EV Hero Module
The EV Hero module welcomes the customer to their EV Charging Coach V3 email. The module welcomes the customer by name, provides the date range associated with the message (except when used in the introduction email), and includes an image that depicts an EV charging in the garage, and a kitchen with various appliances. Together, this information helps the user understand that this message provides energy insights related to EV charging as well as the rest of the home.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Table 6-6 Configuration Options
| Configuration Option | Input Value |
Images The images can be configured to use client-specific colors. Other than that, the image can not be changed. |
Optional Specify client branding colors. |
Program Name The welcome message introduces the customer to the email program, and specifies the name of the email program. Default: Rate Coach for EV drivers |
Optional Specify one of the following:
To see how this module fits into the overall user experience, see Design and Configuration.
