EV Habits Module
The EV Habits module helps to coach readers about how they can create good charging habits for their EV. The module provides two standard charging tips that can save them money and time, and then asks if they can adopt a third tip that will help to alleviate stress on the electric grid.
Configuration Options
For each element listed in the table, indicate the desired configuration in the Input Value column. If you do not provide an input for optional configurations, the default will be used.
Table 6-5 Configuration Options
| Configuration Option | Input Value |
Images The images can be configured to use client-specific colors. |
Optional Specify client branding colors. |
Text and Extra Mile Statement Utilities are encouraged to review the text and statements in this module and adjust them to ensure that they are pushing customers to charge at the times that are most beneficial to the utility. |
Optional Select one of the following:
To see how this module fits into the overall user experience, see Design and Configuration.
