Announcement Introduction - Report Type Label
Default: Customized text is required for each utility. There is no default version.
Required
Contact Your Delivery Team about creating the announcement introduction.
Announcement Introduction - Introduction Text
Required
Welcome Introduction - Report Type Label
The utility may select a report label that supports the report theme.
Default: "Your First Home Energy Report"
Required
Welcome Introduction - Introduction Text
The utility may select introduction text that supports the report theme.
Default:
  • New Customer: "Get ready to save energy!"
  • Legacy Customer: "Get ready to save more!"
Required
Time of Use Introduction - Report Type Label
Default: "Home Energy Report"
Required
Time of Use Introduction - Introduction Text
Default: "Get ready to save more energy when it matters the most!"
Required
Solar Introduction - Report Type Label
The utility may choose an alternative report type label.
Default: "Your Home Energy Report"
Optional
Solar Introduction - Introduction Text
The utility may select alternative introduction text.
Default: "Welcome to your Home Energy Report"
Optional
Solar Introduction - Welcome Message
The utility may select an alternative welcome message.
Default: "Use these personalized reports to learn about your net energy and how you can get the most out of your solar panels."
Optional
Electric Vehicle Introduction - Report Type Label
Optional
Electric Vehicle Introduction - Introduction Text
Optional
Electric Vehicle Introduction - Welcome Message
Optional
Peak Focused Introduction - Introduction Text
Default: "Get ready to save more energy when it matters most!"
Optional
